Is anyone else facing this kind of problem? I have a page with various columns (three). The columns are hosting a narrow, but long table. The introductory paragraphs (title and legend) are spanned across the columns.
Each time I do any edit (applying a text style, deleting a line) InDesign freezes. I get this kind of error in the Console:
12/06/10 13:45:18 [0x0-0x36d36d].com.apple.Safari[30282] Sat Jun 12 13:45:18 MacBook-Pro-di-PaoloT.local Safari[30282] <Error>: CGImageDestinationCreate destination parameter is nil
12/06/10 13:46:56 /usr/sbin/spindump[91509] process 91490 is being monitored
12/06/10 13:46:57 /usr/sbin/spindump[91509] process 91490 is being force quit
12/06/10 13:46:59 kernel IOHIDSystem::relativePointerEventGated: Capping VBL time to 20000000 (was 26824595)
12/06/10 13:47:03 com.apple.launchd[169] ([0x0-0x528127c].com.adobe.InDesign[91490]) Exited: Terminated
12/06/10 13:47:29 SubmitReport[91514] missing kCRProblemReportProblemTypeKey
12/06/10 13:47:31 /usr/sbin/ocspd[91517] starting
12/06/10 13:47:33 SubmitReport[91514] Submitted compressed hang report for Adobe InDesign CS5
12/06/10 13:50:32 /usr/sbin/spindump[91527] process 91518 is being monitored
12/06/10 13:50:34 /usr/sbin/spindump[91527] process 91518 is being force quit
12/06/10 13:50:38 com.apple.launchd[169] ([0x0-0x5287282].com.adobe.InDesign[91518]) Exited: Terminated
I reported this to Adobe, but I would see if anyoady has a workaround. I solved using the old way (separated text frames), but this prevents one of the features of CS5.
Paolo
Bob, according to FontExplorer X there are no problems with the fonts. Not strange, since I only have the system fonts, and the fonts installed by the various Creative Suite editions.
Eugene, maybe the complete system profile is a bit too great? What could be essential to understand the problem?
Paolo
I tried to reproduce the crashing that Eugene reported, and could not. I have a decent C2D with 4 gigs of RAM, and with those specs all I could do was experience slightly-slower-than-expected performance when working with column-spanning headers. However, when I start my Ubuntu VM, and start the processes that cause it to consume about 2 gigs of RAM, then my system specs degrade to the minimum RAM acceptable to ID (just more than 2 gigs) and I start experiencing multi-second delays.
My hunch is that this particular feature requires more resources than the minimum spec from Adobe... or that a buggy plugin is crashing when it doesn't do garbage collection quick enough to prevent the host system from running out of available RAM. Just a hunch, I'm not a developer at all, but the whole thing smells like a memory leak to me. I could never get it to crash, though, so perhaps I'm only muddying the path with my posts about my attempts to reproduce it.
I just noticed that when I use column span on a two-column text block with vertical justification on, every letter I change or add on that spanned line yields a 1-second spinning disc pause, as if the computer doesn't know what to do. Doesn't lead to a crash on my Mac Pro, but it does drive me nuts until I turn it off—which I don't want to do. Thought I'd share...
2 years on, and this issue still exists in CS6. Win7/64, 12GB RAM, delayed screen update.
I often - but not always - get it with split columns on a table. Other 'complications' may be column break character following, or an anchored object. I wish I had more time to isolate the issue...
I have tried exporting to idml, then reopening - same. The only way I can edit split table content sometimes is to remove the split, make the edit, then reapply the split 3/4.
Sometimes, even changing the size of a linked text frame that contains a split table is enough to lock up the program - even if there are no text flow changes from this, due to a column break character and plenty of free space below it...
I'm pulling my hair out with the same problem. Every time I try to change any table related formatting I crash. I'm on a 400 page document with several tables, some with span others without. The span concept is great but of no use if we cannot use it effectively. I am now going to go through the document and 'try' to delete the tables and reinsert them as unanchored objects. Nuts and frustrating.
BTW, I've gone through the full set of debugging steps to no avail.
I think DeezleDeeDee was referencing several of the posters above that talk about minimum spec for InDesign vs possible spec required for this particular feature as a potential solution to the issue. E.g., if a brand new MacBook can't cut it, and the bug was noted here 2.5+ years ago, then it's not (likely) an underspec-hardware problem as was contemplated above.
North America
Asia Pacific
