Flash Player will not install on Win XP with IE 8
May 1, 2010 10:35 AM
I am having the same trouble as many others, please help. I am unable to install
the flash player successfully. Also, please do no refer me to the old generic threads. They have not worked. I have unins
talled every adobe product, restarted my computer and attemptted a re-install which does not work.
I am an administrator.
My system is Win XP (version 5.1 service pack 3) 32bit OS
I am running Internet Explorer 8.0.6001.18702
thank you
    May 1, 2010 6:41 PM   in reply to fred_durst
    Try downloading the offline ActiveX installer for Internet Explorer http://fpdownload.adobe.com/get/flashplayer/current/install_flash_play er_ax.exe; save it to disk, then close all browser windows and run the downloaded installer.
    May 7, 2010 2:12 PM   in reply to fred_durst
    Hi, Yes, many problems do get solved. However, this is a user forum and those of us that try to help are few. Even tho the operating systems that people use are the same, the various add ons, Anti-Virus programs, etc are not.
    Your second post that describes the message you received about the ActiveX Control. This tells me that something is preventing the install of it. You said you are using the Administrator account, which is a must. So next would be your Anti-Virus/Spyware or Firewall. Any adblock or pop up blocker software in use. Your security settings also come into play. If the security setting is set to block an install of ActiveX Controls, then that message would be given.
    Post back what Anti-Virus program you use with a version number if possible. This is necessary as many of these programs have various components that need disabled. Does the Anti-Virus program have a Firewall and if not, do you use any third party Firewall?
    eidnolb
    May 10, 2010 7:21 AM   in reply to fred_durst
    Hi, thanks for your reply. Just a bit of info about Norton, and this would include McAfee as well. I think what is happening is that after you run the Uninstaller and Reboot(restart) your computer and before you run the Installer, Norton automatically re-enables itself. So then it blocks the install of the ActiveX Control. The various Anti-Virus programs and their Firewalls if included work differently.
    Norton 360, NIS 2009 and NIS  2010 have various components and some of these need disabled as well. That is why I asked for your version number. Most of the time, just right clicking on the icon in the system tray will not disable a couple of the components.
    To have a successful Uninstall and Install of Flash Player with the Norton A/V a user has to work around it. Many users are not aware of this.
    Hope this helps explain what may be happening and why.
    eidnolb
    Jun 14, 2010 1:19 PM   in reply to fred_durst
    This is the solution that finally resolved this issue for me:
    http://kb2.adobe.com/cps/494/cpsid_49419.html
    I hope this works for you, too!!
    A damaged Windows system registry or incorrect registry permissions settings may prevent you from installing Flash Player.
    Symptoms may include:
    • During installation, you see the error message "Failed to install. For Troubleshooting please see: http://www.adobe.com/go/tn_19166."
    • Your Flash Player installation finishes with no error, but you cannot view Flash content in Internet Explorer.
    • Some sites tell you that you do not have the correct version of Flash Player, even though you have installed the latest version.
    • Some sites tell you to reinstall Flash Player, but after you do so, you see the same message.
    Permissions can be tricky, but in most cases, you can install and use Adobe Flash Player if you are logged into a Windows Administrator account. If you don't know how to do this, check with your system administrator, or read your Windows documentation.
    System administrators
    If you are a system administrator, see Registry permissions required for Flash Player install or update (TechNote tn_19148).
    Solution
    Warning! By following the directions below, you will modify the Windows System Registry. A mistake could cause serious system damage, which may require you to reinstall your operating system.
    If you are not comfortable editing the registry, get help from your system administrator or another IT professional.
    If you choose to proceed, first back up your entire hard drive, and create a Windows System Restore Point.
    Adobe Systems cannot be held responsible for damage resulting from your following these instructions.
    1. Make sure you are logged into a Windows Administrator account. If you are not, you will not be able to use SubInACL.
    2. Download SubInACL from the Microsoft Download Center.
    3. Follow the installation instructions. Make sure you install SubInACL (subinacl.exe) to the directory C:\Program Files\Windows Resource Kits\Tools.
    4. Download the reset_fp10.zip file.
    5. Open the fp10.zip file and extract the reset_fp10.cmd file to the directory C:\Program Files\Windows Resource Kits\Tools\. Note that that both this file and SubInACL (subinacl.exe) must be in this directory.
    6. Double-click reset_fp10.cmd. A command window will open, and SubInACL will run.
    7. Do not use the machine while SubInACL is running.
    8. After SubInACL finishes, you will see a prompt "Press any key to continue".
    9. Install Flash Player from the Flash Player download page.
    10. To confirm that your installation succeeded, visit the About Flash Player page. At the top of the screen, you should see a message that reads "Adobe Flash Player Successfully Installed."
    Jun 17, 2010 7:08 AM   in reply to psychrat
    Hi
    I'm having the exact same problem as fred_durst at the beginning of this thread:
    Running Win XP (version 5.1 service pack 3) 32bit OS, IE 7, and am an Administrator
    Got prompted a few days ago to upgrade Adobe Flash Player to 10.1.  Dutifully run the upgrade and got:
    "Active X control for flashplayer could not be registered"
    I, like fred_durst, have no problem with Firefox - works great.  I've also tried all the fixes described in the old generic threads to no avail.
    So I tried the suggested course of action described in
    It all appeared to go as described, but then I still got the exact same error when trying to run the Flash Player .exe: "Active X control for flashplayer could not be registered"
    So I upgraded to IE 8.  Re-ran all of the fixes, disabled McAfee, etc., etc.  Still getting:
    Any suggestions would be greatly appreciated.
    Jun 17, 2010 8:54 AM   in reply to _mikey
    Hi _mikey, Just a suggestion, but I think you would receive better help if you started your own thread(discussion)
    McAfee is most likely your problem if you are sure you are the Administrator and using that Account.
    eidnolb
