Flash Builder 4 installation fail
Mar 25, 2010 3:54 PM
Unable to install Flah Builder, bad start...
Here the message, there no log file in C:Common Files, any idea?
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 16 error(s), 14 warning(s)
WARNING: Payload cannot be installed due to dependent operation failure
ERROR: The following payload errors were found during install:
ERROR:  - Microsoft_VC90_ATL_x86: Install failed
ERROR:  - Microsoft_VC90_CRT_x86: Install failed
ERROR:  - Microsoft_VC80_ATL_x86: Install failed
ERROR:  - Adobe Flash Builder: Install failed
ERROR:  - Adobe Player for Embedding: Install failed
ERROR:  - Suite Shared Configuration CS5: Install failed
ERROR:  - AdobeHelp: Install failed
ERROR:  - Adobe Flash Player 10 ActiveX: Install failed
ERROR:  - Microsoft_VC90_MFC_x86: Install failed
ERROR:  - AdobeTypeSupport CS5: Install failed
ERROR:  - Microsoft_VC80_CRT_x86: Install failed
ERROR:  - AdobeCMaps CS5: Install failed
ERROR:  - Microsoft_VC80_MFC_x86: Install failed
ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
ERROR:  - Adobe Flash Player 10 Plugin: Install failed
Replies 1 2 Previous Next
    Mar 25, 2010 3:58 PM   in reply to laurent untereiner
    Did you run the installer with "Run As Administrator"?
    Jason San Jose
    Software Engineer, Flash Builder
    Mar 28, 2010 10:57 PM   in reply to laurent untereiner
    I have the same problem with Flash Builder 4,I can't install Microsoft_VC90_ATL_x86
    Mar 29, 2010 11:19 AM   in reply to longrenyun
    @longrenyun
    Did you also try "Run as Administrator" when installing?
    Jason San Jose
    Mar 29, 2010 12:05 PM   in reply to laurent untereiner
    Unable to install Flash Builder.
    The message:
    Exit Code: 7
    - 0 fatal error(s), 3 error(s), 0 warning(s)
    ERROR: Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
    Mar 29, 2010 12:10 PM   in reply to Marcelo Traldi
    Can you paste your log file from C:\Program Files (x86)\Common Files\Adobe\Installers\Adobe Flash Builder 4.0 <date>.log.gz?
    And just to confirm, did you launch the installer with "Run as Administrator"?
    Jason San Jose
    Mar 29, 2010 1:37 PM   in reply to laurent untereiner
    I have the same problem tried run as administrator and i still get the same error.
    Exit Code: 7
    Mar 29, 2010 1:53 PM   in reply to Sein-kh-reKI5q
    Can you both provide us with more info here?
    - Windows version and language
    - Visual Studio version and language (if installed)
    Jason San Jose
    Mar 29, 2010 3:44 PM   in reply to Jason San Jose
    - I launched the installer with "Run as Administrator"
    - Windows 7 Ultimate
    - I dont't have Visual Studio
    [    3164] Mon Mar 29 19:29:26 2010  INFO
    Visit http://www.adobe.com/go/loganalyzer/ for more information
    START - Installer Session
    RIBS version: 3.0.121.0
    Win OS version: 6.1.0.0  Type: 1
    ::START TIMER:: [Total Timer]
    CHECK: Single instance running
    CHECK : Credentials
    Load Deployment File
    Create Required Folders
    Assuming install mode
    ::START TIMER:: [Bootstrap]
    Perform Bootstrapping ...
    :: END TIMER :: [Bootstrap] took 23322 miliseconds (23.322 seconds) DTR = 72.2066 KBPS (0.0705142 MBPS)
    Looking up install source path
    Sync Media DB ...
    ::START TIMER:: [Sync Media DB]
    Pre check media db sync
    End of Pre check media db sync. Exit code: 0
    :: END TIMER :: [Sync Media DB] took 1470.96 miliseconds (1.47096 seconds)
    Ready to initialize session to start with ...
    ::START TIMER:: [CreatePayloadSession]
    -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
    Updated source path: C:\development\Adobe Flash Builder 4 Standalone
    Updating media info for: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
    Ignoring original data since install source is local
      Type: 0, Volume Order: 1, Media Name: Adobe Flash Builder
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
    Updating media info for: {08D2E121-7F6A-43EB-97FD-629B44903403}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
    Updating media info for: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
    Updating media info for: {177E1CA1-14CC-4398-AB15-A5746EFE8F22}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashBuilder-mul\Install.db
    Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeAPE3-mul\Install.db
    Updating media info for: {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
    Updating media info for: {3BF96AC2-0CA1-11DF-B07B-459956D89593}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeHelp\AIRInstallerRunner.exe
    Updating media info for: {5EE868D6-7B6B-49ee-AF60-09B1358AFFD7}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_axDbg_mul\AdobeFlashPlayer10_a xDbg_mul.msi
    Updating media info for: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
    Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeTypeSupport10-mul\Install.db
    Updating media info for: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
    Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeCMaps3-mul\Install.db
    Updating media info for: {D1A19B02-817E-4296-A45B-07853FD74D57}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
    Updating media info for: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x 86.msi
    Updating media info for: {FB7F30B6-BFBF-4d2c-9F61-B5533659ACBE}
      Path: C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_plDbg_mul\AdobeFlashPlayer10_p lDbg_mul.msi
    --------------------  END  - Updating Media Sources -  END  --------------------
    Supported RIBS version range: [0.0.66.0,3.0.121.0]
    ----------------- CreatePayloadSession: machine is x86 ---------------
    ______ Verify Dependency Subscribers ______
    Setting property "INSTALLDIR" to: C:\Program Files\Adobe
    Setting property "installLanguage" to: pt_BR
    Attempting to find the selected language in the set of available payload languages
    Setting property "installSourcePath" to: C:\development\Adobe Flash Builder 4 Standalone
    Overwrite property "userASUPath" to: C:\Users\M@RCELO\AppData\Local\Adobe\OOBE\PDApp\
    Found payload actions:
    Deciding what installer mode to use...
    BEGIN Setting requested payload actions
    Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: true
    Action string for  {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86  is none
    Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: true
    Action string for  {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86  is none
    Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: true
    Action string for  {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86  is none
    Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: true
    Action string for  {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86  is none
    Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: true
    Action string for  {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86  is none
    Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: true
    Action string for  {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86  is none
    Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: true
    Action string for  {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86  is none
    Value returned on lookup of payload: {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5 is: false
    Action string for  {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5  is none
    Value returned on lookup of payload: {5EE868D6-7B6B-49ee-AF60-09B1358AFFD7} Adobe Flash Player 10 ActiveX is: true
    Action string for  {5EE868D6-7B6B-49ee-AF60-09B1358AFFD7} Adobe Flash Player 10 ActiveX  is none
    Value returned on lookup of payload: {FB7F30B6-BFBF-4d2c-9F61-B5533659ACBE} Adobe Flash Player 10 Plugin is: true
    Action string for  {FB7F30B6-BFBF-4d2c-9F61-B5533659ACBE} Adobe Flash Player 10 Plugin  is none
    Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: false
    Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none
    Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: false
    Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none
    Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: false
    Action string for  {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp  is none
    Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: false
    Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none
    Value returned on lookup of payload: {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder is: false
    Action string for  {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder  is install
    END Setting requested payload actions
    Collected advanced path check information for INSTALLDIR
    INSTALLDIR is a well-formed path
    INSTALLDIR is not the root path
    INSTALLDIR is on a local volume
    INSTALLDIR is on a writable volume
    INSTALLDIR is not on a case sensitive volume
    INSTALLDIR passed path basic path validation: C:\Program Files\Adobe
    [    3164] Mon Mar 29 19:29:27 2010  INFO
    ::START TIMER:: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
    In InstallPreSystemCheckProc
    Custom action return code: 0
    :: END TIMER :: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 3.18845 miliseconds (0.00318845 seconds)
    Payloads passed preflight validation.
    Call PreSession Custom Hook
    ::START TIMER:: [Pre session :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
    In InstallSessionOpenProc
    :: END TIMER :: [Pre session :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 1.94069 miliseconds (0.00194069 seconds)
    Calling the custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
    ::START TIMER:: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}]
    [    3916] Mon Mar 29 19:29:27 2010  INFO
    Installer Operation: InstallThirdPartyPayloadOperation
    Installing third party payload
    Installing payload
    Attempting to install package from:C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
    Payload is already installed with MSI
    MsiSourceListAddSource for  C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi is 0
    MsiSourceListSetInfo with updated name: Microsoft_VC80_CRT_x86.msi, Result: 0
    Payload source is not removable so not updating media info
    Command line arguments:  REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
    1: 0 2: 1033 3: 1252
    [    3916] Mon Mar 29 19:29:28 2010  INFO
    [    3916] Mon Mar 29 19:29:29 2010  INFO
    === Logging started: 29/03/2010  19:29:29 ===
    Message type: 0, Argument: 1033
    Message type: 1, Argument: Microsoft_VC80_CRT_x86
    Action 19:29:29: INSTALL.
    Action start 19:29:29: INSTALL.
    Action 19:29:29: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
    Action start 19:29:29: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
    Action ended 19:29:29: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:29: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
    Action start 19:29:29: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
    Action ended 19:29:29: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:29: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
    Action start 19:29:29: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
    Action ended 19:29:29: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:29: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
    Action start 19:29:29: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
    Action ended 19:29:29: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:29: AppSearch. Searching for installed applications
    Action start 19:29:29: AppSearch.
    Action ended 19:29:29: AppSearch. Return value 0.
    Action 19:29:29: FindRelatedProducts. Searching for related applications
    Action start 19:29:29: FindRelatedProducts.
    Action ended 19:29:29: FindRelatedProducts. Return value 0.
    Action 19:29:29: ValidateProductID.
    Action start 19:29:29: ValidateProductID.
    Action ended 19:29:29: ValidateProductID. Return value 1.
    Action 19:29:29: CostInitialize. Computing space requirements
    Action start 19:29:29: CostInitialize.
    Action ended 19:29:29: CostInitialize. Return value 1.
    Action 19:29:29: FileCost. Computing space requirements
    Action start 19:29:29: FileCost.
    Action ended 19:29:29: FileCost. Return value 1.
    Action 19:29:29: IsolateComponents.
    Action start 19:29:29: IsolateComponents.
    Action ended 19:29:29: IsolateComponents. Return value 0.
    Action 19:29:29: CostFinalize. Computing space requirements
    Action start 19:29:29: CostFinalize.
    Action ended 19:29:29: CostFinalize. Return value 1.
    Action 19:29:29: SetODBCFolders. Initializing ODBC directories
    Action start 19:29:29: SetODBCFolders.
    Action ended 19:29:29: SetODBCFolders. Return value 0.
    Action 19:29:29: MigrateFeatureStates. Migrating feature states from related applications
    Action start 19:29:29: MigrateFeatureStates.
    Action ended 19:29:29: MigrateFeatureStates. Return value 0.
    Action 19:29:29: InstallValidate. Validating install
    Action start 19:29:29: InstallValidate.
    Action ended 19:29:29: InstallValidate. Return value 1.
    Action 19:29:29: RemoveExistingProducts. Removing applications
    Action start 19:29:29: RemoveExistingProducts.
    Action ended 19:29:29: RemoveExistingProducts. Return value 0.
    Action 19:29:29: InstallInitialize.
    Action start 19:29:29: InstallInitialize.
    [    3916] Mon Mar 29 19:29:31 2010  INFO
    Action ended 19:29:31: InstallInitialize. Return value 1.
    Action 19:29:31: SxsInstallCA.
    Action start 19:29:31: SxsInstallCA.
    [    3916] Mon Mar 29 19:29:32 2010  INFO
    1: sxsdelca 2: traceop 3: 1256 4: 0
    1: sxsdelca 2: traceop 3: 1257 4: 0
    1: sxsdelca 2: traceop 3: 1258 4: 0
    1: sxsdelca 2: traceop 3: 1284 4: 0
    1: sxsdelca 2: traceop 3: 1288 4: 0
    1: sxsdelca 2: traceop 3: 1289 4: 0
    1: sxsdelca 2: traceop 3: 1290 4: 0
    1: sxsdelca 2: traceop 3: 1292 4: 0
    1: sxsdelca 2: traceop 3: 1318 4: 0
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18 E
    1: sxsdelca 2: traceop 3: 1284 4: 259
    1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
    Action ended 19:29:32: SxsInstallCA. Return value 1.
    Action 19:29:32: ProcessComponents. Updating component registration
    Action start 19:29:32: ProcessComponents.
    Action 19:29:32: GenerateScript. Generating script operations for action:
    Action ended 19:29:32: ProcessComponents. Return value 1.
    Action 19:29:32: UnpublishComponents. Unpublishing Qualified Components
    Action start 19:29:32: UnpublishComponents.
    Action ended 19:29:32: UnpublishComponents. Return value 0.
    Action 19:29:32: MsiUnpublishAssemblies. Unpublishing assembly information
    Action start 19:29:32: MsiUnpublishAssemblies.
    Action ended 19:29:32: MsiUnpublishAssemblies. Return value 1.
    Action 19:29:32: UnpublishFeatures. Unpublishing product features
    Action start 19:29:32: UnpublishFeatures.
    Action ended 19:29:32: UnpublishFeatures. Return value 1.
    Action 19:29:32: StopServices. Stopping services
    Action start 19:29:32: StopServices.
    Action ended 19:29:32: StopServices. Return value 1.
    Action 19:29:32: DeleteServices. Deleting services
    Action start 19:29:32: DeleteServices.
    Action ended 19:29:32: DeleteServices. Return value 1.
    Action 19:29:32: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 19:29:32: UnregisterComPlus.
    Action ended 19:29:32: UnregisterComPlus. Return value 0.
    Action 19:29:32: SelfUnregModules. Unregistering modules
    Action start 19:29:32: SelfUnregModules.
    Action ended 19:29:32: SelfUnregModules. Return value 1.
    Action 19:29:32: UnregisterTypeLibraries. Unregistering type libraries
    Action start 19:29:32: UnregisterTypeLibraries.
    Action ended 19:29:32: UnregisterTypeLibraries. Return value 0.
    Action 19:29:32: RemoveODBC. Removing ODBC components
    Action start 19:29:32: RemoveODBC.
    Action ended 19:29:32: RemoveODBC. Return value 1.
    Action 19:29:32: UnregisterFonts. Unregistering fonts
    Action start 19:29:32: UnregisterFonts.
    Action ended 19:29:32: UnregisterFonts. Return value 1.
    Action 19:29:32: RemoveRegistryValues. Removing system registry values
    Action start 19:29:32: RemoveRegistryValues.
    Action ended 19:29:32: RemoveRegistryValues. Return value 1.
    Action 19:29:32: UnregisterClassInfo. Unregister class servers
    Action start 19:29:32: UnregisterClassInfo.
    Action ended 19:29:32: UnregisterClassInfo. Return value 0.
    Action 19:29:32: UnregisterExtensionInfo. Unregistering extension servers
    Action start 19:29:32: UnregisterExtensionInfo.
    Action ended 19:29:32: UnregisterExtensionInfo. Return value 0.
    Action 19:29:32: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 19:29:32: UnregisterProgIdInfo.
    Action ended 19:29:32: UnregisterProgIdInfo. Return value 0.
    Action 19:29:32: UnregisterMIMEInfo. Unregistering MIME info
    Action start 19:29:32: UnregisterMIMEInfo.
    Action ended 19:29:32: UnregisterMIMEInfo. Return value 0.
    Action 19:29:32: RemoveIniValues. Removing INI file entries
    Action start 19:29:32: RemoveIniValues.
    Action ended 19:29:32: RemoveIniValues. Return value 1.
    Action 19:29:32: RemoveShortcuts. Removing shortcuts
    Action start 19:29:32: RemoveShortcuts.
    Action ended 19:29:32: RemoveShortcuts. Return value 0.
    Action 19:29:32: RemoveEnvironmentStrings. Updating environment strings
    Action start 19:29:32: RemoveEnvironmentStrings.
    Action ended 19:29:32: RemoveEnvironmentStrings. Return value 1.
    Action 19:29:32: RemoveDuplicateFiles. Removing duplicated files
    Action start 19:29:32: RemoveDuplicateFiles.
    Action ended 19:29:32: RemoveDuplicateFiles. Return value 1.
    Action 19:29:32: RemoveFiles. Removing files
    Action start 19:29:32: RemoveFiles.
    Action ended 19:29:32: RemoveFiles. Return value 0.
    Action 19:29:32: RemoveFolders. Removing folders
    Action start 19:29:32: RemoveFolders.
    Action ended 19:29:32: RemoveFolders. Return value 0.
    Action 19:29:32: CreateFolders. Creating folders
    Action start 19:29:32: CreateFolders.
    Action ended 19:29:32: CreateFolders. Return value 0.
    Action 19:29:32: MoveFiles. Moving files
    Action start 19:29:32: MoveFiles.
    Action ended 19:29:32: MoveFiles. Return value 1.
    Action 19:29:32: InstallFiles. Copying new files
    Action start 19:29:32: InstallFiles.
    File: Copying new files,  Directory: ,  Size:
    [    3916] Mon Mar 29 19:29:33 2010  INFO
    Action ended 19:29:33: InstallFiles. Return value 1.
    Action 19:29:33: PatchFiles. Patching files
    Action start 19:29:33: PatchFiles.
    Action ended 19:29:33: PatchFiles. Return value 0.
    Action 19:29:33: DuplicateFiles. Creating duplicate files
    Action start 19:29:33: DuplicateFiles.
    Action ended 19:29:33: DuplicateFiles. Return value 1.
    Action 19:29:33: BindImage. Binding executables
    Action start 19:29:33: BindImage.
    Action ended 19:29:33: BindImage. Return value 1.
    Action 19:29:33: CreateShortcuts. Creating shortcuts
    Action start 19:29:33: CreateShortcuts.
    Shortcut: Creating shortcuts
    Action ended 19:29:33: CreateShortcuts. Return value 0.
    Action 19:29:33: RegisterClassInfo. Registering class servers
    Action start 19:29:33: RegisterClassInfo.
    Action ended 19:29:33: RegisterClassInfo. Return value 0.
    Action 19:29:33: RegisterExtensionInfo. Registering extension servers
    Action start 19:29:33: RegisterExtensionInfo.
    Action ended 19:29:33: RegisterExtensionInfo. Return value 0.
    Action 19:29:33: RegisterProgIdInfo. Registering program identifiers
    Action start 19:29:33: RegisterProgIdInfo.
    Action ended 19:29:33: RegisterProgIdInfo. Return value 0.
    Action 19:29:33: RegisterMIMEInfo. Registering MIME info
    Action start 19:29:33: RegisterMIMEInfo.
    Action ended 19:29:33: RegisterMIMEInfo. Return value 0.
    Action 19:29:33: WriteRegistryValues. Writing system registry values
    Action start 19:29:33: WriteRegistryValues.
    Action ended 19:29:33: WriteRegistryValues. Return value 1.
    Action 19:29:33: WriteIniValues. Writing INI file values
    Action start 19:29:33: WriteIniValues.
    Action ended 19:29:33: WriteIniValues. Return value 1.
    Action 19:29:33: WriteEnvironmentStrings. Updating environment strings
    Action start 19:29:33: WriteEnvironmentStrings.
    Action ended 19:29:33: WriteEnvironmentStrings. Return value 1.
    Action 19:29:33: RegisterFonts. Registering fonts
    Action start 19:29:33: RegisterFonts.
    Action ended 19:29:33: RegisterFonts. Return value 1.
    Action 19:29:33: InstallODBC. Installing ODBC components
    Action start 19:29:33: InstallODBC.
    Action ended 19:29:33: InstallODBC. Return value 0.
    Action 19:29:33: RegisterTypeLibraries. Registering type libraries
    Action start 19:29:33: RegisterTypeLibraries.
    Action ended 19:29:33: RegisterTypeLibraries. Return value 0.
    Action 19:29:33: SelfRegModules. Registering modules
    Action start 19:29:33: SelfRegModules.
    Action ended 19:29:33: SelfRegModules. Return value 1.
    Action 19:29:33: RegisterComPlus. Registering COM+ Applications and Components
    Action start 19:29:33: RegisterComPlus.
    Action ended 19:29:33: RegisterComPlus. Return value 0.
    Action 19:29:33: InstallServices. Installing new services
    Action start 19:29:33: InstallServices.
    Action ended 19:29:33: InstallServices. Return value 1.
    Action 19:29:33: StartServices. Starting services
    Action start 19:29:33: StartServices.
    Action ended 19:29:33: StartServices. Return value 1.
    Action 19:29:33: RegisterUser. Registering user
    Action start 19:29:33: RegisterUser.
    Action ended 19:29:33: RegisterUser. Return value 0.
    Action 19:29:33: RegisterProduct. Registering product
    Action start 19:29:33: RegisterProduct.
    Registering product
    Action ended 19:29:33: RegisterProduct. Return value 1.
    Action 19:29:33: PublishComponents. Publishing qualified components
    Action start 19:29:33: PublishComponents.
    Action ended 19:29:33: PublishComponents. Return value 0.
    Action 19:29:33: MsiPublishAssemblies. Publishing assembly information
    Action start 19:29:33: MsiPublishAssemblies.
    Application Context:Publishing assembly information, Assembly Name:
    Action ended 19:29:33: MsiPublishAssemblies. Return value 1.
    Action 19:29:33: PublishFeatures. Publishing product features
    Action start 19:29:33: PublishFeatures.
    Feature: Publishing product features
    Action ended 19:29:33: PublishFeatures. Return value 1.
    Action 19:29:33: PublishProduct. Publishing product information
    Action start 19:29:33: PublishProduct.
    Action ended 19:29:33: PublishProduct. Return value 1.
    Action 19:29:33: InstallFinalize.
    Action start 19:29:33: InstallFinalize.
    Action 19:29:33: ProcessComponents. Updating component registration
    Action 19:29:33: RemoveODBC. Removing ODBC components
    Action 19:29:33: InstallFiles. Copying new files
    Shortcut: ARPPRODUCTICON.exe
    20312.msi
    Application Context:Global, Assembly Name:Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32",publicK eyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86"
    Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.CRT,version="8.0.50727.4053",type="win 32-policy",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x8 6"
    Feature: Microsoft_VC80_CRT_x86_
    Message type: 2, Argument: 0
    Action 19:29:33: RollbackCleanup. Removing backup files
    File: C:\Config.Msi\23cd4.rbf
    File: C:\Config.Msi\23cd5.rbf
    Message type: 2, Argument: 1
    Action ended 19:29:33: InstallFinalize. Return value 1.
    Action ended 19:29:33: INSTALL. Return value 1.
