Hi All,
I have created chart using CFCHART. Its working fine in my local system in ALL BROWSERS. But when moved it to my staging sever the CFCHART not rendering in IE(workign in all other browsers).
IE chokes on some code in your CFIDE directory. Just make sure your website has access to the CFIDE directory and it will work.
It needs access to the http://yourwebsite.com /CFIDE/Scripts/ directory.
Hi Hippiex,
I don't have accses to the
i got an error 404 file or directory not found.
what else i can do in order the cfchart will work in IE?
thanks,
yaffa.
Add a virtual directory that points to your CFIDE folder.
Hi BSW2,
how do i can add a virtual directory that point to my CFIED folder?
thanks,
yaffa.
Hi Dileep_NR,
I have just(!) The same problem,
(my cfchart working fine in my local cold fusion administrator in all browsers, and in the remote environment the cfchart not displying in IE)
I need help urgently!
Did you find a solution?
thanks a lot,
yaffa.
