ik heb adobe reader 5 keer opnieuw gedownload,
steeds oude versie verwijderd, maar bij update
komt telkens:
update mislukt, fout 1500.
er draait geen ander programma mee.
iemand enig idee?
What is your operating system?
Are you trying to install Reader 5 or Reader 9?
Are you trying to upgrade Reader 5 to Reader 9? If so, you must completely uninstall Reader 5 before installing the latest Reader version.
Thanks for your answer,
No I donot have reader 5 only adobe reader 9.
I cannot update the last security update.
I already uninstalled reader 9.... 5 times and installed again.
But update constantly Failed error 1500.
I am using internet explorer 8.
Thanks again.
I have the same problem. I get error 1500. It asks me
to run adobe repair from help menu, but that does not work either.
I am runing fully updated XP machine. My acrobat is 9.3 pro extended.
I originally purchased 9.0 in December. Upgrade to worked, but this thing for 9.3.1 will not.
Have rebooted computer many times. The program itself seems to work fine.
Hello,
Thanks for your reply.
It seems nobody knows the answer, about this problem!!!!!
I am glad I am not the only one.
I hope someone from adobe will give the right answer.
Thanks again and if you find a solution for this problem please let me know,
for I tried so may things to solve this problem!!!
so many times unstall and install.
So thanks again.
Jerema.
Can you give us the full error message that comes with error code 1500 ?
Are you trying to install Reader 9.0 or Reader 9.3 ?
Do you try the interactive install from the Adobe website, or did you download the offline installer?
Assuming that you want to install the Dutch version Adobe Reader 9.3 for Windows, you can download the offline installer from http://ardownload.adobe.com/pub/adobe/reader/win/9.x/9.3/nld/AdbeRdr930_nl_NL.msi
Thanks for your reaction.
The message in Dutch translated:
Cannot install update.
Do adobe repair.(already done many times)
Error 1500.
I herewith send you the message.
With kind regards
jerema
Sorry I forgot: adobe reader 9.3.
Available Physical Memory: 1255276 KB
Available Virtual Memory: 1975668 KB
BIOS Version: FICINC - 6040000
Default Browser:
Default Mail: Windows Mail
%ProgramFiles%\Windows Mail\msoe.dll
Version:
Graphics Card: VIA Chrome9 HC IGP Family WDDM
Version: 7.14.14.80
Check: Not Supported
Installed Acrobat:
Installed Acrobat: C:\Program Files\Adobe\Reader 9.0\Reader\AcroRd32.exe
Version: 9.2.0.124
Creation Date: 2009/10/03
Creation Time: 4:07:50 AM
Locale: English (United States)
Monitor:
Name: VIA Chrome9 HC IGP Family WDDM
Resolution: 1280 x 800 x 60
Bits per pixel: 32
OS Manufacturer: Microsoft Corporation
OS Name: Microsoft Windows Vista
OS Version: 6.0.6002 Service Pack 2
Page File Space: 4194303 KB
Processor: x86 Family 6 Model 10 Stepping 9 CentaurHauls ~1496 Mhz
Total Physical Memory: 2097151 KB
Total Virtual Memory: 2097024 KB
Windows Directory: C:\Windows
C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins\Annots.api
Version: 9.2.0.124
Creation Time: 2:39:28 AM
C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins\EScript.api
Version: 9.2.0.124
Creation Time: 2:46:46 AM
C:\Program Files\Adobe\Reader 9.0\Reader\plug_ins\Updater.api
Version: 9.2.0.124
Creation Time: 2:45:18 AM
Hope someone can help.
pimarine
I am able to update Reader properly on my machine. If you can provide me āAdobeARM.logā and āMSIxxx.logā from %temp% location ,probably I can look into this issue.
a) To enable ARM log, set the following registry key,
[HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Adobe ARM\1.0\ARM]
"iLogLevel"=dword:00000001
b) To enable MSI log, set the following registry key,
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Installer\]
"Logging"="voicewarmupx"
After setting above registry values just open Reader and perform the same update action,which was not working for you.
HOw can I copy arm log and software adobe windows installer to you?
See below. Donot how to do it.I tried and tried.
Kind regards jerema.
Steps to create full verbose AdobeARM.log on Windows Xp,
1. Click on Start>Run2. Type "regedit" in the run dialog and press enter3. Navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Adobe4. Right click on "Adobe" key, Select "New">"Key" from the popup menu5. And Provide "Adobe ARM" as the new key and press enter key6. Right click on "Adobe ARM" key, Select "New">"Key" from the popup menu7. And Provide "1.0" as the new key and press enter key8. Right click on "1.0" key, Select "New">"Key" from the popup menu9. And Provide "ARM" as the new key and press enter key10. Right click on "1.0" key, Select "New">"DWORD value" from the popup menu11. And Provide "iLogLevel" as the new name and press enter key12. Double click on "iLogLevel" to edit the DWORD value, change the value data: to 1 and press OK13. Close Registry editor14. Now launch Reader and navigate to Help>Check for updates15. Once Error 1500 comes up, close the updater.16. Click on Start>Run17. Type "%temp%" in the run dialog and press enter18. Copy the "AdobeARM.log" from the temp location and please provide me the log so that I can look into the issue. The log will certainly have some information on what caused the error 1500 to happen.Copy link to clipboard
THANKS A LOT,
I DID IT ALL.
IT TOKES ME A LONG TIME, BUT I SUCCEEDED.
HEREWITHE I SEND YOU THE LOG.Thank you very much if you want to look at it.
Now I find this log I saw that I have many of this.From very different datesI
ONLY SEND YOU THE LAST ONE, IF YOU NEED MORE PLEASE LET ME KNOW.
Hope you can help me
and kind regards jerema.
