CS5 Errors: QuickTime not installed
May 1, 2010 2:09 PM
  Latest reply: thesimondo22, Aug 16, 2011 5:04 AM
Replies 1 2 3 2 Previous Next
    Aug 26, 2010 9:56 AM   in reply to kiogo75
    I've also tried every single bit of advice with no solution in sight. Our final, drastic measure -- formatting the computer that's having trouble and starting from a fresh OS install. We're planning on doing that later this week.
    Aug 26, 2010 12:19 PM   in reply to kiogo75
    @kiogo75-
    Make sure to do Steps 7 and 8:
    7. Click the lock in the Directory Utility window.
    8. Enter an administrator account name and password, then click OK.
    If you don't do those first, then you can't enable the root user.
    Also,  if it does work in Root, but you aren't subsequently able to get it to  work in the original account, then I'd advise taking the steps detailed  in this document:
    http://go.adobe.com/kb/ts_kb408993_en-us
    (Step 2 may not be applicable for this issue, but all of the other steps should be tried.)
    Aug 26, 2010 12:40 PM   in reply to Carey Burgess
    @kiogo75-
    I did everything up to step nine, but after clicking the lock, this is my screen:
    Step 9 says "Choose Enable Root User from the Edit menu."
    Any advise?
    Aug 26, 2010 5:39 PM   in reply to kiogo75
    Ok, I got past step 9 and logged in as root. Launched AfterEffects and got the following errors in sequence on startup:
    Please advise!
    Aug 29, 2010 10:09 PM   in reply to kiogo75
    @Carey Burgess, since it is not working in Root, what should I do?
    Aug 30, 2010 5:28 PM   in reply to kiogo75
    I tried everything but it seems after fx cs5 is useless on my computer ! cs4 worked like a charm, i should reinstall it so I can work.
    please adobe do something ! i'm going mad with this issue ! and i'm not alone...
    Aug 30, 2010 6:04 PM   in reply to kiogo75
    @kiogo75, if it's not working in Root, then we know it's a system-wide problem that isn't related to permissions. This would point to a firewall, web filter, or some other software process that might be blocking the QT32 Server process. Alternatively, it could mean that your installation of Mac OS is damaged.
    Do you, by chance, have a web server set up on your machine? Mac OS includes an Apache web server, although it's not enabled by default, and it's possible it's interfering. I'm just guessing here, but again we are fairly certain that something running in the background the cause.
    @bd2s, if you haven't already, try using After Effects while logged into the Root account. There are instructions for enabling and logging into this posted above. Let me know whether or not that works for you, and then we'll go from there. (Don't want to waste your time with unnecessary steps, and this will help us narrow in on the problem.)
    Aug 30, 2010 6:15 PM   in reply to Carey Burgess
    The Xserve we're having trouble with also functions as our DNS server. I'm assuming that's likely the problem?
    So, the obvious question: what changed from CS4 to CS5 that's now causing trouble, and is it going to be patched?
    Aug 30, 2010 6:29 PM   in reply to Aaron Hildebrandt
    > So, the obvious question: what changed from CS4 to CS5 that's now causing trouble...?
    Apple doesn't provide a 64-bit QuickTime component. We had to create a QuickTime server component to communicate between the 32-bit QuickTime and the 64-bit After Effects. This component uses TCP to communicate. Some aggressive software blocks this TCP communication.
    http://kb2.adobe.com/cps/857/cpsid_85711.html
    Aug 31, 2010 1:06 AM   in reply to Carey Burgess
    @ Carey Burgess
    Thanks for advice but i run win7 x64. I tried using a different account but no luck...
    I think I tried everything from this thread and others.
    I don't know if a fresh windows install will help, but it's my last chance.
    Bored to spend hours and hours on this kind of issue.
    Aug 31, 2010 5:55 AM   in reply to bd2s
    bd2s wrote:
    @ Carey Burgess
    I've read the whole thread but had a similar pb on windows vista.
    I installed Quicktime, then AE CS5 and got the "QT not found" problem.
    Then I installed iTunes with Quicktime, relaunched AE and it worked great.
    So if you've haven't install QT with iTunes, it's worth trying.
    Seb
    Aug 31, 2010 6:17 AM   in reply to Sébastien Périer
    After a fresh install it works great !
    @sebastien : I saw your message after my reinstall process, but I installed the itunes x64 + quicktime bundle and everything works. Maybe it would have been enough to install it, i'll nerver know !
    Sep 3, 2010 11:57 AM   in reply to mograph_bc
    I have same problem (Mac OS 10.6.4).
    Under root and in safe mode i have no problems. But under my accaunt it is(((
    Sep 7, 2010 8:55 PM   in reply to mograph_bc
    Had the same issues here,
    When I read the comment about the preferences I changed the permission for the folder /Users/derek/Library/Preferences/Adobe to Read and Write for staff & everyone, then I restarted the app with Command-Option-Shift held, which prompts to recreate preferences.
    This fixed the issue for me.
    Sep 8, 2010 12:29 AM   in reply to Derek Carroll
    Thanks, Derek. But in my situation, nothing has changed. (
    Sep 8, 2010 5:52 AM   in reply to K0sm0s
    @K0sm0s:
    Let's narrow down the problem further.
    Create a new user account with the same permissions as your current account (e.g. administrator or standard user), log out of your current account (don't use fast user switching), log into the new account, and then try to launch After Effects.
    Do you get the error?
    If you don't get the error in the new account, then I suspect you have login items in the original account that are interfering with After Effects, or that there are some damaged files in your original acount.
    If you still get the error in the new account, then there's a system-wide issue, most likely either damaged system files or incorrectly set permissions.
    Sep 8, 2010 9:40 AM   in reply to Carey Burgess
    In the new account i get error. But in safemode and in the root account i get not.
    Dec 23, 2010 4:36 PM   in reply to K0sm0s
    I have also still the problem. Is there in the meantime a functioning solution?
    MacOs 10.6.5 · AE 10.x
    With kind regards Addi™
    Dec 23, 2010 4:58 PM   in reply to AdiumX
    The QT32 Server that AE uses to communicate with QuickTime is looking specifically for QuickTime 7, so be sure that you have that installed.
    I believe the default option on 10.6 is to install just QuickTime X, and this wouldn't work for AE.
    Here's a document for how to install QuickTime 7:
    http://support.apple.com/kb/ht3678
    Dec 25, 2010 6:54 AM   in reply to Carey Burgess
    I installed both · QuickTime X and QuickTime 7 pro · but that did not also help with the solution!
    Jan 8, 2011 11:59 AM   in reply to AdiumX
    AdiumX,
    There are a few things that cause After Effects to report that QuickTime is not installed.
    One is the obvious one, which it sounds like you've looked into: If QuickTime 7.x is not installed, After Effects will report that QuickTime is not installed.
    The next most common reason is quite different: The TCP communication with the QuickTime server is blocked, so After Effects thinks that QuickTime isn't there at all. The fix for this to remove the blockage in communication. Sometimes the blockage is because of an aggressive firewall program, which sees the TCP communication and stops it. If this is the case, then you can either turn the firewall software off or specifically allow the QT32 Server component to communicate; instructions for letting a specific process communicate are different for each firewall program, so you'll have to look in the documentation for your security software for information about doing that. Here's a document with some more information about this general issue, though it refers to a more serious failure when the blockage happens at a different step in the After Effects startup process: http://kb2.adobe.com/cps/857/cpsid_85711.html
    Another reason is that QuickTime can fail to initialize fully because it gets stuck loading a badly written importer component. If you have any AVI importers/codecs on your Mac, this could be the issue. Here's a message that goes into some detail about that: http://forums.adobe.com/message/2808379#2808379
    Jan 8, 2011 4:05 PM   in reply to Todd_Kopriva
    Thanks! I have the rule for AE in LittleSnitch modified and now start AE correctly.
    action: allow
    process: After Effects
    destination: local-net-IPv4
    port: any
    protocol: any
    help: itself _ activate.wip4.adobe would
    Apr 12, 2011 12:47 PM   in reply to mograph_bc
    Hi i had the same problem here and  i solved with mi macbook pro files, i went to Macintosh  HD>Library>Aplications Support>Adobe>Common>dynamiclink  and bring this folder to my iMac that didn't had so i placed in the same  direction in my mac and now it works perfectly fine.
    i  don't know why in my iMac i didn't had that folder, and i uploaded to a  server so u can download it www.jorgeballeza.co.cc/dynamiclink.zip
    Jul 24, 2011 3:12 AM   in reply to mograph_bc
    Well, i tried everything but only one thing worked, format and new OS install.
    Aug 16, 2011 5:04 AM   in reply to mograph_bc
    Just had this problem, but turning all firewalls and virus checkers fixed it.
Actions
