Since moving to Fireworks CS5, every single slice I export has "_s1" appended to the file name. It doesn't matter how I name the slice or change the file name in the export dialog.
I assume this is supposed to denote "state 1".
Anyone else experience this? Does anyone know how to turn it off?
I see a checkbox for "Current State Only" but it is greyed out when I CTRL+SHIFT+R and choose "Images Only".
I can't describe to you how annoying and disruptive to my workflow this has been the last couple of days. Previous versions didn't do this.
Thanks!
Thanks, I actually found that this morning.
It threw me because this window is only available if you are exporting "HTML and images", but apparently you are right in that they affect the "images only" output as well.
I guess the defaults are just different in CS5.
All is well again.
Thanks!
Hi there,
I'm having the same issue with CS5 and state names. I have used the HTML Setup to control the output of the slice names but I'm still getting s1 for the Up state which is driving me nuts. Didn't happen in CS4 by the way.
The above settings should give me the following results:
Instead I get:
Any ideas as to how to resolve this will be much appreciated.
Cheers,
sf d;-)=
Yeah, what I don't understand about this glitch is that it seems to occur randomly. Halfway through a project it will start doing in on particular pages when just a day before it wasn't. Makes for a frustration thing when you are trying to troubleshoot a problem and it turns out Fireworks is unknowingly renaming your files. Even in the naming dialog box it doesn't reveal that it's renaming...the only hint is if you try to explort it out again and it will ask if you want to replace the existing xxxx_s1.png file....only then, do you see it's happening. Then you have to spend 15 minutes on google trying to find a solution which was supplied here thankfully...Adobe I love fireworks but please address this.
North America
Asia Pacific
