I installed Coldfusion Developer Edition, which I understand
can run JSP files with JRun. When I try to do so, however, I
receive a "500 null"
JRun Servlet Error. The file can be completely empty and
I'll get this same error. As you can imagine, this makes it quite
difficult to incorporate JSPs into my Coldfusion application, and
any help would be greatly appreciated. Most maddening is that the
same file will work on a colleague's machine but not my own, even
after reinstalling Coldfusion/JRun. This is what shows up in the
coldfusion-event.log file:
14/08 14:35:07 user jrun.jsp.JSPServlet: init
14/08 14:35:07 error Exception parsing the TLD null : The tag function on line 14 is not a valid TLD element
[2]jrun.jsp.compiler.JRunTagLibraryInfo$InvalidTLDElementException: The tag function on line 14 is not a valid TLD element
at jrun.jsp.compiler.JRunTagLibraryInfo$TLDParser.startElement(JRunTagLi braryInfo.java:617)
at jrunx.util.SAXReflectionHandler.startElement(SAXReflectionHandler.jav a:24)
at org.xml.sax.helpers.XMLReaderAdapter.startElement(XMLReaderAdapter.ja va:333)
at org.apache.crimson.parser.Parser2.maybeElement(Parser2.java:1674)
at org.apache.crimson.parser.Parser2.content(Parser2.java:1963)
at org.apache.crimson.parser.Parser2.maybeElement(Parser2.java:1691)
at org.apache.crimson.parser.Parser2.parseInternal(Parser2.java:667)
at org.apache.crimson.parser.Parser2.parse(Parser2.java:337)
at org.apache.crimson.parser.XMLReaderImpl.parse(XMLReaderImpl.java:448)
at org.xml.sax.helpers.XMLReaderAdapter.parse(XMLReaderAdapter.java:223)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:314)
at jrun.jsp.compiler.JRunTagLibraryInfo.init(JRunTagLibraryInfo.java:190 )
at jrun.jsp.compiler.JRunTagLibraryInfo.<init>(JRunTagLibraryInfo.java:1 19)
at jrun.jsp.JSPEngine.checkResourceForTaglibs(JSPEngine.java:483)
at jrun.jsp.JSPEngine.findImplicitTaglibs(JSPEngine.java:451)
at jrun.jsp.JSPEngine.<init>(JSPEngine.java:141)
at jrun.jsp.JSPServlet.init(JSPServlet.java:62)
at jrun.servlet.WebApplicationService.loadServlet(WebApplicationService. java:1242)
at jrun.servlet.JRunRequestDispatcher.init(JRunRequestDispatcher.java:79 4)
at jrun.servlet.JRunNamedDispatcher.<init>(JRunNamedDispatcher.java:36)
at jrun.servlet.WebApplicationService.getNamedDispatcher(WebApplicationS ervice.java:1096)
at jrun.servlet.JRunServletContext.getNamedDispatcher(JRunServletContext .java:118)
at coldfusion.license.JspLicenseServlet.service(JspLicenseServlet.java:2 0)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:7 8)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:91)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java: 257)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java: 541)
at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPoo l.java:318)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.j ava:426)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool. java:264)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
[1]jrun.jsp.compiler.JRunTagLibraryInfo$TLDParseException: Exception parsing the TLD null : The tag function on line 14 is not a valid TLD element
at jrun.jsp.compiler.JRunTagLibraryInfo.init(JRunTagLibraryInfo.java:198 )
[0]javax.servlet.ServletException: Exception parsing the TLD null : The tag function on line 14 is not a valid TLD element
at jrun.jsp.JSPEngine.findImplicitTaglibs(JSPEngine.java:457)
java.lang.NullPointerException
at coldfusion.license.JspLicenseServlet.service(JspLicenseServlet.java:3 4)
Latest reply:
Diyet_Uzmani, Sep 3, 2007 11:35 AM
