Pop Horia
Indesign: remove all inline empty frames script?
Mar 18, 2010 4:45 AM
I need to delete all inline empty frames within a document. Those inline empty frames appear after a data merge is done.
Please help!
    Mar 18, 2010 4:53 AM   in reply to Pop Horia
    var doc = app.documents[0]
    var inlines = doc.stories.everyItem().textFrames.everyItem().getElements();
    while(tf=inlines.pop()){
        if(tf.contents==""){tf.remove()}
    (untested)
    Harbs
    Mar 18, 2010 4:54 AM   in reply to Pop Horia
    Are there any other inline frames?
    The code for an inline frame is
    Find
    ^a
    or
    GREP
    ~a
    If you search for these and replace with nothing, then all inline frames will be removed
    But if you have other inline frames I think you may need a script for that.
    Mar 18, 2010 4:58 AM   in reply to Harbs.
    The most excellent Harbs got in before me
    Mar 18, 2010 7:29 AM   in reply to Pop Horia
    Try this:
    var inlines = doc.stories.everyItem().pageItems.everyItem().getElements();
    while(fr=inlines.pop()){
      if(fr instanceof Group){continue}
      if(fr instanceof TextFrame){
        if(fr.contents == ""){fr.remove()}
        continue;
      if(fr.graphics.length==0){fr.remove()}
    Harbs
    May 21, 2013 7:07 AM   in reply to Pop Horia
    Im using indesign CS6 and tried the last solution to remove graphics frames after a data merge.
    It didn't work. What am I doing wrong? =)
    Please help this will save soo much time.
    Thanks.
    May 21, 2013 7:15 AM   in reply to MToys
    Did you get an error message?
    May 21, 2013 7:53 AM   in reply to Peter Spier
    No error message. I tried the delete text frames script and that works.
    May 21, 2013 7:58 AM   in reply to MToys
    I'm not a scripter, so I don't have a lot of good ideas. Maybe Harbs will see this and pop in again.
    In the meantime, try making a subfolder in the scripts folder where you saved this and name it Version 7.0 Scripts (this is case sensitive) and see if you get a different result running the script from inside that subfolder.
    May 21, 2013 8:21 AM   in reply to Peter Spier
    Thanks Peter. I tried that but no luck =(
    May 22, 2013 2:07 AM   in reply to Pop Horia
    Hi Pop Horia. Thanks for your reply. The text frame script works fine even when the frames are NOT selected.
    I am trying to delete all empty graphics frames. I just tried the script with the frames selected it still didn't work.
    May 22, 2013 2:21 AM   in reply to Pop Horia
    What do you mean by inline?
    Like I said the text frame script deletes empty text frames anywhere in the document so this is what I want to do for the graphics frames.
    May 22, 2013 4:07 AM   in reply to MToys
    An "inline" frame is one that is contained inside running text as an anchored object.
Bookmarked By (1)
