Would it be possible to create lens profiles for:
Camera:
Canon EOS 1Ds
Lenses:
1) Canon 17-35mm / f2.8 USM
2) Canon 28-70mm / f2.8L USM
If creating profiles for the above lenses is not viable, can you point me to a source where I can find and/or download them?
Thanks, in advance, for your consideration and help!
CalmLight
I would like to have the profiles of the NIKON lenses as used on the D300 camera:
AFS 70-300 VR 1:4,5
AFS 18-105 VR 1:3,5
Please inform me also how you can totally update the databank of lenses in Lightroom 3.
Note: Do you know that Lightroom 3 doesn''t choose the right lensprofile when the RAW-photo is converted to TIFF or JPEG. So the corrections can only automatically made in the RAW-format?
Thanks or your help,
Michiel Moerdijk
AFS 70-300 VR 1:4,5
AFS 18-105 VR 1:3,5
Community supplied profiles for the 18-105 can be downloaded from Adobe through the lens profile downloader. The 70-300 is already supported. It should work fine with a D300. The profiles usually only work on raw because the corrections give unpredictable results on jpegs and tiffs because you don't know anything about the toning of the jpeg (messing up the vignette correction), the color balance (which makes CA correction difficult on rendered files) sharpening, and other factors.
Most of the lens profiles shipped with LR 3 are intended to be used with raw only. That's why they don't auto-select when processing TIFFs/JPEGs (which may already have had corrections applied, or not). This is by design.
It is true that some lens defects of Micro4/3 lenses are corrected in Lightroom (this has already been the case in Lightroom 2). However, the problem is that these lens corrections are not done in the Auto mode of the lens correction panel. For this reason you only get the default correction of the manufacturers. This means for example that distortion of the panasonic 14-140 is not fully corrected at 14-18 mm. For Canon or Nikon lenses you could increase (or reduce) the amount of distortion correction in the lens correction panel and save it as your default for automatic lens correction. However, with the Panasonic lens you have to do this any time you need it in the manual lens correction mode which is not very convenient. What's more, chromatic abberations are generally not corrected with Olympus lenses and therefore you also have to do this manually. Wouldn't it be possible to get the correction information of the Micro4/3 lenses in the same way into the Auto part of Adobe Lightroom's lens correction panel like this is done for the lenses of other manufacturers? This would have the additional advantage, that you could use the "plain" result without any corrections in Lightroom, which might for example be interesting if you want maximum sharpness in the edges of a wide angle shot and you don't care for distortion in this particular picture.
Eric is correct. If you want to force it, here is a workaround http://forums.adobe.com/message/2856442#2856442.
-Simon
Nikkor 18-105mm f/3.5-5.6 VR DX
It's available through Adobe's lens profile downloader. Just download the app (first link on google), install it, run it and you'll find it and many more profiles.
Eric-
Thanks for your reply, though it leaves me a little confused.
I know LR automatically corrects for the awful barrel distortion the sensor gets at wide-angle (like the S90), but there is no separate profile to correct for more minute dictortions, chromatic abberation, and vignetting. With my S90, I relied on the default corrections as well as the additional lens profile for optimal results.
Also, with my other cameras I get "Camera Standard" and other manufacturer-specific color profiles (that emulate the colors produced in-camera, as in JPEGs), with the option to revert back to "Adobe Standard." I was thrilled a couple years ago when Adobe released the option to use different color profiles; the difference it makes cannot be overstated—it was like night and day. This is what I mean when I say this is lacking for the LX5; "Adobe Standard" is the only color profile available, and I can't help but wonder what color rendition I'm missing out on. So, am I misunderstanding something? Does Adobe Standard mean something different for the LX5 than every other camera I've used (including the S90)? Or is it, as I fear, just that onus is on Panasonic to release color profiles that mimic in-camera color?
Cory
piratejabez wrote:
Also, with my other cameras I get "Camera Standard" and other manufacturer-specific color profiles (that emulate the colors produced in-camera, as in JPEGs), with the option to revert back to "Adobe Standard." ... So, am I misunderstanding something? Does Adobe Standard mean something different for the LX5 than every other camera I've used (including the S90)? Or is it, as I fear, just that onus is on Panasonic to release color profiles that mimic in-camera color?
This is the Lens Profile Creator forum -- not an ideal place to ask about color profiles, but I'll take a shot at it for you.
You can create those profiles yourself using the DNG Profile Editor. Adobe does release camera-matching profiles for some of the most popular cameras, but apparently your LX5 hasn't (yet?) made the cut.
Adobe Standard does indeed mean something different for every camera. As I understand it, Adobe Standard is a profile generated by Adobe which will process the raw data into Adobe's standard "look". Ideally, files produced by multiple cameras processed using Adobe Standard would have identical color and tone. The profiles you've seen that have the word "Camera" in the name are designed to match the camera manufacturer's looks instead. None of them is any more "correct" than any other, it's all personal (or corporate) preference.
I am not sure if this was requested before or not, but I was surprised that the Canon 35mm f/2 has no profile in lightroom, although this is a well known and popular lens.
I tried using the Adobe lens profiler myself, but the results were no where as good as Canon's own correction in DPP, so I looked for user created ones and I found one for the 1D camera, and I am sporting the 60D with the crop sensor.
Please please please, can you include this lens?
I'm not a Canon guy so I don't know if they're the same lens, but there are six user-contributed profiles available for 28-80/3.5-5.6 lenses available through the Adobe Lens Profile Downloader.
Five are marked USM, one is not. That one was also made on a full-frame camera, if you're still using this lens with film.
Mark, thanks a million. I am new to this lens profile feature and I do use this as USM with the EOS A2E which is an auto-focus film based camera. I launched the program but am still trying to figure out how you went to where you saw these listed. Could you send me a link or point me in the right direction?
Dear Adobe Team,
I saw from the beginning of this discussion many requests for Zuiko lenses (Zuiko is the Olympus lenses name). I've made previsously some answers as "courtox" or "courtox1" with some poniters to find such profiles.
The main problem is with your beautiful too: Adobe lens profile download, If you select Olympus you will get no profiles at all. The only way is to replace by hand "Olympus" by "Olympus Imaging" then you will get 42 beautiful profiles.
Is it possible from Adobe to add this name "Olympus Imaging" in the menu and remove "Olypmpus" ?
This is normal, because Olympus is a large company making many products. Olympus Imaging Inc is making lenses (Zuiko) and Camear (E-System and PEN)
So inside the exif data it is written " Olympus Imaging Inc"
Thank you for the work done for us
North America
Asia Pacific