Adobe ARM 1.1.7.0 logging started.
Command Line: /PRODUCT:Reader /VERSION:9.0 /MODE:1
ProductCode: {AC76BA86-7AD7-1033-7B44-A93000000001}
ProductRegistry: SOFTWARE\Adobe\Acrobat Reader\9.0
ProductInstallDir: C:\Program Files\Adobe\Reader 9.0\
Using default ARM preference AUTO_DOWNLOAD.
Failed to read UAC setting, defaulting to Enabled.
GetFileVersion(): C:\Program Files\Common
Files\Adobe\ARM\1.0\AdobeARM.exe
Newer version ARM Update is not available.
New file object: AdbeRdrUpd932_all_incr.msp
file - C:\Documents and Settings\All Users\Application
Data\Adobe\Reader\9.3\ARM\AdbeRdrUpd932_all_incr.msp
Hi vmareje,
The Error Code: 0x670 in the ARM log translates to ERROR_PATCH_NO_SEQUENCE
which is very strange to get this kind of error since your are applying 9.3.2 patch on Reader 9.3 and which is a valid sequence. There could be something wrong in the System/MSI. My suggestion would be to uninstall Reader completely. And then Download full Reader 9.3 from
www.adobe.com and install it. After installing, launch Reader and navigate to Help>Check for updates to get the latest 9.3.2 patch. If the Error 1500 still persists, then please download the 9.3.2 patch from
http://ardownload.adobe.com/pub/adobe/reader/win/9.x/9.3.2/misc/AdbeRdrUpd932_all_incr.msp and apply the patch manually by double clicking on it. Hope it helps.
Regards,
Thanks but I cannot remove the program because it says it cannot find the
source.
-o-O-o- Bill Owen TourGroupPro LLC, PO Box 711, Decatur IL 62525 | 217
422-5002, toll free 877-FUN-GRPS (386-4777), cell 217 454-4525, fax 217
718-3109 | 37 years in group travel www.TourGroupList.info
New address: 363 S Main Suite 175, Decatur IL 62523 (Decatur Professional
Plaza @Main & Decatur; all other contact info is the same) | We are an
independent contractor with: Rio Grande's Franklin Travel of Albuquerque NM
(whose phone is 505-292-7044) IATA #32-516002 & Atlas Travel of Decatur IL
(whose phone is 217-429-2929) IATA #14-597096 |
I have the same problem as you do, did you find a way to solve it? I am tired of this program it is a heck of a mess and I want it out of my machine, how can I delete it? I can't do it with remove programs it does not allow me to do it. I have checked this and it says a Data1 file is missing, I can't remove it, I can't update it and can't replace it. What can I do?
@ Marylou_II - I resolved my problem by manually downloading the update as indicated in my previous post and apply it i.e. look for the update one version higher than the version you are running (you'll find this in "help about adobe reader 9" in the adobe menu). We don't seem to have the same problem so I'm not sure how to advise you other than the above...
Thanks a lot for all the answers I got, I have tried just about everything and nothing works, so my tech is coming over to format my PC and then reinstall everything. I have the bad feeling this is s Microsoft mess up on purpose.
Thanks a lot to all, you have been very kind.
Best regards.
Marylou_II
You are right - we are in exactly the same place. If I learn anything new, I'll post it.
I am getting the same error when I try to install the latest security patch to both of my PCs.
PC1 - Laptop running Vista Home Premium with Service Pack 2. Adobe Acrobat 8 Professional ver 8.2.0
PC2 - Dell Desktop running XP Home Premium with Service Pack 3 Adobe Acrobat 8 Professional ver 8.2.0
I get the Adobe Acrobat Updater message box pop up that says:
Update Failed
Cannot install the update. Please run Adobe Acrobat Repair.
Error: 1500
The Repair will not run, as it tells me:
Windows Installer
The installation source for this product is not available. Verify that the source exists and that you can access it.
I have tried putting the installation CD into the drive and still cannot get the repair to run.
I guess I will have to live with an unpatched Acrobat that has security holes!
Thanks for your answer.
I also have a dell desktop running home premium with service pack 3.
It is a strange story, that nobody knows the answer.
Quote
Unquote.
The same for me.
Thanks again, may be if everone with this problem reports it, adobe will do
something about it.
With kind regards,
Jerema.
I am running windows 7 and have the same problem when trying to install the automatic update to Adobe Reader 9.3. Gavin Meikle
Dear Gavin Meikle,
Let us hope, adobe will do something about it, for I know there are more people
with this problem!
With kind regards
jerema.
(I posted this over in the Adobe Acrobat Pro forum, but looks like it's biting Acrobat Reader people too.)
I got nailed by that update this morning, and am currently restoring my Windows XP-SP3 system from a backup.
Look at your %SystemRoot%\Installer folder. I bet it's completely empty. It's supposed to have a lot of files and folders in it.
At first I just received that obscure "installation failed" message that the Updater throws up (by the way, Updater looks a little different this time around, doesn't it?) After an hour or so of working on the PC a few desktop icons for installed programs went blank, looking like a white box with a blue bar on top of the box. I tried seaching for the icon and was getting messages about %SystemRoot%\Installer\{<some long alphanumeric directory>} not found.
I looked in the %SystemRoot%\Installer folder and it was completely empty.
I booted up a backup hard drive I had been on a couple of weeks ago (I recently migrated to a SSD drive) and looked at %SystemRoot%\Installer and it was full of folders and files. A few minutes later the Updater told me I should apply the update. I did, it failed. I looked into %SystemRoot%\Installer again and it was completely empty.
I'm now restoring from a backup of that hard drive, which I made in case my foray into SSD drives didn't work out.
Regards, Scott
Many people have this problem and I hope acrobat reader will do something about
it.
With kind regards
jerema