    Property(S): DiskPrompt = [1]
    Property(S): UpgradeCode = {662366D8-8FF7-4EA3-92A8-C7FEA8AC8032}
    Property(S): SourcedirProduct = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
    Property(S): SOURCEDIR = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_CRT_x86\
    Property(S): PrimaryVolumeSpaceRemaining = 0
    Property(S): PrimaryVolumeSpaceRequired = 0
    Property(S): PrimaryVolumeSpaceAvailable = 0
    Property(S): OutOfNoRbDiskSpace = 0
    Property(S): OutOfDiskSpace = 0
    Property(S): Installed = 2009/11/13 07:21:16
    Property(S): CostingComplete = 1
    Property(S): ROOTDRIVE = C:\
    Property(S): ACTION = INSTALL
    Property(S): Preselected = 1
    Property(S): QFEUpgrade = 1
    Property(S): UILevel = 2
    Property(S): OriginalDatabase = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
    Property(S): DATABASE = C:\Windows\Installer\23cd0.msi
    Property(S): Privileged = 1
    Property(S): MsiRunningElevated = 1
    Property(S): RedirectedDllSupport = 2
    Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
    Property(S): MsiNetAssemblySupport = 2.0.50727.4927
    Property(S): Date = 29/03/2010
    Property(S): Time = 19:29:33
    Property(S): TTCSupport = 1
    Property(S): ColorBits = 32
    Property(S): TextInternalLeading = 3
    Property(S): TextHeight = 16
    Property(S): BorderSide = 1
    Property(S): BorderTop = 1
    Property(S): CaptionHeight = 22
    Property(S): ScreenY = 768
    Property(S): ScreenX = 1024
    Property(S): SystemLanguageID = 1046
    Property(S): ComputerName = INSPIRON_1525
    Property(S): UserLanguageID = 1046
    Property(S): UserSID = S-1-5-21-1792381714-3552011656-547379065-1000
    Property(S): LogonUser = M@RCELO
    Property(S): MsiTrueAdminUser = 1
    Property(S): AdminUser = 1
    Property(S): VirtualMemory = 3290
    Property(S): PhysicalMemory = 2038
    Property(S): Intel = 6
    Property(S): ShellAdvtSupport = 1
    Property(S): OLEAdvtSupport = 1
    Property(S): GPTSupport = 1
    Property(S): VersionNT = 601
    Property(S): ProgramFilesFolder = C:\Program Files\
    Property(S): ADOBE = C:\Program Files\Adobe\
    Property(S): TARGETDIR = C:\
    Property(S): ALLUSERSPROFILE = C:\
    Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(S): AppDataFolder = C:\Users\M@RCELO\AppData\Roaming\
    Property(S): CommonAppDataFolder = C:\ProgramData\
    Property(S): CommonFiles64Folder = C:\
    Property(S): CommonFilesFolder = C:\Program Files\Common Files\
    Property(S): ISYourDataBaseDir = C:\Program Files\Adobe\My Product Name\Database\
    Property(S): DATABASEDIR = C:\Program Files\Adobe\My Product Name\Database\
    Property(S): DesktopFolder = C:\Users\Public\Desktop\
    Property(S): FavoritesFolder = C:\Users\M@RCELO\Favorites\
    Property(S): FontsFolder = C:\Windows\Fonts\
    Property(S): GlobalAssemblyCache = C:\
    Property(S): MY_PRODUCT_NAME = C:\Program Files\Adobe\My Product Name\
    Property(S): INSTALLDIR = C:\Program Files\Adobe\My Product Name\
    Property(S): ISCommonFilesFolder = C:\Program Files\Common Files\InstallShield\
    Property(S): ISMyCompanyDir = C:\Program Files\My Company Name\
    Property(S): ISMyProductDir = C:\Program Files\My Company Name\My Product Name\
    Property(S): ISUpdateServiceFolder = C:\Program Files\Common Files\InstallShield\UpdateService\
    Property(S): LocalAppDataFolder = C:\Users\M@RCELO\AppData\Local\
    Property(S): MyPicturesFolder = C:\Users\M@RCELO\Pictures\
    Property(S): PersonalFolder = C:\Users\M@RCELO\Documents\
    Property(S): PrimaryVolumePath = C:\
    Property(S): ProgramFiles64Folder = C:\
    Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
    Property(S): SendToFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
    Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(S): System16Folder = C:\Windows\system\
    Property(S): System64Folder = C:\
    Property(S): SystemFolder = C:\Windows\system32\
    Property(S): SourceDir = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_CRT_x86\
    Property(S): TempFolder = C:\Users\M@RCELO\AppData\Local\Temp\
    Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
    Property(S): USERPROFILE = C:\
    Property(S): WindowsFolder = C:\Windows\
    Property(S): WindowsVolume = C:\
    Property(S): WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
    Property(S): payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4 053_none_d08d7da0442a985d\
    Property(S): payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4 2_x-ww_0de06acd\
    Property(S): WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\
    Property(S): SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\system32\
    Property(S): WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
    Property(S): WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
    Property(S): policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4 053_x-ww_e6967989\
    Property(S): policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.8 9_x-ww_0de46bd0\
    Property(S): policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.9 4_x-ww_0de56c0a\
    Property(S): payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.9 3_x-ww_0de56c09\
    Property(S): policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.9 5_x-ww_0de56c0b\
    Property(S): payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.9 6_x-ww_0de56c0c\
    Property(S): policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.9 7_x-ww_0de56c0d\
    Property(S): policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.9 8_x-ww_0de56c0e\
    Property(S): payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.9 9_x-ww_0de56c0f\
    Property(S): policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1 00_x-ww_6818287e\
    Property(S): policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1 01_x-ww_6818287f\
    Property(S): payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1 03_x-ww_68182881\
    Property(S): policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1 04_x-ww_68182882\
    Property(S): payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1 93_x-ww_68212ab8\
    Property(S): policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.2 38_x-ww_689938c4\
    Property(S): policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3 044_x-ww_b80ea88c\
    Property(S): policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3 051_x-ww_b80fa8c8\
    Property(S): policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3 069_x-ww_b810a90f\
    Property(S): payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1 833_x-ww_5ef082d6\
    Property(S): payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4 027_x-ww_e69378d0\
    Property(S): policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x- ww_4428b63a\
    Property(S): payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4 028_x-ww_e69378d1\
    Property(S): payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4 029_x-ww_e69378d2\
    Property(S): payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4 045_x-ww_e695794c\
    Property(S): payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4 052_x-ww_e6967988\
    Property(S): payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4 053_x-ww_e6967989\
    Property(S): ALLUSERS = 1
    Property(S): WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
    Property(S): payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_ 8.0.50727.4053_none_516e2e610f48bda6\
    Property(S): WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
    Property(S): policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\
    Property(S): SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\system32\
    Property(S): WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
    Property(S): payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.42_x-ww_51e427d4\
    Property(S): policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.4053_x-ww_2a9a3690\
    Property(S): policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.94_x-ww_51e92911\
    Property(S): policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.89_x-ww_51e828d7\
    Property(S): policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.93_x-ww_51e92910\
    Property(S): policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.95_x-ww_51e92912\
    Property(S): policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.96_x-ww_51e92913\
    Property(S): policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.97_x-ww_51e92914\
    Property(S): policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.98_x-ww_51e92915\
    Property(S): policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.99_x-ww_51e92916\
    Property(S): policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.100_x-ww_ac1be585\
    Property(S): payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.101_x-ww_ac1be586\
    Property(S): policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.103_x-ww_ac1be588\
    Property(S): payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.104_x-ww_ac1be589\
    Property(S): policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.193_x-ww_ac24e7bf\
    Property(S): policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9 a1e18e3b_x-ww_77c24773\
    Property(S): payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.238_x-ww_ac9cf5cb\
    Property(S): payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.3044_x-ww_fc126593\
    Property(S): payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.3051_x-ww_fc1365cf\
    Property(S): payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.3069_x-ww_fc146616\
    Property(S): payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.1833_x-ww_a2f43fdd\
    Property(S): payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.4027_x-ww_2a9735d7\
    Property(S): payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.4028_x-ww_2a9735d8\
    Property(S): payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.4029_x-ww_2a9735d9\
    Property(S): payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.4045_x-ww_2a993653\
    Property(S): payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.4052_x-ww_2a9a368f\
    Property(S): payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_ 8.0.50727.4053_x-ww_2a9a3690\
    Property(S): RecentFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\Recent\
    Property(S): PrintHoodFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
    Property(S): NetHoodFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
    Property(S): RemoteAdminTS = 1
    Property(S): MsiNTProductType = 1
    Property(S): ServicePackLevelMinor = 0
    Property(S): ServicePackLevel = 0
    Property(S): ISCHECKFORPRODUCTUPDATES = 1
    Property(S): ApplicationUsers = AllUsers
    Property(S): AgreeToLicense = No
    Property(S): _IsMaintenance = Change
    Property(S): SetupType = Typical
    Property(S): _IsSetupTypeMin = Typical
    Property(S): IS_SQLSERVER_USERNAME = sa
    Property(S): IS_SQLSERVER_AUTHENTICATION = 0
    Property(S): RestartManagerOption = CloseRestart
    Property(S): Display_IsBitmapDlg = 1
    Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
    Property(S): DefaultUIFont = Tahoma8
    Property(S): DialogCaption = InstallShield for Windows Installer
    Property(S): DisplayNameCustom = Custom
    Property(S): DisplayNameMinimal = Minimal
    Property(S): DisplayNameTypical = Typical
    Property(S): DWUSINTERVAL = 30
    Property(S): ErrorDialog = SetupError
    Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
    Property(S): InstallChoice = AR
    Property(S): INSTALLLEVEL = 100
    Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
    Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
    Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
    Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
    Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
    Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
    Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
    Property(S): ISVROOT_PORT_NO = 0
    Property(S): Manufacturer = Adobe
    Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
    Property(S): ProductCode = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
    Property(S): ProductID = none
    Property(S): ProductLanguage = 1033
    Property(S): ProductName = Microsoft_VC80_CRT_x86
    Property(S): ProductVersion = 8.0.50727.4053
    Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
    Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
    Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
    Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
    Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
    Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
    Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
    Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
    Property(S): ProgressType0 = install
    Property(S): ProgressType1 = Installing
    Property(S): ProgressType2 = installed
    Property(S): ProgressType3 = installs
    Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
    Property(S): RebootYesNo = No
    Property(S): ReinstallModeText = omus
    Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
    Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
    Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
    Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
    Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
    Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
    Property(S): DWUSLINK = CE2BC78F6EACC0E8D9AC408FEEFC978F8EBCE78FCE9CA7F8CE4B878F7EBC2738E98CA 7A8F9AC
    Property(S): ARPURLINFOABOUT = http://www.Adobe.com
    Property(S): SHOWLAUNCHPROGRAM = 0
    Property(S): REBOOT = ReallySuppress
    Property(S): ARPSYSTEMCOMPONENT = 1
    Property(S): WindowsBuild = 7600
    Property(S): VersionMsi = 5.00
    Property(S): VersionDatabase = 200
    Property(S): PRODUCTLANGUAGE = 1033
    Property(S): CLIENTPROCESSID = 3296
    Property(S): MSICLIENTUSESEXTERNALUI = 1
    Property(S): CLIENTUILEVEL = 3
    Property(S): CURRENTDIRECTORY = C:\Users\M@RCELO\AppData\Local\Adobe\OOBE\PDApp\DWA
    Property(S): REINSTALLMODE = pvoums
    Property(S): REINSTALL = ALL
    Property(S): USERNAME = M@RCELO
    Property(S): ProductToBeRegistered = 1
    Property(S): ProductState = 5
    Property(S): PackageCode = {FA041436-73B8-40C4-97F3-249E037C89EE}
    === Logging stopped: 29/03/2010  19:29:33 ===
    1: 2 2: 0
    1: 2 2: 1
    Installation result: 0
    Third party payload succeded.  Testing return code: 0
    [    3164] Mon Mar 29 19:29:34 2010  INFO
    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
    :: END TIMER :: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] took 7014.88 miliseconds (7.01488 seconds) DTR = 256.597 KBPS (0.250583 MBPS)
    Updating driver data - Action: Add driver entry
    Updating driver data successful. Driver entry was added. ARP estimated size 0KB
    User specified overrideFile:
    Calling the custom action code for post-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86
    Calling the custom action code for pre-install for payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
    ::START TIMER:: [Payload Operation :{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}]
    [    4012] Mon Mar 29 19:29:34 2010  INFO
    Installing payload
    Attempting to install package from:C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x 86.msi
    MsiSourceListAddSource for  C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x 86.msi is 0
    MsiSourceListSetInfo with updated name: Microsoft_VC80_MFCLOC_x86.msi, Result: 0
    [    4012] Mon Mar 29 19:29:35 2010  INFO
    === Logging started: 29/03/2010  19:29:35 ===
    Message type: 1, Argument: Microsoft_VC80_MFCLOC_x86
    Action 19:29:35: INSTALL.
    Action start 19:29:35: INSTALL.
    Action 19:29:35: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
    Action start 19:29:35: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
    Action ended 19:29:35: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:35: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
    Action start 19:29:35: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
    Action ended 19:29:35: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:35: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
    Action start 19:29:35: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
    Action ended 19:29:35: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:35: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
    Action start 19:29:35: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
    Action ended 19:29:35: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:35: AppSearch. Searching for installed applications
    Action start 19:29:35: AppSearch.
    Action ended 19:29:35: AppSearch. Return value 0.
    Action 19:29:35: FindRelatedProducts. Searching for related applications
    Action start 19:29:35: FindRelatedProducts.
    Action ended 19:29:35: FindRelatedProducts. Return value 0.
    Action 19:29:35: ValidateProductID.
    Action start 19:29:35: ValidateProductID.
    Action ended 19:29:35: ValidateProductID. Return value 1.
    Action 19:29:35: CostInitialize. Computing space requirements
    Action start 19:29:35: CostInitialize.
    Action ended 19:29:35: CostInitialize. Return value 1.
    Action 19:29:35: FileCost. Computing space requirements
    Action start 19:29:35: FileCost.
    Action ended 19:29:35: FileCost. Return value 1.
    Action 19:29:35: IsolateComponents.
    Action start 19:29:35: IsolateComponents.
    Action ended 19:29:35: IsolateComponents. Return value 0.
    Action 19:29:35: CostFinalize. Computing space requirements
    Action start 19:29:35: CostFinalize.
    Action ended 19:29:35: CostFinalize. Return value 1.
    Action 19:29:35: SetODBCFolders. Initializing ODBC directories
    Action start 19:29:35: SetODBCFolders.
    Action ended 19:29:35: SetODBCFolders. Return value 0.
    Action 19:29:35: MigrateFeatureStates. Migrating feature states from related applications
    Action start 19:29:35: MigrateFeatureStates.
    Action ended 19:29:35: MigrateFeatureStates. Return value 0.
    Action 19:29:35: InstallValidate. Validating install
    Action start 19:29:35: InstallValidate.
    Action ended 19:29:35: InstallValidate. Return value 1.
    Action 19:29:35: RemoveExistingProducts. Removing applications
    Action start 19:29:35: RemoveExistingProducts.
    Action ended 19:29:35: RemoveExistingProducts. Return value 0.
    Action 19:29:35: InstallInitialize.
    Action start 19:29:35: InstallInitialize.
    Action ended 19:29:35: InstallInitialize. Return value 1.
    Action 19:29:35: SxsInstallCA.
    Action start 19:29:35: SxsInstallCA.
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: uplevel.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: uplevel.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    [    4012] Mon Mar 29 19:29:36 2010  INFO
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18 E
    Action ended 19:29:36: SxsInstallCA. Return value 1.
    Action 19:29:36: ProcessComponents. Updating component registration
    Action start 19:29:36: ProcessComponents.
    Action 19:29:36: GenerateScript. Generating script operations for action:
    Action ended 19:29:36: ProcessComponents. Return value 1.
    Action 19:29:36: UnpublishComponents. Unpublishing Qualified Components
    Action start 19:29:36: UnpublishComponents.
    Action ended 19:29:36: UnpublishComponents. Return value 0.
    Action 19:29:36: MsiUnpublishAssemblies. Unpublishing assembly information
    Action start 19:29:36: MsiUnpublishAssemblies.
    Action ended 19:29:36: MsiUnpublishAssemblies. Return value 1.
    Action 19:29:36: UnpublishFeatures. Unpublishing product features
    Action start 19:29:36: UnpublishFeatures.
    Action ended 19:29:36: UnpublishFeatures. Return value 1.
    Action 19:29:36: StopServices. Stopping services
    Action start 19:29:36: StopServices.
    Action ended 19:29:36: StopServices. Return value 1.
    Action 19:29:36: DeleteServices. Deleting services
    Action start 19:29:36: DeleteServices.
    Action ended 19:29:36: DeleteServices. Return value 1.
    Action 19:29:36: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 19:29:36: UnregisterComPlus.
    Action ended 19:29:36: UnregisterComPlus. Return value 0.
    Action 19:29:36: SelfUnregModules. Unregistering modules
    Action start 19:29:36: SelfUnregModules.
    Action ended 19:29:36: SelfUnregModules. Return value 1.
    Action 19:29:36: UnregisterTypeLibraries. Unregistering type libraries
    Action start 19:29:36: UnregisterTypeLibraries.
    Action ended 19:29:36: UnregisterTypeLibraries. Return value 0.
    Action 19:29:36: RemoveODBC. Removing ODBC components
    Action start 19:29:36: RemoveODBC.
    Action ended 19:29:36: RemoveODBC. Return value 1.
    Action 19:29:36: UnregisterFonts. Unregistering fonts
    Action start 19:29:36: UnregisterFonts.
    Action ended 19:29:36: UnregisterFonts. Return value 1.
    Action 19:29:36: RemoveRegistryValues. Removing system registry values
    Action start 19:29:36: RemoveRegistryValues.
    Action ended 19:29:36: RemoveRegistryValues. Return value 1.
    Action 19:29:36: UnregisterClassInfo. Unregister class servers
    Action start 19:29:36: UnregisterClassInfo.
    Action ended 19:29:36: UnregisterClassInfo. Return value 0.
    Action 19:29:36: UnregisterExtensionInfo. Unregistering extension servers
    Action start 19:29:36: UnregisterExtensionInfo.
    Action ended 19:29:36: UnregisterExtensionInfo. Return value 0.
    Action 19:29:36: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 19:29:36: UnregisterProgIdInfo.
    Action ended 19:29:36: UnregisterProgIdInfo. Return value 0.
    Action 19:29:36: UnregisterMIMEInfo. Unregistering MIME info
    Action start 19:29:36: UnregisterMIMEInfo.
    Action ended 19:29:36: UnregisterMIMEInfo. Return value 0.
    Action 19:29:36: RemoveIniValues. Removing INI file entries
    Action start 19:29:36: RemoveIniValues.
    Action ended 19:29:36: RemoveIniValues. Return value 1.
    Action 19:29:36: RemoveShortcuts. Removing shortcuts
    Action start 19:29:36: RemoveShortcuts.
    Action ended 19:29:36: RemoveShortcuts. Return value 0.
    Action 19:29:36: RemoveEnvironmentStrings. Updating environment strings
    Action start 19:29:36: RemoveEnvironmentStrings.
    Action ended 19:29:36: RemoveEnvironmentStrings. Return value 1.
    Action 19:29:36: RemoveDuplicateFiles. Removing duplicated files
    Action start 19:29:36: RemoveDuplicateFiles.
    Action ended 19:29:36: RemoveDuplicateFiles. Return value 1.
    Action 19:29:36: RemoveFiles. Removing files
    Action start 19:29:36: RemoveFiles.
    Action ended 19:29:36: RemoveFiles. Return value 0.
    Action 19:29:36: RemoveFolders. Removing folders
    Action start 19:29:36: RemoveFolders.
    Action ended 19:29:36: RemoveFolders. Return value 0.
    Action 19:29:36: CreateFolders. Creating folders
    Action start 19:29:36: CreateFolders.
    Action ended 19:29:36: CreateFolders. Return value 0.
    Action 19:29:36: MoveFiles. Moving files
    Action start 19:29:36: MoveFiles.
    Action ended 19:29:36: MoveFiles. Return value 1.
    Action 19:29:36: InstallFiles. Copying new files
    Action start 19:29:36: InstallFiles.
    Action ended 19:29:36: InstallFiles. Return value 1.
    Action 19:29:36: PatchFiles. Patching files
    Action start 19:29:36: PatchFiles.
    Action ended 19:29:36: PatchFiles. Return value 0.
    Action 19:29:36: DuplicateFiles. Creating duplicate files
    Action start 19:29:36: DuplicateFiles.
    Action ended 19:29:36: DuplicateFiles. Return value 1.
    Action 19:29:36: BindImage. Binding executables
    Action start 19:29:36: BindImage.
    Action ended 19:29:36: BindImage. Return value 1.
    Action 19:29:36: CreateShortcuts. Creating shortcuts
    Action start 19:29:36: CreateShortcuts.
    Action ended 19:29:36: CreateShortcuts. Return value 0.
    Action 19:29:36: RegisterClassInfo. Registering class servers
    Action start 19:29:36: RegisterClassInfo.
    Action ended 19:29:36: RegisterClassInfo. Return value 0.
    Action 19:29:36: RegisterExtensionInfo. Registering extension servers
    Action start 19:29:36: RegisterExtensionInfo.
    Action ended 19:29:36: RegisterExtensionInfo. Return value 0.
    Action 19:29:36: RegisterProgIdInfo. Registering program identifiers
    Action start 19:29:36: RegisterProgIdInfo.
    Action ended 19:29:36: RegisterProgIdInfo. Return value 0.
    Action 19:29:36: RegisterMIMEInfo. Registering MIME info
    Action start 19:29:36: RegisterMIMEInfo.
    Action ended 19:29:36: RegisterMIMEInfo. Return value 0.
    Action 19:29:36: WriteRegistryValues. Writing system registry values
    Action start 19:29:36: WriteRegistryValues.
    Action ended 19:29:36: WriteRegistryValues. Return value 1.
    Action 19:29:36: WriteIniValues. Writing INI file values
    Action start 19:29:36: WriteIniValues.
    Action ended 19:29:36: WriteIniValues. Return value 1.
    Action 19:29:36: WriteEnvironmentStrings. Updating environment strings
    Action start 19:29:36: WriteEnvironmentStrings.
    Action ended 19:29:36: WriteEnvironmentStrings. Return value 1.
    Action 19:29:36: RegisterFonts. Registering fonts
    Action start 19:29:36: RegisterFonts.
    Action ended 19:29:36: RegisterFonts. Return value 1.
    Action 19:29:36: InstallODBC. Installing ODBC components
    Action start 19:29:36: InstallODBC.
    Action ended 19:29:36: InstallODBC. Return value 0.
    Action 19:29:36: RegisterTypeLibraries. Registering type libraries
    Action start 19:29:36: RegisterTypeLibraries.
    Action ended 19:29:36: RegisterTypeLibraries. Return value 0.
    Action 19:29:36: SelfRegModules. Registering modules
    Action start 19:29:36: SelfRegModules.
    Action ended 19:29:36: SelfRegModules. Return value 1.
    Action 19:29:36: RegisterComPlus. Registering COM+ Applications and Components
    Action start 19:29:36: RegisterComPlus.
    Action ended 19:29:36: RegisterComPlus. Return value 0.
    Action 19:29:36: InstallServices. Installing new services
    Action start 19:29:36: InstallServices.
    Action ended 19:29:36: InstallServices. Return value 1.
    Action 19:29:36: StartServices. Starting services
    Action start 19:29:36: StartServices.
    Action ended 19:29:36: StartServices. Return value 1.
    Action 19:29:36: RegisterUser. Registering user
    Action start 19:29:36: RegisterUser.
    Action ended 19:29:36: RegisterUser. Return value 0.
    Action 19:29:36: RegisterProduct. Registering product
    Action start 19:29:36: RegisterProduct.
    Registering product
    Action ended 19:29:36: RegisterProduct. Return value 1.
    Action 19:29:36: PublishComponents. Publishing qualified components
    Action start 19:29:36: PublishComponents.
    Action ended 19:29:36: PublishComponents. Return value 0.
    Action 19:29:36: MsiPublishAssemblies. Publishing assembly information
    Action start 19:29:36: MsiPublishAssemblies.
    Action ended 19:29:36: MsiPublishAssemblies. Return value 1.
    Action 19:29:36: PublishFeatures. Publishing product features
    Action start 19:29:36: PublishFeatures.
    Action ended 19:29:36: PublishFeatures. Return value 1.
    Action 19:29:36: PublishProduct. Publishing product information
    Action start 19:29:36: PublishProduct.
    Action ended 19:29:36: PublishProduct. Return value 1.
    Action 19:29:36: InstallFinalize.
    Action start 19:29:36: InstallFinalize.
    Message type: 0, Argument: 1033
    20319.msi
    Application Context:Global, Assembly Name:Microsoft.VC80.MFCLOC,publicKeyToken="1fc8b3b9a1e18e3b",version= "8.0.50727.4053",type="win32",processorArchitecture="x86"
    Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.MFCLOC,publicKeyToken="1fc8b3b9a1e18e3 b",version="8.0.50727.4053",type="win32-policy",processorArchitecture= "x86"
    Feature: Microsoft_VC80_MFCLOC_x
    Action 19:29:36: RollbackCleanup. Removing backup files
    File: C:\Config.Msi\23cdb.rbf
    File: C:\Config.Msi\23cdc.rbf
    Action ended 19:29:36: InstallFinalize. Return value 1.
