• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Cannot load Flash Player 10.1
New Here ,
Jul 03, 2010 Jul 03, 2010
I am running Windows XP SP3 (all updates installed as of 3 July 2010).  I am using IE v 8.0.6001.18702 cipher 128 bit.
When i try to install Flash player 10.1, I get the error "ActiveX control could not be registered."
There is only one user on the computer, and the user has admin rights.
I have successfully installed flash player 10.1 for Mozilla FireFox, but it will not install for IE.  I have tried uninstalling Flash player via control panel and via the unistall program provided by Adobe.
Please help me fix this issue.  Thank you in advance for your help.
Views
2.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
What files do you have in C:Windows\system32\Macromed\Flash ?
Votes
Translate
Translate
Report
Report
New Here ,
Jul 04, 2010 Jul 04, 2010
Thank you for your help.  Below is the file list from th asked about folder.
C:\Windows\System32\macromed\Flash =
     FlashPlayerTrust <folder>
     Flash 10h.ocx
     FlashAuthor.cfg
     FlashInstall.log
     flashplayer.xpt
     FlashUtil10h_ActiveX.dll
     FlashUtil10h_ActiveX.exe
     FlashUtil10h_Plugin.exe
     GetFlash.man
     NPSWF32.dll
     swflash.inf
Votes
Translate
Translate
Report
Report
LEGEND ,
A little test to show us what's causing the problem; please open a Command Prompt window (Start | Run | type cmd), then issue the following sequence of commands:
cd \
cd windows\system32\macromed\flash
regsvr32 flash10h.ocx
exit
Do you get an error message when you issue the regsvr32 command?  What is the message & error code?
Votes
Translate
Translate
Report
Report
New Here ,
DllRegisterServer in flash10h.ocx failed
return code was 0x80070005
Votes
Translate
Translate
Report
Report
LEGEND ,
Thank you.  According to Microsoft, this code is returned when you are trying to run this function from a non-admin account.  However, you are quite sure that you are running as an admin user, so this is a registry permission problem.
To resolve it, see this article http://kb2.adobe.com/cps/494/cpsid_49419.html; this is a bit technical - do you think you could run that procedure?
Votes
Translate
Translate
Report
Report
LEGEND ,
Before embarking on that SubInACL trip, can you check if your antivirus software is potentially blocking access to your registry?
Votes
Translate
Translate
Report
Report
New Here ,
Thank you SO MUCH for your help.  I got it to load.  The setup I have is as follows:
Administrator account (windows created)
Admin account (I created)
When I created the "Admin" account, I set it up as an administrator.  Well apparently Flash does not like my "admin" account and wanted "administrator".  When I logged in as "administrator" I was able to load the new flash.
Thank you again for all your help!
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Check to make sure you are logged in as "administrator" and not just a normal account with admin rights.
Votes
Translate
Translate
Report
Report
