With CS5, some things have changed
Oct 3, 2010 1:50 AM
  Latest reply: Econometric, Oct 13, 2011 7:13 AM
Branched to a new discussion.
Replies 1 2 3 Previous Next
    Mar 29, 2011 11:21 PM   in reply to Harbs.
    Hi Harbs,
    2) PageItems.itemByName(): With the new layers panel comes a name property for PageItems. In previous versions PageItems.itemByName() would return the page item with the specified label in CS5, it will return the page item with the specified name (which can be set in the Layers Panel). There is no longer a quick-and-easy way to get page items by their label using the 7.0 scripting DOM.
    I can able to access a pageItem directly by its name instead of their label.
    For example by using the following code I can able to access a textFrame directly by its name (which is already set in the layers panel).
    var mytextFrame = app.activeDocument.pages.item(0).textFrames.item("FirstTextFrame");
    alert(mytextFrame.contents);
    Green4ever
  • John Hawkinson
    Jun 25, 2009
    Mar 30, 2011 12:52 AM   in reply to Green4ever
    Yes, that is the point. But prior to CS5 you used to be able to use the script label as the parameter, and now you cannot.
    Mar 31, 2011 1:18 AM   in reply to John Hawkinson
    Hi All,
    I have included glue code.jsx in my CS5 Scripting project.
    Because of this app.scriptPreferences.version = 6 command, textFrame.name property becomes invalid in CS5 scripting.
    FYI...... I got the "glue code.jsx" from the "XML Rules" folder.
    I think, Since there is no changes made to xml objects, the version of this script is not changed. Can I change it to version = 7 or is there anyother way to overcome this problem?]
    Green4ever
    Apr 18, 2011 12:24 PM   in reply to Harbs.
    So far, I've slept through all the CS5 activity because our customers have been using CS3 and CS4, but now, some of them are putting their toes into the CS5 water and so I'm finally paying attention to what is now the release before last (ah well).
    According to the CS5 OMV, Text.contents returns either a String or a SpecialCharacters enumerator. But this code is failing on me:
    var txtSample = oSetText.contents.replace(/\t/g,"[Tab]");
    because contents is returning an array.
    Here's what the JS Console has to say:
    oSetText.contents
    Result: Linda [stroke survivor]
    “If you don’t have a proper wheelchair, that is when you really feel that you are disabled. But if you have a proper wheelchair, which meets your needs and suits you, you can forget about your disability.”
    Faustina [person with paraplegia]
    oSetText.contents.constructor.name
    Result: Array
    oSetText.contents.length
    Result: 1
    oSetText
    Result: [object Text]
    Anbody else seen this? Or am I suffering from a third-party plug-in induced weirdness?
    Dave
    Apr 18, 2011 12:50 PM   in reply to Dave Saunders
    I think I see the cause. I typed:
    This is a test.
    into a text frame, and selected it.
    app.selection[0]
    Result: [object Paragraph]
    app.selection[0].texts[0]
    app.selection[0].texts[0].contents
    Result: This is some text.
    app.selection[0].texts[0].contents.constructor.name
    Result: String
    app.selection[0].parentStory.characters.itemByRange(0,-1).texts[0]
    app.selection[0].parentStory.characters.itemByRange(0,-1).texts[0].con tents
    app.selection[0].parentStory.characters.itemByRange(0,-1).texts[0].con tents.constructor.name
    Result: Array
    It appears that using itemByRange across a range of text is at the root of the issue here because this second construction is akin to what I had done in the other script.
    To be blunt, this looks like a bug to me, but as long as it is consistent, I can work with it.
    Dave
    Apr 18, 2011 6:07 PM   in reply to Dave Saunders
    The solution (which works in at least CS4 and CS5) is to use getElements():
    app.selection[0].parentStory.characters.itemByRange(0,-1).texts[0].get Elements()[0].contents.constructor.name
    String
    However, in CS4 and earlier, the use of getElements here was not necessary.
    Dave
    Apr 19, 2011 12:44 PM   in reply to Dave Saunders
    Not actually a bug. This is a side-effect of a request that (wait for it, wait for it) I made two and a half years ago. At the time, I was bemoaning the fact that when you used everyItem() it didn't always return a collection (if there were only one of the items in question). Well, now it does and so does itemByRange.
    Thinking back to an earlier time, it always had struck me as rather mysterious that:
    myText.characters.itemByRange(m, n).texts[0]
    returned a singular text reference. Well, now it doesn't. It returns a collection of one text object. So:
    myText.characters.itemByRange(m, n).texts[0].getElements()[0]
    gives you that text object, which isn't such a big price to pay for consistency elsewhere.
    Dave
    Apr 19, 2011 8:56 PM   in reply to Dave Saunders
    Thanks Dave for pointing out these hidden pitfalls.
    The itemByRange() method has always seemed unpredictable to me, especially with text objects. For example:
    app.selection[0].parentStory.words.itemByRange(0,-1).characters[0].co ntents
    returns only the first character of the first word (in CS4 and CS5), while:
    app.selection[0].parentStory.words.everyItem().characters[0].contents
    returns —as expected— an array that collects the 1st character of each word. Thus, itemByRange() may integrate the 'range' as a single block of data and does not produce, in that case, a collective specifier.
    In addition, the texts collection is really mysterious. In your example, the specifier:
    var spec = app.selection[0].parentStory.characters.itemByRange(0,-1).texts[0];
    should finally be resolved as a range of characters. Indeed, both ID CS4 and CS5 return a character-to-character path when you test this:
    alert( resolve(spec.toSpecifier()).toSpecifier() );
    However —as you have discovered— spec is treated as a collective specifier in CS5, so spec.contents produces an array of one string, while spec is a singular specifier in CS4. So it's sure that something has changed in the implementation of the .texts method, and we probably will find other side effects...
    A final note: technically we cannot say that myText.characters.itemByRange(m, n).texts[0] returns a 'collection'. The returned value is actually a Text specifier (versus a Texts collection). What you found is that, in CS5, this can be a collective specifier, in that any underlying property is returned through an array although the DOM object has in fact a single receiver.
    Marc
    Apr 20, 2011 1:19 PM   in reply to Marc Autret
    Thanks Marc.
    Apr 29, 2011 4:46 AM   in reply to Harbs.
    Just found another really unfortunate change in CS5. It is no longer safe to issue:
    myTextFrame.lines[-1].baseline
    even when the text frame is known to contain at least one line because if that line contains a partial table that is not completely set (i.e., the story goes overset before the end of the table) you'll get "Invalid request in the current state".
    Possibly worse, if the table is completely set, rather than get the bottom coordinate of the part of the table in the text frame, you instead get the baseline of the actual bottom of the last row of the table no matter which text frame it might actually be in on whichever page.
    A really sad state of affairs that wipes out my script that does vertical justification of tables.
    Dave
    May 3, 2011 8:58 PM   in reply to Harbs.
    Apologies for cross posting this to both mailing list and forums, I'm not sure what most people are using.
    Just starting to look at moving the company from CS3 to CS5/5.5 and updating the scripts has been, well, interesting.  The inability to directly refer to page items via their Label has been quite a challenge as EVERYTHING we do names frames and subsequently refers to them by that name.
    One thing that has me stuck is why the following doesn't throw an error in a try block if the frame doesn't exist.
    set myFrame to item 1 of all page items whose label is "kim"
    I simply end up with an undefined variable. I would have thought if it didn't exist and myFrame was undefined an error should be returned.
    Am I missing something here or is this expected behaviour?
    I've just found another issue regarding restoration of styles to a frame. In CS3 we used to simply get the parent story properties from the frame, place the new text and then reapply the properties to restore the style. In CS5 this breaks as it simply applies the default paragraph style despite the properties holding all the individual style elements. I'm thinking this will necessitate applying individual properties (font, leading, tracking, kerning, etc etc) and that's gonna be horrible. If someone has a workaround for this I would appreciate it.
    It's been a long time since I wrote these scripts and there's a LOT of work in updating them to follow the new syntax - this is going to be a far more substantial task than I was expecting.
    cheers
    'k
  • John Hawkinson
    Jun 25, 2009
    May 3, 2011 11:00 PM   in reply to kimtorch
    Perhaps you should consider using:
    --Set to 5.0 scripting object model
    set version of script preferences to 5.0
    until such time as you need to make serious use of CS5 features?
    It is indeed expected!
    A "whose" filter in AppleScript is permitted to return a null list. Errors are only supposed to be thrown in fairly serious errors. Depending on how you try to use the myFrame it might generate an error later though...
    May 3, 2011 11:38 PM   in reply to John Hawkinson
    Well it's certainly returning an error when used later
    And there's the rub, in the CS3 version there was no problem simply checking to see if the frame existed but with the variable assignment failing without error the existence check naturally fails as well. I have coded a (fairly clunky) workaround which I think will be reliable but I still think returning an error when trying to assign a non-existent object to a variable makes sense.
    With regards using the v5 Scripting, I figure I may as well just bite the bullet and get it done. We're probably a few months away from upgrading (and I'm the one who decides so it can be further postponed) so it's just a matter of getting it all done.
    I like fiddling around but when I haven't looked at the scripts in probably 5 years it can take a while to get back into the swing of things
    Jun 7, 2011 2:43 AM   in reply to Harbs.
    With a script that worked OK in CS4 I now find that when I set the strokewidth of a frame to 0 the result is a frame having a stroke of 1 pt, using the default TextFrame Object style. In both cases I used the same template file to start with so the Object Style is somehow changed or is now applied and not inprevious versions ? Do I need to set the ObjectStyle to None on all frames in CS5 to avoid this ?
    Jun 7, 2011 3:10 AM   in reply to RoelofJanssen2
    Just found out myself that just after setting frame.strokewidth = 0 the value for frame.strokewidth is actually 1 pt; if I set strokewidth = 0.000001 then the value returned is actually 0.000001 pt so will show as 0 in InDesign dialogs.
    So now my question is: how to set strokewidth to zero in InDesign CS5 ?
    There is no StrokeWidth - it ALWAYS was StrokeWeight - 2.0.2/CS1/CS2/CS3/CS4/CS5:
    Property StrokeWeight As Variant
        Member of InDesign.TextFrame
        The weight (in points) to apply to the TextFrame's stroke. Type: Unit (Double or String)
    robin
    www.adobescripts.co.uk
    Sep 7, 2011 2:29 PM   in reply to John Hawkinson
    John Hawkinson suggested that changing the version in the script preferences could give one the ability to use properties the way we used to (i.e., set the properties of object A to the properties of object B). Sadly, this isn't the case in CS5 and CS5.5--it's one of those changes that defies versioning--so you're reduced to using other means. I should revise that a bit--*some* properties will transfer; it's important stuff like fill and stroke options won't.
    I wish I'd caught this while I was still at Adobe, but I was working on other stuff during CS5. I can't believe that this big a mistake was made without someone else inside the company noticing.
    Ole
    Sep 7, 2011 4:03 PM   in reply to Harbs.
    Hi Harbs,
    My point was that you were once able to quickly apply all of the formatting of one object to another object, and now you can't--without further work, anyway. Yes, it's almost certainly a problem of the sequence in which items in the properties record are applied. But it shouldn't have changed.
    I do have an example of a change that can be overcome with script versioning--the stacking order of items on a layer. It's possible to end up with mulitple page items with the same index(!)--I think it's a problem that's to do with documents coming from old versions of InDesign, or documents with pasted Illustrator paths--I'm not sure. Whatever causes it, it's something that survives export to IDML and back. When you iterate over the page items in a layer with this problem in CS5/CS5.5, you'll see something like this (this is reverse iteration--counter is counting down from layer.pageItems.length):
    Counter: 62 Index: 60 ID: 4679
    Counter: 61 Index: 59 ID: 4682
    Counter: 3 Index: 1 ID: 4761
    Counter: 2 Index: 0 ID: 4762
    Counter: 1 Index: 1 ID: 4919
    Counter: 0 Index: 0 ID: 4680
    Isn't that crazy? The counter and the index are out of synch. What's more, ID: 4680 and ID:4919 are at the *back*--they should be at the start of the list. If you're trying to rebuild the stacking order of the objects in some other place (like, in a custom FXG or SVG export, in my case--both formats where stacking order depends on output order), this can drive you insane.
    But...switch back to version 6.0 (CS4) before doing the iteration, and you get the items back in the correct back-to-front stacking order:
    Counter: 62 Index: 1 ID: 4919
    Counter: 61 Index: 60 ID: 4679
    Counter: 60 Index: 0 ID: 4680
    Counter: 59 Index: 59 ID: 4682
    Counter: 3 Index: 3 ID: 4759
    Counter: 2 Index: 2 ID: 4760
    Counter: 1 Index: 1 ID: 4761
    Counter: 0 Index: 0 ID: 4762
    ...even though the indices are clearly messed up. I'm not sure anyone else will ever face this particular problem, but it's cost me enough lost sleep that I thought I'd better mention it here!
    Ole
  • John Hawkinson
    Jun 25, 2009
    Sep 8, 2011 6:53 AM   in reply to Olav Kvern
    Ole:
    My claim was intended to be much more narrow, and I'm a bit confused how you thought I was referring to property transfer. I was really just talking about the ability to index objects by their script label.
    That is, given a TextFrame labelled "foo", in CS5:
    app.activeDocument.textFrames.item("foo").contents
    Error: Object is invalid
    However, if one sets the version preferences:
    app.scriptPreferences.version=6.0
    Result: 6
    Result: Foobar
    So that does seem to work.
    Sep 8, 2011 7:47 AM   in reply to John Hawkinson
    Result: 6
    Result: Foobar
    Yes, It was mentioned before and it works perfectly fine
    Or you can do more - set it at the beginning of the script So old scripts work without any changes at all
    Sep 8, 2011 9:16 AM   in reply to John Hawkinson
    Hi John,
    kimtorch's wrote: "In CS3 we used to simply get the parent story properties from the  frame, place the new text and then reapply the properties to restore the  style." I just wanted to note that that was something that script versioning couldn't fix that particular problem. (No worries--your posts here are great!)
    Regarding item(label) vs. itemByName(name)--in my opinion, the biggest problem here is that the behaviors differ. The former may have been a hack (a special case for label that only worked for page items), but it was great in that it would return all of the page items with a given label. The latter only returns a single item, even if multiple items have the same name. In cases where the name is not required to be unique (e.g., page items), itemByName should behave the way that item(label) did. So, yeah, I'm really glad script versioning solves the problem, but I wish they'd just fix itemByName.
    Ole
  • John Hawkinson
    Jun 25, 2009
    Sep 8, 2011 9:35 AM   in reply to Olav Kvern
    Yes, it is a problem.
    Having left the hive-mind, can you advise us: do you think the team
    would be receptive to requests to change .item()'s behavior behavior
    back to the pre-CS5 behavior of searching for a label (where applicable)?
    It seems to me we need .itemByName() and .itemByLabel() and both should
    handle multiple objects. I guess I can file a feature request for the
    .itemByLabel(), but I'm not sure if it makes sense to ask for .item()
    to revert to .itemByName().
    What do you think and what do you think is feasible to get?
    Sep 8, 2011 11:16 AM   in reply to John Hawkinson
    Hi John,
    I really have no idea. But here's what should be done:
    * item(label) should be restored for page items, but deprecated. That is, it should work as it did before the change, but users should be encouraged to use itemByName(name)--see the next point.
    * itemByName(name) should be modified to work the way that item(label) used to work for page items. That is, it should return an array of all page items in a container that have the specified name. For objects where unique names are required (paragraph styles in a paragraph style group, for example), itemByName should return a single item.
    * A new feature should be added: itemByLabel(labelName, labelValue) should get all items with a custom label of "labelName" where the label has the value "labelValue". This way, scripters can mark items using insertLabel in a way that isn't visible (and editable) in the user interface, and get references to items of a given label with a given value. Again, this should return an array of all items in a container with the specified key/value pair. I've run into too many cases where workflow solutions get broken by users accidentally changing labels in the Script Label panel. If you needed to, you could use the default label property by using itemByLabel("label", labelValue).
    I don't think that these would be difficult changes to make, but I doubt if anything will happen. I put more of my faith in our ability to create workarounds.
    Ole
    Sep 9, 2011 2:33 AM   in reply to Olav Kvern
    hey ole,
    i do see your point - especially for exprienced scripters.
    but for beginners and learnes this would confuse even more: the label property would not correspond to the itemByLabel() function (same problem as  insertLabel() and extractLabel() but far less used).
    the mess started with insertLabel() and now there is no easy way out.
    luckily i had never any problems with users accidently changing labels in the label panel.
    gregor
    Sep 9, 2011 2:38 AM   in reply to grefel
    Sorry, I'm coming in late to this discussion. What is the probem with
    insertLabel()?
    Ariel
    Sep 9, 2011 2:57 AM   in reply to [Ariel]
    insertLabel() does not correspond to the property label. in my opinion this would be intuitive. the question was about getting things clear with item() and itemByName(). because of downward compatibility there is no easy solution to clear the DOM in this point.
    Sep 9, 2011 1:57 PM   in reply to Harbs.
    Fellow Scripters,
    It's a long story. First, referring to page items by pageItems.item("label_string")--where "label_string" was the contents of the object label--was never "intuitive." In all other cases in the DOM, item(string) is used for named objects. But, in the early days, page items didn't have names. By creating a special case for page items, we could use the contents of the label property to refer to page items. It wasn't ideal, but it worked, and everyone got used to it.
    I would think that users starting scripting today would expect to be able to set the object name, then use itemByName to get a reference to the object. The Layers panel is usually more visible than the Script Label panel. The only problem is that itemByName doesn't return multiple objects--and it should.
    Later, we realized that the simple label property was not enough--scripters needed a way to store other data on objects (and not just page items), so we added insertLabel and extractLabel. They're incredibly useful! Before we had insertLabel/extractLabel, trying to store multiple data values in the single label property was a chore--you had to use some kind of delimiter to separate the values. (My hat is off, as always, to the great engineers behind InDesign scripting, Peter Boctor and Jonathan Brown. It's sad that neither of them are still working in that area.)
    Note, in addition, that insertLabel/extractLabel work as expected with the label property--to write to the label, you could use:
    insertLabel("Label", "Some value here");
    ...and you can use extractLabel to get the value. Not that anyone needs to do this, it's just nice that it works.
    I think that the changes in this area--since the original implementation--have made things more consistent (and, one hopes, "intuitive"). Unfortunately, the changes, a.) broke something that many scripts depended on, and b.) the new approach, itemByName, does not match the capabilities of the old approach.
    Ole
    Sep 27, 2011 12:51 PM   in reply to Harbs.
    Hi everyone, I am running a VB script that I wrote for InDesign CS2 on CS5. The code below does not seem to work. Does CS5 understand Changecase? If someone knows or could point me to the CS5 VB script reference I would greatly appreciate it. I can't seem to locate any information.
    .Paragraphs(2).Changecase (idSentencecase)
    Thank you for helping!
    Mike
    Sep 27, 2011 2:45 PM   in reply to Econometric
    Hi Mike,
    Try to use numbers:
    Const idSentencecase = 1667461987 (&H63637363)
        Member of InDesign.idChangecaseMode
        Makes the first letter of each sentence uppercase.
       .Paragraphs(2).Changecase (1667461987)
    Are you sure there is 2nd Paragraph ?
    What error do you have ?
    Or what is the type of the Text object you try to modify ?
    robin
    Sep 28, 2011 9:04 AM   in reply to Robert-Tkaczyk
    Using the number worked perfectly. Thank you!!
    Sep 28, 2011 3:43 PM   in reply to Harbs.
    Can anyone point me to a CS5 VB script reference? Having trouble locating one.
    Thank you,
    Mike
    Sep 28, 2011 3:49 PM   in reply to Econometric
    You won't find it - because it doesn't exist ...
    Try this:
    http://www.jongware.com/idjshelp.html
    It's for JS - but should be helpful.
    Or if you have M$ Office - you can add reference to "Resources for Visual Basic.tlb" file and use built-in Visual Basic Editor.
    robin
    www.adobescripts.com
    Oct 4, 2011 8:04 AM   in reply to Harbs.
    I have noticed that in the situation of a two page spread, the left and right pages in CS2 will have different parent IDs, while in CS5 they will have the same parent IDs. I am trying to add pages to a document after a page of my choosing, and have the new page come in next.
    This is my CS2 code:
    X = .Parent.ID
    With idDoc.Pages.Add(at:=idAfter, reference:=idDoc.Pages.ItemByID(X))
    I am wondering if there is a way to set the "reference:" to place a new page by page .ParentPage, since the .Parent.ID is ambiguous?
    Mike
    Oct 4, 2011 9:17 AM   in reply to Econometric
    According to VB Reference Guide:
    Function Add([At As idLocationOptions = idUnknown], [Reference]) As Page
        Member of InDesign.Pages
        Creates a new page.
        Return value: The new page/.
        At: The location of the new page relative to the reference object or within the document or spread. .
        Reference: eference object. Note: Required when the at parameter value specifies before or after. Type: Page, Spread, MasterSpread or Document
    So your reference can be just the page. If you know the page after which you want to add new page - just use it - without reffering to Pages collection of the Document:
    With idDoc.Pages.Add(at:=idAfter, reference:=myPage)
    Beside, X = .Parent.ID will give you ID of the - so you can't use it as reference in PAGES collection.
    Unless by X = .Parent.ID you are trying to get ID of the parent page for the Object on that page, but still - if you know the page you are on - if you have reference to that page - you can use it directly in .Pages.Add().
    If I'm wrong - please show us more of your code.
    robin
    Oct 4, 2011 11:32 AM   in reply to Robert-Tkaczyk
    Mike wrote: "With idDoc.Pages.Add(at:=idAfter, reference:=idDoc.Pages.ItemByID(X))"
    As far ask I know, using labeled parameters (e.g., "at:" or "reference:" in the above) in VBScript/VB method calls has never worked (or has never worked reliably) in InDesign scripting. I think I even wrote a note about it in the documentation somewhere, though I have no idea if it's still there. Just provide the parameters in order, omitting optional parameters that you don't need. In this case, something like this should work (untested, off the top of my head):
    Rem Given a page item "X" in a document "idDoc"...
    idDoc.pages.add(idLocationOptions.idAfter, idDoc.pages.itemByID(X.parentPage.id))
    Ole
    Oct 13, 2011 7:13 AM   in reply to Robert-Tkaczyk
    This is wonderful! Thank you! Everything is working now.
1 2 3 Previous Next
Actions
Bookmarked By (1)