    Action ended 19:29:36: INSTALL. Return value 1.
    Property(S): UpgradeCode = {DBBF67A0-1BA6-4CF4-A1EF-007F1FD45598}
    Property(S): SourcedirProduct = {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
    Property(S): SOURCEDIR = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFCLOC_x86\
    Property(S): Installed = 2009/11/13 07:27:58
    Property(S): OriginalDatabase = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x 86.msi
    Property(S): DATABASE = C:\Windows\Installer\23cd7.msi
    Property(S): Time = 19:29:36
    Property(S): VirtualMemory = 3255
    Property(S): SourceDir = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFCLOC_x86\
    Property(S): WinSxsDirectory.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
    Property(S): payload_ul.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.5072 7.4053_none_03ca5532205cb096\
    Property(S): payload.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.42_x-ww_3415f6d0\
    Property(S): WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\
    Property(S): SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\system32\
    Property(S): WinSxsManifests.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
    Property(S): WinSxsPolicies.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
    Property(S): policydir.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): policydir_ul.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.4053_x-ww_0ccc058c\
    Property(S): policydir.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): policydir.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.89_x-ww_3419f7d3\
    Property(S): policydir.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): policydir.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.93_x-ww_341af80c\
    Property(S): payload.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.94_x-ww_341af80d\
    Property(S): policydir.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): policydir.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.95_x-ww_341af80e\
    Property(S): policydir.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.96_x-ww_341af80f\
    Property(S): policydir.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): policydir.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.97_x-ww_341af810\
    Property(S): payload.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.98_x-ww_341af811\
    Property(S): policydir.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.99_x-ww_341af812\
    Property(S): payload.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.100_x-ww_8e4db481\
    Property(S): policydir.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): policydir.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): policydir.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.101_x-ww_8e4db482\
    Property(S): policydir.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.103_x-ww_8e4db484\
    Property(S): payload.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.104_x-ww_8e4db485\
    Property(S): policydir.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.193_x-ww_8e56b6bb\
    Property(S): policydir.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.238_x-ww_8ecec4c7\
    Property(S): policydir.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.3044_x-ww_de44348f\
    Property(S): payload.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.3051_x-ww_de4534cb\
    Property(S): policydir.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): policydir.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.3069_x-ww_de463512\
    Property(S): payload.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.1833_x-ww_85260ed9\
    Property(S): policydir.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): policydir.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.4027_x-ww_0cc904d3\
    Property(S): payload.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.4028_x-ww_0cc904d4\
    Property(S): policydir.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): policydir.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.4029_x-ww_0cc904d5\
    Property(S): payload.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.4045_x-ww_0ccb054f\
    Property(S): policydir.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b _x-ww_2740f977\
    Property(S): payload.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.4052_x-ww_0ccc058b\
    Property(S): payload.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.5072 7.4053_x-ww_0ccc058c\
    Property(S): WinSxsDirectory.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
    Property(S): payload_ul.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.mfcloc_1fc8b3b9a1e18e 3b_8.0.50727.4053_none_4db266e67dd280ef\
    Property(S): WinSxsPolicies.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
    Property(S): policydir.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\
    Property(S): SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\system32\
    Property(S): WinSxsManifests.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
    Property(S): payload.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.42_x-ww_63bb0537\
    Property(S): policydir.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir_ul.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.4053_x-ww_3c7113f3\
    Property(S): policydir.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.94_x-ww_63c00674\
    Property(S): policydir.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.89_x-ww_63bf063a\
    Property(S): policydir.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.93_x-ww_63c00673\
    Property(S): policydir.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.95_x-ww_63c00675\
    Property(S): policydir.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.96_x-ww_63c00676\
    Property(S): policydir.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.97_x-ww_63c00677\
    Property(S): policydir.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.98_x-ww_63c00678\
    Property(S): policydir.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.99_x-ww_63c00679\
    Property(S): policydir.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.100_x-ww_bdf2c2e8\
    Property(S): payload.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.101_x-ww_bdf2c2e9\
    Property(S): policydir.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.103_x-ww_bdf2c2eb\
    Property(S): payload.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.104_x-ww_bdf2c2ec\
    Property(S): policydir.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.193_x-ww_bdfbc522\
    Property(S): policydir.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): policydir.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b 3b9a1e18e3b_x-ww_caeee150\
    Property(S): payload.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.238_x-ww_be73d32e\
    Property(S): payload.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.3044_x-ww_0de942f6\
    Property(S): payload.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.3051_x-ww_0dea4332\
    Property(S): payload.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.3069_x-ww_0deb4379\
    Property(S): payload.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.1833_x-ww_b4cb1d40\
    Property(S): payload.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.4027_x-ww_3c6e133a\
    Property(S): payload.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.4028_x-ww_3c6e133b\
    Property(S): payload.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.4029_x-ww_3c6e133c\
    Property(S): payload.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.4045_x-ww_3c7013b6\
    Property(S): payload.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.4052_x-ww_3c7113f2\
    Property(S): payload.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e 3b_8.0.50727.4053_x-ww_3c7113f3\
    Property(S): ProductCode = {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
    Property(S): ProductName = Microsoft_VC80_MFCLOC_x86
    Property(S): DWUSLINK = CE0BC0C8E9CBE7B86EACE7CFDEDC978F99CC678F49ABA0E8CE6BC7C8BEDB9088F9ACF 798D9AC
    Property(S): PackageCode = {AF8EF662-EF5A-426A-AA7B-B83C3A5FFFBB}
    === Logging stopped: 29/03/2010  19:29:36 ===
    1: 2 2: 0
    1: 2 2: 1
    [    3164] Mon Mar 29 19:29:36 2010  INFO
    :: END TIMER :: [Payload Operation :{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}] took 2018.62 miliseconds (2.01862 seconds) DTR = 31.7048 KBPS (0.0309617 MBPS)
    [    3164] Mon Mar 29 19:29:37 2010  INFO
    Calling the custom action code for post-install for payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86
    Calling the custom action code for pre-install for payload {D1A19B02-817E-4296-A45B-07853FD74D57}
    ::START TIMER:: [Payload Operation :{D1A19B02-817E-4296-A45B-07853FD74D57}]
    [     340] Mon Mar 29 19:29:37 2010  INFO
    Installer Operation: InstallThirdPartyPayloadOperation
    Installing third party payload
    Installing payload
    Attempting to install package from:C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
    Payload is already installed with MSI
    MsiSourceListAddSource for  C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi is 0
    MsiSourceListSetInfo with updated name: Microsoft_VC80_MFC_x86.msi, Result: 0
    Payload source is not removable so not updating media info
    Command line arguments:  REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
    1: 0 2: 1033 3: 1252
    === Logging started: 29/03/2010  19:29:37 ===
    Message type: 1, Argument: Microsoft_VC80_MFC_x86
    Action 19:29:37: INSTALL.
    Action start 19:29:37: INSTALL.
    Action 19:29:37: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
    Action start 19:29:37: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
    Action ended 19:29:37: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:37: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
    Action start 19:29:37: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
    Action ended 19:29:37: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:37: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
    Action start 19:29:37: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
    Action ended 19:29:37: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:37: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
    Action start 19:29:37: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
    Action ended 19:29:37: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:37: AppSearch. Searching for installed applications
    Action start 19:29:37: AppSearch.
    Action ended 19:29:37: AppSearch. Return value 0.
    Action 19:29:37: FindRelatedProducts. Searching for related applications
    Action start 19:29:37: FindRelatedProducts.
    Action ended 19:29:37: FindRelatedProducts. Return value 0.
    Action 19:29:37: ValidateProductID.
    Action start 19:29:37: ValidateProductID.
    Action ended 19:29:37: ValidateProductID. Return value 1.
    Action 19:29:37: CostInitialize. Computing space requirements
    Action start 19:29:37: CostInitialize.
    Action ended 19:29:37: CostInitialize. Return value 1.
    Action 19:29:37: FileCost. Computing space requirements
    Action start 19:29:37: FileCost.
    Action ended 19:29:37: FileCost. Return value 1.
    Action 19:29:37: IsolateComponents.
    Action start 19:29:37: IsolateComponents.
    Action ended 19:29:37: IsolateComponents. Return value 0.
    Action 19:29:37: CostFinalize. Computing space requirements
    Action start 19:29:37: CostFinalize.
    Action ended 19:29:37: CostFinalize. Return value 1.
    Action 19:29:37: SetODBCFolders. Initializing ODBC directories
    Action start 19:29:37: SetODBCFolders.
    Action ended 19:29:37: SetODBCFolders. Return value 0.
    Action 19:29:37: MigrateFeatureStates. Migrating feature states from related applications
    Action start 19:29:37: MigrateFeatureStates.
    Action ended 19:29:37: MigrateFeatureStates. Return value 0.
    Action 19:29:37: InstallValidate. Validating install
    Action start 19:29:37: InstallValidate.
    Action ended 19:29:37: InstallValidate. Return value 1.
    Action 19:29:37: RemoveExistingProducts. Removing applications
    Action start 19:29:37: RemoveExistingProducts.
    Action ended 19:29:37: RemoveExistingProducts. Return value 0.
    Action 19:29:37: InstallInitialize.
    Action start 19:29:37: InstallInitialize.
    Action ended 19:29:37: InstallInitialize. Return value 1.
    Action 19:29:37: SxsInstallCA.
    Action start 19:29:37: SxsInstallCA.
    [     340] Mon Mar 29 19:29:38 2010  INFO
    1: sxsdelca 2: traceop 3: 1256 4: 0
    1: sxsdelca 2: traceop 3: 1257 4: 0
    1: sxsdelca 2: traceop 3: 1258 4: 0
    1: sxsdelca 2: traceop 3: 1284 4: 0
    1: sxsdelca 2: traceop 3: 1288 4: 0
    1: sxsdelca 2: traceop 3: 1289 4: 0
    1: sxsdelca 2: traceop 3: 1290 4: 0
    1: sxsdelca 2: traceop 3: 1292 4: 0
    1: sxsdelca 2: traceop 3: 1318 4: 0
    1: sxsdelca: Skipping component  2: uplevel.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: uplevel.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18 E
    1: sxsdelca 2: traceop 3: 1284 4: 259
    1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
    Action ended 19:29:38: SxsInstallCA. Return value 1.
    Action 19:29:38: ProcessComponents. Updating component registration
    Action start 19:29:38: ProcessComponents.
    Action 19:29:38: GenerateScript. Generating script operations for action:
    Action ended 19:29:38: ProcessComponents. Return value 1.
    Action 19:29:38: UnpublishComponents. Unpublishing Qualified Components
    Action start 19:29:38: UnpublishComponents.
    Action ended 19:29:38: UnpublishComponents. Return value 0.
    Action 19:29:38: MsiUnpublishAssemblies. Unpublishing assembly information
    Action start 19:29:38: MsiUnpublishAssemblies.
    Action ended 19:29:38: MsiUnpublishAssemblies. Return value 1.
    Action 19:29:38: UnpublishFeatures. Unpublishing product features
    Action start 19:29:38: UnpublishFeatures.
    Action ended 19:29:38: UnpublishFeatures. Return value 1.
    Action 19:29:38: StopServices. Stopping services
    Action start 19:29:38: StopServices.
    Action ended 19:29:38: StopServices. Return value 1.
    Action 19:29:38: DeleteServices. Deleting services
    Action start 19:29:38: DeleteServices.
    Action ended 19:29:38: DeleteServices. Return value 1.
    Action 19:29:38: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 19:29:38: UnregisterComPlus.
    Action ended 19:29:38: UnregisterComPlus. Return value 0.
    Action 19:29:38: SelfUnregModules. Unregistering modules
    Action start 19:29:38: SelfUnregModules.
    Action ended 19:29:38: SelfUnregModules. Return value 1.
    Action 19:29:38: UnregisterTypeLibraries. Unregistering type libraries
    Action start 19:29:38: UnregisterTypeLibraries.
    Action ended 19:29:38: UnregisterTypeLibraries. Return value 0.
    Action 19:29:38: RemoveODBC. Removing ODBC components
    Action start 19:29:38: RemoveODBC.
    Action ended 19:29:38: RemoveODBC. Return value 1.
    Action 19:29:38: UnregisterFonts. Unregistering fonts
    Action start 19:29:38: UnregisterFonts.
    Action ended 19:29:38: UnregisterFonts. Return value 1.
    Action 19:29:38: RemoveRegistryValues. Removing system registry values
    Action start 19:29:38: RemoveRegistryValues.
    Action ended 19:29:38: RemoveRegistryValues. Return value 1.
    Action 19:29:38: UnregisterClassInfo. Unregister class servers
    Action start 19:29:38: UnregisterClassInfo.
    Action ended 19:29:38: UnregisterClassInfo. Return value 0.
    Action 19:29:38: UnregisterExtensionInfo. Unregistering extension servers
    Action start 19:29:38: UnregisterExtensionInfo.
    Action ended 19:29:38: UnregisterExtensionInfo. Return value 0.
    Action 19:29:38: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 19:29:38: UnregisterProgIdInfo.
    Action ended 19:29:38: UnregisterProgIdInfo. Return value 0.
    Action 19:29:38: UnregisterMIMEInfo. Unregistering MIME info
    Action start 19:29:38: UnregisterMIMEInfo.
    Action ended 19:29:38: UnregisterMIMEInfo. Return value 0.
    Action 19:29:38: RemoveIniValues. Removing INI file entries
    Action start 19:29:38: RemoveIniValues.
    Action ended 19:29:38: RemoveIniValues. Return value 1.
    Action 19:29:38: RemoveShortcuts. Removing shortcuts
    Action start 19:29:38: RemoveShortcuts.
    Action ended 19:29:38: RemoveShortcuts. Return value 0.
    Action 19:29:38: RemoveEnvironmentStrings. Updating environment strings
    Action start 19:29:38: RemoveEnvironmentStrings.
    Action ended 19:29:38: RemoveEnvironmentStrings. Return value 1.
    Action 19:29:38: RemoveDuplicateFiles. Removing duplicated files
    Action start 19:29:38: RemoveDuplicateFiles.
    Action ended 19:29:38: RemoveDuplicateFiles. Return value 1.
    Action 19:29:38: RemoveFiles. Removing files
    Action start 19:29:38: RemoveFiles.
    Action ended 19:29:38: RemoveFiles. Return value 0.
    Action 19:29:38: RemoveFolders. Removing folders
    Action start 19:29:38: RemoveFolders.
    Action ended 19:29:38: RemoveFolders. Return value 0.
    Action 19:29:38: CreateFolders. Creating folders
    Action start 19:29:38: CreateFolders.
    Action ended 19:29:38: CreateFolders. Return value 0.
    Action 19:29:38: MoveFiles. Moving files
    Action start 19:29:38: MoveFiles.
    Action ended 19:29:38: MoveFiles. Return value 1.
    Action 19:29:38: InstallFiles. Copying new files
    Action start 19:29:38: InstallFiles.
    File: Copying new files,  Directory: ,  Size:
    Action ended 19:29:38: InstallFiles. Return value 1.
    Action 19:29:38: PatchFiles. Patching files
    Action start 19:29:38: PatchFiles.
    Action ended 19:29:38: PatchFiles. Return value 0.
    Action 19:29:38: DuplicateFiles. Creating duplicate files
    Action start 19:29:38: DuplicateFiles.
    Action ended 19:29:38: DuplicateFiles. Return value 1.
    Action 19:29:38: BindImage. Binding executables
    Action start 19:29:38: BindImage.
    Action ended 19:29:38: BindImage. Return value 1.
    Action 19:29:38: CreateShortcuts. Creating shortcuts
    Action start 19:29:38: CreateShortcuts.
    Shortcut: Creating shortcuts
    Action ended 19:29:38: CreateShortcuts. Return value 0.
    Action 19:29:38: RegisterClassInfo. Registering class servers
    Action start 19:29:38: RegisterClassInfo.
    Action ended 19:29:38: RegisterClassInfo. Return value 0.
    Action 19:29:38: RegisterExtensionInfo. Registering extension servers
    Action start 19:29:38: RegisterExtensionInfo.
    Action ended 19:29:38: RegisterExtensionInfo. Return value 0.
    Action 19:29:38: RegisterProgIdInfo. Registering program identifiers
    Action start 19:29:38: RegisterProgIdInfo.
    Action ended 19:29:38: RegisterProgIdInfo. Return value 0.
    Action 19:29:38: RegisterMIMEInfo. Registering MIME info
    Action start 19:29:38: RegisterMIMEInfo.
    Action ended 19:29:38: RegisterMIMEInfo. Return value 0.
    Action 19:29:38: WriteRegistryValues. Writing system registry values
    Action start 19:29:38: WriteRegistryValues.
    Action ended 19:29:38: WriteRegistryValues. Return value 1.
    Action 19:29:38: WriteIniValues. Writing INI file values
    Action start 19:29:38: WriteIniValues.
    Action ended 19:29:38: WriteIniValues. Return value 1.
    Action 19:29:38: WriteEnvironmentStrings. Updating environment strings
    Action start 19:29:38: WriteEnvironmentStrings.
    Action ended 19:29:38: WriteEnvironmentStrings. Return value 1.
    Action 19:29:38: RegisterFonts. Registering fonts
    Action start 19:29:38: RegisterFonts.
    Action ended 19:29:38: RegisterFonts. Return value 1.
    Action 19:29:38: InstallODBC. Installing ODBC components
    Action start 19:29:38: InstallODBC.
    Action ended 19:29:38: InstallODBC. Return value 0.
    Action 19:29:38: RegisterTypeLibraries. Registering type libraries
    Action start 19:29:38: RegisterTypeLibraries.
    Action ended 19:29:38: RegisterTypeLibraries. Return value 0.
    Action 19:29:38: SelfRegModules. Registering modules
    Action start 19:29:38: SelfRegModules.
    Action ended 19:29:38: SelfRegModules. Return value 1.
    Action 19:29:38: RegisterComPlus. Registering COM+ Applications and Components
    Action start 19:29:38: RegisterComPlus.
    Action ended 19:29:38: RegisterComPlus. Return value 0.
    Action 19:29:38: InstallServices. Installing new services
    Action start 19:29:38: InstallServices.
    Action ended 19:29:38: InstallServices. Return value 1.
    Action 19:29:38: StartServices. Starting services
    Action start 19:29:38: StartServices.
    Action ended 19:29:38: StartServices. Return value 1.
    Action 19:29:38: RegisterUser. Registering user
    Action start 19:29:38: RegisterUser.
    Action ended 19:29:38: RegisterUser. Return value 0.
    Action 19:29:38: RegisterProduct. Registering product
    Action start 19:29:38: RegisterProduct.
    Registering product
    Action ended 19:29:38: RegisterProduct. Return value 1.
    Action 19:29:38: PublishComponents. Publishing qualified components
    Action start 19:29:38: PublishComponents.
    Action ended 19:29:38: PublishComponents. Return value 0.
    Action 19:29:38: MsiPublishAssemblies. Publishing assembly information
    Action start 19:29:38: MsiPublishAssemblies.
    Application Context:Publishing assembly information, Assembly Name:
    Action ended 19:29:38: MsiPublishAssemblies. Return value 1.
    Action 19:29:38: PublishFeatures. Publishing product features
    Action start 19:29:38: PublishFeatures.
    Feature: Publishing product features
    Action ended 19:29:38: PublishFeatures. Return value 1.
    Action 19:29:38: PublishProduct. Publishing product information
    Action start 19:29:38: PublishProduct.
    Action ended 19:29:38: PublishProduct. Return value 1.
    Action 19:29:38: InstallFinalize.
    Action start 19:29:38: InstallFinalize.
    Shortcut: ARPPRODUCTICON.exe
    20320.msi
    Application Context:Global, Assembly Name:Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1 fc8b3b9a1e18e3b",version="8.0.50727.4053",type="win32"
    Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.MFC,processorArchitecture="x86",public KeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",type="win32-polic y"
    Feature: Microsoft_VC80_MFC_x86_
    Message type: 2, Argument: 0
    Action 19:29:38: RollbackCleanup. Removing backup files
    File: C:\Config.Msi\23ce2.rbf
    File: C:\Config.Msi\23ce3.rbf
    Message type: 2, Argument: 1
    [     340] Mon Mar 29 19:29:39 2010  INFO
    Action ended 19:29:39: InstallFinalize. Return value 1.
    Action ended 19:29:39: INSTALL. Return value 1.
