I need to get only this year's publications. Here's my where clause:
where pubdate = '2010'
and it generates an error. How can I set the criteria to get only this year's results?
THansk,
Jenn
Ok, if your code errors... make sure to post the error. Also if you're posting SQL questions, make sure to post the datatype of the columns concerned. And the DB system you're using.
I suspect your column is a date or timestamp or something? If so, you cannot compare it to a string, you can only compare the same data types (on the whole... there are some exceptions there, but not relevant to your situation).
Also, if the date value is "2010-04-20" (ie: today), then it's not going to match "2010" is it: because those are two different things.
What you need to do is to consult your DB's docs, and find out if there's a function for extrsacting the year part of a date (in indeed your column is a date), so you can compare like-for-like. The function name and how it works will be specific to your DB system.
Adam
In addition to Adam's answer, and assuming that the datatype is date or timestamp, using functions in the where clause are sometimes slower than using the actual fields. For your specific example,
where datepart(year, YourDateField) = 2010
might not be as optimal as
where YourDateField >= 1 jan this year
and YourDateField < 1 jan next year
Plus, if YourDateField is indexed, you really don't want to use a function.
North America
Asia Pacific
