kelarius
Flash shows green screen when playing videos
Jun 10, 2010 5:12 PM
I installed 10.1 today and any time I play a flash video on hulu on youtube all it shows is a green screen, the sound works fine. I'm using firefox and windows 7 x64, video card is an ATI 4870. If i disable hardware acceleration it works but the video stutters a bit (not surprising), I was under the impression that with 10.1 hardware acceleration would work now.
I have the 10.2 version of ATI Catalyst drivers installed.
    Jun 10, 2010 8:07 PM   in reply to kelarius
    Hi, the following thread may be helpful to you:
    http://forums.adobe.com/message/2706243#2706243
    Hope it helps.
    eidnolb
    Jun 10, 2010 8:56 PM   in reply to kelarius
    Hi, I should have read the entire thread. Well that doesn't sound good, if the beta was the fix, and now you have Installed the final release and have the green screen. Hmmmm.
    Someone today had that issue and there was a response and it wasn't the beta. Ok, I found it. This user had a flashing green screen, but take a look.
    http://forums.adobe.com/thread/657387?tstart=0
    If this is a common issue, then we'll be receiving more threads and hopefully have a solution. I have never seen that, so don't have anything to suggest.
    eidnolb
    Jun 10, 2010 9:37 PM   in reply to kelarius
    Hi, well so much for that. So back to square one. Do you think this is due to the 10.1? Did you ever experience this with the 10.0.45.2 version? I would just guess no. Until today I had not heard of anything like you describe nor those other threads.
    You do have the Shockwave Flash Object Enabled in the IE add ons don't you? Check all add ons for it.
    Then using FF, find the plug-in SWF and it should be Enabled as well.
    Then you can also use this Adobe test site, first Using IE, then Using FF:
    http://www.adobe.com/software/flash/about/
    Let me know.
    eidnolb
    Nov 28, 2010 12:14 PM   in reply to kelarius
    VERY Simple Solution.
    When it plays in Green.
    Right Click on the video
    Uncheck Hardware Acceleration
    Refresh Window
    Problem solved.
    [sig deleted by host]
    Dec 30, 2010 12:52 PM   in reply to ed przybylski
    Unchecking harware accleration worked for me, Thanks Ed.
    Jay
    Dec 30, 2010 1:19 PM   in reply to Jay Chevako
    Glad that helped Jay. I had to do it in both my firefox browser and internet explorer browser. After that I haven't had to do anything since.
    Nov 9, 2011 7:35 PM   in reply to ed przybylski
    In my case, the browser hung on the 'green screen', so there was no ability to right-click in the video area to disable hardware acceleration.  There's no option to disable hardward acceleration prior to playing the video.  This problem occurred with all latest version of all browser and standalone flash players (i.e. Sothink FLV player).  The only way I was able to disable hardware acceleration was to go to this site: http://kb2.adobe.com/cps/839/cpsid_83952.html and then right-click on the Flash logo block.
    Flash and ATI's Catalyst drivers used to work and play well together, but obviously, that's no longer the case.  After today's announcement from Adobe (conceding defeat of Flash to Apple/HTML5), it's probably hopeless to think that any more resources will be devoted to fix any more problems with it.
    Nov 9, 2011 9:06 PM   in reply to danno33
    danno33 wrote:
    Flash and ATI's Catalyst drivers used to work...
    You may need to update the drivers for your display adapter.
    Nov 9, 2011 10:18 PM   in reply to Pat Willener
    Sorry, I should have mentioned that I had already updated the Catalyst driver to the latest version with no success.
    Dec 20, 2011 5:55 PM   in reply to danno33
    The fix is however simple and its not ur catalyst driver or adobe. While you are on a video page, right click anywhere inside the Flash Player and choose settings. Now click the first tab that says Display (look for the monitor icon) and uncheck “Enable Hardware Acceleration.” Then hit F5 or refresh..
    Dec 20, 2011 11:31 PM   in reply to Welsh1979
    Please read my 11/9 message above - there's no option to right-click inside the Flash Player because the browser (all of them FF, IE, Chrome) has locked up and hung.  I just downloaded and installed another update to the Catalyst driver and the problem still exists, so I still believe it's the Catalyst driver that's to blame.  I've reported the problem to ATI/AMD, but since it's been at least 6 weeks without a response or fix, I assume that they've ignored it.
    Feb 5, 2012 1:34 PM   in reply to ed przybylski
    Thanks man! Unchecking the hardware acceleration works for me!
    Feb 7, 2012 4:30 PM   in reply to gerhemmes
    No problem! Ur welcome
    [private data removed]
    Apr 6, 2012 12:57 PM   in reply to Welsh1979
    for anyone else with nothing above working for you like me.....
    i had to go into Global Settings >>  Advanced Tab >>  Delete All browsing settings and data.
    refresh site page.
    working again.
