Ugh, What is up with CS5 and why can't Adobe release a product that works? As far as I can tell this program should still be in beta. I have been working on a couple large files for a 2 hours and it is to the point where I am going to have to quit and restart again. I have to do this 4-5 times a day. When I first open CS5 and start working it is fast as hell but within a couple hours it slows to a crawl. I never had this issue like this w/ CS4. Anyone else having this issue.
2.66 quad
16 gigs ram (12 for CS5)
300gig raptor drive as dedicated scratch
10.6.4
Fresh install of OS and CS5
Other fun issues with photoshop.
-The eraser tool locks on and the only way to get rid of it is to restart.
-I had to istall a 300g scratch disk because with the 150 g drive I was getting too many "scratch disk full errors"
Are you sure you have done everything as recommended? Like repaired permissions prior and after install and verified that all your fonts are »good«.
I have no CS5-experience yet, but from experience with older versions a possible culprit might be your History-settings – what are they?
Rod,
I'd like more information about what you're seeing.
1. What video card are you using?
2. Have you changed the the default performance settings, and if so, what are they? (I'm mainly curious about cache levels and tile size)
3. Do you have any 3rd party plug-ins installed or use any flash panels in PS?
thanks,
-Adam
Thanks for your help.
Nvidia GeForce 7300 GT
General
-Turned off flick paneling
Memory
-11.5 g for ps (16g total)
-300g dedicated scratch disk 10k rpm
History and Cache
-history states 7
-cache levels 2
-cache tile size 128k
GPU settings
-turned off (unchecked) enable openGL drawing
No additional plugins and unchecked all options in extension panels
Type unchecked font preview size
no. This was a complete new install for the os(10.6.4) and cs5 (new hard drive). The only other programs installed on this machine besides the basic OS programs and CS5 are yousendit, MS word, silverfast(a scanning program), and a wacom tablet
All software is up to date, I have trashed ps preferences a couple times and always repair disk permissions before and after updated.
I'm not sure why things are slowing down on your system with PS, but I have a couple of ideas. There's a known performance issue with 10.6.4 and nVidia GPUs - this may be causing some problems on your system (even if OGL is disabled in PS). Also, if you work with large files, you may want to try changing the tile size to 1024K. If you don't work with large files, are you opening and closing many document windows as you work in PS?
I reinstalled the OS back to 10.6.3 and tried to reinstall CS4 as I had given up on CS5 working properly. Strange thing, CS4 does not work with 10.6.2 or 10.6.3, for me it crashes with in 3-5 minutes. So I uninstalled CS4 and am trying to change my workflow to still be able to use CS5. I save all files and restart every couple hours. The issue that I am still having is that when dragging a smart object or layer to another document there is a very long lag time. When cutting and pasting a large image to another document it is even worse. When I do copy large images to paste in a another document the scratch disk fills up and seems to keep that disk space occupied, purging does not release that space Not to repeat myself but this was never an issue w/ CS4. Dragging layers, smart objects, curves, etc from one document to another was always seamless and instant, my scratch disk never became full and unworkable. What is causing this an has anyone else having the same problems?
Rod,
If you aren't using it, try the attached Disable VM Buffering plug-in. It may be the key to clearing up the performance issues you describe.
Just un-zip the archive and copy the plug-in into your plug-ins folder.
-Adam
I have similar issues with relatively small files (though sometimes with a lot of layers/folders/type layers)
Photoshop keeps grabbing memory up to the max I set it at . . . and never goes below that. Never releases the RAM back until I quit the app.
Isn't this anti-thetical to how modern memory management is supposed to work?
Shouldn't it release both 'real' memory and virtual memory once I close all documents?
Yes, that is normal.
No. Otherwise it would be much slower, and in 32 bits address space fragmentation would make it worse still.
Photoshop will get slower when you hit the limit on RAM usage you set in preferences - as it hits the scratch disk more often. But, again, that's normal and been the behavior since Photoshop 1.0.
If the system starts paging, Photoshop will recognize that and release some memory.
Also Photoshop will release memory for plugins that request more memory.
Adam,
Thanks I am willing to try it but can you explain to me how you think this might help. I work on very large files, have 16gigs of ram(12g for CS5), and have never experienced a pause while painting. From what I understand about VM buffering the reason why I would want to disable it is if I do not have a lot of ram, work on smaller files, and experience pauses while painting.
So this is by design that Photoshop never releases RAM even when all documents are closed, is in the background and not doing anything?
I open or switch to other apps and they are incredibly sluggish - but Photoshop never gives up a single kilobyte of memory unless I close it.
I did not have performance problems like this with CS4.
Yes. Photoshop assumes you have work to do and don't want to wait too long to get that work done.
(the OS memory allocation is SLOW, and in 32 bit address space fragmentation makes things much worse)
Well, then they're not related to not releasing memory -- because that has been the same since Photoshop 1.0.
