Robert G Boulay
Are Adobe gradients all the same?
Apr 1, 2010 5:09 AM
Specifically, are gradients produced in Photoshop superior? Or is it the same rendering engine for those produced in InDesign and Illustrator?
Thanks in advance for your comments.
    Apr 1, 2010 5:46 AM   in reply to Robert G Boulay
    Photoshop is a pixel-oriented program (with some path-capabilities) whereas Illustrator and Indesign are vector-oriented, so the comparison seems to be of limited usefulness.
    Why do you ask?
    Apr 1, 2010 7:50 AM   in reply to Robert G Boulay
    The same gradient out of Photoshop at 300 - 400 ppi @ 100% will be an un-necessarily large and cumbersome file.  Screen ( monitor ) rendering in InDesign may or may not give you an accurate rendering of the actual vector gradient in InDesign or Illustrator.  You should have your InDesign view set for high quality and the document resolution set for 5080dpi / 300ppi ( depending on RIP screening requirements ).  Monitors tend to have an issue with rendering gradients accurately.  Proof the project to check the rendering via a reliable printer ( i.e., Postscript Level 3 RIP ).  But, getting back to your original question, gradients in Illustrator are different than Photoshop gradients whereas IL = Vector; PS = Bitmap.  However, the RIP will render them the same through its internal print engine.  How the gradient is created will make or break the artwork.
    Apr 1, 2010 8:02 AM   in reply to Robert G Boulay
    Indesign makes vector-gradients.
    Of course depending on transparency-flattening-necessities it may have to pixelate them on pdf-export.
    Apr 2, 2010 5:29 AM   in reply to Robert G Boulay
    Recently a colleague of mine had to proof a pdf where the jpg-compression had seriously messed up pixel-gradients, the solution to which was creating an uncompressed pdf – which of course bloated the file-size … anyway, best be aware that jpg-compression can have a negative effect on pixel-gradients.
    Apr 5, 2010 2:24 PM   in reply to John Danek
    Not if you use Gradient Fill layers.