    Property(S): DiskPrompt = [1]
    Property(S): UpgradeCode = {BA8F3080-8370-4EB2-8827-F83E97A7A343}
    Property(S): SourcedirProduct = {D1A19B02-817E-4296-A45B-07853FD74D57}
    Property(S): SOURCEDIR = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFC_x86\
    Property(S): PrimaryVolumeSpaceRemaining = 0
    Property(S): PrimaryVolumeSpaceRequired = 0
    Property(S): PrimaryVolumeSpaceAvailable = 0
    Property(S): OutOfNoRbDiskSpace = 0
    Property(S): OutOfDiskSpace = 0
    Property(S): Installed = 2009/11/13 07:25:22
    Property(S): CostingComplete = 1
    Property(S): ROOTDRIVE = C:\
    Property(S): ACTION = INSTALL
    Property(S): Preselected = 1
    Property(S): QFEUpgrade = 1
    Property(S): UILevel = 2
    Property(S): OriginalDatabase = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
    Property(S): DATABASE = C:\Windows\Installer\23cde.msi
    Property(S): Privileged = 1
    Property(S): MsiRunningElevated = 1
    Property(S): RedirectedDllSupport = 2
    Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
    Property(S): MsiNetAssemblySupport = 2.0.50727.4927
    Property(S): Date = 29/03/2010
    Property(S): Time = 19:29:39
    Property(S): TTCSupport = 1
    Property(S): ColorBits = 32
    Property(S): TextInternalLeading = 3
    Property(S): TextHeight = 16
    Property(S): BorderSide = 1
    Property(S): BorderTop = 1
    Property(S): CaptionHeight = 22
    Property(S): ScreenY = 768
    Property(S): ScreenX = 1024
    Property(S): SystemLanguageID = 1046
    Property(S): ComputerName = INSPIRON_1525
    Property(S): UserLanguageID = 1046
    Property(S): UserSID = S-1-5-21-1792381714-3552011656-547379065-1000
    Property(S): LogonUser = M@RCELO
    Property(S): MsiTrueAdminUser = 1
    Property(S): AdminUser = 1
    Property(S): VirtualMemory = 3248
    Property(S): PhysicalMemory = 2038
    Property(S): Intel = 6
    Property(S): ShellAdvtSupport = 1
    Property(S): OLEAdvtSupport = 1
    Property(S): GPTSupport = 1
    Property(S): VersionNT = 601
    Property(S): ProgramFilesFolder = C:\Program Files\
    Property(S): ADOBE = C:\Program Files\Adobe\
    Property(S): TARGETDIR = C:\
    Property(S): ALLUSERSPROFILE = C:\
    Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(S): AppDataFolder = C:\Users\M@RCELO\AppData\Roaming\
    Property(S): CommonAppDataFolder = C:\ProgramData\
    Property(S): CommonFiles64Folder = C:\
    Property(S): CommonFilesFolder = C:\Program Files\Common Files\
    Property(S): ISYourDataBaseDir = C:\Program Files\Adobe\My Product Name\Database\
    Property(S): DATABASEDIR = C:\Program Files\Adobe\My Product Name\Database\
    Property(S): DesktopFolder = C:\Users\Public\Desktop\
    Property(S): FavoritesFolder = C:\Users\M@RCELO\Favorites\
    Property(S): FontsFolder = C:\Windows\Fonts\
    Property(S): GlobalAssemblyCache = C:\
    Property(S): MY_PRODUCT_NAME = C:\Program Files\Adobe\My Product Name\
    Property(S): INSTALLDIR = C:\Program Files\Adobe\My Product Name\
    Property(S): ISCommonFilesFolder = C:\Program Files\Common Files\InstallShield\
    Property(S): ISMyCompanyDir = C:\Program Files\My Company Name\
    Property(S): ISMyProductDir = C:\Program Files\My Company Name\My Product Name\
    Property(S): ISUpdateServiceFolder = C:\Program Files\Common Files\InstallShield\UpdateService\
    Property(S): LocalAppDataFolder = C:\Users\M@RCELO\AppData\Local\
    Property(S): MyPicturesFolder = C:\Users\M@RCELO\Pictures\
    Property(S): PersonalFolder = C:\Users\M@RCELO\Documents\
    Property(S): PrimaryVolumePath = C:\
    Property(S): ProgramFiles64Folder = C:\
    Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
    Property(S): SendToFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
    Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(S): System16Folder = C:\Windows\system\
    Property(S): System64Folder = C:\
    Property(S): SystemFolder = C:\Windows\system32\
    Property(S): SourceDir = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_MFC_x86\
    Property(S): TempFolder = C:\Users\M@RCELO\AppData\Local\Temp\
    Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
    Property(S): USERPROFILE = C:\
    Property(S): WindowsFolder = C:\Windows\
    Property(S): WindowsVolume = C:\
    Property(S): WinSxsDirectory.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
    Property(S): payload_ul.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.4 053_none_cbf21254470d8752\
    Property(S): payload.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4 2_x-ww_dec6ddd2\
    Property(S): WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\
    Property(S): SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\system32\
    Property(S): WinSxsManifests.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
    Property(S): WinSxsPolicies.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
    Property(S): policydir.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir_ul.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4 053_x-ww_b77cec8e\
    Property(S): policydir.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.8 9_x-ww_decaded5\
    Property(S): policydir.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.9 3_x-ww_decbdf0e\
    Property(S): payload.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.9 4_x-ww_decbdf0f\
    Property(S): policydir.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.9 5_x-ww_decbdf10\
    Property(S): payload.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.9 6_x-ww_decbdf11\
    Property(S): policydir.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.9 7_x-ww_decbdf12\
    Property(S): payload.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.9 8_x-ww_decbdf13\
    Property(S): policydir.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.9 9_x-ww_decbdf14\
    Property(S): policydir.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1 00_x-ww_38fe9b83\
    Property(S): payload.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1 01_x-ww_38fe9b84\
    Property(S): policydir.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1 03_x-ww_38fe9b86\
    Property(S): payload.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1 04_x-ww_38fe9b87\
    Property(S): payload.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1 93_x-ww_39079dbd\
    Property(S): policydir.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.2 38_x-ww_397fabc9\
    Property(S): policydir.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): policydir.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3 044_x-ww_88f51b91\
    Property(S): policydir.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3 051_x-ww_88f61bcd\
    Property(S): policydir.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3 069_x-ww_88f71c14\
    Property(S): policydir.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x- ww_dbdc31f5\
    Property(S): payload.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1 833_x-ww_2fd6f5db\
    Property(S): payload.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4 027_x-ww_b779ebd5\
    Property(S): payload.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4 028_x-ww_b779ebd6\
    Property(S): payload.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4 029_x-ww_b779ebd7\
    Property(S): payload.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4 045_x-ww_b77bec51\
    Property(S): payload.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4 052_x-ww_b77cec8d\
    Property(S): payload.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4 053_x-ww_b77cec8e\
    Property(S): ALLUSERS = 1
    Property(S): WinSxsDirectory.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
    Property(S): payload_ul.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.mfc_1fc8b3b9a1e18e3b_ 8.0.50727.4053_none_49ef489714173a89\
    Property(S): WinSxsPolicies.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
    Property(S): policydir.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\
    Property(S): SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\system32\
    Property(S): WinSxsManifests.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
    Property(S): payload.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.42_x-ww_22ca9ad9\
    Property(S): policydir.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir_ul.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.4053_x-ww_fb80a995\
    Property(S): policydir.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.94_x-ww_22cf9c16\
    Property(S): policydir.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.89_x-ww_22ce9bdc\
    Property(S): policydir.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.93_x-ww_22cf9c15\
    Property(S): policydir.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.95_x-ww_22cf9c17\
    Property(S): policydir.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.96_x-ww_22cf9c18\
    Property(S): policydir.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.97_x-ww_22cf9c19\
    Property(S): policydir.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.98_x-ww_22cf9c1a\
    Property(S): policydir.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.99_x-ww_22cf9c1b\
    Property(S): policydir.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.100_x-ww_7d02588a\
    Property(S): payload.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.101_x-ww_7d02588b\
    Property(S): policydir.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.103_x-ww_7d02588d\
    Property(S): payload.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.104_x-ww_7d02588e\
    Property(S): policydir.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.193_x-ww_7d0b5ac4\
    Property(S): policydir.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): policydir.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9 a1e18e3b_x-ww_0f75c32e\
    Property(S): payload.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.238_x-ww_7d8368d0\
    Property(S): payload.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.3044_x-ww_ccf8d898\
    Property(S): payload.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.3051_x-ww_ccf9d8d4\
    Property(S): payload.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.3069_x-ww_ccfad91b\
    Property(S): payload.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.1833_x-ww_73dab2e2\
    Property(S): payload.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.4027_x-ww_fb7da8dc\
    Property(S): payload.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.4028_x-ww_fb7da8dd\
    Property(S): payload.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.4029_x-ww_fb7da8de\
    Property(S): payload.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.4045_x-ww_fb7fa958\
    Property(S): payload.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.4052_x-ww_fb80a994\
    Property(S): payload.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_ 8.0.50727.4053_x-ww_fb80a995\
    Property(S): RecentFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\Recent\
    Property(S): PrintHoodFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
    Property(S): NetHoodFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
    Property(S): RemoteAdminTS = 1
    Property(S): MsiNTProductType = 1
    Property(S): ServicePackLevelMinor = 0
    Property(S): ServicePackLevel = 0
    Property(S): ISCHECKFORPRODUCTUPDATES = 1
    Property(S): ApplicationUsers = AllUsers
    Property(S): AgreeToLicense = No
    Property(S): _IsMaintenance = Change
    Property(S): SetupType = Typical
    Property(S): _IsSetupTypeMin = Typical
    Property(S): IS_SQLSERVER_USERNAME = sa
    Property(S): IS_SQLSERVER_AUTHENTICATION = 0
    Property(S): RestartManagerOption = CloseRestart
    Property(S): Display_IsBitmapDlg = 1
    Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
    Property(S): DefaultUIFont = Tahoma8
    Property(S): DialogCaption = InstallShield for Windows Installer
    Property(S): DisplayNameCustom = Custom
    Property(S): DisplayNameMinimal = Minimal
    Property(S): DisplayNameTypical = Typical
    Property(S): DWUSINTERVAL = 30
    Property(S): ErrorDialog = SetupError
    Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
    Property(S): InstallChoice = AR
    Property(S): INSTALLLEVEL = 100
    Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
    Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
    Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
    Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
    Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
    Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
    Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
    Property(S): ISVROOT_PORT_NO = 0
    Property(S): Manufacturer = Adobe
    Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
    Property(S): ProductCode = {D1A19B02-817E-4296-A45B-07853FD74D57}
    Property(S): ProductID = none
    Property(S): ProductLanguage = 1033
    Property(S): ProductName = Microsoft_VC80_MFC_x86
    Property(S): ProductVersion = 8.0.50727.4053
    Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
    Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
    Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
    Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
    Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
    Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
    Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
    Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
    Property(S): ProgressType0 = install
    Property(S): ProgressType1 = Installing
    Property(S): ProgressType2 = installed
    Property(S): ProgressType3 = installs
    Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
    Property(S): RebootYesNo = No
    Property(S): ReinstallModeText = omus
    Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
    Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
    Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
    Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
    Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
    Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
    Property(S): DWUSLINK = CE8C979FAE7BF06819ACF728AE3C978F3EBCC78FFEEB4798CE8CE7EF9EDBA75FF9ABA 7E8FEAC
    Property(S): ARPURLINFOABOUT = http://www.Adobe.com
    Property(S): SHOWLAUNCHPROGRAM = 0
    Property(S): ARPSYSTEMCOMPONENT = 1
    Property(S): REBOOT = ReallySuppress
    Property(S): WindowsBuild = 7600
    Property(S): VersionMsi = 5.00
    Property(S): VersionDatabase = 200
    Property(S): PRODUCTLANGUAGE = 1033
    Property(S): CLIENTPROCESSID = 3296
    Property(S): MSICLIENTUSESEXTERNALUI = 1
    Property(S): CLIENTUILEVEL = 3
    Property(S): CURRENTDIRECTORY = C:\Users\M@RCELO\AppData\Local\Adobe\OOBE\PDApp\DWA
    Property(S): REINSTALLMODE = pvoums
    Property(S): REINSTALL = ALL
    Property(S): USERNAME = M@RCELO
    Property(S): ProductToBeRegistered = 1
    Property(S): ProductState = 5
    Property(S): PackageCode = {032B02B2-4D8D-45FF-BB1E-864B26F4ADDC}
    === Logging stopped: 29/03/2010  19:29:39 ===
    1: 2 2: 0
    1: 2 2: 1
    Installation result: 0
    Third party payload succeded.  Testing return code: 0
    [    3164] Mon Mar 29 19:29:40 2010  INFO
    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
    :: END TIMER :: [Payload Operation :{D1A19B02-817E-4296-A45B-07853FD74D57}] took 3011.22 miliseconds (3.01122 seconds) DTR = 1064.02 KBPS (1.03908 MBPS)
    User specified overrideFile:
    Calling the custom action code for post-install for payload {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86
    Calling the custom action code for pre-install for payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
    ::START TIMER:: [Payload Operation :{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}]
    [     316] Mon Mar 29 19:29:40 2010  INFO
    Installing payload
    Attempting to install package from:C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
    MsiSourceListAddSource for  C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi is 0
    MsiSourceListSetInfo with updated name: Microsoft_VC80_ATL_x86.msi, Result: 0
    [     316] Mon Mar 29 19:29:41 2010  INFO
    === Logging started: 29/03/2010  19:29:41 ===
    Message type: 0, Argument: 1033
    Message type: 1, Argument: Microsoft_VC80_ATL_x86
    Action 19:29:41: INSTALL.
    Action start 19:29:41: INSTALL.
    Action 19:29:41: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
    Action start 19:29:41: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
    Action ended 19:29:41: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:41: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
    Action start 19:29:41: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
    Action ended 19:29:41: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:41: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
    Action start 19:29:41: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
    Action ended 19:29:41: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:41: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
    Action start 19:29:41: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
    Action ended 19:29:41: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E. Return value 1.
    Action 19:29:41: AppSearch. Searching for installed applications
    Action start 19:29:41: AppSearch.
    Action ended 19:29:41: AppSearch. Return value 0.
    Action 19:29:41: FindRelatedProducts. Searching for related applications
    Action start 19:29:41: FindRelatedProducts.
    Action ended 19:29:41: FindRelatedProducts. Return value 0.
    Action 19:29:41: ValidateProductID.
    Action start 19:29:41: ValidateProductID.
    Action ended 19:29:41: ValidateProductID. Return value 1.
    Action 19:29:41: CostInitialize. Computing space requirements
    Action start 19:29:41: CostInitialize.
    Action ended 19:29:41: CostInitialize. Return value 1.
    Action 19:29:41: FileCost. Computing space requirements
    Action start 19:29:41: FileCost.
    Action ended 19:29:41: FileCost. Return value 1.
    Action 19:29:41: IsolateComponents.
    Action start 19:29:41: IsolateComponents.
    Action ended 19:29:41: IsolateComponents. Return value 0.
    Action 19:29:41: CostFinalize. Computing space requirements
    Action start 19:29:41: CostFinalize.
    Action ended 19:29:41: CostFinalize. Return value 1.
    Action 19:29:41: SetODBCFolders. Initializing ODBC directories
    Action start 19:29:41: SetODBCFolders.
    Action ended 19:29:41: SetODBCFolders. Return value 0.
    Action 19:29:41: MigrateFeatureStates. Migrating feature states from related applications
    Action start 19:29:41: MigrateFeatureStates.
    Action ended 19:29:41: MigrateFeatureStates. Return value 0.
    Action 19:29:41: InstallValidate. Validating install
    Action start 19:29:41: InstallValidate.
    Action ended 19:29:41: InstallValidate. Return value 1.
    Action 19:29:41: RemoveExistingProducts. Removing applications
    Action start 19:29:41: RemoveExistingProducts.
    Action ended 19:29:41: RemoveExistingProducts. Return value 0.
    Action 19:29:41: InstallInitialize.
    Action start 19:29:41: InstallInitialize.
    [     316] Mon Mar 29 19:29:42 2010  INFO
    Action ended 19:29:42: InstallInitialize. Return value 1.
    Action 19:29:42: SxsInstallCA.
    Action start 19:29:42: SxsInstallCA.
    1: sxsdelca: Skipping component  2: uplevel.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: uplevel.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18 E
    1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18 E
    Action ended 19:29:42: SxsInstallCA. Return value 1.
    Action 19:29:42: ProcessComponents. Updating component registration
    Action start 19:29:42: ProcessComponents.
    Action 19:29:42: GenerateScript. Generating script operations for action:
    Action ended 19:29:42: ProcessComponents. Return value 1.
    Action 19:29:42: UnpublishComponents. Unpublishing Qualified Components
    Action start 19:29:42: UnpublishComponents.
    Action ended 19:29:42: UnpublishComponents. Return value 0.
    Action 19:29:42: MsiUnpublishAssemblies. Unpublishing assembly information
    Action start 19:29:42: MsiUnpublishAssemblies.
    Action ended 19:29:42: MsiUnpublishAssemblies. Return value 1.
    Action 19:29:42: UnpublishFeatures. Unpublishing product features
    Action start 19:29:42: UnpublishFeatures.
    Action ended 19:29:42: UnpublishFeatures. Return value 1.
    Action 19:29:42: StopServices. Stopping services
    Action start 19:29:42: StopServices.
    Action ended 19:29:42: StopServices. Return value 1.
    Action 19:29:42: DeleteServices. Deleting services
    Action start 19:29:42: DeleteServices.
    Action ended 19:29:42: DeleteServices. Return value 1.
    Action 19:29:42: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 19:29:42: UnregisterComPlus.
    Action ended 19:29:42: UnregisterComPlus. Return value 0.
    Action 19:29:42: SelfUnregModules. Unregistering modules
    Action start 19:29:42: SelfUnregModules.
    Action ended 19:29:42: SelfUnregModules. Return value 1.
    Action 19:29:42: UnregisterTypeLibraries. Unregistering type libraries
    Action start 19:29:42: UnregisterTypeLibraries.
    Action ended 19:29:42: UnregisterTypeLibraries. Return value 0.
    Action 19:29:42: RemoveODBC. Removing ODBC components
    Action start 19:29:42: RemoveODBC.
    Action ended 19:29:42: RemoveODBC. Return value 1.
    Action 19:29:42: UnregisterFonts. Unregistering fonts
    Action start 19:29:42: UnregisterFonts.
    Action ended 19:29:42: UnregisterFonts. Return value 1.
    Action 19:29:42: RemoveRegistryValues. Removing system registry values
    Action start 19:29:42: RemoveRegistryValues.
    Action ended 19:29:42: RemoveRegistryValues. Return value 1.
    Action 19:29:42: UnregisterClassInfo. Unregister class servers
    Action start 19:29:42: UnregisterClassInfo.
    Action ended 19:29:42: UnregisterClassInfo. Return value 0.
    Action 19:29:42: UnregisterExtensionInfo. Unregistering extension servers
    Action start 19:29:42: UnregisterExtensionInfo.
    Action ended 19:29:42: UnregisterExtensionInfo. Return value 0.
    Action 19:29:42: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 19:29:42: UnregisterProgIdInfo.
    Action ended 19:29:42: UnregisterProgIdInfo. Return value 0.
    Action 19:29:42: UnregisterMIMEInfo. Unregistering MIME info
    Action start 19:29:42: UnregisterMIMEInfo.
    Action ended 19:29:42: UnregisterMIMEInfo. Return value 0.
    Action 19:29:42: RemoveIniValues. Removing INI file entries
    Action start 19:29:42: RemoveIniValues.
    Action ended 19:29:42: RemoveIniValues. Return value 1.
    Action 19:29:42: RemoveShortcuts. Removing shortcuts
    Action start 19:29:42: RemoveShortcuts.
    Action ended 19:29:42: RemoveShortcuts. Return value 0.
    Action 19:29:42: RemoveEnvironmentStrings. Updating environment strings
    Action start 19:29:42: RemoveEnvironmentStrings.
    Action ended 19:29:42: RemoveEnvironmentStrings. Return value 1.
    Action 19:29:42: RemoveDuplicateFiles. Removing duplicated files
    Action start 19:29:42: RemoveDuplicateFiles.
    Action ended 19:29:42: RemoveDuplicateFiles. Return value 1.
    Action 19:29:42: RemoveFiles. Removing files
    Action start 19:29:42: RemoveFiles.
    Action ended 19:29:42: RemoveFiles. Return value 0.
    Action 19:29:42: RemoveFolders. Removing folders
    Action start 19:29:42: RemoveFolders.
    Action ended 19:29:42: RemoveFolders. Return value 0.
    Action 19:29:42: CreateFolders. Creating folders
    Action start 19:29:42: CreateFolders.
    Action ended 19:29:42: CreateFolders. Return value 0.
    Action 19:29:42: MoveFiles. Moving files
    Action start 19:29:42: MoveFiles.
    Action ended 19:29:42: MoveFiles. Return value 1.
    Action 19:29:42: InstallFiles. Copying new files
    Action start 19:29:42: InstallFiles.
    [     316] Mon Mar 29 19:29:43 2010  INFO
    Action ended 19:29:43: InstallFiles. Return value 1.
    Action 19:29:43: PatchFiles. Patching files
    Action start 19:29:43: PatchFiles.
    Action ended 19:29:43: PatchFiles. Return value 0.
    Action 19:29:43: DuplicateFiles. Creating duplicate files
    Action start 19:29:43: DuplicateFiles.
    Action ended 19:29:43: DuplicateFiles. Return value 1.
    Action 19:29:43: BindImage. Binding executables
    Action start 19:29:43: BindImage.
    Action ended 19:29:43: BindImage. Return value 1.
    Action 19:29:43: CreateShortcuts. Creating shortcuts
    Action start 19:29:43: CreateShortcuts.
    Action ended 19:29:43: CreateShortcuts. Return value 0.
    Action 19:29:43: RegisterClassInfo. Registering class servers
    Action start 19:29:43: RegisterClassInfo.
    Action ended 19:29:43: RegisterClassInfo. Return value 0.
    Action 19:29:43: RegisterExtensionInfo. Registering extension servers
    Action start 19:29:43: RegisterExtensionInfo.
    Action ended 19:29:43: RegisterExtensionInfo. Return value 0.
    Action 19:29:43: RegisterProgIdInfo. Registering program identifiers
    Action start 19:29:43: RegisterProgIdInfo.
    Action ended 19:29:43: RegisterProgIdInfo. Return value 0.
    Action 19:29:43: RegisterMIMEInfo. Registering MIME info
    Action start 19:29:43: RegisterMIMEInfo.
    Action ended 19:29:43: RegisterMIMEInfo. Return value 0.
    Action 19:29:43: WriteRegistryValues. Writing system registry values
    Action start 19:29:43: WriteRegistryValues.
    Action ended 19:29:43: WriteRegistryValues. Return value 1.
    Action 19:29:43: WriteIniValues. Writing INI file values
    Action start 19:29:43: WriteIniValues.
    Action ended 19:29:43: WriteIniValues. Return value 1.
    Action 19:29:43: WriteEnvironmentStrings. Updating environment strings
    Action start 19:29:43: WriteEnvironmentStrings.
    Action ended 19:29:43: WriteEnvironmentStrings. Return value 1.
    Action 19:29:43: RegisterFonts. Registering fonts
    Action start 19:29:43: RegisterFonts.
    Action ended 19:29:43: RegisterFonts. Return value 1.
    Action 19:29:43: InstallODBC. Installing ODBC components
    Action start 19:29:43: InstallODBC.
    Action ended 19:29:43: InstallODBC. Return value 0.
    Action 19:29:43: RegisterTypeLibraries. Registering type libraries
    Action start 19:29:43: RegisterTypeLibraries.
    Action ended 19:29:43: RegisterTypeLibraries. Return value 0.
    Action 19:29:43: SelfRegModules. Registering modules
    Action start 19:29:43: SelfRegModules.
    Action ended 19:29:43: SelfRegModules. Return value 1.
    Action 19:29:43: RegisterComPlus. Registering COM+ Applications and Components
    Action start 19:29:43: RegisterComPlus.
    Action ended 19:29:43: RegisterComPlus. Return value 0.
    Action 19:29:43: InstallServices. Installing new services
    Action start 19:29:43: InstallServices.
    Action ended 19:29:43: InstallServices. Return value 1.
    Action 19:29:43: StartServices. Starting services
    Action start 19:29:43: StartServices.
    Action ended 19:29:43: StartServices. Return value 1.
    Action 19:29:43: RegisterUser. Registering user
    Action start 19:29:43: RegisterUser.
    Action ended 19:29:43: RegisterUser. Return value 0.
    Action 19:29:43: RegisterProduct. Registering product
    Action start 19:29:43: RegisterProduct.
    Registering product
    Action ended 19:29:43: RegisterProduct. Return value 1.
    Action 19:29:43: PublishComponents. Publishing qualified components
    Action start 19:29:43: PublishComponents.
    Action ended 19:29:43: PublishComponents. Return value 0.
    Action 19:29:43: MsiPublishAssemblies. Publishing assembly information
    Action start 19:29:43: MsiPublishAssemblies.
    Action ended 19:29:43: MsiPublishAssemblies. Return value 1.
    Action 19:29:43: PublishFeatures. Publishing product features
    Action start 19:29:43: PublishFeatures.
    Action ended 19:29:43: PublishFeatures. Return value 1.
    Action 19:29:43: PublishProduct. Publishing product information
    Action start 19:29:43: PublishProduct.
    Action ended 19:29:43: PublishProduct. Return value 1.
    Action 19:29:43: InstallFinalize.
    Action start 19:29:43: InstallFinalize.
    Action 19:29:43: ProcessComponents. Updating component registration
    Action 19:29:43: RemoveODBC. Removing ODBC components
    Action 19:29:43: InstallFiles. Copying new files
    20327.msi
    Application Context:Global, Assembly Name:Microsoft.VC80.ATL,type="win32",version="8.0.50727.4053",publicK eyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86"
    Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.ATL,type="win32-policy",version="8.0.5 0727.4053",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x8 6"
    Feature: Microsoft_VC80_ATL_x86_
    Action 19:29:43: RollbackCleanup. Removing backup files
    File: C:\Config.Msi\23ce9.rbf
    File: C:\Config.Msi\23cea.rbf
    Action ended 19:29:43: InstallFinalize. Return value 1.
    Action ended 19:29:43: INSTALL. Return value 1.
