Cis_456
LiveCycle connector for Sharepoint issue
Jun 24, 2010 6:03 AM
Hello,
I'm trying to integrate Sharepoint with LiveCycle via the LiveCycle Connector for Sharepoint. But some issues occure.
Because of the load, I'm running Livecycle and Sharepoint on a separate machine. Sharepoint even runs in a Virtual machine.
The installation and configuration are neighter a problem for both products. Except the fact that it is not possible to publish a pdf file from LiveCycle to sharepoint, where it is possible to add a new folder on sharepoint. Adding the pdf via the web interface of sharepoint is not a problem.
These are the exceptions that are thrown:
Creating a file:
com.adobe.repository.RepositoryException: ALC-REP-744-000: Operation failed with the following error code [Unknown] and error message [Object reference not set to an instance of an object.].
Please verify the values of following [documentLibraryName:Shared Documents], [folderUrl:], [newFileName:contractPdf.pdf]
Deleting a file:
com.adobe.repository.RepositoryException: File/Folder with given name [test.txt] does not exist in Document Library [Shared Documents].
Can someone help me on this? If you need more info, please let me know!
Thanks!!!
