RE: "Unable to create font" After Effects CS 5 won't launch
May 1, 2010 7:16 AM
My spanking new After Effects CS5 won't launch due to "Unable to create font" error.
I'm running OS X 10.6.3 on a 17" with specs listed below.
After Effects CS3 is running fine. What's the solution?
Model Name: MacBook Pro
  Model Identifier: MacBookPro5,2
  Processor Name: Intel Core 2 Duo
  Processor Speed: 3.06 GHz
  Number Of Processors: 1
  Total Number Of Cores: 2
  L2 Cache: 6 MB
  Memory: 8 GB
  Bus Speed: 1.07 GHz
  Boot ROM Version: MBP52.008E.B05
  SMC Version (system): 1.42f4
  Serial Number (system): W89400R18YB
  Hardware UUID: E2300327-D5D3-5DC2-85CF-9FFA9CEAD9ED
  Sudden Motion Sensor:
  State: Enabled
    May 1, 2010 8:07 AM   in reply to billsantry
    Start with the solutions listed here:
    http://aeerrors.myleniumstuff.de/?p=482
    May 1, 2010 4:47 PM   in reply to billsantry
    Same for me, I'm trying a lot of things but nothing work – I keep checking and let you know If I've got a solution
    May 3, 2010 8:14 AM   in reply to Maherso
    There are 3 possible issues on the system. A corrupt font, a corrupt Adobe font list and/or a corrupt system font database.
    Try the following:
    1) On the Mac, delete all copies of the AdobeFnt.lst on the system. They will have a name like AdobeFnt10.lst, AdobeFnt11.lst, etc.. On the Mac this will be found in the /Library/Application  Support/Adobe/PDFL/9.0/Fonts folder.
    2) Then restart the system holding down the S key while the system is starting up for Safe Mode. That will reset the system database.
    On Windows,
    1) search and delete the AdobeFnt.lst files found in C:\Program Files\Common  Files\Adobe\PDFL\...,
    2) restart the system.
    May 3, 2010 8:44 AM   in reply to Will Lockwood
    Hi Will,
    I did all that but nothing fixed the problems. Finally, I'm suspecting a corrupted drive. When I fix the drive with fsck command it gets corrupted after each system launch. I plan to clone my system on another drive, boot from the new one, check if everything is ok. I let you know.
    May 3, 2010 8:49 AM   in reply to Maherso
    Bummer. Sorry to hear that. Let us know how this works out.
    Mar 3, 2012 12:59 AM   in reply to billsantry
    Finally I found the solution, I don't know if it's gonna work for you, but you should give it a try. After hours of troubleshooting, I found that a missing Verdana Fonts (version 1.0 from Microsoft) is causing the problem. Just put Verdana in YourHardDrive/Library/Fonts and AfterEffects CS5 should start normally. It would be cool to have a better dialog box like "Unable to create font - please locate and Install Verdana".
    For your convenience, you can download Verdana here : [removed by moderator, since Verdana is not a freely distributable font]
    Enjoy
    May 3, 2010 12:00 PM   in reply to Maherso
    Hi Will
    I posted a solution that works for me.
    May 11, 2010 4:17 AM   in reply to Maherso
    After Effects Warning Unable To Create Font
    @Maherso
    Thanks that works perfect.
    Verdana, Typeface and data © 1996 Microsoft Corporation. All Rights Reserved Version 2.45 - Thursday, 8 April 2004 08:00
    May 11, 2010 4:35 PM   in reply to Maherso
    your link to the font is gone. (sigh).
    could you reupload, please?
    Mar 3, 2012 2:12 AM   in reply to karolus ka
    Hi Karolus,
    The link is now working, enjoy...
    [removed by moderator]
    Jun 19, 2010 6:51 AM   in reply to Maherso
    Worked the first time! Thanks for the link too!
    Jun 29, 2010 1:01 PM   in reply to billsantry
    You can buy Verdana font from Microsoft site for 30$ (aamof from Ascender Corporation). It's not legal to download it from above links (unless this guy have license for sharing this font, and I doubt about that). It is laughing because after you spend 999$ for a software, you have to pay 30$ more for the fonts. Did Adobe have no money for licensing this font?
    Jun 29, 2010 3:18 PM   in reply to Mac0SX
    Oooops, I was sure Verdana was free. Sorry folks, you'll have to buy that font or find it in another way (try installing Office 2008 trial...). We live in a strange world full of contradictions.
    Sep 10, 2010 12:55 AM   in reply to Will Lockwood
    I tried this soln ..and it's worked finally
    Sep 10, 2010 8:47 AM   in reply to jackie.vishwakarma
    The After Effects CS5 (10.0.1) update should fix this problem.
    Oct 28, 2010 7:28 AM   in reply to Todd_Kopriva
    For me the Adobe update *DID NOT* fix this but copying over and activating the Veranda family of fonts from my MBP that had Office on it, did - kind of a sorry situation if this is what's actually needed to fix it but at least there is a way.
