Unable to update the NT registry. Variable DRIVERPATH is undefined.
May 4, 2010 5:09 AM
Hi All,
Got a bit of a problem. When i try to add a microsoft access database to the datasources in the coldfusion administrator i get the following error message:
I read the following post (http://forums.adobe.com/thread/142416) which had a possible solution for this problem,
I had same problem with x64 vista found answer
Open C:\Windows\SysWOW64\odbcad32.exe and create a System DSN using the Microsoft Access Driver (*.mdb).
Then open the ColdFusion Admin and create a datasource using the ODBC Socket driver.
Check the Trusted connection checkbox and it should work.
Unfortunately i cannot select the dsn datasource in the coldfusion administrator although i did add it to C:\Windows\SysWOW64\odbcad32.exe
Any help would be greatly appriciated.
Well the following article did work http://forums.adobe.com/message/1971734 so this topic can be closed.
My system specs are:
Windows 7 enterprise (64 bit)
Coldfusion 9 (64 bit)
Kind regards,
Nebu
