InDesign Borders
Jun 20, 2010 12:19 AM
I'm facing a major frustration, and I'm wondering if there's already a solution, or if this needs to be a new feature to be implemented in future InDesign versions.
Adobe Illustrator has a wonderful palette for brushes which can be used as borders for text, etc. However, InDesign seems to be at a standstill in its border palette development since.. well, since the beginning of InDesign. With the exception of some minor corner style developments, designers still seem to be constrained to creating flat, simple multi-lined "Quark" style borders. (e.g.: Thick-Thick, Thick-Thin, etc.) with a propriatory file type: *.inst.
It's impossible to find designers trading *.inst files online, versus the Illustrator Brush file types, *.ai files which can be found in abundance both for free or charge. My theory behind this is that, at some point in the last 10 years, a developer must have intended to expand the border creation abilities in InDesign, but never received any attention and concentrated on other more important features. Well, I'm here to appeal to the developers! It's time! Time, I say!
Now, why would I want the Illustrator Brush/Stroke functionality in InDesign?
Well, it seems like a no-brainer to me; it's a matter of workflow. When I'm designing anything more complicated than a logo or digital illustration, such as a flyer, a book, or any other multi-page piece with text and illustrations, I use InDesign for its pre-press abilities, bleed setups, typography styles, linking, etc. Thus, it just makes sense that if I make a border around a page, I should have a nice, wide variety of borders to choose from, or create ones on the fly from Illustrator *.ai files just like in Illustrator.
This apparent lack of cross-compatibility means in order to achieve anything more than a flat line or easter-egg smiley faces, I'm limited to creating a pre-shaped border Illustrator and placing it into the page. Resizing becomes a disaster as they end up having to be treated as illustrations rather than borders. "Edit original", "Edit original", "Edit original".
During my scouring of the net for a solution, I've found many other designers out there with the same question., some dating all the way back to CS2 days.
Incidentally, while we're at it, heck, I'd love to see the same abilities in Photoshop. I mean why not? It's got vector tools in there as well. There really needs to be more universal palettes in the entire Adobe Creative Suite series. It just makes sense. The unification theory of palettes! Mwahahaha! *clasps his hands* Yes, I ask for too much.. but.. well, it's a good idea, ain't it?
But seriously. It would be of massive use in InDesign; I'm surprised that it doesn't yet exist ten years into InDesign history. Is there a solution at this point? Or is this more of a feature request?
Cheers.
     —RR—
    Jun 20, 2010 3:39 AM   in reply to RevRatspeed
    Jun 20, 2010 5:41 AM   in reply to RevRatspeed
    And I don't know that I'd hold my breath either.
    InDesign was never intended to be a replacement for all things Illustrator. For anything that complicated, just create it in Illustrator and place it in ID. You can have your multiple borders and put them in an InDesign library or have a collection of snippets in a folder accessible through Bridge (and in CS5 minibridge).
    A quick edit original in InDesign after placing will take you back to Illy to do any quick edit you need to make to the border and you're in business.
    Bob
    Jun 20, 2010 6:01 AM   in reply to RevRatspeed
    I wouldn't either. My point is that you can already get what you want very simply by using Illustrator. This is the reason for the Creative Suite. Different tools for different jobs with some overlap.
    Bob
    Jun 21, 2010 3:32 PM   in reply to RevRatspeed
    I know I'm a trifle late as this question is shown as answered. Anyway, a couple of points. I used to use an app called Graphic Type Designer (GTD for short).
    http://www.graphictype.co.uk/using_gtd.php?
    It could create borders,corner peices, lines and corner effects using specially designed fonts. It would save these designs in WMF (Windows MetaFile) or plain text formats. I used it a lot with PageMaker and for a short while, InDesign as InDesign barely improves on the border selection that came with PM. I had to stop using it as it does not wotk with 64 bit Windows as although it is a 32 bit app, it retains a 16bit installer.
    Anothe alternative I have found today by searching for, and finding some great Illustrator brushes is this site:
    http://www.graphicxtras.com/
    There seems to be a hell of a lot of brushes, borders and patterns for Illustrator on this site alone. As bob says, it is probably best (unles they add a ton more borders and effects in InDesign) to use Illustrator's borders and brush libraries to create custom borders. Hope this helps...
    Ian
    Sep 22, 2011 9:26 AM   in reply to Bob Levine
    Bob, I would generally agree with keeping tools simple, but I'm with the poster here. Consider this case:
    I'm making several display ads, all to different specs. I have a custom brush for the border in Illustrator. I need to create a duplicate document in AI for each size of the ad, size the border, create outlines, and paste it over to INDD? That's just silly.
    Sure, InDesign shouldn't be burdened with all of Illustrator's features. I don't need to be able to create a brush in InDesign. But InDesign should at least be able to *load* an Illustrator brush and apply it to an object.
    Sep 22, 2011 11:28 AM   in reply to jarlow
    You’re responding to a post from over a year ago. And if you want to use an Illustrator brush, do it in Illustrator.
    Bob
    Sep 22, 2011 2:12 PM   in reply to RevRatspeed
    RevRatspeed wrote:
    but you have to remember the entire reason InDesign was developed in the first place was to create a hybrid between Pagemaker and Illustrator,
    Where did you get that idea? InDesign was conceived from the ground up as a better replacement for the essentially obsolete Pagemaker and intended to go head-to-head with Quark Xpress. It had, and continues to have, the same sort of rudimentary drawing tools available in competing page layout programs, but there really is no compelling reason for most users to want brushes. If you took a poll of all users, I'm quite sure you'd find Illustrator brushes quite far down on the list of wished-for improvements compared to, say, improved footnotes, support for endnotes, or even support for grayscale profiles.
    Sep 22, 2011 3:29 PM   in reply to RevRatspeed
    Quark didn’t own a decent vector drawing program that worked seamlessly with it. Adobe does. As already pointed out, it’s called Illustrator.
    Bob
    Sep 22, 2011 4:07 PM   in reply to RevRatspeed
    And? And if you want really nice borders in InDesign, do them in Illy and place them.
    Bob
    Sep 22, 2011 4:48 PM   in reply to RevRatspeed
