Hi all,
How to detect camera is in use or not ?? Adobe says, if Camera.getCamera(); returns null, it means camera not installed, or in use ,
i use below, then when i start swf, first one is ok, but then i start new instance of app, it throws and error " .... flash 10 r2has stopped"
how can i solve that problem...
cam = Camera.getCamera();
if (!cam) {
myTextField.text = "No camera is installed.";
} else {
myTextField.text = "Connecting";
connectCamera();
private function connectCamera():void {
var vid:Video = new Video(150, 150);
vid.x = 10;
vid.y = 10;
vid.attachCamera(cam);
addChild(vid);
thanks..
What adobe says is correct. Camera.getCamera() returns the available camera on the system or null if camera is not installed or not free.
To kill a netstream simply do following,
netStream.close();
netStream = null;
that should work.
I use code below,
get an error like that
1. instance working good,
2.instance give an erro when i clicked allow for camera ???
package {
import flash.display.Sprite;
import flash.media.Camera;
import flash.media.Video;
import flash.text.TextField;
import flash.text.TextFieldAutoSize;
import flash.utils.Timer;
import flash.events.TimerEvent;
import flash.events.StatusEvent;
import flash.events.MouseEvent;
import flash.system.SecurityPanel;
import flash.system.Security;
public class Camera_getCameraExample extends Sprite {
private var myTextField:TextField;
private var cam:Camera;
private var t:Timer = new Timer(1000);
public function Camera_getCameraExample() {
myTextField = new TextField();
myTextField.x = 10;
myTextField.y = 10;
myTextField.background = true;
myTextField.selectable = false;
myTextField.autoSize = TextFieldAutoSize.LEFT;
if (!cam) {
} else if (cam.muted) {
myTextField.text = "To enable the use of the camera,\n"
+ "please click on this text field.\n"
+ "When the Flash Player Settings dialog appears,\n"
+ "make sure to select the Allow radio button\n"
+ "to grant access to your camera.";
myTextField.addEventListener(MouseEvent.CLICK, clickHandler);
}else {
connectCamera();
addChild(myTextField);
t.addEventListener(TimerEvent.TIMER, timerHandler);
private function clickHandler(e:MouseEvent):void {
Security.showSettings(SecurityPanel.PRIVACY);
cam.addEventListener(StatusEvent.STATUS, statusHandler);
myTextField.removeEventListener(MouseEvent.CLICK, clickHandler);
private function statusHandler(event:StatusEvent):void {
if (event.code == "Camera.Unmuted") {
connectCamera();
cam.removeEventListener(StatusEvent.STATUS, statusHandler);
var vid:Video = new Video(cam.width, cam.height);
vid.x = 10;
vid.y = 10;
addChild(vid);
t.start();
private function timerHandler(event:TimerEvent):void {
myTextField.y = cam.height + 20;
myTextField.text = "";
myTextField.appendText("bandwidth: " + cam.bandwidth + "\n");
myTextField.appendText("currentFPS: " + Math.round(cam.currentFPS) + "\n");
myTextField.appendText("fps: " + cam.fps + "\n");
myTextField.appendText("keyFrameInterval: " + cam.keyFrameInterval + "\n");
What combination of platform and camera device are you experiencing a flashplayer crash with? I've never encountered this behavior.
hi JayCharles , flash cs4, windows 7, ie8 i use. Thanks ...
I've found that I need to manually release the camera. A function that calls:
vid.attachCamera(null);
Hopefully that is the piece that works for you too.
hi yun, actually i need to detect camera is in use or not ?? because , while a application using the cam, another app shouldnt allow user to use cam. When the app does, crashing. So i need a sample shows, check camera if in use or not before start..
Thanks...
I see, my mistake. I understand what you mean now. Have you tried to instantiate the Camera object in a Try/Catch block to maybe capture the error without crashing your flash player?
Hi yun, i have already tried to use try/catch but, app is crashing down , when started Thanks for your help .