    Property(S): UpgradeCode = {B42842E9-F9F7-4A0F-A616-857958BC88BF}
    Property(S): SourcedirProduct = {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
    Property(S): SOURCEDIR = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_ATL_x86\
    Property(S): Installed = 2009/11/12 11:34:20
    Property(S): OriginalDatabase = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
    Property(S): DATABASE = C:\Windows\Installer\23ce5.msi
    Property(S): Time = 19:29:43
    Property(S): VirtualMemory = 3208
    Property(S): SourceDir = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC80_ATL_x86\
    Property(S): WinSxsDirectory.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
    Property(S): payload_ul.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.4 053_none_d1c738ec43578ea1\
    Property(S): payload.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4 2_x-ww_6e805841\
    Property(S): WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\
    Property(S): SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\system32\
    Property(S): WinSxsManifests.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
    Property(S): WinSxsPolicies.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
    Property(S): policydir.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): payload.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.8 9_x-ww_6e845944\
    Property(S): payload.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.9 4_x-ww_6e85597e\
    Property(S): payload.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.9 3_x-ww_6e85597d\
    Property(S): policydir.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): ANSIFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\system32\
    Property(S): payload.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.9 5_x-ww_6e85597f\
    Property(S): policydir.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): payload.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.9 6_x-ww_6e855980\
    Property(S): payload.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.9 9_x-ww_6e855983\
    Property(S): payload.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.9 7_x-ww_6e855981\
    Property(S): payload.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.9 8_x-ww_6e855982\
    Property(S): payload.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1 00_x-ww_c8b815f2\
    Property(S): payload.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1 01_x-ww_c8b815f3\
    Property(S): policydir.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): payload.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1 04_x-ww_c8b815f6\
    Property(S): payload.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1 03_x-ww_c8b815f5\
    Property(S): policydir.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): payload.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1 93_x-ww_c8c1182c\
    Property(S): payload.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3 044_x-ww_18ae9600\
    Property(S): payload.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.2 38_x-ww_c9392638\
    Property(S): payload.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3 069_x-ww_18b09683\
    Property(S): policydir.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): payload.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3 051_x-ww_18af963c\
    Property(S): payload.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4 028_x-ww_47336645\
    Property(S): payload.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4 027_x-ww_47336644\
    Property(S): payload.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1 833_x-ww_bf90704a\
    Property(S): policydir_ul.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4 053_x-ww_473666fd\
    Property(S): payload.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4 029_x-ww_47336646\
    Property(S): payload.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4 053_x-ww_473666fd\
    Property(S): policydir.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): payload.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4 045_x-ww_473566c0\
    Property(S): payload.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4 052_x-ww_473666fc\
    Property(S): policydir.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): policydir.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x- ww_2b722bc6\
    Property(S): WinSxsDirectory.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
    Property(S): payload_ul.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.atl_1fc8b3b9a1e18e3b_ 8.0.50727.4053_none_4ddfc6cd11929a02\
    Property(S): WinSxsPolicies.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
    Property(S): policydir.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\
    Property(S): SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\system32\
    Property(S): WinSxsManifests.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
    Property(S): payload.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.42_x-ww_b2841548\
    Property(S): policydir.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir_ul.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.4053_x-ww_8b3a2404\
    Property(S): policydir.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.94_x-ww_b2891685\
    Property(S): policydir.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.89_x-ww_b288164b\
    Property(S): policydir.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.93_x-ww_b2891684\
    Property(S): policydir.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.95_x-ww_b2891686\
    Property(S): policydir.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.96_x-ww_b2891687\
    Property(S): policydir.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.97_x-ww_b2891688\
    Property(S): policydir.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.98_x-ww_b2891689\
    Property(S): policydir.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.99_x-ww_b289168a\
    Property(S): policydir.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.100_x-ww_0cbbd2f9\
    Property(S): payload.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.101_x-ww_0cbbd2fa\
    Property(S): policydir.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.103_x-ww_0cbbd2fc\
    Property(S): payload.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.104_x-ww_0cbbd2fd\
    Property(S): policydir.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.193_x-ww_0cc4d533\
    Property(S): policydir.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): policydir.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9 a1e18e3b_x-ww_5f0bbcff\
    Property(S): payload.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.238_x-ww_0d3ce33f\
    Property(S): payload.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.3044_x-ww_5cb25307\
    Property(S): payload.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.3051_x-ww_5cb35343\
    Property(S): payload.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.3069_x-ww_5cb4538a\
    Property(S): payload.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.1833_x-ww_03942d51\
    Property(S): payload.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.4027_x-ww_8b37234b\
    Property(S): payload.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.4028_x-ww_8b37234c\
    Property(S): payload.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.4029_x-ww_8b37234d\
    Property(S): payload.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.4045_x-ww_8b3923c7\
    Property(S): payload.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.4052_x-ww_8b3a2403\
    Property(S): payload.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_ 8.0.50727.4053_x-ww_8b3a2404\
    Property(S): ProductCode = {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
    Property(S): ProductName = Microsoft_VC80_ATL_x86
    Property(S): DWUSLINK = CE0B90581E3CF05FFEAC57B89EEC978F9EDC508F591B0798CEABF7DFDEAB57D8FE1C4 7B8D9AC
    Property(S): ARPURLINFOABOUT = http://www.adobe.com
    Property(S): PackageCode = {3C0DD3C2-B6EC-46C4-8544-00189BC45D86}
    === Logging stopped: 29/03/2010  19:29:43 ===
    1: 2 2: 0
    1: 2 2: 1
    [    3164] Mon Mar 29 19:29:44 2010  INFO
    :: END TIMER :: [Payload Operation :{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}] took 4007.99 miliseconds (4.00799 seconds) DTR = 26.9462 KBPS (0.0263147 MBPS)
    Calling the custom action code for post-install for payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86
    Calling the custom action code for pre-install for payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
    ::START TIMER:: [Payload Operation :{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}]
    [    2320] Mon Mar 29 19:29:44 2010  INFO
    Installer Operation: InstallThirdPartyPayloadOperation
    Installing third party payload
    Installing payload
    Attempting to install package from:C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
    [    2320] Mon Mar 29 19:29:45 2010  INFO
    Payload is already installed with MSI
    MsiSourceListAddSource for  C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi is 0
    MsiSourceListSetInfo with updated name: Microsoft_VC90_ATL_x86.msi, Result: 0
    Payload source is not removable so not updating media info
    Command line arguments:  REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
    1: 0 2: 1033 3: 1252
    === Logging started: 29/03/2010  19:29:45 ===
    Message type: 1, Argument: Microsoft_VC90_ATL_x86
    Action 19:29:45: INSTALL.
    Action start 19:29:45: INSTALL.
    Action 19:29:45: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9 _ADD9_EE9DFF225A2A.
    Action start 19:29:45: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9 _ADD9_EE9DFF225A2A.
    Action ended 19:29:45: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9 _ADD9_EE9DFF225A2A. Return value 1.
    Action 19:29:45: AppSearch. Searching for installed applications
    Action start 19:29:45: AppSearch.
    Action ended 19:29:45: AppSearch. Return value 0.
    Action 19:29:45: FindRelatedProducts. Searching for related applications
    Action start 19:29:45: FindRelatedProducts.
    Action ended 19:29:45: FindRelatedProducts. Return value 0.
    Action 19:29:45: ValidateProductID.
    Action start 19:29:45: ValidateProductID.
    Action ended 19:29:45: ValidateProductID. Return value 1.
    Action 19:29:45: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF 9_ADD9_EE9DFF225A2A.
    Action start 19:29:45: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF 9_ADD9_EE9DFF225A2A.
    Action ended 19:29:45: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF 9_ADD9_EE9DFF225A2A. Return value 1.
    Action 19:29:45: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37 E4_C37F_3B9C_8A4D_0B4F390FB6DC.
    Action start 19:29:45: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37 E4_C37F_3B9C_8A4D_0B4F390FB6DC.
    Action ended 19:29:45: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37 E4_C37F_3B9C_8A4D_0B4F390FB6DC. Return value 1.
    Action 19:29:45: CostInitialize. Computing space requirements
    Action start 19:29:45: CostInitialize.
    Action ended 19:29:45: CostInitialize. Return value 1.
    Action 19:29:45: FileCost. Computing space requirements
    Action start 19:29:45: FileCost.
    Action ended 19:29:45: FileCost. Return value 1.
    Action 19:29:45: IsolateComponents.
    Action start 19:29:45: IsolateComponents.
    Action ended 19:29:45: IsolateComponents. Return value 0.
    Action 19:29:45: CostFinalize. Computing space requirements
    Action start 19:29:45: CostFinalize.
    Action ended 19:29:45: CostFinalize. Return value 1.
    Action 19:29:45: SetODBCFolders. Initializing ODBC directories
    Action start 19:29:45: SetODBCFolders.
    Action ended 19:29:45: SetODBCFolders. Return value 0.
    Action 19:29:45: MigrateFeatureStates. Migrating feature states from related applications
    Action start 19:29:45: MigrateFeatureStates.
    Action ended 19:29:45: MigrateFeatureStates. Return value 0.
    Action 19:29:45: InstallValidate. Validating install
    Action start 19:29:45: InstallValidate.
    Action ended 19:29:45: InstallValidate. Return value 1.
    Action 19:29:45: RemoveExistingProducts. Removing applications
    Action start 19:29:45: RemoveExistingProducts.
    Action ended 19:29:45: RemoveExistingProducts. Return value 0.
    Action 19:29:45: InstallInitialize.
    Action start 19:29:45: InstallInitialize.
    [    2320] Mon Mar 29 19:29:46 2010  INFO
    Action ended 19:29:46: InstallInitialize. Return value 1.
    Action 19:29:46: ProcessComponents. Updating component registration
    Action start 19:29:46: ProcessComponents.
    Action 19:29:46: GenerateScript. Generating script operations for action:
    Action ended 19:29:46: ProcessComponents. Return value 1.
    Action 19:29:46: UnpublishComponents. Unpublishing Qualified Components
    Action start 19:29:46: UnpublishComponents.
    Action ended 19:29:46: UnpublishComponents. Return value 0.
    Action 19:29:46: MsiUnpublishAssemblies. Unpublishing assembly information
    Action start 19:29:46: MsiUnpublishAssemblies.
    Action ended 19:29:46: MsiUnpublishAssemblies. Return value 1.
    Action 19:29:46: UnpublishFeatures. Unpublishing product features
    Action start 19:29:46: UnpublishFeatures.
    Action ended 19:29:46: UnpublishFeatures. Return value 1.
    Action 19:29:46: StopServices. Stopping services
    Action start 19:29:46: StopServices.
    Action ended 19:29:46: StopServices. Return value 1.
    Action 19:29:46: DeleteServices. Deleting services
    Action start 19:29:46: DeleteServices.
    Action ended 19:29:46: DeleteServices. Return value 1.
    Action 19:29:46: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 19:29:46: UnregisterComPlus.
    Action ended 19:29:46: UnregisterComPlus. Return value 0.
    Action 19:29:46: SelfUnregModules. Unregistering modules
    Action start 19:29:46: SelfUnregModules.
    Action ended 19:29:46: SelfUnregModules. Return value 1.
    Action 19:29:46: UnregisterTypeLibraries. Unregistering type libraries
    Action start 19:29:46: UnregisterTypeLibraries.
    Action ended 19:29:46: UnregisterTypeLibraries. Return value 0.
    Action 19:29:46: RemoveODBC. Removing ODBC components
    Action start 19:29:46: RemoveODBC.
    Action ended 19:29:46: RemoveODBC. Return value 1.
    Action 19:29:46: UnregisterFonts. Unregistering fonts
    Action start 19:29:46: UnregisterFonts.
    Action ended 19:29:46: UnregisterFonts. Return value 1.
    Action 19:29:46: RemoveRegistryValues. Removing system registry values
    Action start 19:29:46: RemoveRegistryValues.
    Action ended 19:29:46: RemoveRegistryValues. Return value 1.
    Action 19:29:46: UnregisterClassInfo. Unregister class servers
    Action start 19:29:46: UnregisterClassInfo.
    Action ended 19:29:46: UnregisterClassInfo. Return value 0.
    Action 19:29:46: UnregisterExtensionInfo. Unregistering extension servers
    Action start 19:29:46: UnregisterExtensionInfo.
    Action ended 19:29:46: UnregisterExtensionInfo. Return value 0.
    Action 19:29:46: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 19:29:46: UnregisterProgIdInfo.
    Action ended 19:29:46: UnregisterProgIdInfo. Return value 0.
    Action 19:29:46: UnregisterMIMEInfo. Unregistering MIME info
    Action start 19:29:46: UnregisterMIMEInfo.
    Action ended 19:29:46: UnregisterMIMEInfo. Return value 0.
    Action 19:29:46: RemoveIniValues. Removing INI file entries
    Action start 19:29:46: RemoveIniValues.
    Action ended 19:29:46: RemoveIniValues. Return value 1.
    Action 19:29:46: RemoveShortcuts. Removing shortcuts
    Action start 19:29:46: RemoveShortcuts.
    Action ended 19:29:46: RemoveShortcuts. Return value 0.
    Action 19:29:46: RemoveEnvironmentStrings. Updating environment strings
    Action start 19:29:46: RemoveEnvironmentStrings.
    Action ended 19:29:46: RemoveEnvironmentStrings. Return value 1.
    Action 19:29:46: RemoveDuplicateFiles. Removing duplicated files
    Action start 19:29:46: RemoveDuplicateFiles.
    Action ended 19:29:46: RemoveDuplicateFiles. Return value 1.
    Action 19:29:46: RemoveFiles. Removing files
    Action start 19:29:46: RemoveFiles.
    Action ended 19:29:46: RemoveFiles. Return value 0.
    Action 19:29:46: RemoveFolders. Removing folders
    Action start 19:29:46: RemoveFolders.
    Action ended 19:29:46: RemoveFolders. Return value 0.
    Action 19:29:46: CreateFolders. Creating folders
    Action start 19:29:46: CreateFolders.
    Action ended 19:29:46: CreateFolders. Return value 0.
    Action 19:29:46: MoveFiles. Moving files
    Action start 19:29:46: MoveFiles.
    Action ended 19:29:46: MoveFiles. Return value 1.
    Action 19:29:46: InstallFiles. Copying new files
    Action start 19:29:46: InstallFiles.
    File: Copying new files,  Directory: ,  Size:
    Action ended 19:29:46: InstallFiles. Return value 1.
    Action 19:29:46: PatchFiles. Patching files
    Action start 19:29:46: PatchFiles.
    Action ended 19:29:46: PatchFiles. Return value 0.
    Action 19:29:46: DuplicateFiles. Creating duplicate files
    Action start 19:29:46: DuplicateFiles.
    Action ended 19:29:46: DuplicateFiles. Return value 1.
    Action 19:29:46: BindImage. Binding executables
    Action start 19:29:46: BindImage.
    Action ended 19:29:46: BindImage. Return value 1.
    Action 19:29:46: CreateShortcuts. Creating shortcuts
    Action start 19:29:46: CreateShortcuts.
    Shortcut: Creating shortcuts
    Action ended 19:29:46: CreateShortcuts. Return value 0.
    Action 19:29:46: RegisterClassInfo. Registering class servers
    Action start 19:29:46: RegisterClassInfo.
    Action ended 19:29:46: RegisterClassInfo. Return value 0.
    Action 19:29:46: RegisterExtensionInfo. Registering extension servers
    Action start 19:29:46: RegisterExtensionInfo.
    Action ended 19:29:46: RegisterExtensionInfo. Return value 0.
    Action 19:29:46: RegisterProgIdInfo. Registering program identifiers
    Action start 19:29:46: RegisterProgIdInfo.
    Action ended 19:29:46: RegisterProgIdInfo. Return value 0.
    Action 19:29:46: RegisterMIMEInfo. Registering MIME info
    Action start 19:29:46: RegisterMIMEInfo.
    Action ended 19:29:46: RegisterMIMEInfo. Return value 0.
    Action 19:29:46: WriteRegistryValues. Writing system registry values
    Action start 19:29:46: WriteRegistryValues.
    Action ended 19:29:46: WriteRegistryValues. Return value 1.
    Action 19:29:46: WriteIniValues. Writing INI file values
    Action start 19:29:46: WriteIniValues.
    Action ended 19:29:46: WriteIniValues. Return value 1.
    Action 19:29:46: WriteEnvironmentStrings. Updating environment strings
    Action start 19:29:46: WriteEnvironmentStrings.
    Action ended 19:29:46: WriteEnvironmentStrings. Return value 1.
    Action 19:29:46: RegisterFonts. Registering fonts
    Action start 19:29:46: RegisterFonts.
    Action ended 19:29:46: RegisterFonts. Return value 1.
    Action 19:29:46: InstallODBC. Installing ODBC components
    Action start 19:29:46: InstallODBC.
    Action ended 19:29:46: InstallODBC. Return value 0.
    Action 19:29:46: RegisterTypeLibraries. Registering type libraries
    Action start 19:29:46: RegisterTypeLibraries.
    Action ended 19:29:46: RegisterTypeLibraries. Return value 0.
    Action 19:29:46: SelfRegModules. Registering modules
    Action start 19:29:46: SelfRegModules.
    Action ended 19:29:46: SelfRegModules. Return value 1.
    Action 19:29:46: RegisterComPlus. Registering COM+ Applications and Components
    Action start 19:29:46: RegisterComPlus.
    Action ended 19:29:46: RegisterComPlus. Return value 0.
    Action 19:29:46: InstallServices. Installing new services
    Action start 19:29:46: InstallServices.
    Action ended 19:29:46: InstallServices. Return value 1.
    Action 19:29:46: StartServices. Starting services
    Action start 19:29:46: StartServices.
    Action ended 19:29:46: StartServices. Return value 1.
    Action 19:29:46: RegisterUser. Registering user
    Action start 19:29:46: RegisterUser.
    Action ended 19:29:46: RegisterUser. Return value 0.
    Action 19:29:46: RegisterProduct. Registering product
    Action start 19:29:46: RegisterProduct.
    Registering product
    Action ended 19:29:46: RegisterProduct. Return value 1.
    Action 19:29:46: PublishComponents. Publishing qualified components
    Action start 19:29:46: PublishComponents.
    Action ended 19:29:46: PublishComponents. Return value 0.
    Action 19:29:46: MsiPublishAssemblies. Publishing assembly information
    Action start 19:29:46: MsiPublishAssemblies.
    Application Context:Publishing assembly information, Assembly Name:
    Action ended 19:29:46: MsiPublishAssemblies. Return value 1.
    Action 19:29:46: PublishFeatures. Publishing product features
    Action start 19:29:46: PublishFeatures.
    Feature: Publishing product features
    Action ended 19:29:46: PublishFeatures. Return value 1.
    Action 19:29:46: PublishProduct. Publishing product information
    Action start 19:29:46: PublishProduct.
    Action ended 19:29:46: PublishProduct. Return value 1.
    Action 19:29:46: InstallFinalize.
    Action start 19:29:46: InstallFinalize.
    Shortcut: ARPPRODUCTICON.exe
    2032e.msi
    Application Context:Global, Assembly Name:Microsoft.VC90.ATL,version="9.0.30729.4137",publicKeyToken="1fc8 b3b9a1e18e3b",processorArchitecture="x86",type="win32"
    Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.ATL,version="9.0.30729.4137",publicKey Token="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32-polic y"
    Feature: Microsoft_VC90_ATL_x86_
    Message type: 2, Argument: 0
    Action 19:29:46: RollbackCleanup. Removing backup files
    File: C:\Config.Msi\23cf0.rbf
    File: C:\Config.Msi\23cf1.rbf
    Message type: 2, Argument: 1
    Action ended 19:29:46: InstallFinalize. Return value 1.
    Action ended 19:29:46: INSTALL. Return value 1.
    Property(S): DiskPrompt = [1]
    Property(S): UpgradeCode = {F31F95D5-E2B6-4984-A9D1-CA5E8CF1BFFE}
    Property(S): Installed = 2009/07/27 14:07:38
    Property(S): SourcedirProduct = {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
    Property(S): SOURCEDIR = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_ATL_x86\
    Property(S): PrimaryVolumeSpaceRemaining = 0
    Property(S): PrimaryVolumeSpaceRequired = 0
    Property(S): PrimaryVolumeSpaceAvailable = 0
    Property(S): OutOfNoRbDiskSpace = 0
    Property(S): OutOfDiskSpace = 0
    Property(S): CostingComplete = 1
    Property(S): ROOTDRIVE = C:\
    Property(S): ACTION = INSTALL
    Property(S): Preselected = 1
    Property(S): QFEUpgrade = 1
    Property(S): UILevel = 2
    Property(S): OriginalDatabase = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
    Property(S): DATABASE = C:\Windows\Installer\23cec.msi
    Property(S): Privileged = 1
    Property(S): MsiRunningElevated = 1
    Property(S): RedirectedDllSupport = 2
    Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
    Property(S): MsiNetAssemblySupport = 2.0.50727.4927
    Property(S): Date = 29/03/2010
    Property(S): Time = 19:29:46
    Property(S): TTCSupport = 1
    Property(S): ColorBits = 32
    Property(S): TextInternalLeading = 3
    Property(S): TextHeight = 16
    Property(S): BorderSide = 1
    Property(S): BorderTop = 1
    Property(S): CaptionHeight = 22
    Property(S): ScreenY = 768
    Property(S): ScreenX = 1024
    Property(S): SystemLanguageID = 1046
    Property(S): ComputerName = INSPIRON_1525
    Property(S): UserLanguageID = 1046
    Property(S): UserSID = S-1-5-21-1792381714-3552011656-547379065-1000
    Property(S): LogonUser = M@RCELO
    Property(S): MsiTrueAdminUser = 1
    Property(S): AdminUser = 1
    Property(S): VirtualMemory = 3209
    Property(S): PhysicalMemory = 2038
    Property(S): Intel = 6
    Property(S): ShellAdvtSupport = 1
    Property(S): OLEAdvtSupport = 1
    Property(S): GPTSupport = 1
    Property(S): VersionNT = 601
    Property(S): ProgramFilesFolder = C:\Program Files\
    Property(S): ADOBE = C:\Program Files\Adobe\
    Property(S): TARGETDIR = C:\
    Property(S): ALLUSERSPROFILE = C:\
    Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(S): AppDataFolder = C:\Users\M@RCELO\AppData\Roaming\
    Property(S): CommonAppDataFolder = C:\ProgramData\
    Property(S): CommonFiles64Folder = C:\
    Property(S): CommonFilesFolder = C:\Program Files\Common Files\
    Property(S): ISYourDataBaseDir = C:\Program Files\Adobe\My Product Name\Database\
    Property(S): DATABASEDIR = C:\Program Files\Adobe\My Product Name\Database\
    Property(S): DesktopFolder = C:\Users\Public\Desktop\
    Property(S): FavoritesFolder = C:\Users\M@RCELO\Favorites\
    Property(S): FontsFolder = C:\Windows\Fonts\
    Property(S): GlobalAssemblyCache = C:\
    Property(S): MY_PRODUCT_NAME = C:\Program Files\Adobe\My Product Name\
    Property(S): INSTALLDIR = C:\Program Files\Adobe\My Product Name\
    Property(S): ISCommonFilesFolder = C:\Program Files\Common Files\InstallShield\
    Property(S): ISMyCompanyDir = C:\Program Files\My Company Name\
    Property(S): ISMyProductDir = C:\Program Files\My Company Name\My Product Name\
    Property(S): ISUpdateServiceFolder = C:\Program Files\Common Files\InstallShield\UpdateService\
    Property(S): LocalAppDataFolder = C:\Users\M@RCELO\AppData\Local\
    Property(S): MyPicturesFolder = C:\Users\M@RCELO\Pictures\
    Property(S): PersonalFolder = C:\Users\M@RCELO\Documents\
    Property(S): PrimaryVolumePath = C:\
    Property(S): ProgramFiles64Folder = C:\
    Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
    Property(S): SendToFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
    Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(S): System16Folder = C:\Windows\system\
    Property(S): System64Folder = C:\
    Property(S): SystemFolder = C:\Windows\system32\
    Property(S): SourceDir = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_ATL_x86\
    Property(S): TempFolder = C:\Users\M@RCELO\AppData\Local\Temp\
    Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
    Property(S): USERPROFILE = C:\
    Property(S): WindowsFolder = C:\Windows\
    Property(S): WindowsVolume = C:\
    Property(S): WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF 9_ADD9_EE9DFF225A2A = C:\Windows\
    Property(S): SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9 _ADD9_EE9DFF225A2A = C:\Windows\system32\
    Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3 CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\
    Property(S): payload_ul.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_A DD9_EE9DFF225A2A = C:\Windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4 137_none_51c97d20bbe8350e\
    Property(S): payload.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9 _EE9DFF225A2A = C:\Windows\winsxs\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.30729.4 137_x-ww_35349982\
    Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3 CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\Manifests\
    Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3C F9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\Policies\
    Property(S): policydir.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_AD D9_EE9DFF225A2A = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x- ww_fe8be9c7\
    Property(S): policydir_ul.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9 _ADD9_EE9DFF225A2A = C:\Windows\winsxs\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe8be9 c7\
    Property(S): ALLUSERS = 1
    Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF 37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\
    Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_ C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.atl_1fc8b3b9a1e18e3b_ 9.0.30729.4137_none_f0eecac0f8a1c174\
    Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF3 7E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\Policies\
    Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C 37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.ATL_1fc8b3b9 a1e18e3b_x-ww_9e7eb501\
    Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37 E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\
    Property(S): RecentFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\Recent\
    Property(S): PrintHoodFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
    Property(S): NetHoodFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
    Property(S): RemoteAdminTS = 1
    Property(S): MsiNTProductType = 1
    Property(S): ServicePackLevelMinor = 0
    Property(S): ServicePackLevel = 0
    Property(S): ISCHECKFORPRODUCTUPDATES = 1
    Property(S): ApplicationUsers = AllUsers
    Property(S): AgreeToLicense = No
    Property(S): _IsMaintenance = Change
    Property(S): SetupType = Typical
    Property(S): _IsSetupTypeMin = Typical
    Property(S): IS_SQLSERVER_USERNAME = sa
    Property(S): IS_SQLSERVER_AUTHENTICATION = 0
    Property(S): RestartManagerOption = CloseRestart
    Property(S): Display_IsBitmapDlg = 1
    Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
    Property(S): DefaultUIFont = Tahoma8
    Property(S): DialogCaption = InstallShield for Windows Installer
    Property(S): DisplayNameCustom = Custom
    Property(S): DisplayNameMinimal = Minimal
    Property(S): DisplayNameTypical = Typical
    Property(S): DWUSINTERVAL = 30
    Property(S): ErrorDialog = SetupError
    Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
    Property(S): InstallChoice = AR
    Property(S): INSTALLLEVEL = 100
    Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
    Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
    Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
    Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
    Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
    Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
    Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
    Property(S): ISVROOT_PORT_NO = 0
    Property(S): Manufacturer = Adobe
    Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
    Property(S): ProductCode = {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
    Property(S): ProductID = none
    Property(S): ProductLanguage = 1033
    Property(S): ProductName = Microsoft_VC90_ATL_x86
    Property(S): ProductVersion = 1.00.0000
    Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
    Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
    Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
    Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
    Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
    Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
    Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
    Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
    Property(S): ProgressType0 = install
    Property(S): ProgressType1 = Installing
    Property(S): ProgressType2 = installed
    Property(S): ProgressType3 = installs
    Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
    Property(S): RebootYesNo = Yes
    Property(S): ReinstallModeText = omus
    Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
    Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
    Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
    Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
    Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
    Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
    Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
    Property(S): DWUSLINK = CEAC70DF2E8BD79FDEACA7FFC98B978FCE1B808FFE0BB73FCE1BE08F4EDCE7AFE9FB8 09F89AC
    Property(S): ARPURLINFOABOUT = http://www.Adobe.com
    Property(S): SHOWLAUNCHPROGRAM = 0
    Property(S): ARPSYSTEMCOMPONENT = 1
    Property(S): WindowsBuild = 7600
    Property(S): REBOOT = ReallySuppress
    Property(S): VersionMsi = 5.00
    Property(S): VersionDatabase = 200
    Property(S): PRODUCTLANGUAGE = 1033
    Property(S): CLIENTPROCESSID = 3296
    Property(S): MSICLIENTUSESEXTERNALUI = 1
    Property(S): CLIENTUILEVEL = 3
    Property(S): CURRENTDIRECTORY = C:\Users\M@RCELO\AppData\Local\Adobe\OOBE\PDApp\DWA
    Property(S): REINSTALLMODE = pvoums
    Property(S): REINSTALL = ALL
    Property(S): ProductToBeRegistered = 1
    Property(S): USERNAME = M@RCELO
    Property(S): ProductState = 5
    Property(S): PackageCode = {BC1C6355-192C-4334-94F9-4A03B0DCB75C}
    === Logging stopped: 29/03/2010  19:29:46 ===
    1: 2 2: 0
    1: 2 2: 1
    Installation result: 0
    Third party payload succeded.  Testing return code: 0
    [    3164] Mon Mar 29 19:29:47 2010  INFO
    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
    :: END TIMER :: [Payload Operation :{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}] took 3005.53 miliseconds (3.00553 seconds)
    [    3164] Mon Mar 29 19:29:48 2010  INFO
    User specified overrideFile:
    Calling the custom action code for post-install for payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86
    Calling the custom action code for pre-install for payload {08D2E121-7F6A-43EB-97FD-629B44903403}
    ::START TIMER:: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}]
    [    1000] Mon Mar 29 19:29:48 2010  INFO
    Installing payload
    Attempting to install package from:C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
    MsiSourceListAddSource for  C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi is 0
    MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86.msi, Result: 0
    === Logging started: 29/03/2010  19:29:48 ===
    Message type: 0, Argument: 1033
    Message type: 1, Argument: Microsoft_VC90_CRT_x86
    Action 19:29:48: INSTALL.
