DaveJosias
Changing pms color in InDesign from a imported (linked) InDesign file
Apr 8, 2010 5:07 PM
I'm working on multiple (8) versions of a book in InDesign. I'm linking pages from one version (in Design document) to another version (inDesign document). My problem lies in that in one of the versions, a color prints 4c, but in the other version it will print the same color but as a pms spot. Is there a setting where the InDesign document will overide the imported swatches of the linked InDesign document so I can change the imported color from a 4c to a spot whithout changing it in the linked file? I know you can with .ai, psd, etc.... Just not sure if this is possible with an imported InDesign file? Any help would be greatly appreciated!
Cheers,
Dave
    Apr 8, 2010 5:10 PM   in reply to DaveJosias
    Have you tried synchronizing swatches in the book?
    Apr 8, 2010 5:50 PM   in reply to DaveJosias
    You probably realise this already but if you could make it fit your workflow you can do it in reverse with Ink Manager.....  When I tried (in CS3) a placed Indesign file doesn't bring in it's CMYK swatches so you can't do it then.  But if you made the placed the Indesign file with the spot you then turn that spot into a CMYK mix.
    Apr 9, 2010 10:00 AM   in reply to DaveJosias
    Use the Ink Manager to alias the imported swatch with the desired swatch.
    Apr 9, 2010 10:29 AM   in reply to DaveJosias
    Sorry, I misunderstood you and thought you had a book already.
    I still think that's going to be the ultimate solution. Make a new book, add all the documents you're extracting page from, then synch the swatches using a file with the right definitions as the source.
    WARNING: This will make real, permanent changes to the documents. You might want to use copies instead, then relink the placed pages to the copies after the synching.
    Apr 9, 2010 10:33 AM   in reply to DaveJosias
    You have a cmyk value that you want to convert to a spot - that ain't gonna happen outside of the source, sorry to be blunt. (Edit - you could accomplish this on a pdf file in Acrobat with Pitstop)
    You have access to the ID file, not just a pdf; you must have a good reason not to edit the cmyk doc to spot and there are plenty of reasons not to in a perfect - out of your control - enviroment.
    btw, you cannot do this with an .ai or .psd link defined cmyk.
