Elgriyo
HELP!  "Error: Profile validation Error"
Jun 16, 2010 8:59 AM
Hi all,
I'm using newtek tricaster with Adobe Media Encoder 3. So far I've been able to stream without problems, even after personalizing profiles. This was using VP6 codec. Now that I had to switch to H264 I'm still able to stream files, but I cannot save those files, no matter what profile I use, everytime I check the Save file box, I get an error "Media Encoder finished prematurely. Try Again", when I look at the directory, a log file is created. (if i only stream, it works fine).
Here's a log example, and also a .xml profle that i'm currently use
LOG
File: C:\Program Files\Adobe\Flash Media Live Encoder 3\FMLEcmd.exe
Description: Adobe® Flash® Media Live Encoder
Copyright: © 2008 - 09 Adobe Systems Incorporated. All Rights Reserved. Adobe, the Adobe logo, and Flash are either registered trademarks or trademarks of Adobe Systems Incorporated in the United States and/or other countries. All other trademarks are the property of their respective owners. <AdobeIP#0000716>
Version: 3.0.0.4743
Wed Jun 16 2010 12:09:44 : Error: Profile validation Error : Validator failed.
Wed Jun 16 2010 12:09:44 : Error: Profile Validation : Some of the tags in the profile have incorrect or no values. For details, please refer to encoding logs.
Wed Jun 16 2010 12:09:44 : Profile Warnings : 1. Name of the file to which encoded video is to be saved, has wrong extension. It should be .f4v
---------------------------------------------------------------------- ---------------------------------------------------------------------- ---------------------------------------------------------------------- -------PROFILE
<?xml version="1.0" encoding="UTF-16"?>
<flashmedialiveencoder_profile>
    <preset>
        <name>Custom</name>
        <description></description>
    </preset>
    <capture>
        <video>
        <device>VT Video Device</device>
        <crossbar_input>0</crossbar_input>
        <frame_rate>25.00</frame_rate>
        <size>
            <width>720</width>
            <height>576</height>
        </size>
        </video>
        <audio>
        <device>VT Audio Device</device>
        <sample_rate>44100</sample_rate>
        <channels>2</channels>
        <input_volume>99</input_volume>
        </audio>
    </capture>
    <process>
        <video>
        <crop>
            <left>19</left>
            <top>14</top>
            <right>19</right>
            <bottom>14</bottom>
        </crop>
        <deinterlace></deinterlace>
        </video>
    </process>
    <encode>
        <video>
        <format>H.264</format>
        <datarate>200;</datarate>
        <outputsize>384x288;</outputsize>
        <advanced>
            <profile>Baseline</profile>
            <level>3.1</level>
            <keyframe_frequency>1 Second</keyframe_frequency>
        </advanced>
        <autoadjust>
            <enable>false</enable>
            <maxbuffersize>1</maxbuffersize>
            <dropframes>
            </dropframes>
            <degradequality>
            <minvideobitrate></minvideobitrate>
            <preservepfq>false</preservepfq>
            </degradequality>
        </autoadjust>
        </video>
        <audio>
        <format>MP3</format>
        <datarate>96</datarate>
        </audio>
    </encode>
    <restartinterval>
        <days></days>
        <hours></hours>
        <minutes>59</minutes>
    </restartinterval>
    <reconnectinterval>
        <attempts>10</attempts>
        <interval>90</interval>
    </reconnectinterval>
    <output>
        <rtmp>
        <url>rtmp://</url>
        <backup_url></backup_url>
        <stream>video</stream>
        </rtmp>
    </output>
    <metadata>
        <entry>
        <key>author</key>
        <value></value>
        </entry>
        <entry>
        <key>copyright</key>
        <value></value>
        </entry>
        <entry>
        <key>description</key>
        <value></value>
        </entry>
        <entry>
        <key>keywords</key>
        <value></value>
        </entry>
        <entry>
        <key>rating</key>
        <value></value>
        </entry>
        <entry>
        <key>title</key>
        <value></value>
        </entry>
    </metadata>
</flashmedialiveencoder_profile>
I would appreciate any help!
Thanks in advanced
Sebas
    Jun 17, 2010 12:52 PM   in reply to Elgriyo
    Change the output tag as done below:
    <output>
          <rtmp>
                <url>rtmp://</url>
          </rtmp>
          <file>
                <path>filepath.f4v</path>
          </file>
    </output>
