How to overcome Error 1402 on Reader 9.3 installation?
Apr 12, 2010 9:00 PM
I am getting Error 1402 attempting to install Reader 9.3.  It points to registry problem in Hkey_Local_Machine\Software\Microsoft\Windows\Current version\Run\Optional Components\IMAIL
I have read instructions to correct error 1402 but I am still having problems.  Adobe Reader does not appear in the Add/Install section of the Control panel.  I have used Regedit to look at the above registry key.  I can get all the way to the end where IMAIL appears.  But I do not know what to do at that point.  I am fearful of damaging the registry file until I know precisely what to do.  Can someone please step me through the instructions so that I can correct the problem?
Thank you.
Steve
    Apr 13, 2010 9:43 PM   in reply to Steve3153
    What Windows version are you using?
    Are you installing it with Administrator rights?
    You may need to change the permissions for the registry key listed in the error message, using regedit or regedt32, depending on your Windows version.
    You are right being concerned about editing the registry.  You should always take a registry backup before attempting any edits.  ERUNT is a proven tool for backup and restore registry files.
    Apr 13, 2010 11:48 PM   in reply to Steve3153
    You can check in Control Panel | Users if you userid has Administrator rights.
    If not, right-click on the downloaded installer and select 'Run as Administrator'.  You can download the installer from here http://ardownload.adobe.com/pub/adobe/reader/win/9.x/9.3/enu/AdbeRdr93 0_en_US.exe
    If the above doesn not work, follow this article on how to change registry key permissions (to Full Control): http://support.microsoft.com/kb/310426/.  Don' hesitate to ask if you need further clarifications on this.
    Apr 20, 2010 7:24 PM   in reply to Steve3153
    I have exactly the same issue since I tried to update  Adobe Reader. I have admin rights, and when I used regedit as suggested the key (same key) is not listed.  Any other suggestions?
    Thx,
    Marc
    Apr 20, 2010 7:54 PM   in reply to Rubicon4me2
    Found the key, changed the permissions, same error.
    Apr 21, 2010 9:30 PM   in reply to Steve3153
    Steve - I've spent weeks on this and most recently hours tonight.  I finally got it through changing the permissions and owners in the registry.  I could not find the post of the person who posted instructions for changing the registry.  After tweaking it worked.  I have Windows 7, 64-bit, Firefox 3.63, Adobe Reader 9.2.  For error 1402 - the error says MACHINE32 but it is a misprint - it is actually MACHINE.  I think that since I have 64-bit I had to add:  "Wow6432Node" between SOFTWARE and Microsoft in the location given in the error message to find the Run\OptionalComponents\MSFS, IMAIL, and MAPI.
    Run regedit.exe
    Find MSFS, IMAIL, and MAPI
    In each change the permissions to full control of CREATOR OWNER, Administrator, Administrators, Users (my name), SYSTEM
    Change OWNER in each of those 3 to SYSTEM
    Change OWNER in OptionalComponents to SYSTEM
    I was sure to click "APPLY" any time I made a change.  When done, I successfully updated to Reader 9.3.
    Some of these changes may be unnecessary - but I didn't know which ones - so I changed them all.
    I am the only one using my computer and I don't know if these settings should not be used if the computer is shared.
    Good luck to all who are having this problem.  I hope this works for you.  Over the past few weeks I've had to shut down the computer & when turning it on, press F8 to USE THE LAST GOOD CONFIGURATION since I thought I might have screwed up the registry - and then I'd try again.  Don't give up!
    Apr 21, 2010 10:10 PM   in reply to Steve3153
    Again, good luck!
    May 6, 2010 2:12 PM   in reply to regina33
    Hello regina33;
    Following your instructions, I can get as far as "Run" then when I click on "OptionalComponents" I get the following message:
    Error Opening Key
    OptionalComponents cannot be opened.
    An error is preventing this key from being opened.
    Details: Access is denied.
    Did you run across this error when you performed this regedit?
    I presently have Adobe Reader 9.1.2 and can't update to 9.3. Even tried to uninstall and was denied.
    Any help will be appreciated.
    May 6, 2010 5:17 PM   in reply to gojoagogo
    Hey gojo - I couldn't either until I did a search for "MSFS" and that appeared under something like "wow6432."  The address I found was a bit different than the one in the error message.
    Good luck
    May 6, 2010 6:27 PM   in reply to regina33
    Hello regina33:
    Thanks for your reply. I did the search for "MSFS" and was directed to "LEGACY MSFS", is this correct location? If yes, how do I change the IMAIL and MAPI? I did a search for both IMAIL and MAPI but no results.