    Action start 19:29:48: INSTALL.
    Action 19:29:48: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9 _BDB6_3C16D4C5E6B7.
    Action start 19:29:48: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9 _BDB6_3C16D4C5E6B7.
    Action ended 19:29:48: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9 _BDB6_3C16D4C5E6B7. Return value 1.
    Action 19:29:48: AppSearch. Searching for installed applications
    Action start 19:29:48: AppSearch.
    Action ended 19:29:48: AppSearch. Return value 0.
    Action 19:29:48: FindRelatedProducts. Searching for related applications
    Action start 19:29:48: FindRelatedProducts.
    Action ended 19:29:48: FindRelatedProducts. Return value 0.
    Action 19:29:48: ValidateProductID.
    Action start 19:29:48: ValidateProductID.
    Action ended 19:29:48: ValidateProductID. Return value 1.
    Action 19:29:48: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B 9_BDB6_3C16D4C5E6B7.
    Action start 19:29:48: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B 9_BDB6_3C16D4C5E6B7.
    Action ended 19:29:48: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B 9_BDB6_3C16D4C5E6B7. Return value 1.
    Action 19:29:48: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0 FC_F91D_35A6_89C5_7544A81A5FCF.
    Action start 19:29:48: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0 FC_F91D_35A6_89C5_7544A81A5FCF.
    Action ended 19:29:48: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0 FC_F91D_35A6_89C5_7544A81A5FCF. Return value 1.
    Action 19:29:48: CostInitialize. Computing space requirements
    Action start 19:29:48: CostInitialize.
    Action ended 19:29:48: CostInitialize. Return value 1.
    Action 19:29:48: FileCost. Computing space requirements
    Action start 19:29:48: FileCost.
    Action ended 19:29:48: FileCost. Return value 1.
    Action 19:29:48: IsolateComponents.
    Action start 19:29:48: IsolateComponents.
    Action ended 19:29:48: IsolateComponents. Return value 0.
    Action 19:29:48: CostFinalize. Computing space requirements
    Action start 19:29:48: CostFinalize.
    Action ended 19:29:48: CostFinalize. Return value 1.
    Action 19:29:48: SetODBCFolders. Initializing ODBC directories
    Action start 19:29:48: SetODBCFolders.
    Action ended 19:29:48: SetODBCFolders. Return value 0.
    Action 19:29:48: MigrateFeatureStates. Migrating feature states from related applications
    Action start 19:29:48: MigrateFeatureStates.
    Action ended 19:29:48: MigrateFeatureStates. Return value 0.
    Action 19:29:48: InstallValidate. Validating install
    Action start 19:29:48: InstallValidate.
    Action ended 19:29:48: InstallValidate. Return value 1.
    Action 19:29:48: RemoveExistingProducts. Removing applications
    Action start 19:29:48: RemoveExistingProducts.
    Action ended 19:29:48: RemoveExistingProducts. Return value 0.
    Action 19:29:48: InstallInitialize.
    Action start 19:29:48: InstallInitialize.
    [    1000] Mon Mar 29 19:29:49 2010  INFO
    Action ended 19:29:49: InstallInitialize. Return value 1.
    Action 19:29:49: ProcessComponents. Updating component registration
    Action start 19:29:49: ProcessComponents.
    Action 19:29:49: GenerateScript. Generating script operations for action:
    Action ended 19:29:49: ProcessComponents. Return value 1.
    Action 19:29:49: UnpublishComponents. Unpublishing Qualified Components
    Action start 19:29:49: UnpublishComponents.
    Action ended 19:29:49: UnpublishComponents. Return value 0.
    Action 19:29:49: MsiUnpublishAssemblies. Unpublishing assembly information
    Action start 19:29:49: MsiUnpublishAssemblies.
    Action ended 19:29:49: MsiUnpublishAssemblies. Return value 1.
    Action 19:29:49: UnpublishFeatures. Unpublishing product features
    Action start 19:29:49: UnpublishFeatures.
    Action ended 19:29:49: UnpublishFeatures. Return value 1.
    Action 19:29:49: StopServices. Stopping services
    Action start 19:29:49: StopServices.
    Action ended 19:29:49: StopServices. Return value 1.
    Action 19:29:49: DeleteServices. Deleting services
    Action start 19:29:49: DeleteServices.
    Action ended 19:29:49: DeleteServices. Return value 1.
    Action 19:29:49: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 19:29:49: UnregisterComPlus.
    Action ended 19:29:49: UnregisterComPlus. Return value 0.
    Action 19:29:49: SelfUnregModules. Unregistering modules
    Action start 19:29:49: SelfUnregModules.
    Action ended 19:29:49: SelfUnregModules. Return value 1.
    Action 19:29:49: UnregisterTypeLibraries. Unregistering type libraries
    Action start 19:29:49: UnregisterTypeLibraries.
    Action ended 19:29:49: UnregisterTypeLibraries. Return value 0.
    Action 19:29:49: RemoveODBC. Removing ODBC components
    Action start 19:29:49: RemoveODBC.
    Action ended 19:29:49: RemoveODBC. Return value 1.
    Action 19:29:49: UnregisterFonts. Unregistering fonts
    Action start 19:29:49: UnregisterFonts.
    Action ended 19:29:49: UnregisterFonts. Return value 1.
    Action 19:29:49: RemoveRegistryValues. Removing system registry values
    Action start 19:29:49: RemoveRegistryValues.
    Action ended 19:29:49: RemoveRegistryValues. Return value 1.
    Action 19:29:49: UnregisterClassInfo. Unregister class servers
    Action start 19:29:49: UnregisterClassInfo.
    Action ended 19:29:49: UnregisterClassInfo. Return value 0.
    Action 19:29:49: UnregisterExtensionInfo. Unregistering extension servers
    Action start 19:29:49: UnregisterExtensionInfo.
    Action ended 19:29:49: UnregisterExtensionInfo. Return value 0.
    Action 19:29:49: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 19:29:49: UnregisterProgIdInfo.
    Action ended 19:29:49: UnregisterProgIdInfo. Return value 0.
    Action 19:29:49: UnregisterMIMEInfo. Unregistering MIME info
    Action start 19:29:49: UnregisterMIMEInfo.
    Action ended 19:29:49: UnregisterMIMEInfo. Return value 0.
    Action 19:29:49: RemoveIniValues. Removing INI file entries
    Action start 19:29:49: RemoveIniValues.
    Action ended 19:29:49: RemoveIniValues. Return value 1.
    Action 19:29:49: RemoveShortcuts. Removing shortcuts
    Action start 19:29:49: RemoveShortcuts.
    Action ended 19:29:49: RemoveShortcuts. Return value 0.
    Action 19:29:49: RemoveEnvironmentStrings. Updating environment strings
    Action start 19:29:49: RemoveEnvironmentStrings.
    Action ended 19:29:49: RemoveEnvironmentStrings. Return value 1.
    Action 19:29:49: RemoveDuplicateFiles. Removing duplicated files
    Action start 19:29:49: RemoveDuplicateFiles.
    Action ended 19:29:49: RemoveDuplicateFiles. Return value 1.
    Action 19:29:49: RemoveFiles. Removing files
    Action start 19:29:49: RemoveFiles.
    Action ended 19:29:49: RemoveFiles. Return value 0.
    Action 19:29:49: RemoveFolders. Removing folders
    Action start 19:29:49: RemoveFolders.
    Action ended 19:29:49: RemoveFolders. Return value 0.
    Action 19:29:49: CreateFolders. Creating folders
    Action start 19:29:49: CreateFolders.
    Action ended 19:29:49: CreateFolders. Return value 0.
    Action 19:29:49: MoveFiles. Moving files
    Action start 19:29:49: MoveFiles.
    Action ended 19:29:49: MoveFiles. Return value 1.
    Action 19:29:49: InstallFiles. Copying new files
    Action start 19:29:49: InstallFiles.
    Action ended 19:29:49: InstallFiles. Return value 1.
    Action 19:29:49: PatchFiles. Patching files
    Action start 19:29:49: PatchFiles.
    Action ended 19:29:49: PatchFiles. Return value 0.
    Action 19:29:49: DuplicateFiles. Creating duplicate files
    Action start 19:29:49: DuplicateFiles.
    Action ended 19:29:49: DuplicateFiles. Return value 1.
    Action 19:29:49: BindImage. Binding executables
    Action start 19:29:49: BindImage.
    Action ended 19:29:49: BindImage. Return value 1.
    Action 19:29:49: CreateShortcuts. Creating shortcuts
    Action start 19:29:49: CreateShortcuts.
    Action ended 19:29:49: CreateShortcuts. Return value 0.
    Action 19:29:49: RegisterClassInfo. Registering class servers
    Action start 19:29:49: RegisterClassInfo.
    Action ended 19:29:49: RegisterClassInfo. Return value 0.
    Action 19:29:49: RegisterExtensionInfo. Registering extension servers
    Action start 19:29:49: RegisterExtensionInfo.
    Action ended 19:29:49: RegisterExtensionInfo. Return value 0.
    Action 19:29:49: RegisterProgIdInfo. Registering program identifiers
    Action start 19:29:49: RegisterProgIdInfo.
    Action ended 19:29:49: RegisterProgIdInfo. Return value 0.
    Action 19:29:49: RegisterMIMEInfo. Registering MIME info
    Action start 19:29:49: RegisterMIMEInfo.
    Action ended 19:29:49: RegisterMIMEInfo. Return value 0.
    Action 19:29:49: WriteRegistryValues. Writing system registry values
    Action start 19:29:49: WriteRegistryValues.
    Action ended 19:29:49: WriteRegistryValues. Return value 1.
    Action 19:29:49: WriteIniValues. Writing INI file values
    Action start 19:29:49: WriteIniValues.
    Action ended 19:29:49: WriteIniValues. Return value 1.
    Action 19:29:49: WriteEnvironmentStrings. Updating environment strings
    Action start 19:29:49: WriteEnvironmentStrings.
    Action ended 19:29:49: WriteEnvironmentStrings. Return value 1.
    Action 19:29:49: RegisterFonts. Registering fonts
    Action start 19:29:49: RegisterFonts.
    Action ended 19:29:49: RegisterFonts. Return value 1.
    Action 19:29:49: InstallODBC. Installing ODBC components
    Action start 19:29:49: InstallODBC.
    Action ended 19:29:49: InstallODBC. Return value 0.
    Action 19:29:49: RegisterTypeLibraries. Registering type libraries
    Action start 19:29:49: RegisterTypeLibraries.
    Action ended 19:29:49: RegisterTypeLibraries. Return value 0.
    Action 19:29:49: SelfRegModules. Registering modules
    Action start 19:29:49: SelfRegModules.
    Action ended 19:29:49: SelfRegModules. Return value 1.
    Action 19:29:49: RegisterComPlus. Registering COM+ Applications and Components
    Action start 19:29:49: RegisterComPlus.
    Action ended 19:29:49: RegisterComPlus. Return value 0.
    Action 19:29:49: InstallServices. Installing new services
    Action start 19:29:49: InstallServices.
    Action ended 19:29:49: InstallServices. Return value 1.
    Action 19:29:49: StartServices. Starting services
    Action start 19:29:49: StartServices.
    Action ended 19:29:49: StartServices. Return value 1.
    Action 19:29:49: RegisterUser. Registering user
    Action start 19:29:49: RegisterUser.
    Action ended 19:29:49: RegisterUser. Return value 0.
    Action 19:29:49: RegisterProduct. Registering product
    Action start 19:29:49: RegisterProduct.
    Registering product
    Action ended 19:29:49: RegisterProduct. Return value 1.
    Action 19:29:49: PublishComponents. Publishing qualified components
    Action start 19:29:49: PublishComponents.
    Action ended 19:29:49: PublishComponents. Return value 0.
    Action 19:29:49: MsiPublishAssemblies. Publishing assembly information
    Action start 19:29:49: MsiPublishAssemblies.
    Action ended 19:29:49: MsiPublishAssemblies. Return value 1.
    Action 19:29:49: PublishFeatures. Publishing product features
    Action start 19:29:49: PublishFeatures.
    Action ended 19:29:49: PublishFeatures. Return value 1.
    Action 19:29:49: PublishProduct. Publishing product information
    Action start 19:29:49: PublishProduct.
    Action ended 19:29:49: PublishProduct. Return value 1.
    Action 19:29:49: InstallFinalize.
    Action start 19:29:49: InstallFinalize.
    20335.msi
    Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8 b3b9a1e18e3b",processorArchitecture="x86",type="win32"
    Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.4137",publicKey Token="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32-polic y"
    Feature: Microsoft_VC90_CRT_x86_
    Action 19:29:49: RollbackCleanup. Removing backup files
    File: C:\Config.Msi\23cf7.rbf
    File: C:\Config.Msi\23cf8.rbf
    Action ended 19:29:49: InstallFinalize. Return value 1.
    Action ended 19:29:49: INSTALL. Return value 1.
    Property(S): UpgradeCode = {0FD62DF3-05EA-44F2-9C45-98FA04CF85DE}
    Property(S): Installed = 2009/07/27 14:12:16
    Property(S): SourcedirProduct = {08D2E121-7F6A-43EB-97FD-629B44903403}
    Property(S): SOURCEDIR = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_CRT_x86\
    Property(S): OriginalDatabase = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
    Property(S): DATABASE = C:\Windows\Installer\23cf3.msi
    Property(S): Time = 19:29:49
    Property(S): VirtualMemory = 3212
    Property(S): SourceDir = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_CRT_x86\
    Property(S): WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B 9_BDB6_3C16D4C5E6B7 = C:\Windows\
    Property(S): SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9 _BDB6_3C16D4C5E6B7 = C:\Windows\system32\
    Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_3 2B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\
    Property(S): payload_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_B DB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4 137_none_508fc1d4bcbb3eca\
    Property(S): payload.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6 _3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4 137_x-ww_d494ac0e\
    Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_3 2B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Manifests\
    Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32 B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\
    Property(S): policydir.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BD B6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x- ww_1742743b\
    Property(S): policydir_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9 _BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_174274 3b\
    Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AA C0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\
    Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_ F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_ 9.0.30729.4137_none_f47d3254f657e518\
    Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC 0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\Policies\
    Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F 91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9 a1e18e3b_x-ww_b7353f75\
    Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0 FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\
    Property(S): ProductCode = {08D2E121-7F6A-43EB-97FD-629B44903403}
    Property(S): ProductName = Microsoft_VC90_CRT_x86
    Property(S): DWUSLINK = CEBCC75FFEEBF7C8BEACA0F8D9CB978FB9FB078FDE8CE0E8CE2BC08F9EAB5058BEDCD 0A8FEAC
    Property(S): PackageCode = {5DB7D0CC-71CB-4DD2-993F-C9E909FA78F0}
    === Logging stopped: 29/03/2010  19:29:49 ===
    1: 2 2: 0
    1: 2 2: 1
    [    3164] Mon Mar 29 19:29:50 2010  INFO
    :: END TIMER :: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}] took 2005.79 miliseconds (2.00579 seconds) DTR = 39.8846 KBPS (0.0389498 MBPS)
    Calling the custom action code for post-install for payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86
    Calling the custom action code for pre-install for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
    ::START TIMER:: [Payload Operation :{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}]
    [    2848] Mon Mar 29 19:29:50 2010  INFO
    Installing payload
    Attempting to install package from:C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
    MsiSourceListAddSource for  C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi is 0
    MsiSourceListSetInfo with updated name: Microsoft_VC90_MFC_x86.msi, Result: 0
    [    2848] Mon Mar 29 19:29:51 2010  INFO
    === Logging started: 29/03/2010  19:29:51 ===
    Message type: 1, Argument: Microsoft_VC90_MFC_x86
    Action 19:29:51: INSTALL.
    Action start 19:29:51: INSTALL.
    Action 19:29:51: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872 _85D9_3C96F6A74B2D.
    Action start 19:29:51: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872 _85D9_3C96F6A74B2D.
    Action ended 19:29:51: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872 _85D9_3C96F6A74B2D. Return value 1.
    Action 19:29:51: AppSearch. Searching for installed applications
    Action start 19:29:51: AppSearch.
    Action ended 19:29:51: AppSearch. Return value 0.
    Action 19:29:51: FindRelatedProducts. Searching for related applications
    Action start 19:29:51: FindRelatedProducts.
    Action ended 19:29:51: FindRelatedProducts. Return value 0.
    Action 19:29:51: ValidateProductID.
    Action start 19:29:51: ValidateProductID.
    Action ended 19:29:51: ValidateProductID. Return value 1.
    Action 19:29:51: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_387 2_85D9_3C96F6A74B2D.
    Action start 19:29:51: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_387 2_85D9_3C96F6A74B2D.
    Action ended 19:29:51: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_387 2_85D9_3C96F6A74B2D. Return value 1.
    Action 19:29:51: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0 F1_7C00_33DE_BBF5_5539993CCCBF.
    Action start 19:29:51: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0 F1_7C00_33DE_BBF5_5539993CCCBF.
    Action ended 19:29:51: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0 F1_7C00_33DE_BBF5_5539993CCCBF. Return value 1.
    Action 19:29:51: CostInitialize. Computing space requirements
    Action start 19:29:51: CostInitialize.
    Action ended 19:29:51: CostInitialize. Return value 1.
    Action 19:29:51: FileCost. Computing space requirements
    Action start 19:29:51: FileCost.
    Action ended 19:29:51: FileCost. Return value 1.
    Action 19:29:51: IsolateComponents.
    Action start 19:29:51: IsolateComponents.
    Action ended 19:29:51: IsolateComponents. Return value 0.
    Action 19:29:51: CostFinalize. Computing space requirements
    Action start 19:29:51: CostFinalize.
    Action ended 19:29:51: CostFinalize. Return value 1.
    Action 19:29:51: SetODBCFolders. Initializing ODBC directories
    Action start 19:29:51: SetODBCFolders.
    Action ended 19:29:51: SetODBCFolders. Return value 0.
    Action 19:29:51: MigrateFeatureStates. Migrating feature states from related applications
    Action start 19:29:51: MigrateFeatureStates.
    Action ended 19:29:51: MigrateFeatureStates. Return value 0.
    Action 19:29:51: InstallValidate. Validating install
    Action start 19:29:51: InstallValidate.
    Action ended 19:29:51: InstallValidate. Return value 1.
    Action 19:29:51: RemoveExistingProducts. Removing applications
    Action start 19:29:51: RemoveExistingProducts.
    Action ended 19:29:51: RemoveExistingProducts. Return value 0.
    Action 19:29:51: InstallInitialize.
    Action start 19:29:51: InstallInitialize.
    [    2848] Mon Mar 29 19:29:52 2010  INFO
    Action ended 19:29:52: InstallInitialize. Return value 1.
    Action 19:29:52: ProcessComponents. Updating component registration
    Action start 19:29:52: ProcessComponents.
    Action 19:29:52: GenerateScript. Generating script operations for action:
    Action ended 19:29:52: ProcessComponents. Return value 1.
    Action 19:29:52: UnpublishComponents. Unpublishing Qualified Components
    Action start 19:29:52: UnpublishComponents.
