WHere did the Copyright symbol go in CS5?
Jul 3, 2010 10:45 PM
This option has changed for CS5.
How do i find the characters so that i can add the copyright symbol in CS5?
For CS4 this is the procedure:
To insert the copyright symbol, ©, into your web page, do the following:
  1. Move your cursor to the place on your web page where you want the symbol  to appear.
  2. Select "Insert | Characters and Symbols" from the menu. That is, click  the "Insert" menu, and then select the "Characters and Symbols" item on the menu that appears.
  3. Select the "Common Symbols" radio box in the dialog box that appears, if  it is not already selected. Click the down arrow for the box labelled "Character:". A drop down box will appear, allowing you to  select ©.
  4. Once you've selected the character you want, click the "Insert" button.  Finally, click the "Close" button.
I did search the forums, google and look at teh DW faq, but i couldn't find the option.
    Jul 4, 2010 2:10 AM   in reply to micro5797
    Insert palette/ toolbar --> mode : Text
    Mylenium
    Jul 4, 2010 2:15 AM   in reply to micro5797
    As Mylenium says, you can use the Text category of the Insert panel/bar. Alternatively, use Insert > HTML > Special Characters.
    Jul 4, 2010 8:03 AM   in reply to micro5797
    micro5797 wrote:
    Since CS5 has changed things around from CS4, there is no longer a "Insert palette/ toolbar --> mode : Text".
    Actually, there is. I use it all the time. The Insert panel is normally displayed at the top right in the Designer workspace. In the Classic workspace, it's displayed as a multi-tabbed toolbar at the top of the screen. If you can't see the Insert panel/bar, use Window > Insert, or press Ctrl/Cmd+F2. The Text category can be accessed from the panel's drop-down menu or the bar's Text tab.
