Expand my Community achievements bar.
Learn about Edge Delivery Services in upcoming GEM session
SOLVED
Could you point me to the documentation?
Avatar
Level 3
I'm trying to find good documentation about how to build a custom function with Javascript in my LS-created form.
Would someone please point me in the right direction?
Thanks!
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Then what you are looking for is called a scripting object. It is well described in the online help in Designer.
Paul
View solution in original post
Avatar
Hi there!
You can try this link: http://help.adobe.com/en_US/livecycle/9.0/lc_dp_list.html and under the "Creating Forms Using LiveCycle Designer ES2" heading, you can find a variety of documentation resources that include a basics guide and reference material.
Hope that helps!
...Gil
Avatar
Level 3
Thanks Gil,
I'm looking for a description of how to create a custom function within LS then
call it from various events.
The pointer you sent has lots of info but I don't seem to be able to find what
I'm seeking.
I'm not sure what I want to do can even be done within LS, do you know?
Thanks again
 Bill
Avatar
Sorry, what is LS? Do you mean LC, for LiveCycle?
If you click on LiveCyc'e Designer ES2 Scripting Basics, there is a section on Events. That section may have some of events information you seek. There is a entire Application model available that let's you key in on different types of events that include Application events and form interaction events.  What are you trying to accomplish?
Avatar
Level 3
Sorry, meant LC.
I have to exec some complex code at both prePrint and preSave events (maybe also others) and am looking for a way to only write it once then execute it when I need it. A custom (global?) function may be one answer but I don't know how to create it.
Is there some other way?
Avatar
Correct answer by
Paul
Avatar
As Paul mentions (Thanks Paul!), it is well described in the Designer Help.
Here's a direct link to the Scripting section in the Designer Help: http://help.adobe.com/en_US/livecycle/9.0/designerHelp/index.htm?content=000715.html#1613857.
Other subtopics that may help you with what you seek based on what I think you said you were trying to accomplish:
  • Referencing Objects in Calculations and Scripts (http://help.adobe.com/en_US/livecycle/9.0/designerHelp/000794.html#1592676)
  • To create a script object (http://help.adobe.com/en_US/livecycle/9.0/designerHelp/000819.html)
  • To reference JavaScript functions stored in a script object. ( http://help.adobe.com/en_US/livecycle/9.0/designerHelp/000820.html)
Feel free to look at other topics in the Scripting section. It is fairly comprehensive. If not, providing a snippet of code might help as well.
I presume you are familiar with working with the Scripting environment in Designer ES2. If not, there is a small calculation tutorial that shows you how to use the Script Editor (http://www.adobe.com/go/learn_lc_subtotals_9).
Hope that helps!
...Gil
Avatar
Level 3
Thanks to you both, it looks like the info I need. No doubt there will be other
questions in the future...
 Bill
Avatar
You want to put your JS functions in a Scripting Object.  If you don't see one at the bottom of the hierarchy list, right click the root and add it.  Then put the code in this one place and call it from one to many places on your form.
Avatar
Level 3
Thanks to all of you for the great assistance!
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