    Action ended 19:29:52: UnpublishComponents. Return value 0.
    Action 19:29:52: MsiUnpublishAssemblies. Unpublishing assembly information
    Action start 19:29:52: MsiUnpublishAssemblies.
    Action ended 19:29:52: MsiUnpublishAssemblies. Return value 1.
    Action 19:29:52: UnpublishFeatures. Unpublishing product features
    Action start 19:29:52: UnpublishFeatures.
    Action ended 19:29:52: UnpublishFeatures. Return value 1.
    Action 19:29:52: StopServices. Stopping services
    Action start 19:29:52: StopServices.
    Action ended 19:29:52: StopServices. Return value 1.
    Action 19:29:52: DeleteServices. Deleting services
    Action start 19:29:52: DeleteServices.
    Action ended 19:29:52: DeleteServices. Return value 1.
    Action 19:29:52: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 19:29:52: UnregisterComPlus.
    Action ended 19:29:52: UnregisterComPlus. Return value 0.
    Action 19:29:52: SelfUnregModules. Unregistering modules
    Action start 19:29:52: SelfUnregModules.
    Action ended 19:29:52: SelfUnregModules. Return value 1.
    Action 19:29:52: UnregisterTypeLibraries. Unregistering type libraries
    Action start 19:29:52: UnregisterTypeLibraries.
    Action ended 19:29:52: UnregisterTypeLibraries. Return value 0.
    Action 19:29:52: RemoveODBC. Removing ODBC components
    Action start 19:29:52: RemoveODBC.
    Action ended 19:29:52: RemoveODBC. Return value 1.
    Action 19:29:52: UnregisterFonts. Unregistering fonts
    Action start 19:29:52: UnregisterFonts.
    Action ended 19:29:52: UnregisterFonts. Return value 1.
    Action 19:29:52: RemoveRegistryValues. Removing system registry values
    Action start 19:29:52: RemoveRegistryValues.
    Action ended 19:29:52: RemoveRegistryValues. Return value 1.
    Action 19:29:52: UnregisterClassInfo. Unregister class servers
    Action start 19:29:52: UnregisterClassInfo.
    Action ended 19:29:52: UnregisterClassInfo. Return value 0.
    Action 19:29:52: UnregisterExtensionInfo. Unregistering extension servers
    Action start 19:29:52: UnregisterExtensionInfo.
    Action ended 19:29:52: UnregisterExtensionInfo. Return value 0.
    Action 19:29:52: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 19:29:52: UnregisterProgIdInfo.
    Action ended 19:29:52: UnregisterProgIdInfo. Return value 0.
    Action 19:29:52: UnregisterMIMEInfo. Unregistering MIME info
    Action start 19:29:52: UnregisterMIMEInfo.
    Action ended 19:29:52: UnregisterMIMEInfo. Return value 0.
    Action 19:29:52: RemoveIniValues. Removing INI file entries
    Action start 19:29:52: RemoveIniValues.
    Action ended 19:29:52: RemoveIniValues. Return value 1.
    Action 19:29:52: RemoveShortcuts. Removing shortcuts
    Action start 19:29:52: RemoveShortcuts.
    Action ended 19:29:52: RemoveShortcuts. Return value 0.
    Action 19:29:52: RemoveEnvironmentStrings. Updating environment strings
    Action start 19:29:52: RemoveEnvironmentStrings.
    Action ended 19:29:52: RemoveEnvironmentStrings. Return value 1.
    Action 19:29:52: RemoveDuplicateFiles. Removing duplicated files
    Action start 19:29:52: RemoveDuplicateFiles.
    Action ended 19:29:52: RemoveDuplicateFiles. Return value 1.
    Action 19:29:52: RemoveFiles. Removing files
    Action start 19:29:52: RemoveFiles.
    Action ended 19:29:52: RemoveFiles. Return value 0.
    Action 19:29:52: RemoveFolders. Removing folders
    Action start 19:29:52: RemoveFolders.
    Action ended 19:29:52: RemoveFolders. Return value 0.
    Action 19:29:52: CreateFolders. Creating folders
    Action start 19:29:52: CreateFolders.
    Action ended 19:29:52: CreateFolders. Return value 0.
    Action 19:29:52: MoveFiles. Moving files
    Action start 19:29:52: MoveFiles.
    Action ended 19:29:52: MoveFiles. Return value 1.
    Action 19:29:52: InstallFiles. Copying new files
    Action start 19:29:52: InstallFiles.
    Action ended 19:29:52: InstallFiles. Return value 1.
    Action 19:29:52: PatchFiles. Patching files
    Action start 19:29:52: PatchFiles.
    Action ended 19:29:52: PatchFiles. Return value 0.
    Action 19:29:52: DuplicateFiles. Creating duplicate files
    Action start 19:29:52: DuplicateFiles.
    Action ended 19:29:52: DuplicateFiles. Return value 1.
    Action 19:29:52: BindImage. Binding executables
    Action start 19:29:52: BindImage.
    Action ended 19:29:52: BindImage. Return value 1.
    Action 19:29:52: CreateShortcuts. Creating shortcuts
    Action start 19:29:52: CreateShortcuts.
    Action ended 19:29:52: CreateShortcuts. Return value 0.
    Action 19:29:52: RegisterClassInfo. Registering class servers
    Action start 19:29:52: RegisterClassInfo.
    Action ended 19:29:52: RegisterClassInfo. Return value 0.
    Action 19:29:52: RegisterExtensionInfo. Registering extension servers
    Action start 19:29:52: RegisterExtensionInfo.
    Action ended 19:29:52: RegisterExtensionInfo. Return value 0.
    Action 19:29:52: RegisterProgIdInfo. Registering program identifiers
    Action start 19:29:52: RegisterProgIdInfo.
    Action ended 19:29:52: RegisterProgIdInfo. Return value 0.
    Action 19:29:52: RegisterMIMEInfo. Registering MIME info
    Action start 19:29:52: RegisterMIMEInfo.
    Action ended 19:29:52: RegisterMIMEInfo. Return value 0.
    Action 19:29:52: WriteRegistryValues. Writing system registry values
    Action start 19:29:52: WriteRegistryValues.
    Action ended 19:29:52: WriteRegistryValues. Return value 1.
    Action 19:29:52: WriteIniValues. Writing INI file values
    Action start 19:29:52: WriteIniValues.
    Action ended 19:29:52: WriteIniValues. Return value 1.
    Action 19:29:52: WriteEnvironmentStrings. Updating environment strings
    Action start 19:29:52: WriteEnvironmentStrings.
    Action ended 19:29:52: WriteEnvironmentStrings. Return value 1.
    Action 19:29:52: RegisterFonts. Registering fonts
    Action start 19:29:52: RegisterFonts.
    Action ended 19:29:52: RegisterFonts. Return value 1.
    Action 19:29:52: InstallODBC. Installing ODBC components
    Action start 19:29:52: InstallODBC.
    Action ended 19:29:52: InstallODBC. Return value 0.
    Action 19:29:52: RegisterTypeLibraries. Registering type libraries
    Action start 19:29:52: RegisterTypeLibraries.
    Action ended 19:29:52: RegisterTypeLibraries. Return value 0.
    Action 19:29:52: SelfRegModules. Registering modules
    Action start 19:29:52: SelfRegModules.
    Action ended 19:29:52: SelfRegModules. Return value 1.
    Action 19:29:52: RegisterComPlus. Registering COM+ Applications and Components
    Action start 19:29:52: RegisterComPlus.
    Action ended 19:29:52: RegisterComPlus. Return value 0.
    Action 19:29:52: InstallServices. Installing new services
    Action start 19:29:52: InstallServices.
    Action ended 19:29:52: InstallServices. Return value 1.
    Action 19:29:52: StartServices. Starting services
    Action start 19:29:52: StartServices.
    Action ended 19:29:52: StartServices. Return value 1.
    Action 19:29:52: RegisterUser. Registering user
    Action start 19:29:52: RegisterUser.
    Action ended 19:29:52: RegisterUser. Return value 0.
    Action 19:29:52: RegisterProduct. Registering product
    Action start 19:29:52: RegisterProduct.
    Registering product
    Action ended 19:29:52: RegisterProduct. Return value 1.
    Action 19:29:52: PublishComponents. Publishing qualified components
    Action start 19:29:52: PublishComponents.
    Action ended 19:29:52: PublishComponents. Return value 0.
    Action 19:29:52: MsiPublishAssemblies. Publishing assembly information
    Action start 19:29:52: MsiPublishAssemblies.
    Action ended 19:29:52: MsiPublishAssemblies. Return value 1.
    Action 19:29:52: PublishFeatures. Publishing product features
    Action start 19:29:52: PublishFeatures.
    Action ended 19:29:52: PublishFeatures. Return value 1.
    Action 19:29:52: PublishProduct. Publishing product information
    Action start 19:29:52: PublishProduct.
    Action ended 19:29:52: PublishProduct. Return value 1.
    Action 19:29:52: InstallFinalize.
    Action start 19:29:52: InstallFinalize.
    2033c.msi
    Application Context:Global, Assembly Name:Microsoft.VC90.MFC,version="9.0.30729.4137",publicKeyToken="1fc8 b3b9a1e18e3b",processorArchitecture="x86",type="win32"
    Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.MFC,version="9.0.30729.4137",publicKey Token="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32-polic y"
    Feature: Microsoft_VC90_MFC_x86_
    Action 19:29:52: RollbackCleanup. Removing backup files
    File: C:\Config.Msi\23cfe.rbf
    File: C:\Config.Msi\23cff.rbf
    Action ended 19:29:52: InstallFinalize. Return value 1.
    Action ended 19:29:52: INSTALL. Return value 1.
    Property(S): UpgradeCode = {7534F528-4E84-4BFB-A8F2-BBD75974F28F}
    Property(S): Installed = 2009/07/27 14:13:22
    Property(S): SourcedirProduct = {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
    Property(S): SOURCEDIR = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_MFC_x86\
    Property(S): OriginalDatabase = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
    Property(S): DATABASE = C:\Windows\Installer\23cfa.msi
    Property(S): Time = 19:29:52
    Property(S): VirtualMemory = 3211
    Property(S): SourceDir = C:\development\Adobe Flash Builder 4 Standalone\payloads\Microsoft_VC90_MFC_x86\
    Property(S): WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_387 2_85D9_3C96F6A74B2D = C:\Windows\
    Property(S): SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872 _85D9_3C96F6A74B2D = C:\Windows\system32\
    Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3 872_85D9_3C96F6A74B2D = C:\Windows\winsxs\
    Property(S): payload_ul.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_8 5D9_3C96F6A74B2D = C:\Windows\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.4 137_none_4bf45688bf9e2dbf\
    Property(S): payload.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9 _3C96F6A74B2D = C:\Windows\winsxs\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.4 137_x-ww_a57b1f13\
    Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3 872_85D9_3C96F6A74B2D = C:\Windows\winsxs\Manifests\
    Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_38 72_85D9_3C96F6A74B2D = C:\Windows\winsxs\Policies\
    Property(S): policydir.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85 D9_3C96F6A74B2D = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x- ww_aef5eff6\
    Property(S): policydir_ul.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872 _85D9_3C96F6A74B2D = C:\Windows\winsxs\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aef5ef f6\
    Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400 D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\
    Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_ 7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.mfc_1fc8b3b9a1e18e3b_ 9.0.30729.4137_none_ecfe4c8afb2661fb\
    Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D 0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\Policies\
    Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7 C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.MFC_1fc8b3b9 a1e18e3b_x-ww_4ee8bb30\
    Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0 F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\
    Property(S): ProductCode = {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
    Property(S): ProductName = Microsoft_VC90_MFC_x86
    Property(S): DWUSLINK = CEDCD08F9EDBA7DF5EAC87CFDEDB978F8EABA08FCEECA7AFCEFCA0AFF9DBF78FB9ABA 7F819AC
    Property(S): PackageCode = {FCC5DFDD-8D3B-457A-9232-4D938A966CD6}
    === Logging stopped: 29/03/2010  19:29:52 ===
    1: 2 2: 0
    1: 2 2: 1
    [    3164] Mon Mar 29 19:29:53 2010  INFO
    :: END TIMER :: [Payload Operation :{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}] took 3012.27 miliseconds (3.01227 seconds) DTR = 7.96742 KBPS (0.00778068 MBPS)
    Calling the custom action code for post-install for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86
    Calling the custom action code for pre-install for payload {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE}
    ::START TIMER:: [Payload Operation :{3423F36D-004F-4DFC-8BCE-07A20B8DFBDE}]
    [    2756] Mon Mar 29 19:29:53 2010  INFO
    Installer Operation: PayloadInstaller
    Request to install payload
    Extracting assets...
    [    2756] Mon Mar 29 19:29:54 2010  INFO
    Extracting assets complete. Number assets: 1
    Beginning installation for payload at C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
    Evaluating condition# 1
    Condition failed
    Completing installation for payload at C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
    [    2756] Mon Mar 29 19:29:55 2010  INFO
    UninstallDBPath=C:\Program Files\Common Files\Adobe\Installers\uninstall\{3423F36D-004F-4DFC-8BCE-07A20B8DFBD E}.db
    [    3164] Mon Mar 29 19:29:55 2010  INFO
    *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
    :: END TIMER :: [Payload Operation :{3423F36D-004F-4DFC-8BCE-07A20B8DFBDE}] took 2010.99 miliseconds (2.01099 seconds) DTR = 3246.16 KBPS (3.17008 MBPS)
    [    3164] Mon Mar 29 19:29:56 2010  INFO
    Calling the custom action code for post-install for payload {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5
    Calling the custom action code for pre-install for payload {5EE868D6-7B6B-49ee-AF60-09B1358AFFD7}
    ::START TIMER:: [Payload Operation :{5EE868D6-7B6B-49ee-AF60-09B1358AFFD7}]
    [    2856] Mon Mar 29 19:29:56 2010  INFO
    Installing payload
    Attempting to install package from:C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_axDbg_mul\AdobeFlashPlayer10_a xDbg_mul.msi
    MsiSourceListAddSource for  C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_axDbg_mul\AdobeFlashPlayer10_a xDbg_mul.msi is 0
    MsiSourceListSetInfo with updated name: AdobeFlashPlayer10_axDbg_mul.msi, Result: 0
    Command line arguments:  /UILevel=2  REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
    [    2856] Mon Mar 29 19:29:57 2010  INFO
    === Logging started: 29/03/2010  19:29:57 ===
    Message type: 1, Argument: Adobe Flash Player 10 ActiveX
    Action 19:29:57: INSTALL.
    Action start 19:29:57: INSTALL.
    Action 19:29:57: AppSearch. Searching for installed applications
    Action start 19:29:57: AppSearch.
    Action ended 19:29:57: AppSearch. Return value 0.
    Action 19:29:57: LaunchConditions. Evaluating launch conditions
    Action start 19:29:57: LaunchConditions.
    Action ended 19:29:57: LaunchConditions. Return value 1.
    Action 19:29:57: FindRelatedProducts. Searching for related applications
    Action start 19:29:57: FindRelatedProducts.
    Action ended 19:29:57: FindRelatedProducts. Return value 0.
    Action 19:29:57: ValidateProductID.
    Action start 19:29:57: ValidateProductID.
    Action ended 19:29:57: ValidateProductID. Return value 1.
    Action 19:29:57: CostInitialize. Computing space requirements
    Action start 19:29:57: CostInitialize.
    Action ended 19:29:57: CostInitialize. Return value 1.
    Action 19:29:57: FileCost. Computing space requirements
    Action start 19:29:57: FileCost.
    Action ended 19:29:57: FileCost. Return value 1.
    Action 19:29:57: IsolateComponents.
    Action start 19:29:57: IsolateComponents.
    Action ended 19:29:57: IsolateComponents. Return value 0.
    Action 19:29:57: CostFinalize. Computing space requirements
    Action start 19:29:57: CostFinalize.
    [    2856] Mon Mar 29 19:29:58 2010  INFO
    Action ended 19:29:58: CostFinalize. Return value 1.
    Action 19:29:58: SetODBCFolders. Initializing ODBC directories
    Action start 19:29:58: SetODBCFolders.
    Action ended 19:29:58: SetODBCFolders. Return value 0.
    Action 19:29:58: MigrateFeatureStates. Migrating feature states from related applications
    Action start 19:29:58: MigrateFeatureStates.
    Action ended 19:29:58: MigrateFeatureStates. Return value 0.
    Action 19:29:58: InstallValidate. Validating install
    Action start 19:29:58: InstallValidate.
    Action ended 19:29:58: InstallValidate. Return value 1.
    Action 19:29:58: RemoveExistingProducts. Removing applications
    Action start 19:29:58: RemoveExistingProducts.
    Action ended 19:29:58: RemoveExistingProducts. Return value 0.
    Action 19:29:58: InstallInitialize.
    Action start 19:29:58: InstallInitialize.
    [    2856] Mon Mar 29 19:29:59 2010  INFO
    Action ended 19:29:59: InstallInitialize. Return value 1.
    Action 19:29:59: MakePropsAvailable.
    Action start 19:29:59: MakePropsAvailable.
    Action ended 19:29:59: MakePropsAvailable. Return value 1.
    Action 19:29:59: ProcessComponents. Updating component registration
    Action start 19:29:59: ProcessComponents.
    Action 19:29:59: GenerateScript. Generating script operations for action:
    Action ended 19:29:59: ProcessComponents. Return value 1.
    Action 19:29:59: UnpublishComponents. Unpublishing Qualified Components
    Action start 19:29:59: UnpublishComponents.
    Action ended 19:29:59: UnpublishComponents. Return value 0.
    Action 19:29:59: UnpublishFeatures. Unpublishing product features
    Action start 19:29:59: UnpublishFeatures.
    Action ended 19:29:59: UnpublishFeatures. Return value 1.
    Action 19:29:59: StopServices. Stopping services
    Action start 19:29:59: StopServices.
    Action ended 19:29:59: StopServices. Return value 1.
    Action 19:29:59: DeleteServices. Deleting services
    Action start 19:29:59: DeleteServices.
    Action ended 19:29:59: DeleteServices. Return value 1.
    Action 19:29:59: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 19:29:59: UnregisterComPlus.
    Action ended 19:29:59: UnregisterComPlus. Return value 0.
    Action 19:29:59: SelfUnregModules. Unregistering modules
    Action start 19:29:59: SelfUnregModules.
    Action ended 19:29:59: SelfUnregModules. Return value 1.
    Action 19:29:59: UnregisterTypeLibraries. Unregistering type libraries
    Action start 19:29:59: UnregisterTypeLibraries.
    Action ended 19:29:59: UnregisterTypeLibraries. Return value 0.
    Action 19:29:59: RemoveODBC. Removing ODBC components
    Action start 19:29:59: RemoveODBC.
    Action ended 19:29:59: RemoveODBC. Return value 1.
    Action 19:29:59: UnregisterFonts. Unregistering fonts
    Action start 19:29:59: UnregisterFonts.
    Action ended 19:29:59: UnregisterFonts. Return value 1.
    Action 19:29:59: RemoveRegistryValues. Removing system registry values
    Action start 19:29:59: RemoveRegistryValues.
    Action ended 19:29:59: RemoveRegistryValues. Return value 1.
    Action 19:29:59: UnregisterClassInfo. Unregister class servers
    Action start 19:29:59: UnregisterClassInfo.
    Action ended 19:29:59: UnregisterClassInfo. Return value 0.
    Action 19:29:59: UnregisterExtensionInfo. Unregistering extension servers
    Action start 19:29:59: UnregisterExtensionInfo.
    Action ended 19:29:59: UnregisterExtensionInfo. Return value 0.
    Action 19:29:59: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 19:29:59: UnregisterProgIdInfo.
    Action ended 19:29:59: UnregisterProgIdInfo. Return value 0.
    Action 19:29:59: UnregisterMIMEInfo. Unregistering MIME info
    Action start 19:29:59: UnregisterMIMEInfo.
    Action ended 19:29:59: UnregisterMIMEInfo. Return value 0.
    Action 19:29:59: RemoveIniValues. Removing INI file entries
    Action start 19:29:59: RemoveIniValues.
    Action ended 19:29:59: RemoveIniValues. Return value 1.
    Action 19:29:59: RemoveShortcuts. Removing shortcuts
    Action start 19:29:59: RemoveShortcuts.
    Action ended 19:29:59: RemoveShortcuts. Return value 0.
    Action 19:29:59: RemoveEnvironmentStrings. Updating environment strings
    Action start 19:29:59: RemoveEnvironmentStrings.
    Action ended 19:29:59: RemoveEnvironmentStrings. Return value 1.
    Action 19:29:59: RemoveDuplicateFiles. Removing duplicated files
    Action start 19:29:59: RemoveDuplicateFiles.
    Action ended 19:29:59: RemoveDuplicateFiles. Return value 1.
    Action 19:29:59: RemoveFolders. Removing folders
    Action start 19:29:59: RemoveFolders.
    Action ended 19:29:59: RemoveFolders. Return value 1.
    Action 19:29:59: CreateFolders. Creating folders
    Action start 19:29:59: CreateFolders.
    Folder: Creating folders
    Action ended 19:29:59: CreateFolders. Return value 1.
    Action 19:29:59: MoveFiles. Moving files
    Action start 19:29:59: MoveFiles.
    Action ended 19:29:59: MoveFiles. Return value 1.
    Action 19:29:59: InstallFiles. Copying new files
    Action start 19:29:59: InstallFiles.
    Action ended 19:29:59: InstallFiles. Return value 1.
    Action 19:29:59: PatchFiles. Patching files
    Action start 19:29:59: PatchFiles.
    Action ended 19:29:59: PatchFiles. Return value 0.
    Action 19:29:59: DuplicateFiles. Creating duplicate files
    Action start 19:29:59: DuplicateFiles.
    Action ended 19:29:59: DuplicateFiles. Return value 1.
    Action 19:29:59: BindImage. Binding executables
    Action start 19:29:59: BindImage.
    Action ended 19:29:59: BindImage. Return value 1.
    Action 19:29:59: CreateShortcuts. Creating shortcuts
    Action start 19:29:59: CreateShortcuts.
    Action ended 19:29:59: CreateShortcuts. Return value 0.
    Action 19:29:59: RegisterClassInfo. Registering class servers
    Action start 19:29:59: RegisterClassInfo.
    Action ended 19:29:59: RegisterClassInfo. Return value 0.
    Action 19:29:59: RegisterExtensionInfo. Registering extension servers
    Action start 19:29:59: RegisterExtensionInfo.
    Action ended 19:29:59: RegisterExtensionInfo. Return value 0.
    Action 19:29:59: RegisterProgIdInfo. Registering program identifiers
    Action start 19:29:59: RegisterProgIdInfo.
    Action ended 19:29:59: RegisterProgIdInfo. Return value 0.
    Action 19:29:59: RegisterMIMEInfo. Registering MIME info
    Action start 19:29:59: RegisterMIMEInfo.
    Action ended 19:29:59: RegisterMIMEInfo. Return value 0.
    Action 19:29:59: WriteRegistryValues. Writing system registry values
    Action start 19:29:59: WriteRegistryValues.
    Key: Writing system registry values, Name: , Value:
    Action ended 19:29:59: WriteRegistryValues. Return value 1.
    Action 19:29:59: WriteIniValues. Writing INI file values
    Action start 19:29:59: WriteIniValues.
    Action ended 19:29:59: WriteIniValues. Return value 1.
    Action 19:29:59: WriteEnvironmentStrings. Updating environment strings
    Action start 19:29:59: WriteEnvironmentStrings.
    Action ended 19:29:59: WriteEnvironmentStrings. Return value 1.
    Action 19:29:59: RegisterFonts. Registering fonts
    Action start 19:29:59: RegisterFonts.
    Action ended 19:29:59: RegisterFonts. Return value 1.
    Action 19:29:59: InstallODBC. Installing ODBC components
    Action start 19:29:59: InstallODBC.
    Action ended 19:29:59: InstallODBC. Return value 0.
