Chris_Hof
Flex 4 - Error with DataGrid in Module
Apr 2, 2010 7:23 AM
Hey, I'm using Flex 4 final and am now getting the following error when loading a Module with a DataGrid inside:
TypeError: Error #1009: Cannot access a property or method of a null object reference
    at mx.styles::StyleProtoChain$/initProtoChainForUIComponentStyleName()[E :\dev\4.0.0\frameworks\projects\framework\src\mx\styles\StyleProtoChai n.as:356]
It is created via MXML:
<mx:Module layout="absolute" xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:mx="library://ns.adobe.com/flex/mx">
    <mx:DataGrid>
        ... config etc.
    </mx:DataGrid>
    ... other code
</mx:Module>
If I remove the DataGrid the Module works fine. The code used to work in the various betas.
If I put a DataGrid in the main application that also renders fine, so it's only inside Modules.
Thanks in advance for any help or ideas!
    Apr 2, 2010 8:22 AM   in reply to Chris_Hof
    I suspect the problem is with how you are creating the module. Are you calling the module.factory.create() function like ModuleLoader does in moduleReadyHandler?
    -Darrell
    Apr 3, 2010 4:26 AM   in reply to Chris_Hof
    I do not think that this is a bug, because I load modules which contains a datagrid successfully by using Module Manager. You can find an example on my playground. Every click on one of the buttons from the top navigation button bar will load and open a module.
    Apr 3, 2010 10:13 PM   in reply to Chris_Hof
    What error are you getting?
    Apr 6, 2010 11:00 AM   in reply to Chris_Hof
    I'm going to take a guess at what the problem might be.
    It looks like the name of your module is "Benutzerverwaltung". Generate a link report for the application that contains the ModuleLoader of the module. Check the link report for the "Benutzerverwaltung" class. I suspect the class is there which means you are referencing the module from the application. Can you check if this true.
    -Darrell
    Apr 22, 2010 7:17 AM   in reply to Darrell Loverin
    Hi Darrell,
         I have the exact same error, and yes I am using module.factory.create() but I get an error when I try to add the module to my stage.  Here it is the code in my modReady function.
    var _sd:Object = new Object();
    _sd = util.app.SDModule.factory.create() as SequenceDetail;
                _sd.sequenceId = event.currentTarget.selectedItem.sequenceId;
                _sd.environment = event.currentTarget.selectedItem.environment;
                _sd.seqname = event.currentTarget.selectedItem.sequenceName;
                util.app.page.addChildAt(_sd as SequenceDetail, util.app.page.numChildren);
                util.app.nav_buttons.selectedIndex = -1;
                util.app.page.selectedIndex = util.app.page.numChildren-1;
    I get an error on util.app.page.addChildAt(........).
    error is
    TypeError: Error #1009: Cannot access a property or method of a null object reference.
        at mx.styles::StyleProtoChain$/initProtoChain()[E:\dev\4.0.0\frameworks\ projects\framework\src\mx\styles\StyleProtoChain.as:171]
        at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::initProtoChain()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\UIComponent. as:10186]
        at mx.core::UIComponent/regenerateStyleCache()[E:\dev\4.0.0\frameworks\p rojects\framework\src\mx\core\UIComponent.as:10249]
        at mx.core::Container/regenerateStyleCache()[E:\dev\4.0.0\frameworks\pro jects\framework\src\mx\core\Container.as:3737]
        at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::addingChild()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\UIComponent. as:7114]
        at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::rawChildren_addChild()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\Container.as :4464]
        at mx.core::ContainerRawChildrenList/addChild()[E:\dev\4.0.0\frameworks\ projects\framework\src\mx\core\ContainerRawChildrenList.as:143]
        at mx.containers::TabNavigator/createChildren()[E:\dev\4.0.0\frameworks\ projects\framework\src\mx\containers\TabNavigator.as:559]
        at mx.core::UIComponent/initialize()[E:\dev\4.0.0\frameworks\projects\fr amework\src\mx\core\UIComponent.as:7250]
        at mx.core::Container/initialize()[E:\dev\4.0.0\frameworks\projects\fram ework\src\mx\core\Container.as:3129]
        at mx.core::UIComponent/http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\UIComponent. as:7142]
