When I try to use my Flash Media Live Encoder to stream on ustream, I keep getting an error that says, "Assertion Failed! Program: ... File: .\inpin.cpp Line: 516 Expression: SUCCEEDED(hr) For information on how your program can cause an assertion failure, see the Visual C++ documentation on asserts. (Press Retry to debug the application - JIT must be enabled)" Then there are three buttons, Abort, Retry, and Ignore. Abort causes FME to quit, Retry does nothing, and Ignore does nothing. If it makes any difference, I just got a new computer with Windows 7. When I used FME on my old computer with Windows XP, it worked. What can I do?
Here's more details about what happens (after playing around some more).
When I open of FMLE, it seems to be fine. I can hook up my Dazzle and it can obtain video and audio from Dazzle. When I go to start my stream on ustream, I just get the loading ring, though on my stream (using FireFox). When I click the "Stop" button at the bottom, then I get the error message, and the stream actually gets an image (but very low quality, no sound, and only an image, not video).
Here is the log of my activities when testing this out:
Wed Apr 14 2010 17:05:30 : Primary - Connected to FMS/3,5,1,517
Wed Apr 14 2010 17:05:30 : Primary - Stream[He40Ok91Fvpp26CoMggOLu7VIdZ0MyStoffair] Status: Success
Wed Apr 14 2010 17:05:30 : Primary - Stream[He40Ok91Fvpp26CoMggOLu7VIdZ0MyStoffair] Status: NetStream.Publish.Start
Wed Apr 14 2010 17:05:30 : Session Started
Wed Apr 14 2010 17:05:31 : Primary - Network Command: moduleInit
Wed Apr 14 2010 17:05:31 : Primary - Network Command: moduleInfo
Wed Apr 14 2010 17:05:32 : Primary - Network Command: broadcastStarted
Wed Apr 14 2010 17:06:22 : Primary - Stream[He40Ok91Fvpp26CoMggOLu7VIdZ0MyStoffair] Status: NetStream.Unpublish.Success
Wed Apr 14 2010 17:06:25 : Video capture device not selected. Please select video capture device connected to your system.
Wed Apr 14 2010 17:06:28 : Selected video input device: Dazzle DVC100 Video
Wed Apr 14 2010 17:06:36 : Audio source does not support the selected sample rate and/or channels. Re-sampling the audio to desired setting.
Wed Apr 14 2010 17:06:36 : The selected audio device "Dazzle DVC100 Audio Device" doesn't allow setting volume intensity. Disabling the volume slider control.
Wed Apr 14 2010 17:06:39 : Resample Required.
Wed Apr 14 2010 17:06:40 : Primary - Stream[He40Ok91Fvpp26CoMggOLu7VIdZ0MyStoffair] Status: Success
Wed Apr 14 2010 17:06:40 : Primary - Stream[He40Ok91Fvpp26CoMggOLu7VIdZ0MyStoffair] Status: NetStream.Publish.Start
Wed Apr 14 2010 17:06:40 : Session Started
Wed Apr 14 2010 17:06:40 : Video Encoding Started
Wed Apr 14 2010 17:06:40 : Primary - Network Command: broadcastStarted
Wed Apr 14 2010 17:07:42 : Primary - Network Command: moduleInfo
Wed Apr 14 2010 17:07:56 : Primary - Network Command: moduleInfo
Wed Apr 14 2010 17:08:00 : Video Encoding Stopped
Wed Apr 14 2010 17:08:00 : Session Stopped
Wed Apr 14 2010 17:08:03 : Primary - Network Command: moduleInfo
Wed Apr 14 2010 17:08:07 : Audio source does not support the selected sample rate and/or channels. Re-sampling the audio to desired setting.
Wed Apr 14 2010 17:08:24 : Resample Required.
Wed Apr 14 2010 17:08:24 : Primary - Stream[He40Ok91Fvpp26CoMggOLu7VIdZ0MyStoffair] Status: Success
Wed Apr 14 2010 17:08:25 : Primary - Stream[He40Ok91Fvpp26CoMggOLu7VIdZ0MyStoffair] Status: NetStream.Publish.Start
Wed Apr 14 2010 17:08:25 : Session Started
Wed Apr 14 2010 17:08:25 : Video Encoding Started
Wed Apr 14 2010 17:08:25 : Primary - Network Command: broadcastStarted
Wed Apr 14 2010 17:08:25 : Primary - Network Command: moduleInfo
Wed Apr 14 2010 17:08:37 : Primary - Network Command: moduleInfo
Wed Apr 14 2010 17:08:39 : Primary - Network Command: moduleInfo
I'm running on Windows 7 Home Edition and using Dazzle DVC 100 Video
I have the same problem, running windows 7 ultimate, 64-bit, FMLE 3.1, dazzle dvc100 with vista 64-bit drivers. When i select DVC100 as audio source on FMLE, it gives me this error. I also noticed that it shows it 2 times, but second time line part is line:533, when first time its line:516 like in the picture.
Thu Apr 15 2010 18:37:39 : Selected video input device: Dazzle DVC100 Video
Thu Apr 15 2010 18:37:39 : Selected audio input device: Dazzle DVC100 Audio Device
Thu Apr 15 2010 18:37:41 : Audio source does not support the selected sample rate and/or channels. Re-sampling the audio to desired setting.
Thu Apr 15 2010 18:37:41 : The selected audio device "Dazzle DVC100 Audio Device" doesn't allow setting volume intensity. Disabling the volume slider control.
Thu Apr 15 2010 18:37:49 : Resample Required.
Thu Apr 15 2010 18:37:50 : Primary - Connected to FMS/3,5,2,654
Thu Apr 15 2010 18:37:50 : Primary - Stream[[PRIVATE STREAM NUMBER HERE]] Status: Success
Thu Apr 15 2010 18:37:51 : Primary - Stream[[HERE TOO]] Status: NetStream.Publish.Start
Thu Apr 15 2010 18:37:51 : Session Started
Thu Apr 15 2010 18:37:51 : Video Encoding Started
On my stream, it says live but doesn't show any video, or sound. If i select any other recording source, my dazzle video comes out fine.
Yes, i can stream when i select other audio source, for example stereo mix. Then video is fine, and it had been fine for video and audio on XP too. Other thing i found out, that Virtual audio cable doesn't also recognize DVC100 audio device on win 7 , but on xp it did.
The Dazzle dvc100 vista 64-bit drivers are only ones available atm, that work on windows 7. Pinnacle haven't made windows 7 drivers for dazzle dvc100 yet, so vista drivers are all i can use atm. also, audio works on Pinnacle studio 12.
To any and all who are still having difficulties with this issue, search for and download the MLE version 3.0. There is obviously a bad compile or library linked to version 3.1. I was having the same issue with an AverMedia card, downgraded to v3.0, and it works perfectly fine now. After I had downgraded, I received an error stating that the audio sample values currently selected did not match the imput source and the values were automatically updated to 'compatible' numbers. If Adobe is intending to review/fix this bug, perhaps that is where the issue originates? In any event good luck to you...
North America
Asia Pacific
