May 31, 2010 4:13 AM
[JS][CSX] ScriptUI Tip
Like (0)
Hi
I thought it was about time I contributed back on here, and share a quick tip I stumbled accross.
I have attached a screen shot of a dialog to select different scripts from, but you may notice the top text looks bold.
To make the text appear bold, simply repeat the line of code:
myText = myMainPanel.add('statictext',[15,15,260,34.5],'Choose the mailer to run the script for');
myText2 = myMainPanel.add('statictext',[15,15,260,34.5],'Choose the mailer to run the script for');
Anyway, just thought I'd share that with you.
Roy
Cute!
FWIW, the "official" way to use a bold font is like this:
var font = myMainPanel.graphics.font.family;
var fontSize = myMainPanel.graphics.font.size;
var boldFont = ScriptUI.newFont (font,'BOLD',fontSize);
var myText = myMainPanel.add('statictext',[15,15,260,34.5],'Choose the mailer to run the script for');
myText.graphics.font = boldFont;
Harbs
I should've guessed there was a correct way to do this! Consider my efforts a hack. Sort of using the "B" for Bold in the MS Word Toolbar, when as we DTP Pros all know you should be using the correct font weight!
I will probably play with these settings when I get a moment,
Cheers
Roy
Beware, Harbs bold trick, doesn't always work on windows. I think panels specificly show bold text correctly on mac but not on Windows
Steven,
I didn't know it was a "trick"...
Can you give more details? Which version?
Harbs
Here is some Rapid ScriptUI code
var rapidDlg = new Window('dialog',"Bold",undefined);
buildWindow();
rapidDlg.show();
function buildWindow(){
// Properties for rapidDlg.StaticText1
rapidDlg.StaticText1 = rapidDlg.add('statictext',undefined,"Lets Be Bold");
rapidDlg.StaticText1.graphics.font = ScriptUI.newFont(rapidDlg.StaticText1.graphics.font.family,"BOLD",rapidDlg.StaticText1.graphics.font.size);
// Properties for rapidDlg.Panel1
rapidDlg.Panel1 = rapidDlg.add('panel',undefined,"I'm Bold on a mac");
rapidDlg.Panel1.graphics.font = ScriptUI.newFont(rapidDlg.Panel1.graphics.font.family,"BOLD",rapidDlg.Panel1.graphics.font.size);
// Properties for rapidDlg.Panel1.Button1
rapidDlg.Panel1.Button1 = rapidDlg.Panel1.add('button',undefined,"Hey Bold fellow");
rapidDlg.Panel1.Button1.graphics.font = ScriptUI.newFont(rapidDlg.Panel1.Button1.graphics.font.family,"BOLD",rapidDlg.Panel1.Button1.graphics.font.size);
This is what it looks like on Windows XP SP3 using CS4 & CS5
if I remember correctly it does show correctly on the mac
Hey Steven!
Just tested your code here, Windows 7 64-bit, InDesign CS5, and it's same, panel text isn't bold.
tomaxxi
Yes. It's bold on Mac.
So it's panel labels which have this problem.
I assume the same happens if you use a reference to the window.graphics gont. Yes?
Harbs
Hmm.
Actually, it's not Bold on the Mac -- I'd say it's Black. It's a much heavier weight than bold in other elements...
Harbs
even this doesn't work
buildWindow();
rapidDlg.show();
rapidDlg.StaticText1.graphics.font = ScriptUI.newFont("Arial","BOLD",rapidDlg.StaticText1.graphics.font.size);
rapidDlg.Panel1.graphics.font = ScriptUI.newFont("Gill Sans Ultra Bold","Regular",rapidDlg.Panel1.graphics.font.size);
rapidDlg.Panel1.Button1.graphics.font = ScriptUI.newFont("Gill Sans Ultra Bold","Regular",rapidDlg.Panel1.Button1.graphics.font.size);
looks like this
which means that the font object is not wired at all for panel on Windows
I wouldn't say it's not wired.
If you pay attention, you'll notice that the border leaves room for the wider font. The text is just not drawn correctly...
Harbs
Wow, thanks for the cool input. Harbs, I Checked out Kris' post. Most interesting. What I have ended up doing is making an Applescript app in Xcode. Saved as a floating window, gave it a cool icon, and it looks, and works good. I still feel I have cheated taking this route, as it takes 5 mins to throw this together with only a single doscript line of code in Applescrip to trigger my long scripts. Still, it works. Thanks all again for your help Roy
Copyright © 2011 Adobe Systems Incorporated. All rights reserved.
Use of this website signifies your agreement to the Terms of Use and Online Privacy Policy (updated 07-14-2009).
