I just started using CS5 today and ran into the same issue. Every CS5 program I have open is all of a sudden disabled in terms of being able to use the space bar / cmd / option keys to get the hand tool, and magnification tool.
It happened in Photoshop and Illustrator simultaneously.
I have gone through this thread and disabled spotlight shortcuts and other keyboard modifiers used by os x by default and it is still broken. I restarted both Photoshop and Illustrator and it still does not work.
I am going to attempt re-booting my machine but if this is going to be the norm it is going to seriously impact my workflow since those are keyboard commands I use all the time.
Thanks DrunkCyclist. Be sure to try my debugging steps above ( http://forums.adobe.com/message/2846310#2846310 ) to see if there is another process that is conflicting.
I've had the same problem and i can confirm that quitting the webbrowser brings back the hand-tool in Photoshop. Adobe - I hope this information helps you to fix this bug quick. I also hope for an Photoshop-Update that fixes the "slow scrolling" problem (off topic).
Apart from that Photoshop CS5 seems to run smoother and faster on my MacBook Pro than CS4 did, seems you guys did a good job! =)
Matthias,
It helps. We haven't reproduced the problem in house for the Hand/Spacebar issue but we have some good clues.
Which Web Browser do you use? Do you remember what content/URLs were active/visible? What version of Flash Player do you have?
Slow scrolling - Yes, we're aware of the issue. I was looking at a fix for it yesterday. Which mouse (brand/model) do you use?
Jeffrey -
I use Firefox 3.6.3. I don't remember all the websites that were visible, but I think I had www.spiegel.de as a tab open and in another tab i was logged into an account of http://basecamphq.com/. is it possible, that there is a conflict, when a javascript/JQuery/lightbox on a website responds to keyboard-commands?
my flash player is version 10,1,52,15
and the scrolling problem appears with this new "apple magic mouse" as well as with the old "mighty mouse" (wired version)
Hi guys,
I've just had the same problem in InDesign CS4 - you don't realise how much you use this command until it stops working!! First time it's happened to me since installing the CS4 suite some 3 months ago.
Anyway, having read the thread, I did what Jeffrey Tranberry suggested and quit my web browser, which fixed the problem straight away (was running Firefox 3.6.3 if that's of any help).
Cheers
I don't believe it but I think that I finally found the culprit: hulu (the desktop app, not through a browser).
To make sure, I rebooted, launched PS, Flash, and InDesign, and then fired up every app that I could think of, one by one, testing each time, leaving hulu for last. Sure enough, it was not until I got to hulu that the space bar hand/zpom stopped working. And then I went one by one, quitting each app, testing each time, again leaving hulu till the last. Sure enough again, the space bar continued not working until I quit hulu, the very last app that I had running (aside from CS5 and system processes).
Please, please do not tell me that there is a conflict between CS5 and hulu's utilization of Flash! That would just make Mad Dog Jobs' a happy camper. (I am a big supporter of Flash on the iPad).
What a relief. Except how am I now going to watch my TV shows while working???
In regards to browser conflicts, I have had none with Safari, Firefox, or Chrome.
Adobe, I hope that this information helps. Let me know if you need any info screen capped.
I haven't got Hulu loaded on my Mac, so that's definitely not the culprit in my case.
Either way, it's damn annoying. Hasn't happened again to me since relaunching Firefox however, and, as I said in my earlier message, it had never happened before - and I use Firefox on a daily basis at work... so it may have actually just been a coincidence that it started working again then.
I'll follow this thread with interest...
When it started happening for me, it was very, VERY random but I can't remember if I was launching and quitting hulu. Honestly, I expect this to be a fluke. Sure... today it is linked to hulu but tomorrow may not be the case. I'll just have to keep an eye on it. And I agree that it is very frustrating. Those are two huge functions for me and having to hit the "H" or "Z" key to perform the function, and then hit the key to toggle back to the previous tool is extremely disruptive.
Flash Player 10,1,52,15
Firefox 3.6.3
Just to keep you up to date, as long as I don't have Hulu Desktop running (0.9.8.2), all is well with CS5. As soon as I fire it up, the space bar hand/zoom goes away.
rudy pospisil / ny, ny
http://rudypospisil.com/
http://anothernormal.com/
For me its not HULU - I don't have it installed.
For me, Since I quite Dreamweaver and discovered that solved the problem. I have had PS and DW open at the same time and was working with it last night, Space Bar Hand worked perfectly.
I put the Mac to sleep last night, woke this morning. Woke it up and PS hand space not working anymore. Saw this update about Firefox (3.6.3), so I quite Firefox to test that and didn't make a difference, I closed Dreamweaver and it works fine again.
Thought Im on to something here - restart Dreamweaver though it still works.
At this point, i suspect it's related to Flash (as others have pointed out). Hulu desktop is an AIR app running the flash player. Dreamweaver probably runs some form of flash when loaded, triggering the same bug. Using the Hulu desktop gives us a reproducible case, so we can have a developer look at it and figure out what's going on. Thanks.
yep it's definitely a Firefox thing. My spacebar wasn't working in ID CS5 all of a sudden. Closed Firefox (without even restarting ID) and it's working again fine. I'll let everyone know when it' stops working and will take a screenshot of the Firefox windows open. I'm in Firefox v 3.6.3 and OS X v 10.6.3
This happened to me again today in Photoshop, (only the 2nd time its happened to me). I had Flash and Photoshop open at the same time, but no Firefox or any other apps at the time it happened.
Not only did the spacebar tool stop working, after clicking around a few times in Photoshop, the program just froze up and I had to force-quit and restart Photoshop, at which time the keyboard commands came back.
Don't know if it is the same issue, but I was locked out of the keyboard commands before Photoshop finally choked completely.
So if you only have Photoshop CS5 open after a fresh start and one does not have spotify on their system, and they are not using Safari or Firefox at that moment it should all work, right? I am not sure what you (Chris Cox) are saying in your comment. Is there a solution some where? Are you still working on a solution? The "spacebar" short cut to the hand tool, is one of the most used function when retouching. At least for me. If there is no fix for that, CS5 will be only a plugin sort of, when I 'd like to use one of the new features of CS5, and CS4 will still be the main Software to use.
Is there not a possibility to program that function, as a new short cut?
Thanks and keep looking for the problem.
Whoa!!! Wait a second!
While running PS CS4, I have no issues. If I quit PS CS4 and fire up PS CS5, I immediately have the spacebar issue. You are saying that this is the fault of the other programs? Sorry, but the only new variable is Adobe and therefore, the issue probably lays there.
And to clarify, running PS CS5 with Hulu causes the spacebar issue. Running PS CS4 with Hulu causes NO issues. Something happened with the move from CS4 to CS5 that caused the problem. Adobe, you, not other programs, broke it.
Sorry. It's hot here and I'm cranky.
rudy
I am sorry, I didn't want to stir up angry comments. It looks like rudy713 has a point. Maybe without admitting any fault, you could please look into this and tell us what the difference in the two versions ( CS4 - CS5 ) regarding the spacebar issue is. Than we might be able to solve the problem on our machines, with different programs loaded, in different ways. Otherwise we might spend hours and hours on turning things on and off, to find yet a new program that does not want to play with the new CS5.
Your responds is very much appreciated.
North America
Asia Pacific