I have the same problem on two computers as Rod with smart objects. Also, multiple users are complaining about how slow CS5 is compared to CS4. All the computers are running 10.6.4. They are mostly Mac Pro's with at least 10Gigs of ram and scratch drives.
Tried using FontAgent Pro and FontExplorer Pro but problems continue.
I may do a test by going back to 10.6.3 but this isn't a good solution for companies with lots of Macs.
I went back to 10.6.3, installed the plugin that Adam recommended in an earlier post (disable vm buffering), installed 16 gigs of ram, turned off fonts, no 3rd party plugins, added two raptor drives on raid 0 for scratch, I try to keep no more than 5 windows open at a time, and restart the machine before I open a new file. I can say that it finally works w/o all the issues of past but have not noticed any performance increase. I updated to 12.0.1 after I did all of this so no idea if that fixed any of the earlier issues and not ready to trust it enough to uninstall the disable VM plugin and upgrade to 10.6.4. CS5 is great and has some useful new features but I think if I had it to do all over again I would have gone back to CS4 rather than all of these work arounds, hardware upgrades, and going back to 10.6.3. as there seem to be stability issues w/ 10.6.3.
Twice in the past couple of days a user was working in a CS5 PhotoShop file and out of nowhere partially transparent white rectangles will pop up all over a layer. "No matter what I do they won't go away deeming the file useless and I have to start over. Even if I delete that layer it will pop up on another".Has anyone heard of anything like this?
Thanks.
Have you tried deleting the preferences and restarting the machine. I have had a lot of strange things happen w/ CS5 and deleting the preferences works occasionally. If you are committed to using CS5 you may want to try and delete preference, go back to 10.6.3, and install the disable VM buffering plugin as a test. There are definite issues with the nvidia graphics card, 10.6.4 and CS5.
We are having all these issues and more. It continues to slow down, and all tools become sluggish. Touching the transform window starts the beach ball. The transform window can only be moved a small distance and has to be accepted and applied again. When it starts the slow down, anything brings up the ball. Trying to grab a point in curves, and it won't move. File size growth is bizarre. We can save a file that is 13 gigs open, and open it on another box, (similar configuration) and the open file size has grown to 28 gigs. Saving to the server has become almost impossible and is critical for workgroup production of large complex files. Problems with saving after the first save, "disc version has changed" errors. It happens with both PSB and PSD files but seems to be a bigger problem with PSB. Every save needs to be a "SaveAs" This is on top of issues like the type tool crashing when you look at it and the many other well documented bugs. Has there just been so much effort put into the "Auto" features that the tools for serious image creation have been compromised for people working on large files? Not that the type tool should be considered serious.
10.5.11 or 10.6.4
dual 3.2 quad
32 gigs ram
The only people seeing anything even close to that have corrupt fonts, or a buggy third party plugin (mostly FontAgentPro).
There is something about your system that causes this, something that differs from millions of other users not seeing a slowdown.
We need you to help figure out what that difference is.
We're having these issues at my work also. Computer is nice and happy in the morning, but throughout the day it gets slower and slower and slower the more we work on it. A restart would make it go back to normal, but when you are working with 8-10 Gb files and it takes 10 minutes to save and 10 minutes to open it again, we can't restart the computer every hour or so.
I'd be happy to help however I can to find what the problem is.
Andre
We see these same problems across the board. We are using MacBook Pros, iMacs on up to 2x3.2 quads with 32 gig of ram. Files sizes from 300 mb PSDs to 20 gb PSBs. The problems are all similar, the problems are consistent across various computers and operating systems. We have no common denominator like font plug ins. The machines are in various configurations and the bugs are the same. Time to stop chasing the configuration tail and get this fixed. At this point I want the 20 grand back the company spent on upgrades.
One insight to where there is an issue is in the performance preferences. There is the option for small files with many layers "Tall and Thin" or big files with few layers "Big and Flat" since there is no option for a large file with many layers, it seems a quiet nod to the fact focus has been moved away from large complex files.
I think the known font issue is becoming an excuse for what seems to be a growing list of problems.
Where did you get that? What "growing list of problems"?
After the dot release, there are only a few known problems in the app (and many, many more in the OS) -- and we're still working on those problems.
Just because you have an issue with your system, does not mean that there are widespread problems with the application.
Please stop trying to make it sound worse than it is, and focus on helping us figure out what is different about your systems that is causing this slowdown.
Please don’t take this the wrong way, but when you offer the statement
I have a standard windows machine..
to someone like Mr.Cox you seem to betray some misunderstanding – he might be able to help you, but not unless he is provided with the relevant information.
The term »standard windows machine« appears rather uninformative as it does not make in the least clear what OS-version, processor, video card, etc. you are using, not to mention the upgrade state of your copy of Photoshop.
North America
Asia Pacific
