Hi all,
i think i just found a bug in PPro CS5. I've tested it on two PCs. Exporting an MPEG-2 through PPro CS5-Export or Media Encoder CS5 causes asynchronous Audio/Video - exactly 3 Frames the Video is before the Audio. I tested it with all MPEG-2-Export-Options, all kinds of Source-Material and all Export-Formats. The problem appears only with MPEG-2.
Maybe there's a problem with the MainConcept MPEG Exporter built in PPro CS5. The same procedures with PPro CS4 and Media Encoder CS4 work fine. There's one interesting exception. Changing the Audio-Settings in MPEG-2 Audio-Export-Configuration from MPEG to Dolby Digital, exports a video with asynchronous A/V of app. 0,5 Frames.
So i think it's a bug in the new built-in PPro MPEG-2 Exporter (MainConcept,CS5, 64 -Bit), focusing on the Audio-Export-Feature of an MPEG-Stream.
Anyone can reproduce this bug?
Where can i report such a bug to Adobe?
Thanks.
I've never had this problem and I export MPEG-2s all the time. The only time I've had any issue like this is when i made some change to MPE or something and I didn't then restart premiere pro afterwards. I'm not saying your not having an issue, but the mpeg-2s have been the most reliable for me so hopefully you can find the problem. Also check to see if you have any Anti virus software running at the same time. Can do crazy things.
Sorry to come to this thread so late. The fixes that I know of for audio synch with MPEG-2 in the Premiere Pro CS5 (5.0.2) update required a deleting of files from the media cache to force re-indexing of the media for the fix to work---since the problem was with bad MPEG indexing.
North America
Asia Pacific
