Flash Player won't install on firefox
Mar 20, 2010 4:42 PM
Win 7 Home Premium 64
Firefox
When I try to install Flash using a plug in pop up on firefox, I get this  error message:
C:\Users\Owner\AppData\Loca\Temp|FP_PL_PFS_INSTALLER-4.exe
The  specified procedure could not be found
When I click on manual install, I  get this error message:
C:\Users\Owner\AppData\Roaming\Mozilla\Firefox\Profiles4ou8fmmf.
Default\extensions\{E2883E8F-472F-4fb0-9522-AC9BF37916A7}\chrome\
Content\getPlusPlus_Adobe_reg.exe
The  specified procedure could not be found.
Works in IE.
The files are in the locations specified above, however, they will not install correctly when you click.  When you click on the fp_pl.... file,, you see two small windows pop up too quick to read, but install does not work.
Thx
spencer
    Mar 20, 2010 4:54 PM   in reply to SpencerTN
    Hi Spencer, Let's see what of Flash Player is and is not installed. Go to C:\Windows\SysWOW64\Macromed\Flash
    Open the Flash folder and post back all of the files listed there. The IE files version numbers will be evident. However,
    the FF(Firefox) and "other browser" files will not. Right click on NPSWF32.dll and NPSWF32_FlashUtil.exe and then click
    on Properties to obtain the version numbers for each.
    Then using IE, find in your manage add ons Shockwave Flash Object...ActiveX Control...Flash10e.ocx and make sure it
    is enabled and is vs 10.0.45.2.
    Then using FF, find in the plug-ins the SWF vs 10.0.45.2 and make sure it is enabled. If there are more than one listing of
    the SWF, I need to know that also. I understand that vs 10.0.45.2 may not be there since you are having a problem installing. I just want to make sure.
    eidnolb
    Mar 20, 2010 5:34 PM   in reply to SpencerTN
    Hi Spencer, The Flash Player files for IE and the SWO add on are correct.
    I would download and SAVE to your Desktop this FF Installer:
    http://fpdownload.macromedia.com/get/flashplayer/current/install_flash _player.exe
    Unlike IE Flash Player Installs, due to the ActiveX Control that is used, you shouldn't have any problem with Anti-Virus/Firewall blocks with FF.
    I would however, close all browsers and RUN it then. After installed, Reboot(restart) your computer. Then you can check
    the Flash files and get the versions and check the SWF in the FF plug-in.
    eidnolb
    Mar 20, 2010 5:48 PM   in reply to SpencerTN
    Hi, I have not encountered this before. During the install with that link for FF, you received that message? Is this from
    Windows or your Anti-Virus/Firewall or IE ?
    eidnolb
    Mar 20, 2010 6:00 PM   in reply to SpencerTN
    That is strange that I have not encountered this before. I've worked with so many with Win7/IE8 users, never came up
    before.  I will have to do some searching on Microsoft. I would just off the top of my head guess that this is an IE8 feature,
    since Flash Player is a browser plug-in and not a program per se.
    So did the FP get installed? Did you check the Flash folder?  If they are installed, then I know what you need to do to get
    the SWF add on, but first things first.
    eidnolb
    Mar 20, 2010 6:13 PM   in reply to SpencerTN
    Ok, Spencer, you have the FF Flash Player files installed!! Now I doubt if the SWF plug-in has been installed in the plug-in section for FF.  You can check and if it is, let me know. But more than likely it is not. If not, using the FF browser, go here:
    http://www.adobe.com/software/flash/about/
    If there is a message that you need a plug-in, do whatever it says. Then post back after you have checked for the SWF.
    eidnolb
    Mar 20, 2010 6:26 PM   in reply to SpencerTN
    Well, there must be some setting within the IE8 or Win7. It doesn't help since I don't know what it is without taking time
    to search for it. Let me check Mozilla and see what they say. I have some FF plug-in info in my folders. Let me check and
    I'll get back to you as soon as I can.
    eidnolb
    You can try this test site from Adobe, won't hurt anything, you may get a different message without the DLM.
    http://www.adobe.com/products/flash/about
    Mar 20, 2010 7:02 PM   in reply to SpencerTN
    Hi, You are correct, it wouldn't have anything to do with IE8. Ever since Win7 came out, I know it has IE8 so I just connect the two in my brain.LOL  I read that you can't go back to any other version of IE, with Win7.
    Firefox calls their add ons "plug-ins"; Internet Explorer calls their add ons "ActiveX Controls". Adobe calls Flash Player a browser "plug-in" Now most likely you will find the Flash Player listed in the add/remove or programs and features section, where programs are listed. Confused yet? Now when Flash Player is installed using IE, 4 files are installed into
    the Flash folder. That alone is not enought for Flash Player to work. In the IE add ons, the Shockwave Flash Object, yes the ActiveX Control and it is the Control must be there and enabled.
    Now if Flash Player is installed in FF, also 4 files are installed into the Flash folder. You have 8 files, so you have all of what you need for Flash Player to work using IE since you have the SWO. FF also needs that "control", but it is called
    SWF(Shockwave Flash) and it must be enabled. The SWF is called a "plug-in".
