Apply transparent fade to photo edges
Mar 24, 2010 11:32 AM
I have found that I can apply a fade to transparent using the Gradient tool, and dragging it in to the picture.  Works great, but I can only apply fade to one side of the photo. If I try to do the other side of the photo, the previous fade is undone.  I have to save the changed photo and redo the Gradient tool to another side of the pic, and so on.  Goal is to apply an uneven fade to transparency around the edges of a picture.   I have also tried the Background Eraser, results have not been great - seems to leave a lot of pixels behind.  Is there a way to do this - without repeatedly fading one side, saving, fading a side, saving, etc....?
    Mar 24, 2010 11:51 AM   in reply to SG51
    Try a google search for photoshop vignette tutorial. There are a few different ways to go about achieving this.
    Mar 24, 2010 12:05 PM   in reply to SG51
    Rename the Background layer by Alt-double clicking it.
    Create a new layer, fill it with white and drag it below the other one.
    With the Rectangular Marquee make a selection a bit smaller than the  image.
    Make a layer mask from the selection, on the image layer by clicking on the mask icon at the bottom of the layers palette.
    Apply a Gaussian blur to the mask and adjust to taste.
    Mar 24, 2010 3:31 PM   in reply to SG51
    You can modify the layer mask by painting on it with a soft black brush with medium opacity.
    (You select the mask in the layers palette and actually paint on the image.)
    Doing the torn effect is a matter of your painting ability.
    There are also plug-ins and actions for all sorts of other effects
    Feb 26, 2011 6:20 PM   in reply to John Joslin
    Hello John,
    Sorry for jumping in, but I have followed your instructions (in Photoshop CS4), but without success.  I have read a lot about it, but I have never been able to make it work.  I presume the rectange marquee is done on the background image layer, right?  Once I create  the mask, the center of my selection become transparent red.  At that point only the red section becomes editable.  I don't want to shade the center of the image, but the edges.  What am I doing wrong??
    Regards,
    Ronald
  • Pierre Courtejoie
    Jan 11, 2006
    Feb 27, 2011 2:39 AM   in reply to barpos
    Hello!
    Barpos, it seems that you did not promote the background to a layer.
    You then went in Quickmask mode. Did you click on the letter Q, or did you click on the bottommost button of the Toolbox?
    http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e 41001031ab64-76c1a.html
    Pierre.
    Feb 27, 2011 3:54 AM   in reply to Pierre Courtejoie
    Hello Pierre,
    >it seems that you did not promote the background to a layer.<
    I have no idea what that means.  My background image was copied into a separate layer, then I deleted my original background layer, if that's what you mean.
    >You then went in Quickmask mode. Did you click on the letter Q, or did you click on the bottommost button of the Toolbox?<
    I clicked on the bottommost button of the toolbox.
    Here's an excerpt of the link you provided:
    1. Using any selection tool, select the part of the image you want to change.
    2. Click the Quick Mask mode button in the toolbox.
      A color overlay (similar to a rubylith) covers and protects the area outside the selection. Selected areas are left unprotected by this mask. By default, Quick Mask mode colors the protected area using a red, 50% opaque overlay.
    1.  Using the marquee selection tool, I select 85% of the image.
    2.  I click on the Quick Mask mode button.  Then my selection become red, not the outside of the selection.  Well, actually if I double click on the quick mask button, I can reverse it by choosing Masked Area instead of Selected Area.
    But, from then on, how do I apply a blur to make my edges transparent (not white)??  That image will be sitting on a pattern underneath in my website.
    Ron
  • Pierre Courtejoie
    Jan 11, 2006
    Feb 27, 2011 8:07 AM   in reply to barpos
    Yes, that's what I thougth.
    In John's instructions in the third post, it is written to add a layer mask, from the layer panel, you added a quick mask from the toolbox.
    It is the same icon, but in the layers panel. (I can see where the confusion comes from!)
    So you double click to create a new layer
    Create a new layer below the first one.
    Target the former background layer, click on the layer mask icon if the layers panel, then modify it as you want.
    You should not see any red, unless you click on the quickmask icon of the toolbox or if you clicked on the layer mask eye on the channels panel, or if you hit backslash.
    Feb 27, 2011 8:38 AM   in reply to Pierre Courtejoie
    Yes, I see my mistake now. <g>
    Ok, I now have a white picture frame around my image.  John is not telling us how to apply that blur though.
    BTW, I did find a way of doing the same thing, but with a completely different [lenghty] approach.  I'd like to do it John's way though.
    Ron
    Feb 27, 2011 8:45 AM   in reply to barpos
    Ron,
    Your Blur (Filter>Gaussian Blur, or similar), can be applied to the Layer Mask. In the Layer w/ the Mask, click on the icon of the Mask, or with that Layer active, go to Channels Palette, and make it active.
    [Edit] Another similar method is to add Feather, when you have done your Selection, before you make it a Mask.
    Aug 16, 2011 12:00 PM   in reply to SG51
    An even easier method (CS5):
    Make your selection of what you wish to keep via the Marquee tool or thru a series of Select menu options (All - Modify border (lg) - Modify Feather (sm)- Inverse).
    Choose Select - Refine Edges...
    Before clicking OK:
    1) Adjust the Feather slider (large)
    2) Adjust the Edge (left)
    3) Choose Output to: as Layer Mask
    4) re-adjust as necessary
    Click OK and there you go. Ready to Place it into another photo or onto a background where it can be Free Transformed to meet your needs.
    If you also choose Remember Settings before you click OK after you have figured out what you like then it will be even easier yet the next time you need to do this.
    Dec 14, 2011 10:35 PM   in reply to JustLittleOlMe
    Thanks so much. I t took me a minute to fiddle around with it but with your help and the preceding posts, I figured it out. Thanks!
