Adobe installer "failed to initialize" error.
Apr 20, 2010 10:52 PM
I have been trying without success for 2 days to install the tr
ial version of Flash Builder 4 but cannot get past the following erro
r - displayed affter launching the Set-up.exe in the Adobe flash Builder 4 Standalone folder.
The following information is showing the PDApp.log file:
4/21/2010 15:38:09 [INFO] Setup - Build Version - 1.0.172.0
4/21/2010 15:38:09 [INFO] Setup - Logging Level verbosity Set  to 4
4/21/2010 15:38:09 [INFO] Setup - Start Adobe Setup
4/21/2010 15:38:09 [INFO] Setup - TimeLog: Bootstrapper Start
4/21/2010 15:38:09 [INFO] Setup - TimeLog: Start initial checks
4/21/2010 15:38:09 [INFO] Setup - Dictionary Path: C:\Documents and Settings\SW102124\My Documents\Adobe\Adobe Flash Builder 4 Standalone\resources\Dictionary\en_US\stringTable.zdct
4/21/2010 15:38:09 [INFO] PIM - Trying to access xml at path:C:\Documents and Settings\SW102124\My Documents\Adobe\Adobe Flash Builder 4 Standalone\resources\setup.xml
4/21/2010 15:38:09 [FATAL] PIM - Failed to Create XML instance : DOMDocument40 ADXML::initWithXMLPath Error:80040154
4/21/2010 15:38:09 [FATAL] Setup - Could not initialize ADXML object
4/21/2010 15:38:09 [FATAL] Setup - Unable to initialize. Error parsing setup.xml file
4/21/2010 15:38:09 [WARN] Setup - Reboot is pending from earlier installation.
4/21/2010 15:41:05 [INFO] Setup - End Adobe Setup. Exit code: 0
I am running XP service pack 2.
I have installed and continue to use Flex Builder 3.
Also running fully licensed copies of MS Vis Sudio 2005 and 2008, Adobe Master Collection CS4 and CS3; also trial version of WebOrb - all of which are working fine.
I have been running the setup/install using an account with admin rights
I have tried installing after booting up in Safe mode - doesn't help
I have confirmed that my account has full control over all the folders/files in the installation package
I have tried the install with virus protection turned off, and have tried right click>Run As> Current user - with "Protect my computer..." unchecked.
I suspect that I am either missing a dll or a dll needs to be registered - most likely the one required for opening and parsing the setup.xml file shown in the error log above, however, I have no idea which dll(s) are implicated.
Any help will be very gratefully received!
    May 4, 2010 7:34 AM   in reply to chris_taplin
    Hi Chris,
    It seems that a particular dll which is missing or corrupted on your machine. I would suggest you try to repair your installation of Windows XP with the windows install CD and then try to install Flash Builder.
    Let me know if this fixes your problem. In case it does not then do post the PDApp.log file.
    May 4, 2010 11:30 AM   in reply to ritesh kapoor
    Hi Chris,
    You could try installing the MSXML Service Pack 7 posted on Microsoft website. In my previous post, the attempt was to ensure that MSXML was properly installed on your machine by trying to repair the Windows installation - however this would be a time consuming exercise and I would suggest you try this alternative. Details below -
    1) Go to the webpage -  http://www.microsoft.com/downloads/details.aspx?familyid=28494391-052b -42ff-9674-f752bdca9582&displaylang=en
    2) Scroll down and click on the Download button next to msxml3.msi (size 1 MB). Its a small file and will take a few moments to download.
    3) Double click this file to launch the installer for MSXML.
    4) Follow the screen instructions and the installer should finish in a few seconds.
    5) Try installing the Flash Builder.
    Do post your observations and let me know if this fixes your problem.
    May 4, 2010 8:04 PM   in reply to chris_taplin
    Go to your temp directory and remove all the temporary files. Then retry the install.
    May 5, 2010 3:42 AM   in reply to chris_taplin
    Chris,
    Could you confirm whether after you reinstalled your OS if you were able to install Flash Builder 4 successfully?
    May 6, 2010 11:06 AM   in reply to chris_taplin
    Thanks for sharing this Chris. I'll try to dig deeper in this issue and try to corner down the exact problem.
    Nov 6, 2011 5:07 AM   in reply to chris_taplin
    This error occurred on my laptop! Here is my workaround:
    Change the computer's clock to the correct time!
    I hope this help eveyone!
    Jun 21, 2012 6:49 AM   in reply to pghoan
    Thanks for this clock correction suggestion.  I had borrowed someones pc which displayed the date 01/01/2007.  I was racking my brain with this Flash download problem and didn't fancy the detailed work around suggested by others.  I corrected the date and the download completed properly.  Thanks again.
    Jun 30, 2012 9:06 PM   in reply to Purpleultra
    You're welcome!
    Date: Thu, 21 Jun 2012 07:49:51 -0600
    To: onsiteconsultant@hotmail.com
    Subject: Re: Adobe installer "failed to initialize" error. Adobe installer "failed to initialize" error.
        created by Purpleultra in Installing and activating Flash Builder - View the full discussion
         Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Re: Adobe installer "failed to initialize" error.
         To unsubscribe from this thread, please visit the message page at Re: Adobe installer "failed to initialize" error.. In the Actions box on the right, click the Stop Email Notifications link.
         Start a new discussion in Installing and activating Flash Builder by email or at Adobe Forums
      For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
