How do I get a transparent background in my Illustrator file?
Apr 18, 2012 5:50 AM
I'm relatively new to Illustrator, (I'm working in CS4) and created a corporate logo for one of my clients.  When I place the logo into Photoshop or InDesign, the logo is in a white box.  How can I make the background transparent in the original Illustrator file?
    Jul 2, 2010 6:09 AM   in reply to alwasha
    Ok so I do not know if you did this or not but if one just saves the after flattening the transparency then this will happen if one saves it as an eps this will happen but if one saves it s an .ai file without flattening the transparency then the art retains its transparency..
    Like such same art one with the transparency flattened the other as an ai file without flattening the transparency.
    I want to clarify he issue if you have effects applied to the art  and save as an eps this will occur with no effects then the eps should work fine.
    Jul 2, 2010 6:45 AM   in reply to alwasha
    Without seeing the file it is hard to say. You could try to export it as a psd file.
    But if you can post the file I can see if not if you can use the camera icon in the message composer to attach screenshots of you art and or layers panel expanded and the appearance panel also expanded that would be helpful.
    If you can describe what steps you foloewed to create the art that might help.
    Right now it is a little vague.
    Jul 2, 2010 10:29 AM   in reply to Wade_Zimmerman
    Hold Shift as you place the file in InDesign or click on Show Import Options. You may have set the program to add a white background to placed objects. Changing Import Options for a placed file will set that as the default for future imports, where appropriate to the format of the placed graphic.
    Oct 27, 2011 10:08 AM   in reply to alwasha
    Save it as an eps file.
    When you save it, an EPS Options dialog box will open.
    Under "Preview" there is a drop down menu "Format".
    Select "TIFF (8-bit Color)", no matter if it is a one colour or 4 colour file.
    Under the drop down menu there are 2 options, "Transparent" and "Opaque". Choose Transparent.
    When you link this file in InDesign, it will come in without a background.
    If you need a raster file, open it in Photoshop and save it as a .tiff and check off "Transparent".
    Hope this helps everyone!
    Oct 27, 2011 10:20 AM   in reply to cosimcgrl78
    If you want to place a file in InDesign, don't use EPS. Use AI or PDF. EPS is kind of dated.
    Oct 27, 2011 10:22 AM   in reply to alwasha
    Illustrator >> View >> Show transparency grid
    You will see a checkerboard pattern showing you where you have tranparency.
    Save your .ai fle with pdf compatible and place into InDesign
    If you placed as .eps in InDesign you need to
    InDesgin>>View >> Display Performace >> High quality Display
    Oct 27, 2011 10:28 AM   in reply to Monika Gause
    EPS files are not dated. They may be bigger than .ai files but they are still a common file type especially when dealing with all the different levels of software (CS 5, CS 5.5)....
    May 7, 2012 9:42 AM   in reply to cosimcgrl78
    cosimcgrl78 and Mike
    t does not matter what you do or what setings you give an eps file if the file contains araster effect it will not place in another application with a transparent background but an ai file will
    even in Word if you are using a Ma to import it.
    This is an eps witth a drop shadow exported from AI and placed in ID
    Withoput the raster effects it will be fine but with raster effect it does not support transparency.
    May 7, 2012 9:54 AM   in reply to Wade_Zimmerman
    Actually of course it is the pdf compatibility feature that saves a pdf versio in the ai file that allows it to be read by other programs such as ID and Word (on the Mac only).
    So saving as a pdf is probably a very good way of going about it.
    Here is the ai file with the same raster effect as the eps above.
    here is the same ai file in Word on a Mac.
    Aug 28, 2012 9:54 AM   in reply to Wade_Zimmerman
    In Illustrator - for the shadow graphic only, taking for granted you gassian blured a vector graphic, try 'tranparency >> set blending mode to Multipy >> Save as an .ai file'
    Sep 5, 2012 5:03 PM   in reply to alwasha
    I am not exactly certain of your problem, but when I want to create an image to insert into a word file, or InDesign or whatever, I do a FILE>SAVE FOR WEB.
    Then make it a GIF. Set it to have transparancy and it comes right in with no white background. You have to play with the size of it, as they usually start really small.
    Nov 29, 2012 9:07 AM   in reply to bfarrelli2
    I have designed a menu with overlapping pics screened to 15% n the background. When I sent this to a print shop for copying I am getting black lines that show up. It looks like my artboard and guidleines. When I used my home printer to print these linses are not there. Can you make a suggestion to remedy this or tell me what I might be doing wrong
    Mar 9, 2013 10:01 AM   in reply to msleute
    Nice work guys I got what i'm looking in my classifide .
    this topic has full answer of my needs
    Apr 6, 2013 2:22 AM   in reply to alwasha
    Make sure to Place the file! (File > Place...) Hope this helps!
Bookmarked By (1)
