Where are the edited files located in Lightroom?
May 27, 2010 5:29 PM
I want to be able to use my edited files in InDesign but the only way I know how to do it is to export them to a folder in the finder. This poses a couple of problems. For one it doubles the amount of disk space I use and perhaps more importantly it will not bring the changes I make in Lightroom over to InDesign. Does anyone know where Lightroom saves the edited files after they have been edited in Lightroom?
    May 27, 2010 5:36 PM   in reply to pik80
    May 27, 2010 5:45 PM   in reply to pik80
    2 key points about LR 1) its designed primarily as a raw processor. 2) it is a non-destructive workflow. LR stores all the changes in a database and reapplies them each time you view the image in LR, the original file (raw or otherwise) is never altered -- and you can always go back to the original. To transfer the changes to another application, as you said, you must export.
    LR isn't for everyone. If you don't buy into the concepts and workflow principles of the application something else may work better.
    May 27, 2010 5:48 PM   in reply to pik80
    That is the only way, yes.
    space I use
      Of course it does. Why would you think it doesn't? You export as a TIF,
      with all the edited changes applied to it. Then use the TIF in InDesign.
      You misunderstand how LR works. There are no "edited" files. All there
      are are your original files, and a set of edits (stored in the catalog).
      So the file you see in LR, with the editing changes applied to it, does
      not exist as a separate file anywhere. It only becomes a separate
    file when you export it.
    May 28, 2010 4:16 AM   in reply to pik80
    Oops, I worded this wrong. What I meant to say was if you make a change to a file and then export to InDesign. Then later on make another change to the file I don't believe it will bring that change across unless you export that file again and over write the old file.
    Well, correct in that - yes, if you make changes after you have
    exported, then you have to re-export, in order to have a file that
    some other program can use. However, you could always name it
    differently; you don't have to overwrite. You could keep multiple
    revisions, perhaps.
    May 29, 2010 5:21 AM   in reply to pik80
    I don't know InDesign, so your mileage may possibly vary, but I don't get involved in formal LR exports and imports when editing with other apps.  What I do when I need to use another editing app in addition to LR is right-click the image in LR and select Edit In... and pick the app I want to use.*
    I'm given three choices for the other app:  Edit a Copy With Lightroom Adjustments (the choice you want in your example), Edit Copy (start over, ignoring what I've done in Lightroom), Edit Original (ditto, but BZZT! not a great idea, to me at least).
    The file opens in the other app (and also in Lightroom, as a copy) in the default file format that app is set to use, such as .tif, assumed here.  I make the edits I want there, and then I Save the image again within that app.  That saves the app-edited .tif copy back to the Windows folder being used by Lightroom for the imported .dng Lightroom image files. Note also that there is now a second copy of the image that appears in the Lightroom filmstrip, adjacent to the right side of the .dng image, that is the .tif file and reflects all the edits in the other app. I can make further edits within Lightroom to the .tif (or to the .dng file without the app edits), but in the .tif file, I now can't undo any changes made before I saved in the other app.  Those edits, including the Lightroom edits before opening in the other app, have now become destructive edits in that .tif file.  (This is why I recommend working with a copy, not the original.)  If I need to undo something LR did before I went to the other app, I delete the .tif file and start over with the .dng.
    When I'm done editing from LR (I let LR manage the final edited copy), I can Export that .tif file with any additional edits LR made, Print from within LR, etc.
    *If you can't see the app you want to use when you select Edit In, go in LR to Edit>Preferences>External Editing tab, and under Additional External Editor, click the Choose button and navigate to the .exe file for the app you want to use.  You also set the file format and other preferences there. Save your new preference with the OK button, and right-clicking will bring the other app up in LR as an Edit In option.
