lombardodl
How do I convert a PDF File to a JPEG File?
Apr 30, 2010 10:56 AM
I have a photo that I scanned. The printer/Computer scans it using Adobe Reader 9. I need to convert the photo to a JPEG file. I have NO idea how to do this.  Can someone please give me an easy to do this?
    Apr 30, 2010 11:58 AM   in reply to lombardodl
    It can't be done with Reader unfortunately.
    Reader isn't doing the scanning or involved at all in the scanning process short of viewing the file after it's been scanned. You need to check the settings in your scanning software to see if it has the option to save as a .jpg (it should).
    Apr 30, 2010 7:49 PM   in reply to lombardodl
    Also, if you already have the scanned object as a PDF file, there are many (free) online converters - search Google for 'PDF to JPG converter' and you will find one that will do the conversion for you.
    The quality of the JPG will probably be better if you scan it directly as a JPG (or PNG) file.
    May 3, 2010 8:07 PM   in reply to lombardodl
    The simplest way is to use Zamzar.com which is an online software that can help you convert PDF to Image. As it is free, so I am not sure the quality would meet your needs. For me, I would like to use PDF to PowerPoint Converter, which can preserve the photo in slides with high quality and  you can easily set the size and quality. Then you can save it as JPEG. Choose an approach you like. ^_^
    Jun 21, 2010 2:51 PM   in reply to lombardodl
    You can do it with OpenOffice.org's Word Processor (I forget what exactly it is called, it may in fact just be "Word") if I remember correctly.
    But aside from third-party utilities, there is no way to do it from Adobe Reader, unfortunately.
    Jun 21, 2010 3:02 PM   in reply to ssmith4822
    Again, Reader isn't involved in scanning the file at all. It only opens it when the scan is done because their scanning software is saving it as a .pdf.
    Instead of going through a lot of trouble and extra steps to convert the .pdf to a .jpg, simply look at the scanner settings and change it from .pdf to .jpg.
    Jun 24, 2010 10:42 AM   in reply to lombardodl
    Use Open Office to open or import the file.
    Jun 24, 2010 12:02 PM   in reply to Poor Country Boy
    Ok. I give up. You can all stop now.
    Jun 29, 2010 2:32 AM   in reply to lombardodl
    You can try zamzar.com, which can help you convert PDF file to a JPEG file. You just need a coffee to wait for the conversion result.
    Sep 22, 2010 1:04 PM   in reply to ~graffiti
    My scanner is set to scan pictures to JPEG.  But it seems that Adobe Reader just came in and took over and then the pictures came out in PDF and I've been unable to change back to JPEG.  I wish someone would tell me how to make that change in simple terms.
    Sep 22, 2010 1:21 PM   in reply to DJL3365
    Check your scanning software. It is creating the PDF, not Reader. Reader is simply the application used by your computer to open PDF's.
    Oct 5, 2010 11:50 PM   in reply to lombardodl
    http://www.mediafire.com/?z656uuu34lbzmcg
    Oct 8, 2010 6:28 AM   in reply to narmada engineers
    I did get it taken care of.  I just uninstalled Adobe Reader and I had no
    more problem with my files.
    Jun 23, 2011 8:30 AM   in reply to lombardodl
    Using an online converter is sure a right way to handle this task. However, the one indicated above does not work (I've waited forever but nothing happened). I found another PDF to JPG converter which works just fine. Enjoy!
    Jun 23, 2011 8:32 AM   in reply to lombardodl
    (sorry for the double post, my browser tricked me )