    May 6, 2010 7:35 PM   in reply to gojoagogo
    I have Windows 7 so this may be a bit different.  I did not have "LEGACY".  I'd try it - though I'd check to see if there are any other MSFS's.  I counted on being able to restore my registry from the last good one by pressing F8 when booting up - just in case I screwed something up.  Maybe the IMAIL & MAPI will appear after you get permissions to MSFS.
    Good luck!
    May 6, 2010 9:16 PM   in reply to regina33
    I have Windows 7 Home Premium 64 Bit and this "LEGACY" thing I get concerns me as it's different from what you got and it apprears we both have the same Windows 7 system. It would be so much easier if Adobe would just release a fix for this mess. What is scarey is the fact I can't delete Adobe Reader and remain a security risk with the  older version 9.1.2.
    I'm not sure what I will do now. Thanks again for your input.
    May 6, 2010 9:26 PM   in reply to gojoagogo
    Try a search for "wow."  Let me know.
    May 7, 2010 5:31 PM   in reply to regina33
    Hi regina33:
    I did the registry search for "wow" and no results were found.
    I did a "Bing" search on the internet for "Error 1402 HKEY_LOCAL_MACHINE32/..." and found out Adobe Reader isn't the only program assosiated with this. I found that some people with Kaspersky products also have gotten this type of Error when they try to uninstall or install.
    May 7, 2010 6:23 PM   in reply to gojoagogo
    Did you actually find MACHINE32?  I only found MACHINE.  Either way - if you screwed up your registry, you could always restore it from the last good one.
    Again, good luck.
    May 9, 2010 8:03 PM   in reply to gojoagogo
    Put this in the FWIW category - but I was having the same 1402 error involving msfs registry key (XP) when trying to update Acrobat Pro 9.
    Downloading and running Dial-a-fix allowed the update to finish.  http://wiki.lunarsoft.net/wiki/Dial-a-fix  Download link is 3/4 of the way down the page. Use the 2nd download location - the first returned a corrupt file.
    Run the software and use the hammer icon. This will open advanced tools and you need to choose the "repair permissions" option. Runs in two parts.
    Afterwards I was able to do the update w/o even a reboot. Then did a reboot w/o issue and Adobe updater was able to complete a follow-up update with no problems.
    May 9, 2010 8:36 PM   in reply to wbm5656
    It appears Dial-a-fix isn't compatible with Windows 7 64 Bit.
    May 10, 2010 10:03 AM   in reply to Pat Willener
    Ok people, I am really green when it comes to computers.  What the heck is the key and how do I find it? I cannot get this darn reader to work and I need it badly. Someone help or else this computer is going out the window.  lol
    May 10, 2010 10:30 AM   in reply to jolenejude
    The key is located in your registry.  You can do a search of your C drive to find the registry.  It might be best if you had a friend with you before attempting to change your registry.  This friend should have some familiarity with the registry.
    May 12, 2010 11:24 AM   in reply to regina33
    I used the Windows Installer Cleanup  Utility to remove Adobe Reader which worked then tried to install Adobe Reader 9.3 which once again produced the Error 1402. I have given up and excepted that I can't use Adobe Reader with my  Windows 7 64 Bit, no great loss. I have installed the Foxit PDF Reader which has a free version. It comes with a Foxit Toolbar which I don't like to use toolbars but can easily be removed through your "Programs and Features".
    http://www.foxitsoftware.com/pdf/reader
    May 12, 2010 11:48 AM   in reply to gojoagogo
    Sorry I couldn't help
    May 12, 2010 12:41 PM   in reply to regina33
    I do appreciate you trying to help. I don't know have much you use Adobe Reader but you may have the same problem everytime Adobe Reader has a new update. If you do have problems in the future, give "Foxit PDF Reader" a try. It's a smaller program only 10.6 MB and works the same way Adobe Reader does for reading PDF files. CNET gives it 5 Stars.
    May 12, 2010 1:41 PM   in reply to Steve3153
    You're welcome. I think you will enjoy using it, low resources and does a great job reading PDF files. I wasn't  having the Erorr 1402 on my Windows XP but I removed Adobe Reader and installed Foxit PDF Reader because I was so impressed with the way the program performed on my Windows 7 64 Bit.
    Jun 30, 2010 7:54 AM   in reply to regina33
    This solution is correct, only you have to first change the owner, before you are ALLOWED to make changes in permissions.
    Feb 2, 2011 7:51 AM   in reply to Steve3153
    I worked all day on
    the problem and tried all suggested solution but no help. Finally, I tried to run the Norton Antivirus that found 23 threats. The problem was solved immediately and the system is back to normal. I think the company offering and selling their products put the virus. Good Luck, kakabator