    The only thing I found on Mozilla is how to install the Flash Player "plug-in" which I thot they meant the SWF. No they
    mean how to install what Adobe calls Flash Player, i.e. the "plug-in" Now are you confused? But you already have Flash Player installed and the 4 files are sitting in the Flash folder. Dizzy yet?
    I am going to Microsoft and it may be tomorrow before we get an answer. LOL
    Now I know why I liked Accounting, 2+2 was always 4.
    eidnolb
    Mar 20, 2010 7:11 PM   in reply to eidnolb
    Hi, I wanted to link to that Mozilla "plug-in" info. It may be that you can follow it and get this SWF installed. I don't see where it would hurt. There is also a video of the instructions.  Whether the message from Win7 would overrule this is hard to tell.  Might be worth looking at.
    http://support.mozilla.com/en-US/kb/Installing+the+Flash+plugin
    eidnolb
    Mar 20, 2010 7:52 PM   in reply to SpencerTN
    Hi again, honestly. Hey where are all of the FF people? You know the ones that loathe IE? ROFL Oh, that's right, they are over at Google singing Chrome's praises, at least until a new kid shows up on the block. Well, I am going to review your
    thread to see if there is anything that gives a hint as to what is causing this.
    I just cannot imagine a "plug-in" being blocked?
    Oh, what version of FF are you using?
    eidnolb
    Mar 20, 2010 8:16 PM   in reply to SpencerTN
    Thanks Spencer, Since I don't use FF, is this the latest vs? I am reading here and don't know if this many questions about
    FF is normal or more than usual; I'll let you decide.
    http://support.mozilla.com/search.php?where=f&locale=en-US&qs=s&q=vers ion+3.6+problems&sa=
    eidnolb
    Mar 20, 2010 8:46 PM   in reply to SpencerTN
    Hi, so from the iPhone:-)  I was just wondering if there may be a glitch or something. It happens with new versions. I try not to update on Patch Tuesday either for that very reason. LOL
    Well I'll see what I can find out. Like I said I had never heard of what you have experienced so for me it is something new.
    Have a good night.
    eidnolb
    Mar 20, 2010 9:27 PM   in reply to eidnolb
    just got this to work...
    after trying to manual install, like in your original post:
    close firefox
    find getPlusPlus_Adobe_reg.exe and run it. leave it open
    start firefox
    if there are errors or firefox can't find hosts restart it
    I did this and getPlus downloaded and installed flash player
    win 7 64
    firefox 3.6
    Mar 20, 2010 9:45 PM   in reply to bigyooper
    where did you get getPlusPlus_Adobe_reg.exe?
    Mar 20, 2010 9:51 PM   in reply to bigyooper
    still doesn't show up in firefox, even after plugin installs and system is rebooted.
    bummer....
    Mar 20, 2010 9:52 PM   in reply to cliff roy
    read first post in the string
    Mar 23, 2010 6:39 PM   in reply to SpencerTN
    Hi Spencer, Well they came out with that update fast. I just read Mozilla yesterday and they said 3/30/10 for the update.
    I'm assuming when you said the DLM downloaded the file, you are speaking of the update. Does this have any meaning?
    http://support.mozilla.com/en-US/forum/1/626868?s=Shockwave%20Flash%20 wont%27%20install%20in%20add-ons&as=q
    I have entered searches and can't get the results to match my search topic.
    I see the other helper is on, I'll see if he has any idea as to what might be going on.
    By the way, do you have a getPlus or DLM plug-in, or add-on? I saw someone on the Firefox site saying they did.
    eidnolb
    Mar 23, 2010 7:41 PM   in reply to SpencerTN
    Hi, thanks. So you have those 2 plug-ins. Hmmm. Well, go to Programs and Features and see if the DLM/getPlus is listed
    there also. If they are then that is problably your problem. I would remove both and Reboot. That should remove the getPlus extension and the DLM add on. Check though afterwards.
    The DLM and the getPlus are supposed to disconnect after they download. However they don't always and have been
    causing problems for I don't know how long. I have for quite some time advised users to Remove them both. They could be hanging up and that is why you are having a problem.
    The last few days is the first I recall of them causing a problem with FF however.
    If you are concerned about removing them, don't be. From what I can tell Firefox will use them again when  you try to
    install that SWF 10.0.45.2 plug-in.
    Let me know.
    eidnolb
    Mar 25, 2010 4:48 PM   in reply to SpencerTN
    Pssst. I guess you didn't see my post 3 days ago when I figured this out
    Mar 25, 2010 4:52 PM   in reply to SpencerTN
    Hi Spencer, Well, actually the person that found out that it was bitdefender was bigyooper here:
    http://forums.adobe.com/thread/601019?tstart=0
    He put this thread up and we were hoping you and the others that were having the same problem that night would see it!
    He contacted bitdefender about it but haven't heard if they have responded. He was one that was having that problem too that night.
    Well I am glad everyone has it solved now
    Thanks for the feedback, you just never know what is going to conflict.
    eidnolb
