how can i use getUserID method in my main.as ??
NetConnectionClient.as
package com {
import flash.events.EventDispatcher;
import flash.events.Event;
public class NetConnectionClient extends EventDispatcher {
public static const ONUSERID:String = "onUserID";
private var _uID :Number;
public function setUserID(uID:Number):void {
_uID : uID;
dispatchEvent(new Event(NetConnectionClient.ONUSERID));
public function getUserID():Number {
return _uID;
Thanks!
That depends... do you have a reference to the NetConnectionClient in your main.as? If so, you should be able to just listen for the event dispatch, or just invoke the getUserId mehod from main.as. Are those not working for you?
Might be helpful if you post the relevant code from your main.as, or explain the classes that stand between main.as and your NetConnectionClient instance
package{
import com.NetConnectionClient;
import com.NetConnectionClientEvent;
import com.NetConnectionManager;
import fl.data.DataProvider;
import flash.display.Sprite;
import flash.events.MouseEvent;
import flash.events.NetStatusEvent;
import flash.events.SecurityErrorEvent;
import flash.events.SyncEvent;
import flash.net.SharedObject;
import fl.video.FLVPlayback;
import flash.display.MovieClip;
public class MainAdm extends Sprite{
private var nc:NetConnectionManager;
private var so:SharedObject;
private var soEl:SharedObject;
private var selectedUser:Number = 0;
private var userID:String;
public function MainAdm(){
nc=new NetConnectionManager();
nc.addEventListener("onConnect",onConnect);
nc.client = new NetConnectionClient();
nc.client.addEventListener("onUserID",onUserId);
nc.client.addEventListener("onReceiveChatMsg",onReceiveChatMsg);
nc.client.addEventListener("onElKaldirMsg",onElKaldirMsg);
nc.client.addEventListener("ongetUserID",ongetUserID);
i want to trace it here
trace(?????.getUserID().toString());
sendButton.label = "Send Message";
sendButton.addEventListener(MouseEvent.CLICK,onSendButtonClicked);
deselectButton.label = "clear";
deselectButton.addEventListener(MouseEvent.CLICK,onDeselectButtonClicked);
/*chatInputText.addEventListener(Event.CHANGE,onEnterPressed);*/
usersList.addEventListener(Event.CHANGE,onUserSelected);
/*sendButton.enabled =
chatInputText.enabled = false;*/
elKaldir.label = "El Kaldir";
elKaldir.addEventListener(MouseEvent.CLICK,onElKaldir);
/*usersTList.columnWidth = 100;
usersTList.rowHeight = 100;
usersTList.columnCount = 1;
usersTList.rowCount = 2;
usersTList.move(30, 250);*/
nc.createNetConnection("rtmp://localhost/FMSTutorial22");
I'd need to see your NetConnectionClient class to know for sure that this would work.... but what I'd do is define the NetConnectionClient so it's a member of the main.as. That would make it easier to reference.
public var ncc:NetConnectionClient;
ncc = new NetConnectionClient();
nc.client = ncc
ncc.addEventListener("onUserID",onUserId);
ncc.addEventListener("onReceiveChatMsg",onReceiveChatMsg);
ncc.addEventListener("onElKaldirMsg",onElKaldirMsg);
ncc.addEventListener("ongetUserID",ongetUserID);
trace(ncc.getUserID().toString());
package com{
public class NetConnectionClient extends EventDispatcher{
public function setUserID(uID:Number):void{
_uID : uID;
/*public function getUserID(uID:Number):void{
dispatchEvent(new NetConnectionClientEvent("onGetUserId",_uID));
public function receiveChatMessage(msg:String):void{
var tempObj:Object = new Object();
tempObj.msg = msg;
dispatchEvent(new NetConnectionClientEvent("onReceiveChatMsg",tempObj));
public function getUserIDMessage(uID:String):void{
tempObj.msg = uID;
dispatchEvent(new NetConnectionClientEvent("ongetUserID",tempObj));
public function getUserID():Number{
return _uID;
I see no reason why you couldn't make the NetConnectionClient a member of your main.as, unless there's something else in your architecture that would make it a problem.
that said, it looks like you're going to have some runtime errors with that NetConnectionClient class when getUserIDMessage or receiveChatMessage is invoked ... I don't see an import statement for your NetConnectionClientEvent class.
JayCharles thanks, i ll check it again
