Hello,
I having trouble trying to write AS3 to take a screenshot of a MC that’s on the stage and pass the data to a .cfc method which saves it as a jpg on the server. The current code I have kind of works except the jpg is unreadable. I think it has something to do with not using Flex, AMF, and writing binary files. When I look at the jpg via a hex viewer I think it doesn’t have the right jpg header.
The jpg begins with:
c3 bf c3 98 c3 bf c3 a0 00 10 4a 46
When I think it should begin with:
ff d8 ff e0 00 10 4a 46
//AS3 source code
import flash.net.NetConnection;
import flash.net.Responder;
import flash.display.Bitmap;
import flash.display.BitmapData;
import flash.utils.ByteArray;
import com.dynamicflash.util.Base64;
import com.adobe.images.JPGEncoder;
var myService:NetConnection = new NetConnection();
var myStruct:Object = new Object; //for passing arguments to cfc
var hostSite:String;
hostSite = "test.somedomain.com";
myService.objectEncoding = 0;
myService.connect("http://" + hostSite + "/flashservices/gateway")
//sketch_mc is source MC we would like to take a snapshot of, which is already on the stage.
var jpgSource:BitmapData = new BitmapData (sketch_mc.width, sketch_mc.height);
jpgSource.draw(sketch_mc);
var imgEncoder = new JPGEncoder(90);
var jpgStream:ByteArray = imgEncoder.encode(jpgSource);
saveImg(jpgStream);
function saveImg(jpg:ByteArray){
trace("Sending image to cfc");
var encoded:String = Base64.encode(jpg.toString());
myStruct.jpgDataString = encoded;
var responder:Responder = new Responder(saveImg_Result, onFault);
myService.call("latestVersion.secure.saveImage", responder, myStruct);
function saveImg_Result(result){
trace("Image Sent Result: "+result)
function onFault(f){
trace("Error: " + f.description);
<!--- .cfc source --->
<cfcomponent>
<cffunction name="saveImage" output="no" access="remote" returntype="any" >
<cfargument name="jpgDataString" type="string" required="yes">
<cfset img = toBinary(arguments.jpgDataString)>
<cffile action="write" accept="image" file="d:\test.jpg" output="#img#" nameconflict="overwrite"/>
<cfreturn "Image Saved">
</cffunction>
</cfcomponent>
Think you may want to use Base64.encodeByteArray in your saveImg function.
var encoded:String = Base64.encodeByteArray(jpg)
On the server end, you'd need to decode the base64 string. I assume that's what this does:
