In Flash Builder (flex 4) I try to use next code to set selected by user (from file system) Image as a repeated background. It worked with mx:Image but I want to use cool repited capabiletis of s:BitmapFill.
BTW: Technic I use also does not work with S:BitmapImage. Also FP does not return any errors. What Shall I do with my code to make it work?
xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:net="flash.net.*">
<fx:Script>
<![CDATA[
import mx.controls.Alert;
import mx.utils.ObjectUtil;
private function btn_click(evt:MouseEvent):void {
var arr:Array = [];
arr.push(new FileFilter("Images", ".gif;*.jpeg;*.jpg;*.png"));
fileReference.browse(arr);
private function fileReference_select(evt:Event):void {
fileReference.load();
private function fileReference_complete(evt:Event):void {
img.source = fileReference.data;
Alert.show(ObjectUtil.toString(fileReference));
</fx:Script>
<fx:Declarations>
<net:FileReference id="fileReference"
select="fileReference_select(event);"
complete="fileReference_complete(event);" />
</fx:Declarations>
<s:Rect id="backgroundRect" left="0" right="0" top="0" bottom="0">
<s:fill>
<s:BitmapFill id="img" source ="@Embed('1.jpg')" fillMode="repeat" />
</s:fill>
</s:Rect>
<mx:Button id="btn"
label="Browse and preview..."
click="btn_click(event);" />
</s:Application>
Any ideas?
Glad you found the answer ![]()
I had just redone your original posted code, same thing but changed the rect/fill to a straight bitmapimage.
David.
<fx:Script>
<![CDATA[
import mx.controls.Image;
private var ldr:Loader = new Loader();
var arr:Array = [];
ldr.contentLoaderInfo.addEventListener(Event.COMPLETE,onComplete);
ldr.loadBytes(fileReference.data);
private function onComplete(event:Event):void
ldr.contentLoaderInfo.removeEventListener( Event.COMPLETE, onComplete );
img.source = ldr.content;
</fx:Script>
<fx:Declarations>
</fx:Declarations>
<s:BitmapImage id="img" left="0" right="0" top="0" bottom="0" source ="@Embed('myimage.jpg')" fillMode="repeat"/>
<mx:Button id="btn"
<mx:Image id="newimg" x="430" y="227" width="515" height="392"/>
</s:Application>
Here are some examples of how to get BitmapImage to work with non-embedded images:
http://flexponential.com/2010/03/17/using-non-embedded-images-in-a-spa rk-bitmapimage/
http://www.tink.ws/blog/non-embedded-assets-spark-bitmapimage/
http://polygeek.com/2452_flex_extending-spark-bitmapimage
North America
Asia Pacific
