[svn:osmf:] 15954: Reverting on statically binding the VideoQoSPlugin from OSMFPlayer, as per Brian's suggestion.
May 7, 2010 10:24 AM
Revision: 15954
Revision: 15954
Author:   evrijkom@adobe.com
Date:     2010-05-07 10:23:38 -0700 (Fri, 07 May 2010)
Log Message:
Reverting on statically binding the VideoQoSPlugin from OSMFPlayer, as per Brian's suggestion. In order to see the video FPS, one now needs to uncomment the "videoQoSFPS" tag in config.xml, and add custom code to load a precompiled version of the VideoQoSPlugin (from the plugins sample folder).
Modified Paths:
    osmf/trunk/apps/samples/framework/OSMFPlayer/.actionScriptProperties
    osmf/trunk/apps/samples/framework/OSMFPlayer/.project
    osmf/trunk/apps/samples/framework/OSMFPlayer/OSMFPlayer-build-config. xml
    osmf/trunk/apps/samples/framework/OSMFPlayer/src/OSMFPlayer.as
    osmf/trunk/apps/samples/framework/OSMFPlayer/src/assets/configuration .xml
