ShazWhatName
Reader damaged or corrupted files
May 17, 2010 12:18 AM
I downloaded the new version of Adobe Reader (from the Adobe site) last week.
After that I began having trouble opening pdf files that I had created with Illustrator (I hadn't had that problem before and didn't connect it to the Reader update) - the message said something like 'couldn't open ... since the file is damaged'.  I'd save the file as a pdf, open it to check it was there (which it was), close it and couldn't re-open it again (on my computer nor on a friend's computer) - it also did something dodgy to the original illustrator file so that became damaged and wouldn't open either...
Then other files on the USB stick that I had stored the files on also began to be damaged/unreadable with scrambled file names - I couldn't open or delete the files from the stick either! Now most of the files are missing or damaged - even though I hadn't opened them before they scrambled...
I also lost a number of files on an external drive that I was using to try and rescue some of the files on the stick that looked like they might be okay - scrambled file names etc
So far my computer itself seems to be okay (cross fingers!)
I run up-to-date virus scanning software - which says the files are 'clean'
I unistalled Adobe Reader completely (after my browser started telling me that it couldn't read pdf's) and installed Acrobat - I can now happily open pdf files without a problem.
BUT - I'd like to be able to repair all the other lost files... any tips/hints on how I might do it?
Sharon
    May 17, 2010 7:58 AM   in reply to ShazWhatName
    If this also happens w
    ith files that are not PDFs, I would suspect corruption in the pendrive, and run a repair program if I had one...
    Extra linefeed kindly provided by the software.
    May 17, 2010 3:23 PM   in reply to ShazWhatName
    If the corruption "propagated" from PDFs to non PDFs, and from a pendrive to another drive, I would suspect a virus of some kind. But you say you have run an antivirus with up to date definitions?
