teaser195
compatibility between Windows 7 & Indesign CS4 & CS5
Jun 23, 2010 11:06 AM
Hello All,
i have  written a program in vb6 that build catalog  in indesign CS2,3,4,5 this  program works very well in indesign CS2,3,4,5  on Windows XP. but the  same programs gives error when i run on Windows7  & indesign CS4  & CS5. error is ."Adobe Indesign Stop  Working..." & i have  checked the code & found no problem in  that. error position is also  not certain.some time it build catalog  10-15 pages & some time it  just build only 3 pages & show the  error & then close......when  i checked the event viewer i got this  information about the  error..please take a look....
Faulting  application name: InDesign.exe,  version: 7.0.0.355, time stamp:  0x4bad00be
Faulting module name:  APPFRAMEWORK.RPLN, version:  7.0.0.355, time stamp: 0x4bad0252
Exception  code: 0xc0000005
Fault  offset: 0x00043e0b
Faulting process id:  0xe68
Faulting  application start time: 0x01cb1171024188d5
Faulting  application path:  C:\Program Files\Adobe\Adobe InDesign  CS5\InDesign.exe
Faulting  module path: C:\Program Files\Adobe\Adobe  InDesign  CS5\Required\APPFRAMEWORK.RPLN
Report Id:   5c7a9338-7d66-11df-a98a-0019d185
please help me to solve the  problem...its  over a month..i have posted question in adobe forum but no  reply  yet......
Dhiraj
    Jun 26, 2010 6:53 AM   in reply to teaser195
    Exception c0000005 is an access violation. This normally occurs if heap is corrupted (i.e. a NULL pointer is accessed, unallocated memory is freed or allocated memory is freed twice).
    However i have the same problem with 4 lines of code that do run on windows 7 cs5, but don't on windows 7 cs3 and 4:
    http://forums.adobe.com/thread/668315?tstart=0
    I think the best thing you can do is installing indesign debug version on windows 7 to trace the exception.
    Jul 4, 2010 11:15 AM   in reply to teaser195
    One more with a similar problem
    http://forums.adobe.com/thread/670027
    Jul 6, 2010 2:30 PM   in reply to teaser195
    I used to debug scripts with script toolkit (JS) or commenting out (vbs), I never had to do it with debug version.
    I can execute your code with Indesign debug versions on Windows 7 if you send it.
    Mar 8, 2012 6:50 AM   in reply to nope0000
    I am having similar issue and just wondering what was the solution as its marked answered..or should I do a new post ?
