Online bank statement pdf opens blank
Apr 12, 2010 4:59 PM
All of a sudden I am not able to open my bank online statements.  I can open local .pdf files just fine and I can open pdfs from other websites just fine.  The pdf for my bank statesments is https but that has never made a difference before.
I have already tried the following:
1.  Uninstalled Adobe Reader
2.  Rebooted machine
3.  Re-installed Adobe Reader
4.  Ran a repair install of Adobe Reader.
Nothing!  It appears the file is downloading (at least that's what it says in the status bar) and then BLANK!
Suggestions would be greatly appreciated.
    Apr 12, 2010 6:16 PM   in reply to tonymuffin
    There is a free PDF reader called FoxIt.
    Try downloading it and see if the PDF in question still appears blank in FoxIt.
    If it does, it's an issue with either the browser or the website and the file being downloaded.
    If not, we'll look at what can be done with Reader 9.
    Apr 12, 2010 6:38 PM   in reply to tonymuffin
    Let's try a "clean install":
    1.  Uninstall Reader (using the Control Panel).
    2. Download and install the Windows  Installer Cleanup Utility (msicuu2.exe)
    3. Run the Windows Installer Cleanup Utility to remove the  installer for Reader 9 (and any previous versions if they are still  installed).
    4. Download and install a  new copy of Reader, and update it (if required) to 9.3.1.
    Apr 13, 2010 9:50 AM   in reply to tonymuffin
    I can open pdfs from other websites and I can open them locally just fine.
    That tells me that it probably has something to do with the way the PDF is being produced?
    Can the bank tell you what application they use to produce the PDF? If not (sometimes they don't cooperate), can they at least download a PDF for you and email it so you can open it locally and get that information from the file properties?
    Apr 13, 2010 11:13 AM   in reply to tonymuffin
    I am also having problems viewing my bank statements.  The bank says their sys
    tem does not support the 9.3.1 which I seem to have.  I tried to download the old 8 and it would
    n't let me because I had newer version.  Any suggestions for me also.
    Apr 13, 2010 12:14 PM   in reply to hmc_one
    To install 8, you need to uninstall 9, run the Windows Installer Cleanup Utility (msicuu2.exe - google it) and remove all Reader install files, then go to oldversion.com and download the 8 installer. Install it, and you can return to viewing PDFs in Reader 8.
    Apr 13, 2010 12:36 PM   in reply to 370H55V
    Alternately, you can get it from the Adobe FTP site at ftp://ftp.adobe.com/pub/adobe/reader/win/8.x/8.0/enu/AdbeRdr80_en_US.e xe
    Apr 13, 2010 1:06 PM   in reply to 370H55V
    thanks, will go try that.
    Apr 13, 2010 2:47 PM   in reply to tonymuffin
    Tony, even though my bank told me they did not support the adobe 9.3.1!
    Once I deleted the old version 9.3.1 and reinstalled the new 9.3.1  I was
    able to view my bank statements without any problem.  I had run the
    Windows Installer Cleanup Utility by that time.  SO, whatever it was
    that fixed it I am now singing Halleujah.  But about 6 hours of my time
    went into it before I had success and that was just today lol.  Hope you
    have success soon.
    Apr 13, 2010 6:47 PM   in reply to tonymuffin
    Tony, have you tried going back to Reader 8?
    Since this appears to be a problem with the bank site and their PDF generation software, Reader 8 should allow you to still access your statements until they get caught up, and then you can upgrade to 9 again.
    Apr 13, 2010 7:19 PM   in reply to tonymuffin
    tony, when mine finally worked - I had uninstalled thru control panel, then
    went to bank.  I had always been able to get into my bank account just
    couldn't look at the statements.  SO, when I went to the bank I clicked
    on the adobe.com thru the bank and it installed.  It was so frustrating.
    I spent about 6 hours today, and lots of time days before.  Good luck.
    Apr 13, 2010 9:06 PM   in reply to tonymuffin
    Can you actually view any online PDF documents, e.g. http://www.adobe.com/devnet/acrobat/pdfs/deploying_reader9.pdf ?
    Apr 14, 2010 6:39 AM   in reply to tonymuffin
    tonymuffin wrote:
    I stated already in this thread that I can view local and other online pdfs...
    Then there most certainly isn't an issue with Adobe Reader or you wouldn't be able to read any at all.
    The fact that you can read PDFs from other online sources as well as offline indicates that the problem lies in PDFs from the bank site and Reader 9 opening them properly.
    I'll stand by my recommendation of going back to Reader 8 until the Bank gets their stuff together for Reader 9.3.
    This will be my final post on this topic, regardless of what you choose to do or if it works or not.
    Apr 14, 2010 7:49 PM   in reply to tonymuffin
    Since you cannot use Reader 9.3 and cannot install Reader 8.2, then I would recommend the first suggestion in this topic: try an alternate PDF reader.
    However, if you completely uninstalled all versions of Adobe Reader, then it should be possible to install Reader 8.2; download it from http://ardownload.adobe.com/pub/adobe/reader/win/8.x/8.2/enu/AdbeRdr82 0_en_US.msi; save it to disk, then close all browser windows and run the downloaded installer.
    If you still get an error during the install, please give the full error message.
