jcadobeuser
Flash Player causing Firefox to hang
Mar 11, 2010 7:07 AM
Hi there, I am having an issue with Firefox hanging everytime I try to navigate away from a page that contains Flash Player. Does anyone have an answer as to why this happens?
My Computer specs:
     Intel Core Duo (2.4Ghz)
     Windows XP
     Internet Explorer 6
     Firefox 3.6
     Kaspersky 6.0.4 (Anti-virus and firewall)
My Flash information:
     FlashAuthor.cfg                   (No version)
     flashplayer.xpt                    (No version)
     genuinst.exe                      6.0.2500.1531
     install.log                           (No version)
     KB923789.inf                     (No version)
     NPSWF32.dll                    10.0.45.2
     NPSWF32_FlashUtil.exe    10.0.45.2
     Restart.exe                        (No version)
     RestartIE.exe                     (No version)
     uninstall_plugin.exe            10.0.45.2
My IE Shockwave Flash Object: Flash10e.ocx (It is enabled)
My Firefox Shockwave Flash plugin: version 10.0.45.2 (currently disabled as it causes my browser to freeze)
Listed in my Firefox Extension list:
     Adobe DLM (powered by getPlus(R)) 1.6.2.63
     Java Console 6.0.03
     Java Console 6.0.04
     Java Console 6.0.02
     Microsoft .NET Framework Assistant 1.1
Listed in IE Addons:
     Java Plug-in 1.6.1_01
     Java Plug-in 1.6.1_02
     Java Plug-in 1.6.1_03
     Java Plug-in 1.6.1_04
     Shockwave ActiveX Control (swdir.dll)
     Shockwave Flash Object (Flash10e.ocx)
Any help would be greatly appreciated, thanks!!
    Mar 11, 2010 7:53 AM   in reply to jcadobeuser
    No real answer, other than I've both heard and experienced this frequently. As much as I dislike M$, Silverlight will prevail as Flash deteriorates.
    Mar 11, 2010 8:31 AM   in reply to jcadobeuser
    Hi jc, You have a mix of Flash files, some are missing and some that are there are correct and some I have no idea where
    they may have come from.
    Thanks for the info, since providing that I can give you some directions.
    1. Go to Add/Remove and Remove the DLM(download manager), and if the getPlus is there, Remove it also.
    While you are there, Remove ALL Java listings, since they are old.(I'll give you info on Installing the latest)
    After you have Removed all of the above, Reboot your computer(restart)
    Go back to your FF extensions and make sure the DLM, getPlus and Java entries have been removed also(by the removal of them from Add/Remove)
    You are going to need to Uninstall Flash Player and Install the latest, but let's get the above done first.
    If you have any questions, please ask.
    eidnolb
    Mar 11, 2010 12:34 PM   in reply to jcadobeuser
    Hi jc, I am late getting back on.(errands and unexpected company):-)
    Ok, thanks for the update. Now we are going to install the latest Java. This is the link:
    http://java.sun.com/javase/downloads/index.jsp
    When the site opens, look for "Here are the Java SE downloads in detail" Then look for "What Java do I need?"
    To the right click on "Download JRE" This is the one you want. Click on it and you'll see "Select Platform & Language
    for your download" Click on the arrow and Select Windows; check box to agree to license info. Skip over the user
    name and password info and click on Continue. Next, disregard any installer info, etc. Look for i586 & you want Offline
    Install. After that just follow the instructions. You will SAVE this to your Desktop. After that, close all browsers and click
    on it and RUN. After it is fully installed, Reboot your computer.
    Open a  browser and go to Programs and Features and confirm that JRE 6 update 18 is listed. Close that out and go to
    IE add ons, all sections and post back all Java add ons installed, including BHO's and ActiveX Controls.
    Do the same using FF.
    eidnolb
    Mar 11, 2010 2:04 PM   in reply to jcadobeuser
    Good work jc! You are a good student:-) All Java add ons in IE are correct and FF also. Nice.
    Now that we have all of that out of the way, we can Uninstall and Install FP
    This is the Uninstaller that you will download and SAVE to your Desktop:
    http://kb2.adobe.com/cps/141/tn_14157.html
    This is the Installer FOR INTERNET EXPLORER, download and SAVE to your Desktop:
    http://fpdownload.macromedia.com/get/flashplayer/current/install_flash _player_ax.exe
    This is the Installer FOR FIREFOX, download and SAVE to your Desktop:
    http://fpdownload.macromedia.com/get/flashplayer/current/install_flash _player.exe
    After those are on your Desktop, you will do the following:
    Close ALL browsers
    Disconnect from the Internet
    Disable All Anti-Virus/Spyware and any Firewall other than Windows Firewall Also check to make sure no applications that use Flash are running, check the system tray.
    RUN the Uninstaller Once. Then Reboot and RUN the Uninstaller again(to make sure old files are removed)
    Then RUN the Installer for IE and Reboot ONCE
    Then RUN the Installer for FF and Reboot ONCE
    Re-enable your Anti-Virus/Spyware and Firewall
    Re-Connect back to the Internet.
    Then using IE first, go to the test site:http://www.adobe.com/products/flash/about
    Then using FF do the same test.
    Then post back the results or if there were any problems and/or any messages.
    eidnolb
    If you have any questions before you start, post back.
    Message was edited by: eidnolb  add'l
    Mar 11, 2010 3:27 PM   in reply to jcadobeuser
    Hi jc, good news. Glad it all worked for you and you got all of your ducks in a row:-)
    Thanks for the teamwork!!
    eidnolb
