I'm having the same "Application Error - 0xc000001d" problem. Also running an AMD Athlon with NVIDIA GeForce4 MX video card. Photoshop CS4 runs just fine, but CS5 won't launch. I've uninstalled and re-downloaded/installed four times, and still have the problem. Hope you find a DLL fix soon!
On sp2 work good on my laptop
The problem is not with Windows
"sinedrock" <forums@adobe.com> pisze:
First you must upgrade your version of windows to sp3!
I'm having the same problem and I'm running Windows XP Home SP3, AMD Athlon XP 3200+ 2.19 GHz with 2GB of memory. I'll be installing it on my Windows 7 Ultimate 64 bit with an AMD Athlon 64 machine soon to see if the problem exists there too. I'll keep PS CS2 installed until the issue is resolved.
Three months ago bought a HP, Windows 7, 64 bit system, with the Athelon Phenom II. CS5 installed and is working fine so far. I have run into keyboard changes that annoy me, and found a few things either moved around or missing from the CS4 design. My onme compaklint so far was in PS was the delete keys no longer deleted, they now bring up a fill window. When processing some of my photos I just marguw what I want gone then hit delete. Now, I have to use the control+Backshift keys, or the dropdown menu and Clear.
CHEERS...Mathew
At least you can get it . I'm thinking of uninstalling it getting my
money back.
In a message dated 5/10/2010 1:04:03 P.M. Eastern Daylight Time,
forums@adobe.com writes:
CHEERS...Mathew
resolved.
True - but the problem with Photoshop CS5 seems to be with the AMD Athlon
XP processor. Should be a way to fix the dll responsible. I do not want
to have to buy a new system just to use CS5. I'll ask Adobe for my money
back first, and continue using CS4, thank you very much.
Adobe will make enough money off everyone else, I'm sure they won't miss it
(for a while) if I don't buy (or recommend) any of their software anymore.
Besides, there are a lot of good looking things like GIMP coming out.
In a message dated 5/10/2010 1:36:29 P.M. Eastern Daylight Time,
It is either this May or June that Microsoft will no longer support
Windows XP SP2 or below with Security updates. If people want a secure system
they should update to SP3. Also SP3 made XP a lot more stable and responsive.
I hope so.
In a message dated 5/10/2010 1:49:27 P.M. Eastern Daylight Time,
I understand your frustration but I'm sure Adobe will have a fix for this
soon.
How long do they (Adobe) give you to ask for a refund?
In a message dated 5/10/2010 3:08:35 P.M. Eastern Daylight Time,
I hope Adobe will fix it soon..
Hi Herron,
I think it depends on where you placed the order. At least for the Adobe.com store North American market it is 30 days. (http://kb2.adobe.com/cps/153/tn_15327.html#Step-by-step:%20Return%20a% 20boxed%20product%20purchased%20from%20Adobe)
You're correct that Ps CS5 only has a soft requirement for XP SP3 (warning indicator on install, but install should proceed). The installer will not install on XP SP1. The issue with these Athlon chipsets is not tied to the service pack. As you've noted and it has been mentioned there is a DLL that is trying to use SSE2 when it shouldn't, thus causing the Ps process to fail initializing. Unfortunately, removal of that DLL is not a workaround solution.
I'll keep updating this thread as we get information to share.
regards,
steve
Hi Herron,
The reason I bought the new computer and the matching software was to start completely new. I still have my Window 98ME 500 mhz Pentium 2 machine thats 12 years old, and paid only $100 for it. That is where I am coming from, and was using PS4, with Elements 2 that came with my Canon 300D rebel from about 5-6 years ago. I am still shooting with the 6.3 mgb baby but added last year a Canon 10D IR conversion. I do a lot of photo stitching and needed the raw processing power to do all of this in 16 bit before conversion to 8 bit and printing. 64 bit allows for the huge temp files while the image is being created with PTgui.
The old softwares I had did not have the fine adjustments I read about in the magazines. And I am now taking a beginner photoshop class and CS4 class to get started with all of the added stuff.
I went from Ok as a Photoshop user to a ignorant child in the new softwares. It is a daunting task to learn this stuff and barely time to eat and sleep while attending college.
The new HP was a model I found online at Fry's. It was not on display at the store, and they tried to steer me to a model $150 higher. So I had them look up the model I saw online for about $550, 8 gig ram, 750 Gig hd, and the AMD Phenom II, and with the savings I bought a spare 500 Gig internal and got my nephew to install it. This gave me safe duplication of some of the key files along with an external 300 gig drive. The last purchase was a 2 Terrabyte external strictly for archiving. I have yet to get it out of the box, nor add speakers to my computer which I also have now. Not enough time to get everything done. Sigh.
CHEERS...Mathew
money back.
mailto:forums@adobe.com writes:
CHEERS...Mathew
resolved.
I did order from Adobe NA ... and I hope I don't have to take advantage of
the 30 days. I'll get rid of it long before that, but I'm hoping Adobe
figures something out ... soon ... so I don't have to.
But this is frustrating.
In a message dated 5/10/2010 4:38:43 P.M. Eastern Daylight Time,
Hi Herron,
m%20Adobe)
solution.
regards,
steve
Yes I know and figured it would work. I had posted earlier in this thread that I was going to install it on my Windows 7 64-bit system to see if it worked so I was just reporting that it had.
As for my computer here at work? It's the one I'm having the issue with since it's an Athlon XP system.
Another one here.
CS5 Works great on my LapTop with Vista and AMD Turion.
Just get the Oxc000001d error message on my desctop using
Win XP with SP3 and AMD Athlon XP2800 processor.
Have uninstall - cleaned and re-installed as per Adobe help desc
but makes no difference.
Help coming soon - I hope.
David
I'm also having this problem on an Athlon XP2500+. I know it's an old processor by today's standards but still feels fairly zippy for most stuff - including photoshop (previous versions which actually work!). I hope Adobe don't simply abandon customers who don't feel the, often unnecessary, need to have the latest spec machine.
I feel that if this thread becomes long enough Adobe will have to do something.
I assume everyone has registred the problem formally through the support portal. If not, please do. Perhaps then it'll be escalated.
I also get the application error too when trying to start Photoshop CS 5 ext."The application was unable to start correctly(0xc000001d) .Click on to close the application"I too have a AMD Athlon Processor. I have installed the CS5 Master Collection.I am unable to start Adobe Encore.I receive an "X Runtime Error" message ! I am also unable to load the Adobe Media Encoder.Getting the message"Processor does not support SSE2 instruction set"I have the same problem with starting Adobe Pixel Bender as I do with Photoshop CS5,application unable to start (0Xc000001d ) Finally Adobe SoundBooth wont start.Not bad 6 applications failing to start/load/work. My operating system is Win 7 on a PC,with all the latest updates and drivers installed. I previously used Adobe Photoshop CS4 Ext,Illustrator CS4,Dreamweaver CS4,Lightroom2.All worked with no problems.I am anxiously awaiting a fix/patch as soon as possible please.All the best from NUGCS5.
I have contacted Adobe and the National Association of Photoshop
Professionals (NAPP). I hope someone out there listens and comes up with a solution
soon!
In a message dated 5/11/2010 2:03:19 P.M. Eastern Daylight Time,
something.
North America
Asia Pacific
