I assume that's a new release, touted to be CS5-compatible. I haven't tried that one yet.
However, I've been able to get the 6.0.4 Genuine Fractals code to work with CS5 by copying appropriate files. Notably there are a number of DLLs that are copied both to several areas under CS5, including the Photoshop main folder as well as the plug-ins folder.
Check to see if the following files or folders are present under any of these areas "C:\Program Files\Adobe\Adobe Photoshop CS5" (32 bit Windows) or "C:\Program Files (x86)\Adobe\Adobe Photoshop CS5" and "C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)" (64 bit Windows):
Folder:
C:\Program Files\Adobe\Adobe Photoshop CS5 (64 Bit)\Plug-ins\Panels\onOne
Files:
CoreFoundation.dll
glut32.dll
glut64.dll
icudt42.dll
icuin42.dll
icuuc42.dll
onOneGF6StandardCheck.dll
onOneToolbox2.dll
onOneWelcomeDialog.dll
OnOneWidgets.dll
Plug-ins\Genuine Fractals 6.0.plugin\GFAutomation.8li
Plug-ins\Genuine Fractals 6.0.plugin\GFFilter.8li
Plug-ins\Genuine Fractals 6.0.plugin\GFFormat.8li
Plug-ins\Genuine Fractals 6.0.plugin\onOneActivationToolbox.dll
Plug-ins\Genuine Fractals 6.0.plugin\onOneWelcomeDialog.dll
Plug-ins\Panels\onOne\onOne.jsx
Plug-ins\Panels\onOne\onOne.swf
I am not absolutely sure all of these are Genuine Fractals files, but they do share the exact same time and date on my system. Copying these files to my CS5 folder prior to there being an OnOne installer for Genuine Fractals that knows about Photoshop CS5 worked to get Genuine Fractals working in CS5.
-Noel
Since my prior message I have installed 6.0.6 into Photoshop CS5 on Windows 7 x64 and I do not see the error you are describing. Perhaps there are several different CoreFoundation.dlls on your system, and Genuine Fractals is accessing the wrong one.
Is yours the 6.0.6 version? And are you seeing it in 32 bit Photoshop or 64 bit or both?
What is your operating system?
Sounds like their installer didn't remove everything it installed.
If it can help you to remove all the files, these are the files it installed into my Photoshop 32 bit folder, all having a Mod date of 5/31/2010. Note that there are several more beyond the list shown above:
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\CoreFoundation.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\glut32.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\icudt42.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\icuin42.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\icuuc42.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\onOneGF6StandardCheck.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\onOneToolbox2.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\onOneWelcomeDialog.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\OnOneWidgets.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-ins\Genuine Fractals 6.0.plugin\GFAutomation.8li"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-ins\Genuine Fractals 6.0.plugin\GFFilter.8li"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-ins\Genuine Fractals 6.0.plugin\GFFormat.8li"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-ins\Genuine Fractals 6.0.plugin\GFStandardMenu.onli.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-ins\Genuine Fractals 6.0.plugin\onOneActivationToolbox.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-ins\Genuine Fractals 6.0.plugin\onOneWelcomeDialog.dll"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-ins\Panels\onOne\onOne Palette Config.txt"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-ins\Panels\onOne\onOne.jsx"
"C:\Program Files (x86)\Adobe\Adobe Photoshop CS5\Plug-ins\Panels\onOne\onOne.swf"
Make sure all of the above are removed.
Also, you should try resetting your prefs (Ctrl-Shift-Alt immediately after starting Photoshop).
-Noel
Thank you for your feedback. I am on Windows 7 x64. In my case I have the whole Suite 5 and I am trying to install the 5.1 update to compatibility with CS5. The only thing that shows up in PS is Mask Pro after my installation. Maybe there is a conflict here, but I still have PS CS3 installed.
PS CS5
Nik Color Efex Pro 3
OnOne Bundle 5
Win 7 x64
iTunes 10
Had to copy:
ASL.dll
CoreFoundation.dll
icudt40.dll
icuin40.dll
icuuc40.dll
libdispatch.dll
objc.dll
pthreadVC2.dll
from: C:\Program Files (x86)\Common Files\Apple\Apple Application Support
to: C:\Program Files (x86)\Adobe\Adobe Photoshop CS5
Now, all is well.
Sometimes I have wonder whether Apple's software for PC doesn't cause problems just to make the PC environment less friendly and subtly steer people toward buying Apple computers.
The inability to discern between different versions of DLLs used to be a big problem with Windows PCs - but this was back years ago! It was called "DLL H ell". But connecting software to the right DLL has been essentially solved for quite a while with "side by side" technology using manifests, the winsxs folder, and stuff. It simply is no longer a given that a DLL needed by a plug-in, and which is kept in a separate folder, should be interfered with by an upgrade of a completely different application. That's just bad application and DLL design, and just look who's responsible for those in this case...
Personally I regard Apple's software for PC about half a step above malware. Not that I don't use some of it.
-Noel
North America
Asia Pacific
