Indesign fitting image after placing
Jun 1, 2010 9:43 AM
I've gotten pretty far with using frame fitting options on image frames that are "loose" on a layout. But for image frames that are anchored in text is where I am failing, though Indesign does not present an error.
I start with a document with some text. And I anchor a labeled image frame into a certain point in the text.
I can place the image, but scaling and the frame fitting options just don't do anything that I can tell.
set imgValue to "Assets:Signatures:AC_Vierra_sig1.tif"
tell application "Adobe InDesign CS4"
     tell document 1
          set allRect to (every rectangle of every story whose label is "CS46Signature")
          if (count of allRect) > 0 then
               repeat with thisRect in allRect
                    tell thisRect
                         set fitting alignment of frame fitting options to bottom left anchor
                         place imgValue
                         redefine scaling to {1.0, 1.0}
                    end tell --ax
               end repeat --drill down into img frames in text
          end if --allRect not empty
     end tell --theDoc
end tell --app
I've tried different combinations of these and they fail without error. What would you do given anchored image frames? thanx, sam
    Jun 1, 2010 3:54 PM   in reply to sam452sam452
    Can you explain what you are actually trying to do to the image?
    Jun 1, 2010 6:27 PM   in reply to sam452sam452
    You're getting scaling because presumably that's how your anchored item options are set up in the document. Meanwhile your simplest approach is probably to place the image, fit given content to frame, set the transform reference point of the layout window to bottom left, then set horizontal and vertical scale to 100%.
    Jun 3, 2010 9:22 PM   in reply to sam452sam452
    You're doing things the hard way. First, set the transform reference point outside your loop:
       set transform reference point of layout window 1 to bottom left anchor
    Then inside your loop, just do this:
    set {thePic} to place imgValue on thisRect
    fit thePic given content to frame
    set properties of thePic to {horizontal scale:100, vertical scale:100}
    Jun 7, 2010 4:41 PM   in reply to sam452sam452
    Try changing:
    to:
    set properties of thePic to {absolute horizontal scale:100, absolute vertical scale:100}
    Jun 8, 2010 4:23 PM   in reply to sam452sam452
    The place command returns a list (of one item). By using brackets, the variable contains the item from the list.