    Action 19:29:59: RegisterTypeLibraries. Registering type libraries
    Action start 19:29:59: RegisterTypeLibraries.
    Action ended 19:29:59: RegisterTypeLibraries. Return value 0.
    Action 19:29:59: SelfRegModules. Registering modules
    Action start 19:29:59: SelfRegModules.
    Action ended 19:29:59: SelfRegModules. Return value 1.
    Action 19:29:59: RegisterComPlus. Registering COM+ Applications and Components
    Action start 19:29:59: RegisterComPlus.
    Action ended 19:29:59: RegisterComPlus. Return value 0.
    Action 19:29:59: InstallServices. Installing new services
    Action start 19:29:59: InstallServices.
    Action ended 19:29:59: InstallServices. Return value 1.
    Action 19:29:59: StartServices. Starting services
    Action start 19:29:59: StartServices.
    Action ended 19:29:59: StartServices. Return value 1.
    Action 19:29:59: RegisterUser. Registering user
    Action start 19:29:59: RegisterUser.
    Action ended 19:29:59: RegisterUser. Return value 0.
    Action 19:29:59: RegisterProduct. Registering product
    Action start 19:29:59: RegisterProduct.
    Registering product
    Action ended 19:29:59: RegisterProduct. Return value 1.
    Action 19:29:59: PublishComponents. Publishing qualified components
    Action start 19:29:59: PublishComponents.
    Action ended 19:29:59: PublishComponents. Return value 0.
    Action 19:29:59: PublishFeatures. Publishing product features
    Action start 19:29:59: PublishFeatures.
    Action ended 19:29:59: PublishFeatures. Return value 1.
    Action 19:29:59: PublishProduct. Publishing product information
    Action start 19:29:59: PublishProduct.
    Action ended 19:29:59: PublishProduct. Return value 1.
    Action 19:29:59: InstallFinalize.
    Action start 19:29:59: InstallFinalize.
    Folder: C:\Windows\system32\Macromed\Flash\
    File: FP_AX_MSI_INSTALLER.exe,  Directory: C:\Users\M@RCELO\AppData\Local\Temp\,  Size: 2168264
    Key: \Software\Macromedia\FlashPlayer, Name: , Value:
    Key: \Software\Macromedia\FlashPlayer, Name: FlashPlayerVersion, Value: 10.0.45.2
    20343.msi
    {20B3FD5B-A987-406B-A5B5-CDE3CA1EF4E1}
    Feature: FlashPlayerAXInstaller
    Action 19:29:59: RollbackCleanup. Removing backup files
    File: C:\Config.Msi\23d05.rbf
    File: C:\Config.Msi\23d06.rbf
    File: C:\Config.Msi\23d07.rbf
    Action ended 19:29:59: InstallFinalize. Return value 1.
    Action ended 19:29:59: INSTALL. Return value 1.
    Property(S): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
    Property(S): Installed = 2010/01/26 14:03:22
    Property(S): SourcedirProduct = {20B3FD5B-A987-406B-A5B5-CDE3CA1EF4E1}
    Property(S): SOURCEDIR = C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_axDbg_mul\
    Property(S): C__ = C:\C__\
    Property(S): C__windows_system32_Macromed_Flash_ = C:\C__windows_system32_Macromed_Flash_\
    Property(S): MACROMED = C:\Windows\system32\Macromed\
    Property(S): FLASH = C:\Windows\system32\Macromed\Flash\
    Property(S): INSTALLDIR = C:\Windows\system32\Macromed\Flash\
    Property(S): ISYourCompanyDir = C:\Program Files\Your Company Name\
    Property(S): ISYourProductDir = C:\Program Files\Your Company Name\Your Product Name\
    Property(S): NEW_DIRECTORY1 = C:\NEW_DIRECTORY1\
    Property(S): SourceDir = C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_axDbg_mul\
    Property(S): _INSTALLDIR_ = C:\_INSTALLDIR_\
    Property(S): _INSTALLDIR_1 = C:\_INSTALLDIR_1\
    Property(S): _SystemFolder_ = C:\_SystemFolder_\
    Property(S): _SystemFolder_1 = C:\_SystemFolder_1\
    Property(S): _SystemFolder__Macromed_Flash_UninstFl.exe = C:\_SystemFolder__Macromed_Flash_UninstFl.exe\
    Property(S): OriginalDatabase = C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_axDbg_mul\AdobeFlashPlayer10_a xDbg_mul.msi
    Property(S): DATABASE = C:\Windows\Installer\23d01.msi
    Property(S): ProductName = Adobe Flash Player 10 ActiveX
    Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
    Property(S): ARPNOMODIFY = 1
    Property(S): ARPURLINFOABOUT = http://www.adobe.com
    Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE 08FD9AC
    Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine.  If available, please run ISScript.msi, or contact your support personnel for further assistance.
    Property(S): Manufacturer = Adobe Systems, Inc.
    Property(S): MsiLogging = voicewarmupx
    Property(S): NewProperty2 = 0
    Property(S): NewProperty3 = 0
    Property(S): ProductCode = {20B3FD5B-A987-406B-A5B5-CDE3CA1EF4E1}
    Property(S): ProductVersion = 10.0.45.2
    Property(S): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;ISACTIONPROP4
    Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
    Property(S): RemoveFilesCA = C:\Windows\system32\Macromed\Flash\
    Property(S): Time = 19:29:59
    Property(S): VirtualMemory = 3237
    Property(S): VersionDatabase = 110
    Property(S): /UILEVEL = 2
    Property(S): PackageCode = {44D0BEEB-41B4-4E02-BEB3-DDBD58851AD3}
    Property(S): MsiLogFileLocation = C:\Users\M@RCELO\AppData\Local\Temp\MSI2ae29.LOG
    === Logging stopped: 29/03/2010  19:29:59 ===
    1: 2 2: 0
    1: 2 2: 1
    [    3164] Mon Mar 29 19:30:00 2010  INFO
    :: END TIMER :: [Payload Operation :{5EE868D6-7B6B-49ee-AF60-09B1358AFFD7}] took 4010.36 miliseconds (4.01036 seconds) DTR = 57.8502 KBPS (0.0564943 MBPS)
    [    3164] Mon Mar 29 19:30:01 2010  INFO
    Calling the custom action code for post-install for payload {5EE868D6-7B6B-49ee-AF60-09B1358AFFD7} Adobe Flash Player 10 ActiveX
    Calling the custom action code for pre-install for payload {FB7F30B6-BFBF-4d2c-9F61-B5533659ACBE}
    ::START TIMER:: [Payload Operation :{FB7F30B6-BFBF-4d2c-9F61-B5533659ACBE}]
    [    3348] Mon Mar 29 19:30:01 2010  INFO
    Installer Operation: InstallThirdPartyPayloadOperation
    Installing third party payload
    Installing payload
    Attempting to install package from:C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_plDbg_mul\AdobeFlashPlayer10_p lDbg_mul.msi
    Payload is already installed with MSI
    MsiSourceListAddSource for  C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_plDbg_mul\AdobeFlashPlayer10_p lDbg_mul.msi is 0
    MsiSourceListSetInfo with updated name: AdobeFlashPlayer10_plDbg_mul.msi, Result: 0
    Payload source is not removable so not updating media info
    Command line arguments:  UILevel=2  REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
    1: 0 2: 1033 3: 1252
    === Logging started: 29/03/2010  19:30:01 ===
    Message type: 1, Argument: Adobe Flash Player 10 Plugin
    Action 19:30:01: INSTALL.
    Action start 19:30:01: INSTALL.
    Action 19:30:01: AppSearch. Searching for installed applications
    Action start 19:30:01: AppSearch.
    Action ended 19:30:01: AppSearch. Return value 0.
    Action 19:30:01: LaunchConditions. Evaluating launch conditions
    Action start 19:30:01: LaunchConditions.
    Action ended 19:30:01: LaunchConditions. Return value 1.
    Action 19:30:01: FindRelatedProducts. Searching for related applications
    Action start 19:30:01: FindRelatedProducts.
    Action ended 19:30:01: FindRelatedProducts. Return value 0.
    Action 19:30:01: ValidateProductID.
    Action start 19:30:01: ValidateProductID.
    Action ended 19:30:01: ValidateProductID. Return value 1.
    Action 19:30:01: CostInitialize. Computing space requirements
    Action start 19:30:01: CostInitialize.
    Action ended 19:30:01: CostInitialize. Return value 1.
    Action 19:30:01: FileCost. Computing space requirements
    Action start 19:30:01: FileCost.
    Action ended 19:30:01: FileCost. Return value 1.
    Action 19:30:01: IsolateComponents.
    Action start 19:30:01: IsolateComponents.
    Action ended 19:30:01: IsolateComponents. Return value 0.
    Action 19:30:01: CostFinalize. Computing space requirements
    Action start 19:30:01: CostFinalize.
    [    3348] Mon Mar 29 19:30:02 2010  INFO
    Action ended 19:30:02: CostFinalize. Return value 1.
    Action 19:30:02: SetODBCFolders. Initializing ODBC directories
    Action start 19:30:02: SetODBCFolders.
    Action ended 19:30:02: SetODBCFolders. Return value 0.
    Action 19:30:02: MigrateFeatureStates. Migrating feature states from related applications
    Action start 19:30:02: MigrateFeatureStates.
    Action ended 19:30:02: MigrateFeatureStates. Return value 0.
    Action 19:30:02: InstallValidate. Validating install
    Action start 19:30:02: InstallValidate.
    Action ended 19:30:02: InstallValidate. Return value 1.
    Action 19:30:02: RemoveExistingProducts. Removing applications
    Action start 19:30:02: RemoveExistingProducts.
    Action ended 19:30:02: RemoveExistingProducts. Return value 0.
    Action 19:30:02: InstallInitialize.
    Action start 19:30:02: InstallInitialize.
    [    3348] Mon Mar 29 19:30:03 2010  INFO
    Action ended 19:30:03: InstallInitialize. Return value 1.
    Action 19:30:03: MakePropsAvailable.
    Action start 19:30:03: MakePropsAvailable.
    Action ended 19:30:03: MakePropsAvailable. Return value 1.
    Action 19:30:03: ProcessComponents. Updating component registration
    Action start 19:30:03: ProcessComponents.
    Action 19:30:03: GenerateScript. Generating script operations for action:
    Action ended 19:30:03: ProcessComponents. Return value 1.
    Action 19:30:03: UnpublishComponents. Unpublishing Qualified Components
    Action start 19:30:03: UnpublishComponents.
    Action ended 19:30:03: UnpublishComponents. Return value 0.
    Action 19:30:03: UnpublishFeatures. Unpublishing product features
    Action start 19:30:03: UnpublishFeatures.
    Action ended 19:30:03: UnpublishFeatures. Return value 1.
    Action 19:30:03: StopServices. Stopping services
    Action start 19:30:03: StopServices.
    Action ended 19:30:03: StopServices. Return value 1.
    Action 19:30:03: DeleteServices. Deleting services
    Action start 19:30:03: DeleteServices.
    Action ended 19:30:03: DeleteServices. Return value 1.
    Action 19:30:03: UnregisterComPlus. Unregistering COM+ Applications and Components
    Action start 19:30:03: UnregisterComPlus.
    Action ended 19:30:03: UnregisterComPlus. Return value 0.
    Action 19:30:03: SelfUnregModules. Unregistering modules
    Action start 19:30:03: SelfUnregModules.
    Action ended 19:30:03: SelfUnregModules. Return value 1.
    Action 19:30:03: UnregisterTypeLibraries. Unregistering type libraries
    Action start 19:30:03: UnregisterTypeLibraries.
    Action ended 19:30:03: UnregisterTypeLibraries. Return value 0.
    Action 19:30:03: RemoveODBC. Removing ODBC components
    Action start 19:30:03: RemoveODBC.
    Action ended 19:30:03: RemoveODBC. Return value 1.
    Action 19:30:03: UnregisterFonts. Unregistering fonts
    Action start 19:30:03: UnregisterFonts.
    Action ended 19:30:03: UnregisterFonts. Return value 1.
    Action 19:30:03: RemoveRegistryValues. Removing system registry values
    Action start 19:30:03: RemoveRegistryValues.
    Action ended 19:30:03: RemoveRegistryValues. Return value 1.
    Action 19:30:03: UnregisterClassInfo. Unregister class servers
    Action start 19:30:03: UnregisterClassInfo.
    Action ended 19:30:03: UnregisterClassInfo. Return value 0.
    Action 19:30:03: UnregisterExtensionInfo. Unregistering extension servers
    Action start 19:30:03: UnregisterExtensionInfo.
    Action ended 19:30:03: UnregisterExtensionInfo. Return value 0.
    Action 19:30:03: UnregisterProgIdInfo. Unregistering program identifiers
    Action start 19:30:03: UnregisterProgIdInfo.
    Action ended 19:30:03: UnregisterProgIdInfo. Return value 0.
    Action 19:30:03: UnregisterMIMEInfo. Unregistering MIME info
    Action start 19:30:03: UnregisterMIMEInfo.
    Action ended 19:30:03: UnregisterMIMEInfo. Return value 0.
    Action 19:30:03: RemoveIniValues. Removing INI file entries
    Action start 19:30:03: RemoveIniValues.
    Action ended 19:30:03: RemoveIniValues. Return value 1.
    Action 19:30:03: RemoveShortcuts. Removing shortcuts
    Action start 19:30:03: RemoveShortcuts.
    Action ended 19:30:03: RemoveShortcuts. Return value 0.
    Action 19:30:03: RemoveEnvironmentStrings. Updating environment strings
    Action start 19:30:03: RemoveEnvironmentStrings.
    Action ended 19:30:03: RemoveEnvironmentStrings. Return value 1.
    Action 19:30:03: RemoveDuplicateFiles. Removing duplicated files
    Action start 19:30:03: RemoveDuplicateFiles.
    Action ended 19:30:03: RemoveDuplicateFiles. Return value 1.
    Action 19:30:03: RemoveFolders. Removing folders
    Action start 19:30:03: RemoveFolders.
    Action ended 19:30:03: RemoveFolders. Return value 1.
    Action 19:30:03: CreateFolders. Creating folders
    Action start 19:30:03: CreateFolders.
    Action ended 19:30:03: CreateFolders. Return value 1.
    Action 19:30:03: MoveFiles. Moving files
    Action start 19:30:03: MoveFiles.
    Action ended 19:30:03: MoveFiles. Return value 1.
    Action 19:30:03: InstallFiles. Copying new files
    Action start 19:30:03: InstallFiles.
    File: Copying new files,  Directory: ,  Size:
    Action ended 19:30:03: InstallFiles. Return value 1.
    Action 19:30:03: PatchFiles. Patching files
    Action start 19:30:03: PatchFiles.
    Action ended 19:30:03: PatchFiles. Return value 0.
    Action 19:30:03: DuplicateFiles. Creating duplicate files
    Action start 19:30:03: DuplicateFiles.
    Action ended 19:30:03: DuplicateFiles. Return value 1.
    Action 19:30:03: BindImage. Binding executables
    Action start 19:30:03: BindImage.
    Action ended 19:30:03: BindImage. Return value 1.
    Action 19:30:03: CreateShortcuts. Creating shortcuts
    Action start 19:30:03: CreateShortcuts.
    Shortcut: Creating shortcuts
    Action ended 19:30:03: CreateShortcuts. Return value 0.
    Action 19:30:03: RegisterClassInfo. Registering class servers
    Action start 19:30:03: RegisterClassInfo.
    Action ended 19:30:03: RegisterClassInfo. Return value 0.
    Action 19:30:03: RegisterExtensionInfo. Registering extension servers
    Action start 19:30:03: RegisterExtensionInfo.
    Action ended 19:30:03: RegisterExtensionInfo. Return value 0.
    Action 19:30:03: RegisterProgIdInfo. Registering program identifiers
    Action start 19:30:03: RegisterProgIdInfo.
    Action ended 19:30:03: RegisterProgIdInfo. Return value 0.
    Action 19:30:03: RegisterMIMEInfo. Registering MIME info
    Action start 19:30:03: RegisterMIMEInfo.
    Action ended 19:30:03: RegisterMIMEInfo. Return value 0.
    Action 19:30:03: WriteRegistryValues. Writing system registry values
    Action start 19:30:03: WriteRegistryValues.
    Action ended 19:30:03: WriteRegistryValues. Return value 1.
    Action 19:30:03: WriteIniValues. Writing INI file values
    Action start 19:30:03: WriteIniValues.
    Action ended 19:30:03: WriteIniValues. Return value 1.
    Action 19:30:03: WriteEnvironmentStrings. Updating environment strings
    Action start 19:30:03: WriteEnvironmentStrings.
    Action ended 19:30:03: WriteEnvironmentStrings. Return value 1.
    Action 19:30:03: RegisterFonts. Registering fonts
    Action start 19:30:03: RegisterFonts.
    Action ended 19:30:03: RegisterFonts. Return value 1.
    Action 19:30:03: InstallODBC. Installing ODBC components
    Action start 19:30:03: InstallODBC.
    Action ended 19:30:03: InstallODBC. Return value 0.
    Action 19:30:03: RegisterTypeLibraries. Registering type libraries
    Action start 19:30:03: RegisterTypeLibraries.
    Action ended 19:30:03: RegisterTypeLibraries. Return value 0.
    Action 19:30:03: SelfRegModules. Registering modules
    Action start 19:30:03: SelfRegModules.
    Action ended 19:30:03: SelfRegModules. Return value 1.
    Action 19:30:03: RegisterComPlus. Registering COM+ Applications and Components
    Action start 19:30:03: RegisterComPlus.
    Action ended 19:30:03: RegisterComPlus. Return value 0.
    Action 19:30:03: InstallServices. Installing new services
    Action start 19:30:03: InstallServices.
    Action ended 19:30:03: InstallServices. Return value 1.
    Action 19:30:03: StartServices. Starting services
    Action start 19:30:03: StartServices.
    Action ended 19:30:03: StartServices. Return value 1.
    Action 19:30:03: RegisterUser. Registering user
    Action start 19:30:03: RegisterUser.
    Action ended 19:30:03: RegisterUser. Return value 0.
    Action 19:30:03: RegisterProduct. Registering product
    Action start 19:30:03: RegisterProduct.
    Registering product
    Action ended 19:30:03: RegisterProduct. Return value 1.
    Action 19:30:03: PublishComponents. Publishing qualified components
    Action start 19:30:03: PublishComponents.
    Action ended 19:30:03: PublishComponents. Return value 0.
    Action 19:30:03: PublishFeatures. Publishing product features
    Action start 19:30:03: PublishFeatures.
    Feature: Publishing product features
    Action ended 19:30:03: PublishFeatures. Return value 1.
    Action 19:30:03: PublishProduct. Publishing product information
    Action start 19:30:03: PublishProduct.
    Action ended 19:30:03: PublishProduct. Return value 1.
    Action 19:30:03: InstallFinalize.
    Action start 19:30:03: InstallFinalize.
    File: FP_PL_MSI_INSTALLER.exe,  Directory: C:\Users\M@RCELO\AppData\Local\Temp\,  Size: 2135667
    Shortcut: ARPPRODUCTICON.exe
    2034a.msi
    {903BE60B-0336-40A0-9024-6D980D1452C2}
    Message type: 2, Argument: 0
    Action 19:30:03: RollbackCleanup. Removing backup files
    File: C:\Config.Msi\23d0d.rbf
    File: C:\Config.Msi\23d0e.rbf
    File: C:\Config.Msi\23d0f.rbf
    Message type: 2, Argument: 1
    Action ended 19:30:03: InstallFinalize. Return value 1.
    Action ended 19:30:03: INSTALL. Return value 1.
    Property(S): DiskPrompt = [1]
    Property(S): UpgradeCode = {D85A1A59-DC52-4D13-9445-EF3F379D4DB5}
    Property(S): Installed = 2010/01/26 14:05:02
    Property(S): SourcedirProduct = {903BE60B-0336-40A0-9024-6D980D1452C2}
    Property(S): SOURCEDIR = C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_plDbg_mul\
    Property(S): PrimaryVolumeSpaceRemaining = 0
    Property(S): PrimaryVolumeSpaceRequired = 0
    Property(S): PrimaryVolumeSpaceAvailable = 0
    Property(S): OutOfNoRbDiskSpace = 0
    Property(S): OutOfDiskSpace = 0
    Property(S): CostingComplete = 1
    Property(S): VersionNT = 601
    Property(S): TARGETDIR = C:\
    Property(S): ALLUSERSPROFILE = C:\
    Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
    Property(S): AppDataFolder = C:\Users\M@RCELO\AppData\Roaming\
    Property(S): CommonAppDataFolder = C:\ProgramData\
    Property(S): CommonFiles64Folder = C:\
    Property(S): CommonFilesFolder = C:\Program Files\Common Files\
    Property(S): DesktopFolder = C:\Users\Public\Desktop\
    Property(S): FavoritesFolder = C:\Users\M@RCELO\Favorites\
    Property(S): FontsFolder = C:\Windows\Fonts\
    Property(S): GlobalAssemblyCache = C:\
    Property(S): ISCommonFilesFolder = C:\Program Files\Common Files\InstallShield\
    Property(S): ISUpdateServiceFolder = C:\Program Files\Common Files\InstallShield\UpdateService\
    Property(S): ProgramFilesFolder = C:\Program Files\
    Property(S): LocalAppDataFolder = C:\Users\M@RCELO\AppData\Local\
    Property(S): SystemFolder = C:\Windows\system32\
    Property(S): MyPicturesFolder = C:\Users\M@RCELO\Pictures\
    Property(S): PersonalFolder = C:\Users\M@RCELO\Documents\
    Property(S): PrimaryVolumePath = C:\
    Property(S): ProgramFiles64Folder = C:\
    Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
    Property(S): SendToFolder = C:\Users\M@RCELO\AppData\Roaming\Microsoft\Windows\SendTo\
    Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
    Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
    Property(S): System16Folder = C:\Windows\system\
    Property(S): System64Folder = C:\
    Property(S): SourceDir = C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_plDbg_mul\
    Property(S): TempFolder = C:\Users\M@RCELO\AppData\Local\Temp\
    Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
    Property(S): USERPROFILE = C:\
    Property(S): WindowsFolder = C:\Windows\
    Property(S): WindowsVolume = C:\
    Property(S): ROOTDRIVE = C:\
    Property(S): ACTION = INSTALL
    Property(S): Preselected = 1
    Property(S): QFEUpgrade = 1
    Property(S): UILevel = 2
    Property(S): OriginalDatabase = C:\development\Adobe Flash Builder 4 Standalone\payloads\AdobeFlashPlayer10_plDbg_mul\AdobeFlashPlayer10_p lDbg_mul.msi
    Property(S): ISCHECKFORPRODUCTUPDATES = 1
    Property(S): ApplicationUsers = AllUsers
    Property(S): AgreeToLicense = No
    Property(S): _IsMaintenance = Change
    Property(S): RestartManagerOption = CloseRestart
    Property(S): IS_SQLSERVER_USERNAME = sa
    Property(S): IS_SQLSERVER_AUTHENTICATION = 0
    Property(S): SetupType = Typical
    Property(S): _IsSetupTypeMin = Typical
    Property(S): Display_IsBitmapDlg = 1
    Property(S): DATABASE = C:\Windows\Installer\23d09.msi
    Property(S): ProductName = Adobe Flash Player 10 Plugin
    Property(S): ALLUSERS = 1
    Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
    Property(S): DWUSINTERVAL = 30
    Property(S): DefaultUIFont = Tahoma8
    Property(S): DialogCaption = InstallShield for Windows Installer
    Property(S): DisplayNameCustom = Custom
    Property(S): Privileged = 1
    Property(S): DisplayNameMinimal = Minimal
    Property(S): DisplayNameTypical = Typical
    Property(S): ErrorDialog = SetupError
    Property(S): INSTALLLEVEL = 100
    Property(S): ISVROOT_PORT_NO = 0
    Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
    Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
    Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
    Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
    Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
    Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
    Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
    Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
    Property(S): InstallChoice = AR
    Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
    Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
    Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
    Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
    Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
    Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions
