Finally, after following these steps I've solved the "Another instance of Updater is already running", installed the patch and got CS5 working!! Thanks you all!!
I'm still not able to update Photoshop to 12.0.1 :/
I followed these steps and fixed the problem of "Another instance of Updater is already running" but now when I try to update I get another error
It says "Could not install some updates" or something like that.
Any solution?
PS: Sorry for my bad english
well the error message displayed in the scrteen
shot is specifically related to the graphic card configuration.
please note photoshop cs5 suppot only open gl graphic cards which are available from nvidia.
to check your graphic card configuration kindly run dxdiag in your run and then select display tab from the top.
I hope you're just confusing Premiere Pro CS5 with Ps CS5. Ps CS5 supports GPU features on a variety of chipsets (nVidia, ATI/AMD, Intel).
http://forums.adobe.com/message/3143341#3143341 (faq on nVidia cards supporting GPU-acceleration for Mercury Playback Engine in Premiere Pro)
BTW, the error message 3posts above says nothing about graphics cards, just that the update installation failed with errors. The OP that you replied to also doesn't mention graphic card configuration, and is related to the SSE2 support of the CPU chipset.
thx,
steve
I have installed the patch and now getting an error about my hardware.
CS5 don't run - however I will run and skip the CS5.
Spending so much time trying to make it work is ridiculous.
Googling the problem and realizes that it is not only CS5 but also other Adobe programs with similar problems.
Hello,
I have the same problem 0xc000001d right now.
I know the answer: update to 12.0.1 but it is impossible to me to do that because I not have yet running any version of Photoshop. I first downloaded the trail version (which is version 12.0.0 !!!) So I cannot update to 12.0.1 before I have run the program almost one time. And the downloaded version not runs at all.
Where I can dowload the whole Photoshop CS5 version in the last version.
Thanks for your help
function(){return A.apply(null,[this].concat($A(arguments)))}French-power wrote:
Of course you can.
http://www.adobe.com/support/downloads/detail.jsp?ftpID=4949
-Noel
Hello. The first link you provided to the update isn't available anymore, it just redirects me to the Adobe Products page and the URL says "notFound=?".
Is that link some posts above me the update I'm supossed to download and install? Also, I don't quite understand the instructions, you're telling us to download and install the upgrade by going into Photoshop CS5 and go to its Help, but I can't even launch it. Could you make it a bit more clear on what link should I use and what's the procedure?
Thanks, I have PS CS5 Trial and Anthlon 2800 2.1 GHz on a Windows XP SP3 machine.
North America
Asia Pacific