    Jan 31, 2011 8:01 AM   in reply to billsantry
    I had the same problem. Also after updating AE. But this worked for me:
    Activate the verdana font in your system Fontbook (dutch: Lettertypecatalogus).
    (Suitcase Fusion 3 turned it off)
    Grtz,
    Code d'Azur
    Feb 24, 2011 12:46 PM   in reply to billsantry
    The Verdana trick worked for me too. AE’s type engine fails if there isn’t a font at /Library/Fonts/Verdana.ttf —common, simple programming problem. Mahalo for posting all this, guys!
    Calculating status...
    Mar 21, 2011 6:40 PM   in reply to Todd_Kopriva
    And a March 2011 download of the Master Collection & update to 10.0.1 (everything that updates) reveals that the same issue still exists. Installing Verdana "fixes" it. <font family="Verdana">Idiots.</font>
    Apr 8, 2011 8:00 AM   in reply to Maherso
    Thank you!!! This totally worked for me!!
    Apr 11, 2011 11:32 PM   in reply to Maherso
    Just want to add that this worked for me. But it didn't at first. I moved Verdana to the right place but it did not work. The problem was that you need all the files. I had them all but not "Verdana Italic.ttf" for som reason. I had to get that from a disc and then it worked. So make sure you get them all to /Library/Fonts/.
    Verdana Bold Italic.ttf
    Verdana Bold.ttf
    Verdana Italic.ttf
    Verdana.ttf
    Apr 25, 2011 7:05 AM   in reply to billsantry
    Worked for me (I ended up adding all the Verdana affiliates as well....bold..italic..etc)
    Such a relief, as I had already gone through a reinstall, and several other troubleshooting workarounds...
    thanks!!!
    jon
    Jun 7, 2011 8:30 AM   in reply to billsantry
    I'm running OSX 10.6.7 and started getting this error after validating my fonts & resolving duplicates in Font Book. Verdana was still installed on my machine (worked in Photoshop & Illustrator), but for some reason After Effects wasn't able to locate it, hence "Unable to create font."
    What worked was re-installing Verdana, which caused another duplicate. Oh well, at least it works again.
    Jun 7, 2011 10:27 AM   in reply to iamshaun
    It's important that you install the specific version of Verdana that comes with AE… probably something to do with its ID #… sounds like you got it figured out!!
    All contents are confidential. Delete if you are not the intended recipient.
    Jun 7, 2011 10:28 AM   in reply to thinkingmanhawaii
    Yep, got it going. Thanks man!
    Aug 5, 2011 4:37 AM   in reply to iamshaun
    Thanks guys
    Nov 3, 2011 3:21 AM   in reply to billsantry
    had the same problem but solved in a little different way since I have no Administrator privileges. I use Fontexplorer to manage my fonts instead of Fontbook. I've found in it multiple versions of Verdana font . I removed everything but system Verdana, now everything works.
    Lorenzo
    Nov 21, 2011 11:06 AM   in reply to Todd_Kopriva
    I updated to the current after effects and I am still getting this problem. I have homework to finish today. Please help! :-)
    Nov 21, 2011 11:15 AM   in reply to suz56
    I went into type book and activated verdana in computer and inactivated verdana in user. It worked.
    Dec 7, 2011 6:47 AM   in reply to Maherso
    And now for something completely different:
    I was having this problem and I went to the Fonts folder and saw that Verdana was there!  Just for giggles, I went ahead and dragged the font out of the folder and, yes, After Effects worked just fine for me afterwards!
    I'm running a 2.66 GHz Intel Core 2 Duo iMac on 10.6.8, but this problem also reared its ugly head when I was running 10.5.
    Feb 17, 2012 3:49 PM   in reply to billsantry
    May 8, 2012 9:25 AM   in reply to billsantry
    I have encountered the same problem on OSX 10.7.3 and I searched for Verdana in the FontBook to find that it was only disabled. Try this first; all you may need to do is enable the font family.
    I hope this is helpfull and nobody needs to spend 30$ to fix this error.
    Oct 31, 2013 7:34 PM   in reply to CristianM7
    This bug is fixed in the After Effects CC (12.1) update:
    http://adobe.ly/AE_CC_12dot1_details
    Let us know how this works for when you've tried with the new update.
    Nov 5, 2013 6:22 AM   in reply to Todd_Kopriva
    Well Todd, seems the newest version has the same problem, or perhaps an unrelated issue. Just upgraded to Mavericks yesterday (10.9) and I'm running AE 12.1. Closed AE last night after working on a project successfully for 4 + hours, tried to get back to work this morning and I see the following error messages. Is this related?
    Nov 5, 2013 6:38 AM   in reply to ericsbowman
    That's a different (but related) failure.
    If you are using a font manager (like Font Explorer), then re-enable the font.
    See this thread:
    http://forums.adobe.com/message/5807941#5807941
    Nov 5, 2013 6:48 AM   in reply to Todd_Kopriva
    Thanks Todd.