        at mx.core::Container/http://www.adobe.com/2006/flex/mx/internal::childAdded()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\core\Container.as :3951]
        at mx.core::Container/addChildAt()[E:\dev\4.0.0\frameworks\projects\fram ework\src\mx\core\Container.as:2616]
        at mx.core::Container/addChild()[E:\dev\4.0.0\frameworks\projects\framew ork\src\mx\core\Container.as:2534]
        at mx.core::Container/createComponentFromDescriptor()[E:\dev\4.0.0\frame works\projects\framework\src\mx\core\Container.as:4371]
        at mx.core::Container/createComponentsFromDescriptors()[E:\dev\4.0.0\fra meworks\projects\framework\src\mx\core\Container.as:4160]
        at mx.containers::Panel/createComponentsFromDescriptors()[E:\dev\4.0.0\f rameworks\projects\framework\src\mx\containers\Panel.as:1685]
        at mx.core::Container/createChildren()[E:\dev\4.0.0\frameworks\projects\ framework\src\mx\core\Container.as:3187]
        at mx.containers::Panel/createChildren()[E:\dev\4.0.0\frameworks\project s\framework\src\mx\containers\Panel.as:1198]
        at SequenceDetail/initialize()
        at mx.containers::ViewStack/addChildAt()[E:\dev\4.0.0\frameworks\project s\framework\src\mx\containers\ViewStack.as:1426]
        at com::MyDBResult/displaySequenceDetail()[/Users/jbhavsar/Documents/wor kspace/virome/src/com/MyDBResult.as:114]
        at <anonymous>()[/Users/jbhavsar/Documents/workspace/virome/src/com/MyDB Result.as:103]
        at flash.events::EventDispatcher/dispatchEventFunction()
        at flash.events::EventDispatcher/dispatchEvent()
        at ModuleInfoProxy/moduleEventHandler()[E:\dev\4.0.0\frameworks\projects \framework\src\mx\modules\ModuleManager.as:1168]
        at ModuleInfo/readyHandler()[E:\dev\4.0.0\frameworks\projects\framework\ src\mx\modules\ModuleManager.as:812]
        at mx.core::FlexModuleFactory/update()[E:\dev\4.0.0\frameworks\projects\ framework\src\mx\core\FlexModuleFactory.as:433]
        at mx.core::FlexModuleFactory/docFrameHandler()[E:\dev\4.0.0\frameworks\ projects\framework\src\mx\core\FlexModuleFactory.as:582]
        at mx.core::FlexModuleFactory/docFrameListener()[E:\dev\4.0.0\frameworks \projects\framework\src\mx\core\FlexModuleFactory.as:126]
    Jay
    p.s: Please dont hammer me if my code isn't upto standard, I am learning this as I go along.
    Apr 22, 2010 10:24 AM   in reply to kingquattro
    If SequenceDetail is the module class you are linking the module into the
    main app and that effectively defeats the point of modules and will cause
    errors in the style system.
    Apr 22, 2010 10:50 AM   in reply to Flex harUI
    Hi
         I agree that this does defeat the purpose of Module but we had developed it so that two portion of the app can be developed independently.  I think I am going to convert it into a panel component, and keep it hidden unless needed.
    Jay
    Apr 22, 2010 2:13 PM   in reply to kingquattro
    You should use a common interface.   That's the recommended practice.  Once
    you do that, you'll see that the app gets smaller because it no longer links
    in the module class.
    Apr 3, 2013 6:02 AM   in reply to Flex harUI
    I was stuck on this protochain error for days!! I migrated from SDK3.5 to 4.6...
    I eventually found the solution - it is a bug in flex... kudos goes to CarbonRider http://flex.carbonrider.com/2010/11/17/flex-3-to-flex-4-migration/
    the actual problem is that stylesRoot is null for the module you are trying to load...
    so to fix it put this code in before calling addChild()
                        var child:DisplayObject = DisplayObject(module.factory.create());
                        var b:IStyleManager2 = StyleManager.getStyleManager(IFlexModule(child).moduleFactory); //(child) is instance of the module loaded
                        if (b.stylesRoot == null)
                                       b.stylesRoot = styleManager.stylesRoot;
      self = addChild(child);
    full code below....
              public var module:IModuleInfo;
              public var self:DisplayObject;
    private function init():void
                        module = ModuleManager.getModule(swfURL);
                        module.addEventListener(ModuleEvent.READY, moduleReady);
                        module.load(ApplicationDomain.currentDomain,null,null,moduleFactory);
              private function moduleReady(e:ModuleEvent):void
                  progbox.visible = false;
