problem in rotating dynamic text field
Mar 29, 2010 7:53 AM
Hi All,
In an application, i am creating dynamic text Field and then try to rotate it by using _rotation method but it become invisible. Please answer if anyone know anything about it.
  • kglad
    Jul 21, 2002
    Mar 29, 2010 8:25 AM   in reply to amitKumarKanda
    you need to embed the font.
  • kglad
    Jul 21, 2002
    Mar 30, 2010 6:41 AM   in reply to amitKumarKanda
    if you don't see your text, you're not embedding the font.
    when you use actionscript to embed a font, you need to have the font in your library with a linkage id, create a textformat instance and assign its font property and finally assign the textformat to your textfield.  for example
    _root.createTextField("txt",_root.getNextHighestDepth(),50,50,50,50);
    _root.txt.embedFonts=true;
    _root.txt.text="hello";
    _root.txt._rotation=20;
    var tfor:TextFormat=new TextFormat();
    tfor.font="yourfontslinkageid";  // <- linkage id of font in your library
    _root.txt.setTextFormat(tfor);
    Aug 2, 2010 6:35 AM   in reply to amitKumarKanda
    I'm having the same problem, but now understand why this happens.
    As a test if you create a dynamic text box and place a var inside - it works.
    Then if you manually rotate the text field it can't see the text anymore. Or when you dynamicaly rotate etc.
    A fix will be to place the text field inside a movieclip, then rotate the movieclip with the text field inside.
  • kglad
    Jul 21, 2002
    Aug 2, 2010 6:37 AM   in reply to djaynickyt
    that's no fix.   you need to embed the font.  that's the fix.
    Aug 4, 2010 1:08 AM   in reply to kglad
    Sorry, your right.
    Embed the font, it works fine now.
  • kglad
    Jul 21, 2002
    Aug 4, 2010 6:30 AM   in reply to djaynickyt
    you're welcome.
